Android: Phone News and Discussion Thread
Old Feb 12, 2013 | 04:16 PM
  #7601
CGFebTSX04's Avatar
Just realized dash clock is only for 4.2 and my Verizon GNex isn't there yet.
Yep Verizon killed the Nexus program which is why they aren't getting any more Nexus devices in the near future. If I were you, I'd just install CM 10.1 on there. So many features that stock AOSP doesn't have like the custom Quick Tiles.
I also just found out that in CM 10.1, if you enable "Maximize Widgets" on the lockscreen, you can press and hold on the padlock and it'll unlock the phone. My mind has been blown. I was complaining about this feature needing two swipes to unlock and I just found out that you can press and hold to unlock with the Widget in its full feature. Its almost the same feeling I had when I realized you can uninstall apps from the Trebuchet launcher by simply holding the app icon over the "X" and it'll become an uninstall function. Prior to that I was going to the App info and uninstalling that way.
Old Feb 12, 2013 | 04:36 PM
  #7602
swoosh's Avatar
takin care of Business in
so the latest firmware I can put on my galaxy note i717 is the cm10 which is jb 4.1.2....
Old Feb 12, 2013 | 05:18 PM
  #7603
CGFebTSX04's Avatar
Really? I see 10.1 builds off CyanogenMod's site.
http://download.cyanogenmod.com/?dev...t&type=nightly
Looks like 10.1 Nightlies just began a few days ago. Might want to check that out. Not sure what's broken but it is a Nightly for a reason.
http://mobile.10.1.cmxlog.com/?device=quincyatt
Old Feb 12, 2013 | 08:45 PM
  #7604
speedemon90's Avatar
wondering.... should i go to CM and try it out....
I want it stable though. The touchwiz roms are super stable mainly cause they are more stock.
Old Feb 12, 2013 | 10:45 PM
  #7605
CGFebTSX04's Avatar
^Most, if not everything, will probably work fine. You'll probably see a hit in the battery though as I'm guessing they don't and probably never will get the proper RIL sources for non-Nexus devices.
Old Feb 12, 2013 | 10:53 PM
  #7606
CGFebTSX04's Avatar
I just found out that if you have an app that requires Accessibility settings, Hotword detection automatically becomes disabled. I have Voice Notify installed on my Nexus so it reads off my SMS and incoming notifications when I'm driving. Unfortunately, enabling it in the Accessibility settings as required, cancels out Hotword detection in Google Now. Seems to be a feature rather than a bug so its something to keep in mind if Google Now won't detect you saying "Google" to activate it in the future.
Here's Voice Notify by the way. Has a few settings and works pretty great. I have it set to work only when it detects a headset being plugged in. (Bluetooth and a headphone) Otherwise it doesn't read out the notifications to me:
https://play.google.com/store/apps/d...WNlbm90aWZ5Il0.
Old Feb 13, 2013 | 12:19 AM
  #7607
i still have yet to try out driving mode on the GS3, i dont need to enable the accessibility settings i think?? I just have that option in the pull down menu so i just need to click on it and it should read out incoming caller ID's and texts. I believe.
Old Feb 13, 2013 | 03:12 AM
  #7608
is300eater's Avatar
I Shoot with a Camera
Old Feb 13, 2013 | 09:55 AM
  #7609
swoosh's Avatar
da fuq...I tried looking but couldnt find it....
so to flash this will I have to delete everything on my phone and restore from a backup (Titanium backup) ? or can i flash it like a flash a nightly update?
Old Feb 13, 2013 | 10:38 AM
  #7610
CGFebTSX04's Avatar
Definitely do a full wipe. Also, don't forget to install GApps. Latest from Goo-IM is 12/12. Restore only the data for the regular apps in Titanium Backup. Some exceptions to this include the SMS/MMS data and a few others but try to avoid restoring system data to avoid any problems. If you get a Status 7 error when trying to flash CM10.1, it probably means you need to update your Recovery if you haven't done so in a while. TWRP is pretty lenient about this error more than CWM so if you want you can install TWRP before you try to flash. Also, backup everything you have and remove them from both the internal and external before you do any of the above just in case it does a full wipe beforehand.
Old Feb 13, 2013 | 10:45 AM
  #7611
swoosh's Avatar
^^^ hmm...weekend project?
damn last time i got lucky....none of my backups worked (MD5 checksum error)....I didnot rename any folder/etc...placed it back to exactly where I took it from.....lucky enough I had it on my phone's internal memory....not sure if i wanna do that again LOL....
