DIY Collection for the 2nd gen TL
Interior
LED Conversion
http://www.ledautomotive.com/OrderIn...03TL/index.asp
http://www.n4te.com/images/acura/leds/guide/
LED Climate Control
https://acurazine.com/forums/showthr...=601528&page=2
Replace LEDs in Headunit
https://acurazine.com/forums/2g-cl-2001-2003-50/diy-radio-led-conversion-485288/
LED Power Window Buttons
https://acurazine.com/forums/2g-tl-1999-2003-98/diy-led-power-window-buttons-620689/
Remove Door Panels and Wood Trim
https://acurazine.com/forums/2g-tl-1999-2003-98/d-i-y-removing-door-panels-wood-grain-626785/
Paint Shiftgate
https://acurazine.com/forums/2g-tl-1999-2003-98/diy-shiftgate-redo-update-621805/
https://acurazine.com/forums/showthr...91#post8965591
Metra Single Din to Double Din
https://acurazine.com/forums/2g-tl-1999-2003-98/diy-metra-kit-alpine-iva-w200-612291/
Fix Door Panel Peeling
Fix Dash Rattle
https://acurazine.com/forums/2g-tl-1999-2003-98/dash-rattle-found-fixed-pictures-546283/
Flush Mount Door Lock Knobs
https://acurazine.com/forums/2g-tl-1999-2003-98/diy-door-lock-knob-adjustment-620740/
Switch Shifter Direction
https://acurazine.com/forums/showpos...2&postcount=76
Exterior
Install Spoiler
https://acurazine.com/forums/2g-tl-1999-2003-98/diy-spoiler-install-626023/
http://www.in.honda.com/Rjanisis/pubs/AI/BII22514.pdf
Install M3/M5 Spoiler
https://acurazine.com/forums/showpos...0&postcount=18
Black Mesh Grill
https://acurazine.com/forums/showthr...ht=mesh+grille
Grill Removal
https://acurazine.com/forums/2g-tl-photograph-gallery-99/diy-taking-off-front-grill-pics-572103/
Cleared Headlight Housing 02-03
http://www.cardomain.com/ride/184466/18
Cleared Headlight Housing 99-01
https://acurazine.com/forums/showthr...18#post2013918
Black Headlight Housing
https://acurazine.com/forums/showthr...6&page=3&pp=25
Wetsanding Headlights
https://acurazine.com/forums/2g-tl-photograph-gallery-99/fun-sandpaper-580286/
http://www./forum/f94/...-steps-321528/
HID Projectors Retrofit
https://acurazine.com/forums/2g-tl-1999-2003-98/diy-hid-projector-retro-fit-02-03-headlights-618263/
Install HID Foglights
https://acurazine.com/forums/2g-tl-problems-fixes-117/replacing-broken-wheel-lug-stud-596439/
Install Foglights 99-01
https://acurazine.com/forums/2g-tl-1999-2003-98/diy-installing-accord-fog-lights-99-01-tl-corner-pocket-565298/
https://acurazine.com/forums/2g-tl-1999-2003-98/replica-6g-accord-4dr-foglights-diy-612321/
https://acurazine.com/forums/2g-tl-1999-2003-98/diy-alternate-fog-diy-01-03-civic-fogs-613806/
https://acurazine.com/forums/2g-tl-1999-2003-98/diy-01-03-civic-fogs-99-01-tl-624705/
Foglight Mod
https://acurazine.com/forums/2g-tl-1999-2003-98/fog-light-mod-alternate-version-549015/
Install Side Markers
https://acurazine.com/forums/2g-tl-1999-2003-98/diy-745-side-markers-545900/
Door Handle LEDs
https://acurazine.com/forums/2g-tl-1999-2003-98/diy-door-handle-leds-613711/
Install 02-03 Taillights
https://acurazine.com/forums/showpos...07#post2040881
Rear License Plate Cathodes
https://acurazine.com/forums/showpos...53#post1778406
Debadge
https://acurazine.com/forums/showthread.php?t=122040
Remove B Pillars
https://acurazine.com/forums/2g-tl-problems-fixes-117/remove-b-pillar-2nd-gen-tl-%5B56k-beware%5D-583946/
Apply Pillar Vinyl
https://acurazine.com/forums/2g-tl-1999-2003-98/fixed-my-pillar-problem-640085/
Paint Calipers
https://acurazine.com/forums/showthr...70#post8898870
Replace Broken Wheel Lug Stud
https://acurazine.com/forums/showthread.php?t=596439
Performance
Lowering Springs
