Microsoft: Windows 7 and Office 2010 Thread
Old Oct 27, 2009 | 11:49 PM
  #1321
Billiam's Avatar
Big Block go VROOOM!
Could also just try "Windows 95" from the compatibility settings on the app's executable.
Old Oct 28, 2009 | 12:07 AM
  #1322
#1 STUNNA's Avatar
Sanest Florida Man
I scrounged through the software bin an found a bunch of old crap but IDK if it's old enough. Most of my old software is Mac only, I got that original iMovie if you want it! Adobe pagemill? I got you son, but it's for Mac only. I did however find a really old version of Transparent Language "learn latin now!" it says it's for Win 95, 98 or NT. I'll try it out but IDK if it's old enough. It seems like it's 32 bit.
Old Oct 28, 2009 | 12:10 AM
  #1323
#1 STUNNA's Avatar
Sanest Florida Man
64 bit won't run 16 bit. There's no way besides virtualization.
Old Oct 28, 2009 | 12:12 AM
  #1324
#1 STUNNA's Avatar
Sanest Florida Man
How can I tell if an app is 16 bit?
Old Oct 28, 2009 | 12:18 AM
  #1325
#1 STUNNA's Avatar
Sanest Florida Man
Holy shit this made me laugh. It made me install quicktime. I think this program is 32 bit
Old Oct 28, 2009 | 12:39 AM
  #1326
ChodTheWacko's Avatar
Moderator Alumnus
Why is the 'Run' not on by default in the start menu? Grrrr.
Although the same resolution, the font is absolutely tiny in windows 7. Not sure why.
I'm flirting towards turning on that magnifier option. Wish it only did text though.
There's a text font changer buried in personalization, but it does everything except window contents. (thanks)
- Frank
Old Oct 28, 2009 | 12:45 AM
  #1327
#1 STUNNA's Avatar
Sanest Florida Man
run has been gone since Vista. There's many ways to deal with this. First is the search bar in the the start menu. you want to open msconfig, cmd prompt, regedit, dxdiag, winver, sigverif, services.msc, etc just type it in the search bar it'll pop up. This will hand most of your run needs. If you need a run window just hit win key + r and pops up the run command. If you really must have the run command in the start menu then right click on the task bar choose properties then go to the start menu tab and hit customize. From there you'll find "run command" in the start menu list which will add it to the start menu.
just try to use the search function it does pretty much everything.
Old Oct 28, 2009 | 12:46 AM
  #1328
Moderator Alumnus
Hmmm, the font might not be smaller, but I have a much harder time reading it. maybe I have to screw around with cleartype or something.
- Frank
Old Oct 28, 2009 | 12:49 AM
  #1329
srika's Avatar
Moderator Alumnus
my Java is broke in Firefox. I can't upload pics to Facebook using the bulk Java interface (which I need) - when I try it says "Error. Click for details". Here are the details - help!
I tried uninstalling (remove all plugins), uninstall from Programs, reboot, reinstall everything. No cigar. It also doesn't work in IE8.
Java Plug-in 1.6.0_16
Using JRE version 1.6.0_16-b01 Java HotSpot(TM) Client VM
User home directory = C:\Users\srika
c: clear console window
f: finalize objects on finalization queue
g: garbage collect
h: display this help message
l: dump classloader list
m: print memory usage
o: trigger logging
q: hide console
r: reload policy configuration
s: dump system and deployment properties
t: dump thread list
v: dump thread stack
x: clear classloader cache
0-5: set trace level to <n>
load: class com.facebook.facebookphotouploader5.FacebookPhotoU ploader5.class not found.
