Apple: Hardware News and Discussion Thread
Old Jan 17, 2013 | 03:52 PM
  #1681
phee's Avatar
I got the Shifts
Originally Posted by jupitersolo
That's a 2.4GHz Core 2 Duo, max RAM 4GB
wrong. apple released a firmware update that enables 6gb use. I know this because I owned one
Old Jan 17, 2013 | 05:07 PM
  #1682
MaxMike93's Avatar
Currently Post-Acura
You sure you didn't have the Santa Rosa architecture 2.4GHz from early 2008? I know that one had the firmware update for 6GB RAM, I just wasn't sure if 2007 models got it as well. And seeing all this SSD talk, I really wish I could afford one in a capacity good for me. My 750GB drive has 90GB free and I don't really like the idea of carrying around an external. I could always take out my optical drive, but I know that I'll end up needing it ONCE, and I also don't want the empty slot on the side of my MacBook Pro. But it sure would make my 2.4GHz Core i7 a lot quicker to use
Old Jan 17, 2013 | 06:38 PM
  #1683
Sly Raskal's Avatar
Yea, my late 2007 model only supports up to 4 GB as well; however, some guys did get theirs up to 6GB but Apple came out and said that you would burn out your computer if you ran it in that configuration. Don't know if that is true or not. To air on the side of caution, I only kept mine at 4GB.
As for SSD, I've been thinking about doing that for my late 2007 model MBP; however, the issue is that it is a SATA I and I don't know if any current SSDs are backwards compatible with that.
Also, in your specific case, if you are doing a lot of writing to that drive, I would stay clear of getting an SSD. Keep the SSD to help your OS run fast/smooth, and use an external drive as a scratch disk and for data storage, but back that up regularly.
Old Jan 17, 2013 | 11:27 PM
  #1684
MaxMike93's Avatar
SATA3 is backwards compatible, but I haven't been shopping around as to how many drives use that standard, as opposed to those that are made using SATA2. I don't know which version your specific MBP uses, but I believe (could be wrong) that each version of SATA has been backwards compatible, and SATA has been around for years at this point.
Old Jan 17, 2013 | 11:39 PM
  #1685
Sly Raskal's Avatar
my MBP only supports SATA I as far as I know. It'd be nice to experiment and see if I can get an SSD working on my machine. If it works great. Otherwise, I just put my original drive back in and use the SSD for something else.
Old Jan 26, 2013 | 12:18 PM
  #1686
Scrib's Avatar
Administrator Alumnus
So, uh... Retina 15"? Good replacement for an aging iMac?
Old Jan 26, 2013 | 12:26 PM
  #1687
Sly Raskal's Avatar
I would say so.
I have an 2009 model iMac 27" and an aging late 2007 model MBP which will probably need to be replaced next year sometime. I'm toying with simply replacing it with a 15 Retina MBP and selling my iMac and buying an external display and only having one machine. I really do like my iMac, but having to worry about keeping two computer backed up, migrating data between them, etc. is wasted time IMHO. The only downside of the MBP is having to connect/disconnect it all the time from the external display. It's much easier now with the thunderbolt connector, but that thunderbolt connector has given me a little bit of grief at times on my MBP (non-retina) that I use at work. They aren't built well enough IMO to withstand numerous connection and disconnections. I guess time will tell.
Old Jan 26, 2013 | 12:33 PM
  #1688
Scrib's Avatar
I would say so.
Yea, my iMac is from 2008 I believe. Works fine, C2D 2.0GHZ, but it's just not cutting it for photos and some of the minimal video stuff I do with the kids activities. Should be able to get a few bucks for the iMac, get an external monitor (already have a secondary 23"), maybe an IPS 27" and call it a day. Have a Macbook Air that I use when sitting on the couch (and travel)....
On the backup piece, what about a NAS running time machine? You can do some replication to/from that? I basically do that with my mac mini, attached 8TB of disk in RAID 5, between my iMac and MBA...
Old Jan 26, 2013 | 01:26 PM
  #1689
Sly Raskal's Avatar
I presently do have a ReadyNAS NV with 4 2TB drives in a Raid X (equivalent to Raid 5) which does support Time Machine Backups, but I try not to run that all day and only turn it on when needed to save on electricity and prolong the life of my NAS, but this isn't used for the iMac. I have a Seagate External 2TB that I use for Time Machine backups for the iMac. The real issue for me with the iMac connects to my router wirelessly and the ReadyNAS is connected to my router physically meaning backups would take forever, especially when I am working with large photos. I have an interesting network configuration at home to say the least and moving the ReadyNAS to my office so I can physically connect it to the iMac would be awesome, but just haven't figured out how I can do that. I should make a drawing of my network configuration to get input from you guys to figure this out.