http://www.cardomain.com/ride/184466/7
https://acurazine.com/forums/2g-tl-tires-wheels-suspension-100/diy-lowering-dropping-your-tl-623631/
Rear Camber Kit
http://www.6thgenaccord.com/forums/s...ead.php?t=3984
Install Intake
https://acurazine.com/forums/ramblings-12/i-love-tattoos-but-just-wrong-107821/
Remove Intake Resonator
https://acurazine.com/forums/showpos...58#post1870075
Paint Aftermarket Intake
https://acurazine.com/forums/2g-tl-1999-2003-98/diy-paint-your-cold-air-short-ram-intake-638335/
Install Headers
http://www.cardomain.com/ride/184466/19
ThermoBlok Spacers
https://acurazine.com/forums/2g-tl-1999-2003-98/diy-thermoblok-spacers-install-egr-cleaning-615644/
Install Radiator
https://acurazine.com/forums/2g-cl-2001-2003-50/griffin-radiator-install-write-up-pictures-486321/
Valve Adjustment
https://acurazine.com/forums/showpos...8&postcount=33
Mugen Thermostat
http://www.cardomain.com/ride/590232/8
Install EZ Oil Drain Valve
https://acurazine.com/forums/2g-tl-1999-2003-98/ez-oil-drain-valve-install-w-pics-611400/
Replace Alternator
http://www.cardomain.com/ride/184466/9
Replace Rotors
http://www.cardomain.com/ride/184466/23
https://acurazine.com/forums/showthr...03#post8898903
Electronics
OEM Navigation Install
https://acurazine.com/forums/showthread.php?t=114084
Keeping Navigation Prompts w/Aftermarket Headunit
https://acurazine.com/forums/audio-video-electronics-navigation-22/d-i-y-retain-your-navi-prompts-w-aftermarket-headunit-338089/
Install Dom's Nav2DVD
https://acurazine.com/forums/audio-video-electronics-navigation-22/diy-doms-nav-dvd-install-w-pics-2000-tl-312145/
Install Aux Port
http://www.skyeflye.com/acura_cls/In...01-2003_CL.pdf
Big 3
https://acurazine.com/forums/2g-tl-1999-2003-98/diy-big-3-a-692969/
Radar Detector Hardwire
https://acurazine.com/forums/2g-tl-1999-2003-98/radar-detector-wired-into-auto-dim-mirror-593753/
https://acurazine.com/forums/showthr...27#post9066127
Optima Battery and Billet Bottom Install
https://acurazine.com/forums/2g-tl-performance-parts-modifications-116/optima-install-using-billet-bottom-mount-holder-photos-included-627795/
Fix Navigation 99
https://acurazine.com/forums/2g-tl-problems-fixes-117/solution-failed-gps-hard-drive-601833/
Maintenance
Seafoam
https://acurazine.com/forums/9053510-post/
https://acurazine.com/forums/2g-tl-1999-2003-98/diy-seafoam-03-tl-s-638176/
Replace HID Headlights
https://acurazine.com/forums/showpos...24&postcount=2
Replace Dash Clock Light
https://acurazine.com/forums/showpos...9&postcount=12
Replace Brake Pads
http://www.cardomain.com/ride/184466/24
Replace AC Cabin Filter
https://acurazine.com/forums/showthread.php?t=107821
120k Service
https://acurazine.com/forums/2g-tl-1999-2003-98/120k-service-completed-610450/
Program Key Fob
https://acurazine.com/forums/showpos...86&postcount=6
99 EGR Cleaning
https://acurazine.com/forums/showthread.php?t=615644
http://www.in.honda.com/Rjanisis/pubs/SB/B00-004.PDF
00-03 EGR Cleaning
https://acurazine.com/forums/showpos...39&postcount=8
Transmission Fluid
https://acurazine.com/forums/showpos...85&postcount=3
Replace Rear View Mirror
https://acurazine.com/forums/showpos...9&postcount=23
Replace Ignition
https://acurazine.com/forums/2g-tl-1999-2003-98/diy-99-tl-ignition-switch-686000/
Brake Switch
https://acurazine.com/forums/2g-tl-1999-2003-98/diy-brake-switch-614710/
Replace Wheel Bearing
https://acurazine.com/forums/2g-tl-1999-2003-98/wheel-bearing-diy-620807/
...I didn't want to study so I decided to clean up the giant DIY thread. Enjoy!
