2nd Gen RL Garage Listing Of Topics*LOOK HERE BEFORE POSTING*
Please always use SEARCH feature prior to your posts. Thanks.
TO FIND THINGS MORE EASILY IN THIS THREAD:
1. CTRL + F (pc) or Command + F (mac)
2. TYPE IN YOUR KEY WORD (JUST ONE WORD WILL WORK BETTER)
3. PRESS ENTER UNTIL YOU FIND IT OR DON'T FIND IT
4. TRY ANOTHER KEY WORD IF NECESSARY
A.
- Engine
- Drivetrain
- Transmission
- ECU
B.
- Intake
- CAI
C.
- Fuel
- Oil
- Filters
D.
- Tires
- Wheels
- Springs
- Suspensions
- Brake
E.
- Exterior
- Exhaust
F.
- Interior
- Console
- MID
- HVAC
G. Lighting
H.
- Car Care
- Clear-bra
I.
- Audio
- Electronics
- Navi
- Bluetooth
- iPod
- MP3
- Alarm
- Radar
J.
- TSB
- Manual
- Safety
K.
- Windows
- Tint
- Trunk
L. Miscellaneous
M.
- Performance
- Drag
- Charts
- Statistics
Ctrl + F (pc) or Command + F (mac) could help look for keywords in this thread
For an informative, funny video on how to survive in this forum, click here
A. Engine (engine bay)/Drivetrain/Transmission/ECU
A-001: Break-in
Flooring it before 600 mile break-in - AcuraZine - Acura Enthusiast Community
A-002: Propeller Shaft Bearing Whine and Differential Whine
https://acurazine.com/forums/second-...l-whir-754805/
A-003: Whining Noise Near 70MPH
A-003: Whining noise at about 70 Mi/h: Acura case number - AcuraZine - Acura Enthusiast Community
A-004: Front and Rear Differential Fluid Change Information
https://acurazine.com/forums/second-...thread-950443/
A-005: A/C Stator Replacement
https://acurazine.com/forums/second-...w-pics-864675/
A-006: Listing of Error Codes from Check Engine Light
A-006: Error codes - good to know before stealership takes you for a ride with jargon - AcuraZine - Acura Enthusiast Community
A-007: DIY: Idler and Tensioner Bearing Changes
https://acurazine.com/forums/second-...change-961289/
A-008: DIY: Spark Plug Change
https://acurazine.com/forums/second-...cement-972411/
A-009: DIY: 2nd Gen RL 3x3 Transmission Fluid Replacement/Flush (Cured Shuddering!)
C-003: 3X3 ATF Change & Transmission Shudder in 4th , 5th @ Low RPM - AcuraZine - Acura Enthusiast Community -> No Pictures
A-012: DIY: UR Crankshaft Pulley Installation
A-012: UR Pulley installed today - AcuraZine - Acura Enthusiast Community -> No Pictures
A-015: Check Oil Level Light / Low Oil Pressure
A-015: Car says "check oil level", but oil level's fine. - AcuraZine - Acura Enthusiast Community
A-018: Cruise Control Not Working! Light Won't Stay On!
A-018: Cruise Control Inop - AcuraZine - Acura Enthusiast Community
A-019: Resetting/Flashing the ECU
https://acurazine.com/forums/second-...h-tune-961270/
A-001: Break-in
B. Intake/CAI
B-001: DIY: Video on Installing Cold Air Intake (CAI)
https://acurazine.com/forums/2g-rl-2005-2012-76/b-001-diy-video-installing-intake-thank-your-tl-brethren-500308/
C. Fuel/Oil/Filters
C-001: DIY: 2nd Gen RL Engine Air Filter Replacement
https://acurazine.com/forums/2g-rl-2005-2012-76/c-001-how-change-air-filter-2g-rl-711362/ -> No Pictures
C-002: DIY:2nd Gen RL Oil Change
https://acurazine.com/forums/second-...ctures-852652/
C-003: DIY: 3x3 Automatic Transmission Fluid Change / ATF Change
https://acurazine.com/forums/2g-rl-2005-2012-76/c-003-3x3-atf-change-transmission-shudder-4th-5th-%40-low-rpm-753017/ -> No Pictures
C-006: K&N Filter Voids Warranty?