Old Jan 26, 2013 | 02:06 PM
  #1690
Scrib's Avatar
It's not that bad over N, although you really need to be able to connect at 5GHZ to do some decent speeds to move files. I am wired on most devices that are IP based in this house with the exception of my MBA and all the iPhones/iPads (of course). But the throughput on MBA is pretty decent backing up wirelessly.
Old Jan 26, 2013 | 02:53 PM
  #1691
Sly Raskal's Avatar
Whenever I have tried using my ReadyNAS to transfer large amounts of data, I lose connectivity to it. I don't know if it's a problem with my ReadyNAS or my iMac and haven't been able to replicate it properly enough to diagnose the issue. This is the primary reason I wanted to hook it up physically.
Old Jan 26, 2013 | 03:20 PM
  #1692
Scrib's Avatar
Well, it's a done deal. Just bought a 15.4" retina. Heading over to pick it up. Oh and also snagged my Dad a 13.3" MBA. I'm a good son.
If anyone wants a mid-2007 iMac, let me know. $400.
File Type: jpg
Old Jan 26, 2013 | 03:22 PM
  #1693
Sly Raskal's Avatar
Did you opt for the larger amount of RAM? If not, I think you should because from what I understand, you can't later.
Old Jan 26, 2013 | 04:06 PM
  #1694
Mizouse's Avatar
did you get the MBA on sale at bestbuy? its $200 off today.
http://www.bestbuy.com/site/Apple%26...&skuId=4775291
Old Jan 26, 2013 | 09:20 PM
  #1695
Scrib's Avatar
Stock 8gig. Should be enough.
  #1696
Scrib's Avatar
Si
Old Jan 26, 2013 | 11:27 PM
  #1697
Mizouse's Avatar
Old Jan 28, 2013 | 03:01 PM
  #1698
Mizouse's Avatar
So I have a question. I have both a Mac and windows PC in my house. My external drive is formatted NTFS. There's no way I can save stuff from the Mac to the external right?
Old Jan 28, 2013 | 03:15 PM
  #1699
Sly Raskal's Avatar
There is. You can use Tuxera NTFS. I have Tuxera NTFS and am able to write to my windows partition on my iMac all the time. Although that is an internal drive, it should work just fine for an external drive but please verify with them first if you want to be safe.
http://www.tuxera.com/products/tuxera-ntfs-for-mac/
Old Jan 28, 2013 | 03:18 PM
  #1700
Sly Raskal's Avatar
Also worthy of mention, if you run bootcamp and do an upgrade for OS X, you may have to upgrade Tuxera NTFS before your boot camp partition is visible again. I ran into this issue when I upgraded from Snow Leopard to Lion, but didn't have any issue upgrading from Lion to Mountain Lion. When I upgraded to Lion I thought I fuxored my boot camp installation, but I think it was just that the drivers needed to be updated for me to see the Windows Partition from OS X. I didn't try to boot into windows before I fixed the Driver issue, so I don't know if there truly was an issue with the boot camp partition, but better safe than sorry I guess to update it first anway.
Old Jan 28, 2013 | 03:50 PM
  #1701
Mizouse's Avatar
Ohh interesting. Thanks.
Even thou I have this issue. It's for my friend.
Old Jan 28, 2013 | 03:53 PM
  #1702
Whiskers's Avatar
Go Giants
Don't use that. Format exFat. I have had nothing but trouble with their crap.
Traded in my MBA 2010 for a 2011, 256GB Drive i5 4GB, then won £400 at the blackjack table next door. Good day in London.
Old Jan 28, 2013 | 05:25 PM
  #1703
Sly Raskal's Avatar
Really? Hmmm, been using Tuxera NTFS for a number of years now with no issue. What were the problems you came across?
Old Jan 28, 2013 | 05:33 PM
  #1704
Whiskers's Avatar
Go Giants
Fucking up NTFS partitions. Eating up memory. No good way to uninstall it. Not needed with exFat.
Old Jan 28, 2013 | 05:40 PM
  #1705
Mizouse's Avatar
Old Jan 28, 2013 | 06:23 PM
  #1706
#1 STUNNA's Avatar
Sanest Florida Man
Ok here's a tip for you! I just bought a 1TB external hard drive, I formatted 500GB HFS+ for Time Machine backups and the other 500GB I wanted to make it so that it could be read and written by both Mac and PC. That used to mean only one option, the FAT32 file format. I'd like to use NTFS but that is Windows only and Mac can only read and not write to NTFS. Even though Mac and PC can read and write to FAT32 I'd rather not use FAT32 because it's a very old disk format that doesn't have advanced features like NTFS. Mainly, it's a 32bit file format can't hold individual files that are larger than 4GB which I do run into.