LED Conversion
LED Climate Control
Paint Shiftgate
Fix Dash Rattle
Exterior
Install Spoiler
Black Mesh Grill
Grill Removal
Foglight Mod
Door Handle LEDs
Debadge
Remove B Pillars
Apply Pillar Vinyl
Paint Calipers
Performance
Lowering Springs
Rear Camber Kit
Install Intake
Install Headers
ThermoBlok Spacers
Install Radiator
Valve Adjustment
Mugen Thermostat
Replace Alternator
Replace Rotors
Electronics
Install Aux Port
Big 3
Fix Navigation 99
Maintenance
Seafoam
Replace Brake Pads
120k Service
Program Key Fob
99 EGR Cleaning
00-03 EGR Cleaning
Transmission Fluid
Replace Ignition
Brake Switch
Nice but i already threw one together weeks go. I just havent finished it by posting it. Ill go thru yours and see if you have any thing that i dont and try to get the one i made posted today to get rid of the abortion of a thread we have
yeh i kind of wish i had made this before i installed my coilovers since i didn't realize there was already a coilover install DIY
btw i really think we should have all of these archived and the pics uploaded to the site
who knows when these old members might delete their photobucket account and all the pictures are gone.
yeah seriously. car forums are based around DIYs. and since the search sucks we need a good way to organize all of them. I am used to forums that have a section with articles or guides and all the information is archived with pictures uploaded to the website so it will be there forever and is very easy to access. these sections also usually have a section of important threads, faqs and the like. I'd much rather have that then having friends and people commenting me...
sorry about that. i wish i could edit it but only mods have that capability but don't worry; fstty says this thread will be trash by the end of the day since he's putting up the better one soon. Yay!
for those who havent seen my oil catch can diy, here u go
https://acurazine.com/forums/2g-tl-1999-2003-98/oil-catch-can-diy-693521/
https://acurazine.com/forums/2g-tl-1999-2003-98/diy-door-peeling-experimental-way-693646/
Door pealing easier way
yes somebody already pointed that out plus i found another mislink but i can't really do anything about it. and our mega mod supposedly has his own that he said he was going to put up a week ago but we haven't seen anything yet. so thats why this one hasn't been stickied.
fog light fix for cracked fog lights, lexan and painted
https://acurazine.com/forums/showthr...2#post10140752
their a diy sticky already and kris is supposed to clean up all the random comments and hasnt gotten to it and their have been new diy mods that cant be posted in the sticky.
take off your rear wheel. and your rear rotor. you will see an adjustable knob for the parking brake at the bottom of the hub. turn that and try putting your rotor on. when you feel it rub just enough, turn the knob one time backwards to loosen it up one click and put everthing back together.
viola, parking break adjusted
HID FOGLIGHT INSTALL DIY
https://acurazine.com/forums/2g-tl-performance-parts-modifications-116/3000k-hid-foglight-install-pics-56k-think-again-602180/
Hopefully the mods will fix the link in your first post
Hey man, I thought the rubber plug on the rotor near the wheel stud could be removed and you can access the screw from there. Then turn your rotor until it grabs then back off a click or two. All without removing the rotor.
