Acura TLX Type S Reviews/Discussion
Old 06-18-2021, 08:38 AM
  #401
AZ Community Team
Tony Pac's Avatar
Received 1,598 Likes on 961 Posts
Originally Posted by F23A4
Agreed. Though I'm running the risk of further belaboring non-TLX-S discussion in a TLX-S thread, I will state that there were more than a few 'missed opportunities' when it came to the 21 TLX ...particularly where it comes to the A-Spec model, where features like more aggressive rubber and active dampers could have used to at least extend the model's handling prowess. And I still say they could have tweaked horsepower to 280-290 for the A-Spec as well; wouldn't have presented a major performance increase but it would at least be a little something above the regular model but well under the Type S.
💯! Acura should make A-spec a little more sportier and boost some
more HP. As you said, 285-295.
Old 06-18-2021, 08:40 AM
  #402
Some Guy Who Loves Cars
someguy11's Avatar
Totally agree with you both on giving the Aspec a more special or serious performance take (rather than only it's dashingly good looks, which it really is) - and also how I attempted to tie my point on an otherwise off topic SH-AWD discussion back to staying somewhat on Type S.
Old 06-18-2021, 08:54 AM
  #403
BEAR-AvHistory's Avatar
Received 2,599 Likes on 1,581 Posts
Originally Posted by someguy11
I just read a C&D article that says the 2021 Accord Sport 2.0T (0.89G) beat the 2021 TLX SH-AWD (0.87G) on the skidpad. I really can't understate how embarrassing that is - however you spin it, likely to blame the tires, which completely neutralize an otherwise undeniable systemic advantage. So much for all this "superior handling on rails in dry pavement" chatter. So we pay $2,000 extra to compensate for bad tires?
As someone without a vested interest in the Type S, I would at least expect it (with SH-AWD and decent OEM tires) to hang with some pretty stiff competition, including as one example, the Civic Type R (0.99G). Different classes? Sure. Both performance oriented though and one gets the benefit of SH-AWD.
Move along, nothing new to see here. Changed the "summer Performance" tires on my 2006 TL 6MT for tires that actually were summer performance tires after the break-in mileage, Seems like transmissions, tires are another thing Acura has difficulty getting right but its stable mate & master does.
FWIW the Type R is one of the best handling cars made today that is not a track day special. It does get a break by being a smaller lighter car, Weight is not your frie on a skidpad.
My Z4 (3535lbs) RWD which runs a version of the M340 suspension with bigger tires 225/255 - 255/285 did1.02 while the bigger heavier M340 (3913lbs) RWD does 0.96. The TLX-S needs to score in the mid/upper 0.90's to be effective against the cars that Acura marketing says it will compete with. S4 0.95, M340 0.96, C43AMG 93.
Old 06-18-2021, 04:19 PM
  #404
leomio2.0's Avatar
A bit off topic, but I wonder how soon I'll see some a-hole in a Type-S with optional wheels with summer tires get stuck in the snow because they're too ignorant to realize that AWD doesn't overcome summer compound in snow.
I still remember 6 or so years ago when there was a pretty big snow storm forecast. Passed by some jabroni in a Carrera 4S stuck on the interstate that couldn't make it up a gradual incline. Wide, max summer tires in the snow? I don't even know why you would take that car out when there's snow forecast ... but especially with (what I assume) were factory tires.
BOWA41 (06-18-2021)
Old 06-18-2021, 05:04 PM
  #405
Camaro194's Avatar
Looks like the Type S has some form of launch control. 2100 rpm isn't that high, but it's something I guess.
https://www.reddit.com/r/Acura/comme...m_source=share
BOWA41 (06-18-2021)
Old 06-18-2021, 05:55 PM
  #406
fiatlux's Avatar
Received 3,429 Likes on 1,879 Posts
2100 is awfully low for an AWD car, especially a turbocharged one. This sure doesn’t dispel the notion that the driveline is not beefy enough. Godspeed to anyone planning to tune this for more power…
F23A4 (06-19-2021)
Old 06-18-2021, 06:34 PM
  #407
6G TLX-S
Edward'TLS's Avatar
Received 1,146 Likes on 818 Posts
For most force-induction engines, 90% of peak torque can be generated at as low as 1500 rpm, not like naturally-aspirated engines with peak torque near the rpm redline.
So 2100 rpm launch is plausible as long as there is minimal turbo lag.
Old 06-18-2021, 07:19 PM
  #408
fiatlux's Avatar
I’m not sure I buy that reasoning. The M340i makes peak torque starting at 1550RPM yet it launches at 3000RPMs. The S4 makes peak torque even lower at 1300RPMs yet it also launches at 3000RPMs
Old 06-18-2021, 10:32 PM
  #409
DubPK's Avatar
This is above me as I've never had a car with launch control or read much about it but if peak torque starts at 1550RPM and it launches at 2100RPM and builds boost there what would be the advantage of another 1000RPM? If 2100RPM is the same as 3000RPM as far as torque is concerned would it make a tangible difference?
