removing both center bins
Old Jul 22, 2004 | 02:33 PM
cornholio's Avatar
hi there, i have been searching and searching in the forum for pictures and instruction to remove the 2 centre bin ( the one below the a/c and the "not an astry" ) I believe i have seen it before but right now i can't find it. Do anyone have a link to a instruction with lots of pictures?
Thanks!
J
Old Jul 22, 2004 | 02:39 PM
Dan Martin's Avatar
Photography Nerd
once you remove the storage bin you can see the two screws that hold the not an ashtray in.
Old Jul 22, 2004 | 09:52 PM
cornholio's Avatar
i got the big one out, and i saw the 2 screw, but is that all the "not an astry" bin is holding on to?
its seems tough to get it out
Old Jul 22, 2004 | 11:17 PM
elduderino's Avatar
VP Electricity
1) I don't understand your post. If you are asking about NOT AN ASHTRAY, there are two screws on the front (visible after you pull the big upper pocket) and two towards the rear (visible after you pull the center console shifet surround/cupholder). 4 total.
2) The center console panel that surrounds the shifter is hard to get out the first time, especially at the front end. The best technique is pretending that it's not your car.
Dan, what happened to the SHOND sticky? I posted instructions on removing that c/c panel in there a while back...
Old Jul 22, 2004 | 11:47 PM
elduderino's Avatar
VP Electricity
Check this thread:
http://www.acura-tsx.com/forums/showthread.php?t=3148
Old Jul 28, 2004 | 09:04 AM
robert_tsxgeek's Avatar
Originally Posted by olegm
its pretty simple yet long
to remove the center storage console, just pull it off.. it will come out...
Where/what should I grab ?
pulling by grabbing the opened door & give it a yank ?
don't want the pucking door come off
thanks
Old Jul 28, 2004 | 09:13 AM
elduderino's Avatar
VP Electricity
Center Console/cupholder removal:
If you have 6AT, take off shift knob.
If you have 5AT, I guess you could take it off, but I just put a baggie witha rubber band over it.
Put some blue masking tape on the passenger side inside of the interior-color console to the right of the aft cupholder. (The hinge of the cupholder sticks out to the right when the lid is open and will scratch the console. Close this lid as soon as you can in this process.)
Place your fingers inside the aft cupholder and press outward. Hard. Pull up.
The first time it is very hard to pull up. I am right handed, and I have trouble doing this from the pass side, but I can do it from the driver's side.
If you struggle, close your eyes and visualize that you are in someone else's car. Really.
Once you get the aft pops out, work your way forward. Pops all the way. the baggie on the shift knob comes in handy when you have to unplug the seat heater switches, as the inside of the shifter surround area could scratch your knob (having someone help you at this moment is best).
When you re-attach, remember the seat heater switches!
Top pocket removal:
Put blue tape on interior-color panels to sides of pocket.
Either
A) reach in with both hands, spread fingers to sides, press HARD, and pull, or
B) Pull the rubber pad off the back/bottom of the pocket and find the hole in the back. Insert a hook tool in the hole and pull.
Again, if you struggle, close your eyes and visualize that you are in someone else's car.
You will have to remove the light bulb from the top of the pocket (rotate 1/2 turn and pull out), and use a pair of needlenose pliers to press the Christmas-tree connector tabs together to release the cable tie on the back for the light bulb wiring harness.
NOT AN ASHTRAY removal:
Take out two screws. Rinse. Repeat. Drop NONE. Unplug cig plug and light.
Old Dec 26, 2004 | 04:22 PM
TSXsurf's Avatar
NBP/EBONY/6MT
I cant get the cupholder to budge. Anybody online that can offer any advice?
Old Dec 26, 2004 | 04:37 PM
xizor's Avatar
Bye TSX, hello domestic?
pull very very hard. start from the top, and work your way down.
Tsx536's Avatar
Rep'n Taxbrain.com
Hey dude...Use this technique. This is how I did mine and I think Neochaser had success with this recently.
http://andylee.us/gallery/console
Old Dec 26, 2004 | 04:41 PM
sigmachi96's Avatar
A-spec Arctic Blue
Once you remove your shift knob, start with the front putting your hands where the shift boot is and pull straight up. You'll hear the front clips release. Continue to do this from front to back. You'll have to put a lot of pressure to pull the console out for the first time.
Old Dec 26, 2004 | 08:29 PM
TSXsurf's Avatar
NBP/EBONY/6MT
thanks for all the help! I finally got everything apart and installed (i ran RCAs from the AUX adapter to the center console). I found this thread helped a lot:
https://acurazine.com/forums/showthread.php?t=9597
Thanks again.
Old Dec 26, 2004 | 10:53 PM
xizor's Avatar
dang, I barely remember writing that glad it helped!
johnalfa
Nov 5, 2015 06:44 PM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
g1underground
Mid-Atlantic
Sep 23, 2015 01:18 AM
ExcelerateRep
Sponsored Sales & Group Buys
Sep 22, 2015 10:39 AM