Old Feb 13, 2013 | 11:32 AM
  #7612
if that was a response to me... I only text when at red lights or stopped for other reason
Old Feb 13, 2013 | 12:12 PM
  #7613
CGFebTSX04's Avatar
You just have to recreate the MD5. Your backups are stilll good to use. You will need to open up terminal on your phone and follow the instructions below:
http://forum.xda-developers.com/showthread.php?t=714114
If you have ADB installed on your computer, you can also do it on your computer opening a command prompt and following the same steps. You're basically deleting the corrupted MD5 and then recreating a new one. Very quick and easy. Sometimes Nandroid doesn't create a proper MD5 but your data should still be intact any way.
Old Feb 13, 2013 | 12:20 PM
  #7614
CGFebTSX04's Avatar
Dash Clock Widget got updated. Fixes the complaints I had with it. The unread SMS message, change how far ahead in the calendar to look for events (wish we could choose which calendars to populate like in Chronos though) and he put back the lockscreen Bold Hour : Regular Minutes layout which I've become accustomed to since 4.2. A few other fixes on there as well. I can see this becoming the default lockscreen for Key Lime Pie. Looks and works great and very functional too.
Old Feb 13, 2013 | 01:20 PM
  #7615
stogie1020's Avatar
Needs more Lemon Pledge
upgraded the dashclock widget on the kindle running 4.2
Love it. Thanks TSXy
Old Feb 13, 2013 | 01:39 PM
  #7616
swoosh's Avatar
I recognize those unix command
Thank you sir....i might try this tonight
Old Feb 13, 2013 | 01:52 PM
  #7617
CGFebTSX04's Avatar
Google Now just got updated! Its a bit fancier especially with the Places card. Widget and Lockscreen widget included as well. Added Real Estate value if looking for a house and Movie passes as well it seems.
Old Feb 13, 2013 | 02:51 PM
  #7618
TSXy Luster's Avatar
Goodbye.
Anyone actually gotten their Google Now to show the movies card at all?
I've ticked and unticked the "show on movie days/days when you search for movies", and still I've never seen a movie card ever. And this is with me searching for new movies every week. I love the new Rotten Tomatoes ratings being included in the card......would just be nice if I could actually get the card to show up.
Old Feb 13, 2013 | 03:00 PM
  #7619
Old Feb 13, 2013 | 03:01 PM
  #7620
I've gotten the card before...after i went to watch a movie haha
and it came sometime after that
i dunno if searching does it. I think it figures movie days when you actually go to the theater
Old Feb 13, 2013 | 03:39 PM
  #7621
CCColtsicehockey's Avatar
So are you saying it is official that the Verizon GNex is not getting anymore updates then?
Old Feb 13, 2013 | 03:41 PM
  #7622
CGFebTSX04's Avatar
It showed up before for me when I was looking up The Hobbit times. I'm not sure how it works but it may have something to do with your location, day of the week you normally watch a movie and movie you're looking for. I was next to the mall on a weekend as I was trying to see movie times and reviews and it popped up then along with info for other movies that were out.
Old Feb 13, 2013 | 03:46 PM
  #7623
CGFebTSX04's Avatar
It may get an update but most likely not. The Nexus has been removed from Verizon's system for a few months now and when Verizon does that it usually means no more support. (BTW if you have a Verizon store near you, they're supposedly selling the Nexus accessories for cheap. This includes the docks and cases.) One of the Android blogs wrote up an article the other day saying that the Verizon Nexus is already 4 updates behind. The Sprint Nexus got an update recently to 4.1.2 I believe but that's one more than the Verizon version. With that said, it is a Nexus phone and its very easy to update it yourself if you really want to. I'm guessing at the minimum, it'll get security updates from this point on.
Old Feb 13, 2013 | 09:16 PM
  #7624
something in google now that got updated is also the flights card. In settings you can now select how early you want to arrive at the airport for departures.
Old Feb 14, 2013 | 03:58 AM
  #7625
Google's harlem shake
Old Feb 14, 2013 | 10:24 AM
  #7626
CGFebTSX04's Avatar
^ Crazy Googlers. Sometimes I wonder how they get work done over there.
Anyone see that Google Now has today's Google Doodle? I wonder how often they're going to take over that banner. Maybe they'll make it interactive in the future too. It beats the generic looking banners they have here for LA. I wonder why they don't have any special ones for us. When I was in Vegas, they had some cool banners that changed depending on the type of day. Also, as a side note, it was great that Google Maps had indoor maps of the hotels. Really useful feature.