https://acurazine.com/forums/2g-rl-2005-2012-76/voided-warranty-k-n-filter-802661/
D. Tires/Wheels/Springs/Suspensions/Brake
D-001: DIY: A-Spec Suspension Installation W/Pictures
https://acurazine.com/forums/2g-rl-tires-wheels-suspension-92/d-001-d-i-y-spec-suspension-install-772102/
D-003: DIY: Brake Fluid Flush
https://acurazine.com/forums/2g-rl-t...-flush-967000/
D-002: DIY: Front Brake Pad Replacement
https://acurazine.com/forums/second-...nt-diy-793010/
D-004: DIY: Inner + Outer Tie Rod Replacement
https://acurazine.com/forums/2g-rl-t...cement-953256/
D-005: DIY:Upper Control Arm replacemement
https://acurazine.com/forums/2g-rl-t.../#post16188268
D-006: 2005-2008 RL Rear Swaybar Upgrade to Stiffer 2009 Bar!
https://acurazine.com/forums/2g-rl-tires-wheels-suspension-92/d-006-2009-sway-bar-update-05-08-parts-list-prices-715573/#post10661181 -> Part No's Plus Info
https://acurazine.com/forums/2g-rl-tires-wheels-suspension-92/d-006-09-rl-rear-sway-bar-installed-my-06-a-700055/#post10628847 -> Pictures!
https://acurazine.com/forums/2g-rl-2005-2012-76/diy-rear-stabilizer-09-05-08-rl-806621/ -> Better pictures
D-009: Replacement PAX Tires Options? Getting rid of PAX tires altogether?
https://acurazine.com/forums/2g-rl-2005-2012-76/d-009-pax-tires-help-please-789576/
https://acurazine.com/forums/2g-rl-tires-wheels-suspension-92/d-009-depax-spare-tire-769085/ --- Spare Tire Part #'s
https://acurazine.com/forums/2g-rl-tires-wheels-suspension-92/d-009-re-pax-de-pax-question-786954/ --- Spare Tire Part #'s for retrofit and More Info!
https://acurazine.com/forums/2g-rl-t...swered-883780/
D-009: Brake Options? Brake Replacement? Warped Rotors?
https://acurazine.com/forums/2g-rl-tires-wheels-suspension-92/d-009-buying-rotors-pads-my-05-a-788056/
D-012: DIY: Rattling From Rear Suspension -> FIXED!
https://acurazine.com/forums/2g-rl-tires-wheels-suspension-92/d-012-rear-right-suspension-noise%3B-e-brake-cable-tightening-772060/
D-015: Broken Wheel Lock!
https://acurazine.com/forums/2g-rl-tires-wheels-suspension-92/d-015-broken-wheel-lock-lug-nut-ever-hear-735498/
D-018: Lowering Options for RL?
https://acurazine.com/forums/2g-rl-tires-wheels-suspension-92/d-018-lowering-options-ride-quality-789882/
D-021: Dount Spare Tire Size?
https://acurazine.com/forums/2g-rl-2005-2012-76/d-021-donut-spare-size-802533/
E. Exterior/Exhaust
E-001: DIY: Front Door Handle Replacement
https://acurazine.com/forums/2g-rl-2005-2012-76/2005-rl-front-door-outer-handle-replacement-747663/
E-002: J-Pipe, High Flow Pre-Cat and Pre-Cat Delete Discussion Thread
https://acurazine.com/forums/second-...inside-854765/
E-003: DIY: Decklid Spoiler Installation W/Pictures
https://acurazine.com/forums/2g-rl-2005-2012-76/e-003-diy-oem-deck-spoiler-install-drilling-3m-adhesive-499938/
E-004: DIY: Wiper Blade Replacement
https://acurazine.com/forums/second-generation-rl-2005-2012-76/e-004-diy-windshield-wiper-wiper-insert-replacement-968697/
E-006: Chrome Peeling Off Front Grille!
https://acurazine.com/forums/2g-rl-2005-2012-76/e-009-chrome-chipping-off-bottom-grille-785691/
E-007: Pictures of Painted Grilles
https://acurazine.com/forums/second-...amples-939229/
E-008: DIY: Rear View Mirror Rattle Fix
https://acurazine.com/forums/second-...le-fix-916395/
E-009: DIY: Side Mirror Rattle/Vibration Fix
https://acurazine.com/forums/2g-rl-2005-2012-76/e-006-sideview-mirror-rattle-vibration-fix-740334/
E-010: Power Folding Mirror Upgrade
https://acurazine.com/forums/second-...irrors-911689/
E-012: Backup Sensors?