java.lang.ClassNotFoundException: com.facebook.facebookphotouploader5.FacebookPhotoU ploader5.class
at sun.plugin2.applet.Applet2ClassLoader.findClass(Un known Source)
at java.lang.ClassLoader.loadClass(Unknown Source)
at sun.plugin2.applet.Plugin2ClassLoader.loadCode(Unk nown Source)
at sun.plugin2.applet.Plugin2Manager.createApplet(Unk nown Source)
at sun.plugin2.applet.Plugin2Manager$AppletExecutionR unnable.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
Caused by: java.io.IOException: open HTTP connection failed:http://upload.facebook.com/controls/...r5/class.class
at sun.plugin2.applet.Applet2ClassLoader.getBytes(Unk nown Source)
at sun.plugin2.applet.Applet2ClassLoader.access$000(U nknown Source)
at sun.plugin2.applet.Applet2ClassLoader$1.run(Unknow n Source)
at java.security.AccessController.doPrivileged(Native Method)
... 7 more
Exception: java.lang.ClassNotFoundException: com.facebook.facebookphotouploader5.FacebookPhotoU ploader5.class
Old Oct 28, 2009 | 12:52 AM
  #1330
#1 STUNNA's Avatar
Sanest Florida Man
so I just searched the interwebs for a 16 bit program and found one. It's Total Commander which sounds like a game and was designed for Win 3.11 and yes it runs in XP mode on my 64 bit Windows 7 Professional!
Notice the wowexec.exe process. wow stands for Windows on Windows which is their emulation process to emulate older versions of windows on newer versions. Even today there's WoW64 which allows 32 bit apps to run on 64 bit windows just as this wowexec.exe process allows 16 bit apps to run on 32 bit windows.
Old Oct 28, 2009 | 12:53 AM
  #1331
#1 STUNNA's Avatar
Sanest Florida Man
I have that too! I didn't think it was a Win7 problem. I'll try it in XP mode! Xp mode to the rescue! I'm having fun with this tonight!
Old Oct 28, 2009 | 12:56 AM
  #1332
srika's Avatar
Moderator Alumnus
ok - guessing we'll see a new version of Java soon - ?
Old Oct 28, 2009 | 01:03 AM
  #1333
#1 STUNNA's Avatar
Sanest Florida Man
It does it in XP mode too! I just installed the latest version of Java. I don't think this is related to Windows 7 at all. And actually this wasn't the error I was getting at all before. I was getting something like upload failed or something when I tried to upload using the java way. This looks was more serious, you can't even choose photos to upload.
Old Oct 28, 2009 | 01:05 AM
  #1334
#1 STUNNA's Avatar
Sanest Florida Man
I get it in Chrome too.
  #1335
srika's Avatar
Moderator Alumnus
you know what, it just failed with same error on my old P4 2.2 XP machine as well............ wtf did Sun do............
Old Oct 28, 2009 | 01:12 AM
  #1336
#1 STUNNA's Avatar
Sanest Florida Man
Here's the 16 bit Win 3.11 app running side by side with another app in Windows 7. Do that in OS X!
Old Oct 28, 2009 | 01:15 AM
  #1337
#1 STUNNA's Avatar
Sanest Florida Man
So Eggplant baring some unforeseen anomaly your app should run fine in Windows 7 professional!
Old Oct 28, 2009 | 01:16 AM
  #1338
srika's Avatar
Moderator Alumnus
I'll be impressed if you can get PCTOOLS for DOS 5.0 running next to a DX11-specific game... haha
Old Oct 28, 2009 | 01:23 AM
  #1339
#1 STUNNA's Avatar
Sanest Florida Man
I think DOS apps stopped running in XP and Me would've probably been the last version to support that. XP of course was the first consumer OS based off the NT kernel and not off DOS as Win95/98/Me was
Old Oct 28, 2009 | 01:25 AM
  #1340
srika's Avatar
Moderator Alumnus
heh. just playing.
really enjoying how you can see the copy progress in the taskbar
Old Oct 28, 2009 | 01:26 AM
  #1341
srika's Avatar
Moderator Alumnus
getting used to the quick launch/task duality as well... it makes a lot of sense.
Old Oct 28, 2009 | 01:43 AM
  #1342
#1 STUNNA's Avatar
Sanest Florida Man
I think aero snap is my favorite new feature. I use it ALL the time now.
Old Oct 28, 2009 | 01:50 AM
  #1343
srika's Avatar
Moderator Alumnus
interesting - didn't know about it - not sure what I'd use it for though -
Old Oct 28, 2009 | 01:54 AM
  #1344
#1 STUNNA's Avatar
Sanest Florida Man
Are you kidding I use it for everything. Doing two things at the sametime. Like watching hulu and making this post. Or copying and pasting from a webpage to a document or an email. Comparing two documents. Copying files from one location to another, etc etc.