Old Feb 14, 2013 | 11:05 AM
  #7627
swoosh's Avatar
they do work at google? hmm
Old Feb 14, 2013 | 12:35 PM
  #7628
they probably work crazy hours there to get things done, hey they have free dinner soo yea haha
Old Feb 14, 2013 | 12:43 PM
  #7629
swoosh's Avatar
^^^ yeah I have been to the google campus....freaking nice !!!
free lunch/dinner/coffee....they have like a spa area/gym/rest area....people just take an hour or 2 nap in the afternoon....its insane !!!
Old Feb 14, 2013 | 12:48 PM
  #7630
why did i become a bme lol
I wanna be able to nap in the afternoon!!!
Why were you there??
Old Feb 14, 2013 | 01:09 PM
  #7631
mdkxtreme's Avatar
The reason why Google have recreation rooms and cafeteria like that is to maximize the staying time of the employees at the work place. When you have amenities like that, it's hard to be anywhere but work!
Old Feb 14, 2013 | 01:12 PM
  #7632
swoosh's Avatar
was visiting a family friend who works there and asked him to show me around....
wish I would have applied for a job there when he was there
Old Feb 14, 2013 | 08:51 PM
  #7633
CGFebTSX04's Avatar
So there will be an Xperia Z version with AT&T LTE bands after all...
http://playstation.com/psm/certified.html
Xperia Z C6602/C6603/C6606/SO-02E
The C6606 will have compatible LTE bands for AT&T, T-Mobile, Rogers and Wind. The C6602 is what Handtec, Clove and all the other international stores are selling right now and that one doesn't have the right LTE bands. No announcement has been made as to when the C6606 version will be available yet.
http://forum.xda-developers.com/show....php?t=2130466
Originally Posted by AwesomeAHlee
hey guys i think i found website which suggests that there will be an xperia z with AT&T compatible LTE and 3g bands (C6606) i compared this to c6506
Originally Posted by Spectre51
Its true. Looking forward to this model. And the ZL C6506
Sent from my Sony Xperia™ TL
None of the carriers will be picking up though so it won't be available on contract and it won't be subsidized. Sony will probably sell it upfront at their stores for full price.
Old Feb 14, 2013 | 10:08 PM
  #7634
Goodbye.
Actually, LA does have it's own banner. It's got the Hollywood sign and lights and jazz. Might just be restricted to certain areas near Hollywood though. Not sure.
In other news, ORBs will be in my hands tomorrow Can't wait!
Old Feb 14, 2013 | 10:20 PM
  #7635
jangkai's Avatar
Full retail price for the Xperia Z? I'm guessing $800. Only if it came in a Nexus version For me, that Z is the best looking phone to date.
Old Feb 14, 2013 | 10:57 PM
  #7636
CGFebTSX04's Avatar
Really? Wth. I was at my girlfriend's place over the weekend and I had the generic one. She lives in K-Town so she's not that far from Hollywood which is like 15 mins away. Maybe they just started rolling it out. I'll have to check it out this weekend again. Lol.
Right now the C6602 version is going for around $650 shipped at Handtec plus conversion fees. (Can be waived if you use a Capital One credit card) I'm guessing if Sony does sell it, it'll be around 700-800. They're only coming out with a 16GB version and you can expand on it with a MicroSD Card up to 64 GB. The plus side of it being sold by Sony would be that there would be no carrier bloatware and the bootloader would be easily unlockable. Sony has already released all the source code and everything needed to build a custom ROM before the phone has been officially released which is great news for devs.
Old Feb 14, 2013 | 11:53 PM
  #7637
mdkxtreme's Avatar
I have a question about the Nexus Orb charger. Does the Orb stop sucking power if the phone isn't on it?
Old Feb 15, 2013 | 01:52 AM
  #7638
CGFebTSX04's Avatar
If I had to guess, it probably acts like a regular adapter. Adapters don't push current, your phone pulls current from it which is why it doesn't matter how many amps the adapter is capable of transmitting. So if nothing is on the charger there isn't anything there to pull any current from the adapter.
Old Feb 15, 2013 | 10:40 AM
  #7639
every change you didnt know about 4.2.2
nothing big btw.... small minor details/touchups done to the OS
http://www.androidpolice.com/2013/02...home-sighting/
Old Feb 15, 2013 | 12:14 PM
  #7640
CGFebTSX04's Avatar
Now this is cool! Sony Xperia Z in a pool:
Every time I see a video or article about this phone it has me flip flopping on whether I want it or not. The video quality is pretty good too. This could be so useful when snorkeling or the like although I wonder how it would fare in the salty ocean vs. a chlorinated pool.