https://acurazine.com/forums/2g-rl-audio-bluetooth-electronics-navigation-90/e-012-backup-sensors-801011/
F. Interior/Console/MID/HVAC
F-001: DIY: 2nd Gen RL Cabin Air Filter Replacement W/ Pictures!
https://acurazine.com/forums/2g-rl-2005-2012-76/f-001-2g-rl-cabin-air-filter-diy-500376/
F-002: DIY:Upgrading to a 09+ RL Climate Control Unit in an '05-'08 RL
https://acurazine.com/forums/second-...-08-rl-915601/
F-003: DIY: Wood Steering Wheel Installation W/Pictures
https://acurazine.com/forums/2g-rl-2005-2012-76/f-003-diy-steering-wheel-install-detailed-pics-499939/
https://acurazine.com/forums/2g-rl-2005-2012-76/f-003-diy-installed-wood-steering-wheel-my-2006-rl-498729/
F-004: DIY: How to replace your door look actuators
https://acurazine.com/forums/second-...motors-932327/
F-005: Flickering Climate Control Top Display/Center Speaker FIXED! POST #9! Detailed DIY Thread 2!
https://acurazine.com/forums/second-...g-help-854144/
https://acurazine.com/forums/2g-rl-a...ay-fix-957702/
F-006: Center Console / Gearshift Making Click Sound
https://acurazine.com/forums/2g-rl-2005-2012-76/f-006-shifter-slight-click-sound-702280/
F-007: DIY: Door Armrest Leather Replacement (Post #15)
https://acurazine.com/forums/second-generation-rl-2005-2012-76/f-007-diy-how-replace-your-door-panel-armrest-leather-cover-950488/
F-008: DIY: Painting the "Not An Ashtray"
https://acurazine.com/forums/second-...-cover-963313/
F-009: Upgrading Center Console Wood to 2009+ Style Possible?
https://acurazine.com/forums/2g-rl-2005-2012-76/f-009-new-acura-rl-console-787491/
F-010:DIY: Replace Chrome Trim on Bumper Trim/General Chrome Trim
https://acurazine.com/forums/second-...e-trim-972529/
F-011: DIY: Replace Turn Signal/Headlight Combination Switch
https://acurazine.com/forums/2g-rl-a...placed-973198/
F-012: DIY: Upgrading Center Console Wood to 2009+ Style
https://acurazine.com/forums/showthread.php?t=716321&highlight=replace+console
F-015: Peeling Center Console Leather -> FIXED
https://acurazine.com/forums/2g-rl-2005-2012-76/f-015-heavy-vs-arm-rest-781944/
F-018: Power Outlet won't Stay Closed-> FIXED
https://acurazine.com/forums/2g-rl-audio-bluetooth-electronics-navigation-90/f-018-center-console-power-outlet-stays-open-712752/
https://acurazine.com/forums/2g-rl-audio-bluetooth-electronics-navigation-90/f-018-fixing-power-outlet-door-779571/
F-021: DIY:Replace Center Console Bulbs!
https://acurazine.com/forums/2g-rl-audio-bluetooth-electronics-navigation-90/f-021-diy-climate-control-bulb-replacement-713113/
https://acurazine.com/forums/2g-rl-audio-bluetooth-electronics-navigation-90/f-021-climate-control-bulbs-changed-716317/
Also consider changing your hazard switch bulb if you haven't already, requires you to remove the radio:
https://acurazine.com/forums/2g-rl-a...emoval-939509/
G. Lighting
G-001: DIY: AFS Unit Learn Procedure
https://acurazine.com/forums/2g-rl-2005-2012-76/g-001-help-afs-unit-learning-procedure-749262/
G-002: DIY: AFS Sensors Alternative Fix
Post #53 here:
https://acurazine.com/forums/second-...fs-fix-930302/
G-003: DIY: Replacing Rear Turn Signal Bulbs
https://acurazine.com/forums/2g-rl-2005-2012-76/g-003-diy-swap-rear-turn-signal-silver-bulb-703419/
G-006: Headlights Flickering
https://acurazine.com/forums/2g-rl-audio-bluetooth-electronics-navigation-90/05-rl-headlight-flicker-695557/
G-009: DIY: Repairing Broken Fog Light Lens (New Glass)
https://acurazine.com/forums/2g-rl-2005-2012-76/g-009-diy-rl-fog-light-glass-replacement-769528/
G-012: DIY: Changing HID Bulbs
https://acurazine.com/forums/showpost.php?p=11824124&postcount=62
G-015: DIY: Changing Fog Light Bulbs
https://acurazine.com/forums/2g-rl-2005-2012-76/quick-diy-jdm-yellow-fog-light-upgrade-754112/
G-018: Replacement LED License Plate Bulbs?
