---------------->> **Audio/Video - DIY, Info and FAQ - All Models ** <<------------
![Arrow](https://acurazine.com/forums/images/icons/icon2.gif)
DIY & Reference Thread
*** If you feel a thread or any information should be added to this section please or if there's a dead link or something needs updated send me a PM(click Here to send me a PM) with a link to the thread and I'll gladly review and add it.
Car Audio Basics / Info. / Reference Guide
?? --> Some Pictures or Images No Longer Working or Even a Dead Site/Link/URL? You can go back to archived version using this LINK
Dash Kits and Wiring Harnesses(In No Particular Order)
Auxillary Inputs / iPod and MP3 Adapters(In No Particular Order)
How To Post Pictures
Second Gen CL (2001-2003)
Ultimate FAQ Answer Thread for the CL
- How To Renew Your XM for $77 or less for 12 Months
- Car Audio Basics or SQ for Noobs
- Info and How To "Amp Up" Your Factory System
- AVIC N1 / AVIC N2 / AVIC D1 - Video Lockout Info.
- MP3 Bitrate Info.
- Hacking The Navigation
- Sound / Demo Boards at Big Chain Retail Stores etc
- Radio and Navigation Retrieval Codes
- Design Speaker Box or Calculate Air Space
- Speaker Box Calculator
- Owner's Manuals-All Acuras and Hondas since 1990
- Find Out What Speakers Fit Your Car
- General Radio and Install Info
- Lost Steering Wheel Controls After Adding Aftermarket Headunit? PAC Audio Offers the Solutions
- Wiring Info
- Installing a Radio Yourself - Instructions by make and model
- Connecting BlueTooth to OnStar
- iSimple
- Blitzsafe
- IceLink / Dension
- USA Spec
- Dice Electronics
- Logjam Electronics
- SoundGate
- PIE Electronics
- Harman Kardon Drive + Play
- IceLink/IPod Install
- Stock Sound System Info
- Stock Amp & HeadUnit Wiring Diagram
- Shock Sensor Install
- Adding an Amp
- Head Unit and Center Console Removal
- Door Panel Removal
- Navigation Wiring Diagram
- Rear Speaker Removal
- Removing Door Panel
- Retain your Navi prompts with an Aftermarket Headunit.
TL Section
Third Gen TL (2004 -Present)
Second Gen TL (1999-2003)
Comprehensive Data on Upgrading 2nd gen Sound System
First Gen TL (1996-1998)
- TONS of Info ---> START HERE
- 3G TL Audio & Electronics FAQ
- Audio, Electronics, BlueTooth and Navigation ---> Info.
- DIY Create Your Own Auxillary Input
- Carputer Install
- Rear Camera Install
- NAVI Screen Converted to Video/DVD Screen
- Info About Stock Amp
- Wiring on Stock Amp
- Navigation Hack Thread
- TVandNav2Go, Mediagate MG-25P, and PIE X3 Install
- Front/rear door panel/handles/wstrip/glass/window regulator removal
- iPod and Sirius Integration (Aux-In)
- Non Navi to Navi Conversion
- Upgraded 04-06 Navi to 07-08 Navi w/ NavTraffic
- Aftermarket Amp, Speaker Install and Amp Install
- Bypassing Bose EQ
- Factory Amp / Sub Wiring
- Adding Factory Navi to a Non-Navi Vehicle
- Keeping Factory Sub While Adding a Aftermarket HeadUnit
- Replacing Stock Sub with an Aftermarket Sub
- Navi Conversion - DIY
- Radio Won't Accept Radio Code Fix
- Clock Bulb Replacement
- How To Remove Radio
TSX Section
Second Gen TSX (2009-Present)
First Gen TSX (2004-2008)
General FAQ's about the TSX Audio system
Satellite Radio:
Door Panel Removal / Speaker Removal:
Head Units:
Navi / TV / DVD Tuners:
- What are my options for upgrading the TSX audio system?