Old Oct 28, 2009 | 01:56 AM
  #1345
srika's Avatar
Moderator Alumnus
hmmm maybe I need to start using it.. I was copying some files earlier and kinda annoyed by how I had to select the window at the bottom... thought it used to be easier in XP and Vista.. you have dual monitors right? I don't - maybe that would help too.
Old Oct 28, 2009 | 02:15 AM
  #1346
#1 STUNNA's Avatar
Sanest Florida Man
no I don't. You can use the win key + left or right arrow to snap a window to either side and then just alt + tab to the next one and do the same.
Old Oct 28, 2009 | 02:18 AM
  #1347
wasupdog's Avatar
My Garage not
i got my preorder copies of windows 7. does this need the ahci drivers or do i just pop the disc in and install it without anything extra? what's the deal with drivers, i keep seeing around the web that windows 7 has most of the generic drivers. i still need to install motherboard drivers and all of that extra stuff right?
my laptop install is going to be easy. i'm putting off my desktop xp to w7 install cus it's going to be a huge pita and i'm not looking forward to it.
Old Oct 28, 2009 | 03:06 AM
  #1348
Ken1997TL's Avatar
Originally Posted by #1 Stunna
Maybe someone here has an old 16-bit app they can throw in XP mode and see if it works. I don't, or if someone posts a link to a known 16bit app I'll try to install it in my XP mode myself.
I've got a lot of old school 16 bit games that work just fine, no DosBox or anything needed
Win7 64 bit here
Old Oct 28, 2009 | 03:46 AM
  #1349
#1 STUNNA's Avatar
Sanest Florida Man
Those XP days of having to load drivers are gone! Just stick it in and it'll probably find everything. It works with AHCI, RAID etc, no more pressing F6 to load drivers. I just rebuilt my system with a new P55 board, core i7 processor and Intel SSD and it installed all the drivers for it. Then once it booted up for the first time it went on Windows Update and found updated drivers for my graphics card and NIC and found drivers for my webcam.
Old Oct 28, 2009 | 07:47 AM
  #1350
Whiskers's Avatar
Go Giants
Grrrr, no drivers for my Sony VGN-T350P video
Old Oct 28, 2009 | 10:06 AM
  #1351
Eggplant-EX's Avatar
you da man!!! I may not do it soon as it is busy at work and I am a non techie... I do appreciate your help.
good recall on my issue.
Old Oct 28, 2009 | 10:13 AM
  #1352
Whiskers's Avatar
Go Giants
Rockin Windows 7 at the Starbucks....Yeah...Im that cool.....Cooler then they guy with the Macbook Air....yep..
Old Oct 28, 2009 | 10:37 AM
  #1353
svtmike's Avatar
If you were really cool you'd post this from your iPhone.
Old Oct 28, 2009 | 10:39 AM
  #1354
Whiskers's Avatar
Go Giants
Old Oct 28, 2009 | 10:56 AM
  #1355
jupitersolo's Avatar
nnInn
Did you try the Vista drivers?
Old Oct 28, 2009 | 11:31 AM
  #1356
Ken1997TL's Avatar
I can post it with my Palm Pre
Old Oct 28, 2009 | 12:10 PM
  #1357
Moderator Alumnus
Perhaps a separate thread for this, since my firefox on XP also can't upload pictures. I have to use IE. I'd be interested in a debugging thread on this (although I can tolerate using IE just for that).
There is a new firefox beta out today (with better win7 support).
i'll try that when I get home.
- Frank
Old Oct 28, 2009 | 12:24 PM
  #1358
Billiam's Avatar
Further proof that Java sucks.
Old Oct 28, 2009 | 12:29 PM
  #1359
#1 STUNNA's Avatar
Sanest Florida Man
Yup FF 3.6 Beta 1 has tab preview using aero peek
Old Oct 28, 2009 | 12:33 PM
  #1360
srika's Avatar
Moderator Alumnus
yeah what's the deal with it? a miserable Java experience seems to be the norm.