https://acurazine.com/forums/2g-rl-2005-2012-76/g-018-will-these-replace-liscense-plate-bulbs-788663/
G-021: Brighter High Beams
https://acurazine.com/forums/2g-rl-2005-2012-76/i-021-headlight-high-beam-question-790209/
G-024: Headlights Flickering / Headlight is Pink!
https://acurazine.com/forums/2g-rl-2005-2012-76/g-024-headlights-going-crazy-788916/
G-027: Replacement Visor / Vanity Lights LEDS?
https://acurazine.com/forums/2g-rl-2005-2012-76/g-027-visor-vanity-bulbs-499866/
G-028: DIY: Reverse Ligh Replacement
https://acurazine.com/forums/second-...cement-885602/
Post #53 here:
H. Car Care/Clear-bra
H-001: DIY: Resetting the Maintenance Minder System
https://acurazine.com/forums/2g-rl-2005-2012-76/h-001-2005-acura-rl-b-service-rest-789971/
https://acurazine.com/forums/2g-rl-2005-2012-76/h-001-maintenance-indicator-785841/
H-003: Changing the Battery?
https://acurazine.com/forums/2g-rl-2005-2012-76/h-003-q-changing-battery-789680/
H-006: Coolant and Brake Fluid Change Intervals?
https://acurazine.com/forums/2g-rl-2005-2012-76/h-006-coolant-brake-fluid-changes-786043/
I. Audio/Electronics/Navi/Bluetooth/iPod/MP3/Alarm/Radar
I-001: iPhone mount and DICE i-HONDA-R/4 Installed
I-001: iPhone mount and DICE i-HONDA-R/4 - AcuraZine - Acura Enthusiast Community
I-002: Tablet audio system
https://acurazine.com/forums/2g-rl-a...anyone-951804/
I-003: DIY: Base RL to Navigation RL conversion
I-003: DIY Base RL to NAV RL conversion - AcuraZine - Acura Enthusiast Community
I-004: Streaming Music Thru Bluetooth: USA Spec BT45
https://acurazine.com/forums/second-...etooth-937031/
I-005: Signs of a Dying Battery
https://acurazine.com/forums/second-...attery-863206/
I-006: DIY: Autotoys.com Navigation to Video Interface (with BOTH Audio and Video) Installation
I-006: DIY Autotoys.com Nav to Video Interface (with BOTH Audio and Video) - AcuraZine - Acura Enthusiast Community
I-009: 2005 Acura RL Rear View Camera Installed
I-009: 2005 RL Rear View Camera Installation w/pics - AcuraZine - Acura Enthusiast Community
https://acurazine.com/forums/audio-v...ra-diy-362179/
I-012: How Do I Change DVD-A groups?
I-012: Acura RL 2008: how do I change between groups on DVD-A disk? - AcuraZine - Acura Enthusiast Community
I-015: Navigation Volume Low?
I-015: Nav Audio Volume Low? - AcuraZine - Acura Enthusiast Community
I-018: DIY: NavTool Installation DIY W/Pictures
I-018: Heavy Vs NavTool... - AcuraZine - Acura Enthusiast Community
I-021: DIY:Clear Warnings/Error/Diagnostic Messages on Navigation System
I-021: Need help with reset of tpms warning on NAV - AcuraZine - Acura Enthusiast Community
I-024: Memory Setting's Presets/settings gone, restored to factory defaults -> Quick Fix!
I-024: electrical interface feedback problem - AcuraZine - Acura Enthusiast Community
I-026: Subwoofer Installation WITH PICS!!
https://acurazine.com/forums/2g-rl-a...t-pics-878491/
In rear deck: https://acurazine.com/forums/2g-rl-a...r-deck-952803/
I-027: Humming Noise After Aftermarket Subwoofer Install -> Quick Fix!
I-027: Humming noise with subwoofer install - AcuraZine - Acura Enthusiast Community
I-027: Aftermarket amp - AcuraZine - Acura Enthusiast Community
https://acurazine.com/forums/2g-rl-audio-bluetooth-electronics-navigation-90/i-002-diy-anc-disable-aftermarket-sub-no-tools-814274/
https://acurazine.com/forums/2g-rl-audio-bluetooth-electronics-navigation-90/i-027-diy-anc-disable-aftermarket-sub-no-tools-814274/
I-030: Iphone Not Working with USB Port! -> Quick Fix!