In comes exFAT to the rescue! It's the newish file format that Mac and PC can write too and it supports files larger than 4GB since it's 64bit like NTFS is. Vista SP1 and newer support exFAT out of the box and you can get drivers for XP and Server 2003 to enable exFAT support. exFAT is becoming the go to format for flash media larger than 32GB like SDXC.
I'm dealing with less and less XP machines so this shouldn't be a big issue.
Here's where you can download exFAT drivers for older Windows OS
http://support.microsoft.com/kb/955704
So if you're looking for an advanced cross platform file format that supports large files then I'd go with exFAT!
P.S. A-ha! OS X didn't get exFAT support until 10.6.5! That's why I was surprised when I saw it as a format option in disk utility, I thought it had been there for years but I just never noticed it. Nope, it's pretty recent add-on to Mac. So yeah, you have to have 10.6.5 or higher to support exFAT on Mac
http://en.wikipedia.org/wiki/ExFAT
Old Jan 28, 2013 | 07:50 PM
  #1707
Mizouse's Avatar
Ohh thanks.
Don't think that would be possible since it means formatting the drive.
I can't really help him in person since he is in NYC and me in SF
Old Jan 28, 2013 | 08:29 PM
  #1708
Sly Raskal's Avatar
I remember the issue with the memory footprint, but IIRC they fixed that with a patch. I remember people complaining about that around the time Lion came out.
Old Jan 28, 2013 | 08:32 PM
  #1709
Sly Raskal's Avatar
Hmmm, need to look into this exFat business.
Old Jan 28, 2013 | 11:46 PM
  #1710
#1 STUNNA's Avatar
Sanest Florida Man
Ohh thanks.
Teamviewer bro...
copy all the data on that drive to his laptop, then format as exFat and copy back
Old Jan 29, 2013 | 01:21 AM
  #1711
Mizouse's Avatar
3 hour difference kind of makes it hard unless its the weekend.
Anyways thanks, ill pass on this info to him.
Old Jan 29, 2013 | 01:29 AM
  #1712
Whiskers's Avatar
Go Giants
You know I do this from GMT, right?
Old Jan 29, 2013 | 02:15 AM
  #1713
Mizouse's Avatar
Yes but not many of us have a sugar momma like you...
Old Jan 29, 2013 | 02:39 AM
  #1714
Whiskers's Avatar
Go Giants
I dont see the connection.
Old Jan 29, 2013 | 08:08 AM
  #1715
#1 STUNNA's Avatar
Sanest Florida Man
I think he's saying he works until 5ish then gets home, masturbates, eats, then masturbates again, takes a shower, and then masturbates again. By the time he's done with all that it's too late on the east coast
Old Jan 29, 2013 | 09:24 AM
  #1716
Mizouse's Avatar
Sounds about right.
Old Jan 31, 2013 | 12:55 AM
  #1717
MaxMike93's Avatar
Decided to throw all that logic out the window and do some ordering earlier this week. Got me the caddy to replace my SuperDrive with my 750GB HDD, an external USB enclosure for my SuperDrive, and a Samsung 840 Pro 128GB SSD (Newegg had it for $140 and then a friend told me about a $20 off coupon ). Hopefully the SSD and caddy should be coming tomorrow so maybe I'll spend tomorrow night working on that since I plan on doing a clean Mountain Lion install. Maybe for the time being I'll just delete all folders but my Users one on my current drive and when I have the time I'll just copy all my files to my external and copy them onto a freshly formatted 2nd drive. I don't trust Time Machine backups just in case something turns out missing. And if only my school would have Windows 8 for free instead of just Windows 7 at the moment
Old Jan 31, 2013 | 03:44 AM
  #1718
Whiskers's Avatar
Go Giants
Windows 8 on Boot Camp runs very, very well. Microsoft should market that fact.
Old Jan 31, 2013 | 11:02 AM
  #1719
Sly Raskal's Avatar
Did you have any driver issues? I thought apple wasn't supporting it yet?
Old Jan 31, 2013 | 11:06 AM
  #1720
Ken1997TL's Avatar
I have it on my rMBP, no issues. Stardock start menu installed and everything works perfectly here.