Old 06-18-2021, 10:46 PM
  #410
fiatlux's Avatar
Even though torque is the same, the horsepower generated is not. Horsepower is a function of RPM and torque, and is what ultimately matters. The higher the revs, the more power you're actually generating per unit time.
Old 06-18-2021, 11:56 PM
  #411
DubPK's Avatar
Good point, didn't think that through enough. I'm known to be an idiot from time to time.
Old 06-19-2021, 12:10 AM
  #412
6G TLX-S
Edward'TLS's Avatar
I'm always confused about torque and horsepower.
It is torque that accelerates the car, and horsepower gives the car the top speed.
For cars with high-tech small displacement engines that generate very little low-end torque, but massive hp towards the redline, they need to be launched at as high a rpm as possible for maximum torque output . However, for cars with large displacement engines (even the old low-tech push-rod V8 muscle engines) or force-induction engines that generate tons of low end torque, there is no need to launch at as high rpm since maximum torque is readily available starting at merely 1,500 rpm.
Old 06-19-2021, 12:28 AM
  #413
DubPK's Avatar
I'm not an expert but I think it's that torque at the wheels is different than just torque output from the engine and torque at the wheels is a combination of the two. I could be wrong but my mind always by default goes to torque = acceleration hp = top end speed as well even though it's probably not 100% accurate.
Old 06-19-2021, 12:30 AM
  #414
djhtsx's Avatar
Old 06-19-2021, 01:09 AM
  #415
DubPK's Avatar
Man.. the shit dealers will say, did he really suggest that the point of the button shift selector is to not grind gears? As if the standard drive selector isn't electric like the push button ones these days lol..
loki (06-22-2021)
Old 06-19-2021, 02:00 AM
  #416
One more step. Gearing determines the final torque number at the wheels. That is why Dyno runs are made in the 1:1 ratio gear.
Torque at the wheels
Should you ever get a chance to drive a Turbo with a manual (pretty rare now) try releasing at 1200,1500, 2000 3000 for a practical demo. You can do the same with an AT but the torque converter adds another layer to the math. With BMW LC (3000) my car will not hold traction on 285X35X19 Michlen PSS summer tires & does a nice set of 11's with expensive rubber. Plan is forget the LC & power brake at 2000.
DubPK (06-21-2021)
Old 06-19-2021, 07:30 AM
  #417
ELIN's Avatar
Received 1,246 Likes on 904 Posts
Originally Posted by djhtsx
The dealer stayed really silent when the test driver commented on how he hates how other manufacturers pipe in engine sound via the speakers. LOL!
The following 3 users liked this post by ELIN:
BOWA41 (06-19-2021), JDM_DOHC_SiR (06-19-2021), loki (06-22-2021)
Old 06-19-2021, 04:03 PM
  #418
TSteezyX's Avatar
Does anyone know when these cars are finally going to start showing up at dealerships?
Old 06-20-2021, 12:43 AM
  #419
Beaverking's Avatar
i swear to god, never. These demos will sit and then each dealer will get 2 cars for the next 6 months it feels like.
Old 06-20-2021, 04:57 PM
  #420
mec30's Avatar
Are the media test cars going out too? Where are all the reviews?
Old 06-20-2021, 10:38 PM
  #421
3rd Gear
massappeals's Avatar
Dealers just started getting the Type S Demos two days ago. chill.
Old 06-21-2021, 06:07 AM
  #422
F23A4's Avatar
Received 1,666 Likes on 930 Posts
We may see an instrumented test by Car and Driver this week but, I’d rather see a segment comparo.
The following 4 users liked this post by F23A4:
BEAR-AvHistory (06-21-2021), bilirubin (06-21-2021), BOWA41 (06-21-2021), Legend2TL (06-22-2021)
Old 06-21-2021, 03:45 PM
  #423
mec30's Avatar
I don't even know what point you're trying to make. Typically the review comes out right as the cars hit dealers. Just look at the 2022 Civic. Hit dealers last week. Same time as all the major reviews came out.
Old 06-21-2021, 08:20 PM
  #424
djhtsx's Avatar
wow they type S sounds so amazing.
The following 3 users liked this post by djhtsx:
a35tl (06-21-2021), bilirubin (06-22-2021), Tony Pac (06-21-2021)
Old 06-21-2021, 08:32 PM
  #425
Camaro194's Avatar
https://youtu.be/6KPQY0BtP4o
Dude talking is annoying, but the car sounds good!
The following 3 users liked this post by Camaro194:
bilirubin (06-22-2021), BOWA41 (06-21-2021), djhtsx (06-21-2021)
Old 06-21-2021, 10:02 PM
  #426
Car Crazy for Sure!
Colorado Guy AF Ret.'s Avatar
Acura is making 2,000 '21's. So, inventory will be low for most dealers. The 2022 can be ordered around the Sept/Oct. time frame and build date of Nov.