I-030: iPhone 3gs is not recognized on the USB port - 2010 RL - AcuraZine - Acura Enthusiast Community
I-033: Store Phonebook Entries Missing?
I-033: Phone Book Entries Gone? WTF? - AcuraZine - Acura Enthusiast Community
I-036: Previous Destinations In Navi?
I-036: Previous Destinations - AcuraZine - Acura Enthusiast Community
I-039: Onstar in 2005/2006 RL?
I-039: on star - AcuraZine - Acura Enthusiast Community
I-042: DIY: Ipod kit PA15-ACU XL Installation
I-042 DIY Ipod Kit PA15-ACU XL - AcuraZine - Acura Enthusiast Community
I-045: USB Audio Input?
I-045: USB audio adapter - AcuraZine - Acura Enthusiast Community
I-048: RL CD Changer Dead...
I-048: RL CD Changer Issues ( Not Reading, Won't Eject CD's) - AcuraZine - Acura Enthusiast Community
I-051: Remote Starter for RL?
I-051: Remote Start - AcuraZine - Acura Enthusiast Community
I-054: GROM Audio AUX Input for RL Works!
I-054: Grom Audio Aux input in 2006 RL working - AcuraZine - Acura Enthusiast Community
I-057: XM Radio Nav Traffic - No more on 2005?
I-057: xm radio said no more traffic.. - AcuraZine - Acura Enthusiast Community
J. TSB/Manual/Safety
J-001: 2nd Gen RL Technical Service Bulletins (TSB)
https://acurazine.com/forums/2g-rl-2005-2012-76/2nd-gen-rl-tsb-information-789213/
J-003: Acura Service News Bulletins
https://acurazine.com/forums/3g-tl-2004-2008-93/acura-servicenews-bulletins-588838/
J-006: Owners Manuals
https://techinfo.honda.com/rjanisis/...01_OMANUAL.asp
J-009: Acura Accessory Installation Instructions
http://estore.honda.com/accesssory-i...asp?make=ACURA
K. Window/Tints/Trunk
K-001: DIY: Sunroof and Window Switch Reset Procedure (Auto Up/Down)
https://acurazine.com/forums/2g-rl-audio-bluetooth-electronics-navigation-90/k-001-sunroof-controls-issues-ac-issues-781674/
K-002: Master Window Switch Reset (Windows won't go up/down from the master switch, but will go down at the door)
https://acurazine.com/forums/second-...cedure-700654/
L. Miscellaneous
L-001: When does a dealer lose money because cars are not sold
https://acurazine.com/forums/4g-tl-2009-2014-123/l-001-when-does-dealer-lose-%24-because-cars-not-sold-711117/
L-002: Service Manual Link (Post #11)
acurazine.com/forums/second-generation-rl-2005-2012-76/l-002-rl-service-manual-link-post-11-a-734029/
https://acurazine.com/forums/second-generation-rl-2005-2012-76/l-002-free-2g-rl-servic
L-003: Thinking About Purchasing a 2nd Gen RL? "Must See Introduction Video!"
https://acurazine.com/forums/2g-rl-2005-2012-76/l-003-thinking-about-rl-must-see-acura-rl-introduction-video-498517/
L-004: DIY: Painting Your Center Caps
https://acurazine.com/forums/second-...ercaps-886303/
L-005: Dim Brake lights/ Dead Brake Lights W/ SH-AWD/VSA lights turning on. Bad Brake Light Switch!
https://acurazine.com/forums/second-...-times-953082/
L-006: RL Trailer Hitch Installed
https://acurazine.com/forums/2g-rl-2005-2012-76/l-006-rl-hitch-installed-pics-499119/
L-009: Determining if a RL has CMBS / PAX options?
https://acurazine.com/forums/2g-rl-2005-2012-76/l-009-cmbs-pax-question-789104/
L-012: How To Use Sport-Shift / Semi-Manual / Manualmatic on RL!
https://acurazine.com/forums/2g-rl-2005-2012-76/l-012-2006-rl-semi-manual-780565/
M. Performance
M-001: List of Aftermarket Parts for the 2nd Gen RL
https://acurazine.com/forums/2g-rl-2005-2012-76/m-001-list-aftermarket-parts-available-your-rl%7E-499683/
M-003: 2006 RL Dyno'ed Pre and Post Mods!
https://acurazine.com/forums/2g-rl-2005-2012-76/m-003-my-rl-dynoed-part-2-post-mod-results-videos-pix-499256/