- Alpine Type S Speaker Upgrade
- Alarm / Remote Start / VSS Wiring Info for TSX
- Step-by-Step -- How to Make Spacers for Door Speakers
- How To Make Spacers for Door Speakers (Con't.)
- Removing the Radio / Navi
- Center Console Removal(Armrest Portion)
- Center Console and Amp Removal
- Center Console Removal Tips
- Accessing the Amp
- Console/Stereo-HVAC Rattle Fix
- Adding a Subwoofer and Amp
- USA Spec PA15-HON2 iPod Adapter Install 05 w/ NAVI and XM
- Aftermarket Bluetooth
- Muting the Stereo / Mute Wire
- Mute Wire (continued)
- Parrot Kit Install
- Hard Wired Radar Detector / Valentine One
- Gas Spring Trunk Replacement
- Carpet Floor Removal
- TSX Sound Deading Info / DIY
- DIY AUX Input (NO SNHOND3 / usa spec or similar)
- The CORRECT way to bypass the TSX stock audio amp (all years)NOTE: This thread is no longer available.
Satellite Radio:
- Sirius Satellite Radio
- XM Commander Install
- Satellite Radio Install
- Satellite AND Auxillary Input
- Satellite Radio
- Front Door Panel Removal
- Door Panel Removal - Front
- Door Panel Removal - Front (cont)
- Speaker Removal - Front
- Speaker Removal - Rear
- Stock Info
Head Units:
- TVandNaviToGo.com (Doms Unit) Install/Info
- AVElectroic Nav TV / Conversion
- RGB Converter
- Non-Navi to Navi Complete **Pictures No Longer Work**
- All the Navi Info You Need
- Doms Navi Conversion - 2006 TSX Non-PnP Install
- Doms Navi Conversion - 2006 TSX Kick Panel Install
- 2004 Dom's Nav and UsaSpec install
- DVD Player with Custom Harness
- DIY Backup Cam w/ navigation, (No Dom's unit / adapter needed) for 2006/2007 only
How To Post Pictures, Resize Pictures and Add/Edit Your Avatar
Not Safe for Work Rules and Guidelines
If you want to post pictures, first you need to get a photo host, like Photobucket or Imageshack or ImageEvent
In order to post a picture in your posts, you need to follow these three easy steps:
1) Resize your photo and save it as a JPG.
- If your picture is too big (ie larger than 800x600 pixels) it will take too long for everyone to download and it won't fit on most people's screens.
- If you don't already have photo editing software, there's an excellent freeware utility called Easy Thumbnails that couldn't be any easier to use.
2) Host the photo on a webserver.
- If your internet service provider doesn't include web space, use Imageshack. There's no registration required and it's ridiculously easy.
3) Link to the photo in your post.
- You can either use the insert image button in the Post New Thread window or you can use IMG tags in your post like this:
**If you can't find the address of your picture you can always right click on the picture and then look for "Link Properties" then you'll see the "Address"
How To Add and Edit Your Avatar
For example, Original Avatar:
96x150
![](http://img.photobucket.com/albums/v509/rets94/Acurazine/Avatar/05Legend96_150_b.jpg)
Altered To:
175x125
![](http://img.photobucket.com/albums/v509/rets94/Acurazine/Avatar/05Legend175_125_b.jpg)
How To Easily Edit and Resize Pictures
HTML Code:
[img]http://www.your-picture-address.com/your-picture-name.jpg[/img]
- Edit your pic to proper size, cannot bigger than 175 (Left column minus 5 pixel margins) x 125 (previously 96x196), as well as 100.00KB will remain the upload limit
- Click Your Account
- Click Edit Avatar
- You can browse your own computer for a new avatar (Upload an Avatar From Your Computer: )
- You can add a link to where your avatar is hosted (Enter Avatar URL: )
- Find image uploader
- Upload your pictures
- Copy that [IMG] link
- Click User CP on your top-left corner
- Click Edit Avatar of Control Panel on your top-left corner
- Check Use Custom Avatar
- Post that link without [IMG] into the field
- Save changes
96x150
Altered To:
175x125
