Apple: Hardware News and Discussion Thread
Old Dec 25, 2012 | 11:00 PM
  #1641
CLtotheTL32's Avatar
I have a 2007 15" MBP 2.4GHz and I'm looking to upgrade the RAM. I currently only have 2GB and I want to have at least 4GB after the upgrade.
Below is where I'm going to buy the upgrade kit but I'm not sure if I should just get a stick of 2GB to keep it at the 4GB max that Apple specified or get the 4GB upgrade so I have 6GB total.
**Apple factory specification maximum 4.0GB, OWC tested to support 6.0GB maximum RAM.
http://eshop.macsales.com/shop/memor...ook/Pro/Core2/
Any advice is truly appreciated
Old Dec 25, 2012 | 11:08 PM
  #1642
Sarlacc's Avatar
The Third Ball
www.otherworldcomputing.com
do a little research. I've seen the same thing about some models saying they can go up to 6GB even though apple says 4GB.
Not sure about it though.
Old Dec 25, 2012 | 11:10 PM
  #1643
The link I posted is from OWC
I was just curious if anyone here is successfully running 6GB with no issues even though Apple advises 4GB being the max.
Bear with me fellas, I'm not a technology wizard
Old Dec 25, 2012 | 11:13 PM
  #1644
Sarlacc's Avatar
The Third Ball
ah..whoops tee hee.
Well, you couldnt buy your memory from a better place
Old Dec 25, 2012 | 11:14 PM
  #1645
Good to know
Unless anyone else chimes in, I'll probably just stick with getting an extra 2GB and call it a day. I don't want to push anything.
Old Dec 26, 2012 | 07:17 AM
  #1646
Whiskers's Avatar
Go Giants
4 Should be ok. Are you putting Mountain Lion on it?
Old Dec 26, 2012 | 08:33 AM
  #1647
phee's Avatar
I got the Shifts
I had 6 in my 2007 MBP. i had the silver keys though, not the black keys. DO NOT PUT 4, IT WILL NOT BE ENOUGH IMO. Mine ran great with 6 for 3 years until i sold it.
Old Dec 26, 2012 | 10:52 AM
  #1648
Nope.
Yep, I have the silver keys. Maybe I'll get the extra 4GB so I have 6GB total now. Thanks
Old Dec 26, 2012 | 11:06 AM
  #1649
Whiskers's Avatar
Go Giants
Should be ok. There are a bunch of Memory Cleaners out there in the Mac App Store that tells you how much RAM you have free. On this MB Air, I only have 2GB on it and I still have free memory after running a bunch of stuff.
Old Dec 26, 2012 | 11:30 AM
  #1650
iStatPro says I have 396MB free. Both slots are being used, each with 1GB. I guess I would have to replace both with a 4GB and a 2GB.
Old Dec 26, 2012 | 12:44 PM
  #1651
#1 STUNNA's Avatar
Sanest Florida Man
IDK what model Mac you're talking about but if it's older and came with only 2GB of RAM it might not be able to handle more than 4GB, but definitely 8GB tops
Old Dec 26, 2012 | 01:51 PM
  #1652
I have this one:
It's the MacBook Pro 3.1 from 2007. 15" with 2.4GHz and 2GB Ram.
I'm tempted to keep it simple and just get the extra 2GB to get me through college then just get a whole new computer when I graduate.
Old Dec 26, 2012 | 02:02 PM
  #1653
jupitersolo's Avatar
nnInn
That's a 2.4GHz Core 2 Duo, max RAM 4GB
Old Dec 26, 2012 | 02:07 PM
  #1654
Acuraluvr's Avatar
Spinnin them beats
Had that exact computer. Just a question for you guys. I upgraded from 2gb - 4gb in 2009. My stock ram was 800mhz and the new was 667mhz. When I installed it, it really had NO difference in performance - sometimes I even though it was a bit slower. Could it be because of that? I noticed the bus speed was 800mhz max and I thought that was the reason...
Just wanted to clear that because the ram upgrade is also 667mhz ram.
Old Dec 26, 2012 | 02:13 PM
  #1655
You are correct! That's exactly what I have.
It either came with 2GB or 4GB RAM but I have the 2GB. A lot of my applications have begun run very slowly, especially iPhoto, which is why I'm contemplating upgrading the RAM.
Old Dec 26, 2012 | 03:12 PM
  #1656
Whiskers's Avatar
Go Giants
I spoke to Apple on a mac simular to that one and we pretty much agreed that more then 4GB would not do much and would be a waste. Personally I would not put any money into it.