So, IF I like the Type S...after testing the '21 "show and tell unit" that will arrive within a week....I will place an order on the first batch so I can take delivery
before end of year. Many at my dealer..buyers....have decided to do the same. MORE inventory will be avail...or "allocations." Depending on the dealer
and their past record of sales, etc.
Old 06-21-2021, 11:07 PM
  #427
AZ Community Team
Tony Pac's Avatar
That sound!!!! Well done Acura!
Old 06-22-2021, 12:11 AM
  #428
6G TLX-S
Edward'TLS's Avatar
The transmission match-rev downshift sounds sounded exceptionally good. They sounded like a Touring Cup race car match-rev downshifts a couple gears preparing to attack a tight corner.
Old 06-22-2021, 01:13 AM
  #429
djhtsx's Avatar
Also I’m sure you guys noticed but there are 4 people in this vehicle and they appear to fit comfortably. 🙃
Old 06-22-2021, 08:02 AM
  #430
dmski's Avatar
How dare you!!!! Here come the trolls with spreadsheets now how Germans are better....
The following 2 users liked this post by dmski:
djhtsx (06-22-2021), dopeboy1 (06-22-2021)
Old 06-22-2021, 09:04 AM
  #431
AZ Community Team
Legend2TL's Avatar
Received 4,172 Likes on 2,590 Posts
Close, but not quite right. The higher the rev's the more work you're generating per unit time (assuming torque is constant). Power is work per unit time, in W or HP.
FWIW, Jason does one of the best explanations of torque and power (HP or W). Ultimately it's power that is acceleration contributing factor.
Edward'TLS (06-22-2021)
Old 06-22-2021, 12:04 PM
  #432
WTF.Acura's Avatar
The following 7 users liked this post by WTF.Acura:
BOWA41 (06-22-2021), Camaro194 (06-22-2021), F23A4 (06-22-2021), JDM_DOHC_SiR (06-22-2021), Legend2TL (06-22-2021), Pens Fan (06-22-2021), Tony Pac (06-22-2021) and 2 others liked this post. (Show less...)
Old 06-22-2021, 01:52 PM
  #433
AZ Community Team
Legend2TL's Avatar
Looks like molybdenum coated piston side skirts. SJ had some engine pics as well, the amount of ancillary plumping on top of the motor looks similar to German engines.
The block looks similar to a J-series with open deck Siamese cylinders, curious if it's a derivative block in the J-series.
Old 06-22-2021, 02:48 PM
  #434
Though the trolls were about the Accord & Civic being better for 4 adults?
Old 06-22-2021, 03:10 PM
  #435
Kense's Avatar
Comments under that drive video say dealers are already asking for 5-6000 dollars over MSRP wtf LOL good luck
Old 06-22-2021, 03:45 PM
  #436
loki's Avatar
Originally Posted by WTF.Acura
+ VCM
- VTEC
= Pass
Old 06-22-2021, 05:44 PM
  #437
DubPK's Avatar
Originally Posted by SRB-TL
+ VCM
- VTEC
= Pass
Curious why these upset you. One we've had in the J35 since the early 2000's and the 3.0T has VVT which is most of what VTEC is. Don't want to get to technical about it just curious why if you otherwise liked the numbers that lack of VTEC and just standard VVT is a deal breaker.
WTF.Acura (06-22-2021)
Old 06-22-2021, 09:04 PM
  #438
djhtsx's Avatar
CF spoiler
The following 6 users liked this post by djhtsx:
a35tl (06-22-2021), BOWA41 (06-23-2021), Colorado Guy AF Ret. (06-23-2021), F23A4 (06-23-2021), Tony Pac (06-23-2021), WTF.Acura (06-22-2021) and 1 others liked this post. (Show less...)
Old 06-23-2021, 07:56 AM
  #439
AZ Community Team
Tony Pac's Avatar
Clearly this shows that Honda and Acura have done their home work. And as I always say, this is just the beginning. We all know that Acura fell behind after the GFC. But now they are on the right track. The RDX is on its 3rd year with zero updates and pushing 50,000+ units per year, even the 3rd Gen MDX was a top seller in its segment after 6-7 years. Now, we have the new TLX, MDX and the TYPE S. Acura will definitely give to their customers that premium vehicle with reliability and decent price.
Waiting for the the ILX replacement and RDX MMC. This year will be a transitioning year for Acura brand. The year 2022 will be interesting to see
The following 2 users liked this post by Tony Pac:
jjsC5 (06-23-2021), WTF.Acura (06-23-2021)
Old 06-23-2021, 02:45 PM
  #440
jjsC5's Avatar
I agree. I think the new MDX is probably Acura’s best work. It has both luxury and sport covered in an affordable segment. I wanted to get my wife the outgoing generation, but she thought it looked too much like a mom-mobile. She loves her GX460, which to me was outdated when Bush was still President (either of them). But I got her what SHE wanted for a change. I’ll be curious how she responds to the new MDX.
Quick Reply: Acura TLX Type S Reviews/Discussion