Old Dec 26, 2012 | 03:45 PM
  #1657
Mizouse's Avatar
4gb of ram is so cheap thou. So why not?
Old Dec 26, 2012 | 04:08 PM
  #1658
Whiskers's Avatar
Go Giants
Because it wont make much of a difference in that Mac and its worth about $100 on ebay.
Old Dec 26, 2012 | 04:23 PM
  #1659
Mizouse's Avatar
Well what's the difference in price between 4 and 2gb? If its a few bucks then I don't see why not. Now if its like a $20+ or so. Then forget it.
Old Dec 26, 2012 | 04:52 PM
  #1660
Whiskers's Avatar
Go Giants
If he have it laying around, then fine.
Old Dec 26, 2012 | 08:48 PM
  #1661
The Dougler's Avatar
Unofficial Goat
putting in an ssd instead of ram will likely have a more significant performance impact. While it will cost more, you can yank it out when you upgrade and use as an external backup drive etc.
Old Dec 27, 2012 | 09:05 AM
  #1662
maharajamd's Avatar
SSD + 4GB memory should make that 2.4 ghz c2d mbp run just fine...
I'd throw $100 at it...
Old Dec 27, 2012 | 11:14 AM
  #1663
Mizouse's Avatar
Yea SSD FTW!
Old Dec 27, 2012 | 11:15 AM
  #1664
Mizouse's Avatar
I played with a Mac mini that's the same model as my moms but upgraded to an SSD, damn that thing screams.
Old Dec 27, 2012 | 11:34 AM
  #1665
Mizouse's Avatar
Although I recently upgraded my core 2 duo windoes pC from 4gb to 8gb. Now it doesn't slow down as much when running LR4 or photoshop CS4.
I may drop in a 120gb SSD for the OS drive, Should hold me off until I save enough coin for a r15"
Old Dec 27, 2012 | 12:09 PM
  #1666
Ken1997TL's Avatar
SSD's really remove the biggest bottleneck out there, data transfer speeds and seek times.
Old Dec 27, 2012 | 01:56 PM
  #1667
As much as I want a SSD, I plan on getting a new laptop when I graduate in a year, so I'm not trying to throw a lot of money at my current Mac. I'm just going to get the 4GB upgrade it (2GB x2) for $55 and call it a day. Thanks fellas!
Old Dec 27, 2012 | 01:59 PM
  #1668
Mizouse's Avatar
How much is that model mac used anyway?
Old Dec 27, 2012 | 02:01 PM
  #1669
Old Dec 29, 2012 | 08:03 AM
  #1670
1StGenCL's Avatar
958 & 991
I threw 8 in my 2008 MacBook aluminum and it is great (apple says only 6 but owc said 8 works and it wasn't much more). Planning on throwing in a small SSD along with the HHD for a bit more speed.
Old Jan 1, 2013 | 05:08 PM
  #1671
Whiskers's Avatar
Go Giants
Someone gave me a 2010 13 inch Macbook Air with a bad HD, bought one for $150 from OWC and on it now. Sweet, $150 Macbook Air....
Put Windows 8 on it with a 70GB bootcamp partition and this thing is awesome.
Old Jan 1, 2013 | 06:15 PM
  #1672
Mizouse's Avatar
messed around with my cousins 15" MBPw/RD last night...
must resist!
Old Jan 1, 2013 | 06:17 PM
  #1673
Whiskers's Avatar
Go Giants
must resist!
I miss mine.
Old Jan 1, 2013 | 06:18 PM
  #1674
Mizouse's Avatar
Old Jan 6, 2013 | 06:49 PM
  #1675
I decided to bite the bullet and order a new MBP today! It's a 2.9GHz 13" with the memory upgraded to a full terabyte (750GB to 1TB for $100). I looked at a SSD but the pricing couldn't be justified (128GB +$100, 256GB +$400, 512GB +$900).
With the student pricing and such along with the extended AppleCare warranty, I paid less than $1800 after tax. Veddy excite.
Old Jan 6, 2013 | 06:52 PM
  #1676
Mizouse's Avatar
I think you mean the hard drive space, not memory.
1TB of memory would be ridiculous!
Old Jan 6, 2013 | 06:53 PM
  #1677
Whoops
Old Jan 17, 2013 | 01:37 PM
  #1678
speedemon90's Avatar
I want this
or this
Old Jan 17, 2013 | 02:02 PM
  #1679
nnInn
Just get a Sharpie, and go to town.
Old Jan 17, 2013 | 02:20 PM
  #1680
I can do stick figures and houses... thats about it lol
