Cameras & Photography Because there aren't already enough ways to share photos...
C&P Random Thread -
Old Aug 20, 2012 | 02:05 PM
  #4841
asianspec's Avatar
Actually, IMO you can get by w/o one for the mean time... I mean, you just adjust accordingly after the first shot, and even further make any more adjustments in PP if necessary
Probably so. I want to be very tiedous about making all my adjustments on-camera than in post processing. If i can have that mindset then it's lesser work I need to do in post production and I can put the extra time on other stuff
Old Aug 20, 2012 | 02:16 PM
  #4842
is300eater's Avatar
I Shoot with a Camera
see for me... a decent light meter is about $300... If I can put that towards something else, I'll just deal with adjusting exposure accordingly, I'd rather do that (for now). I mean... seriously... it takes just a few seconds to adjust and take another photo. I always start with ISO100, F4, and "guesstimate" on the power (of the monolight or flashgun). Plus IMO that's how you'll learn to "eyeball" the condition...
I mean... I can see if you're booked back to back with gigs and time is THAT important to you... but why buy a meter first when you don't even have strobes to use it with yet?
Old Aug 20, 2012 | 02:19 PM
  #4843
asianspec's Avatar
True, I guess I'm kinda worried I don't get the proper exposure in my shots. What may look proper to me, might be way off
Old Aug 20, 2012 | 02:22 PM
  #4844
is300eater's Avatar
practice? You don't need a person or model to practice on... just photograph random things around your room... hell, use a blow up doll if you have to
Old Aug 20, 2012 | 03:51 PM
  #4845
JLatimer's Avatar
Creepy guy in the mirror.
Originally Posted by einsatz
Seriously? A lens being unable to focus for half of its effective zoom range is "normal"? Fuck that shit. So now I'm fighting with them to give me a refund since I paid for 22 days of rental and I had it for less than 22 hours.
There is a reason for this. I cant find a reference immediately but it has to do with types of AF sensors (cross-type vs vertical line) and their sensitivity rating. I read once that Canon only promises that AF will work at f5.6 or less. Not sure if you tried this but if you set your AF to use only the center AF point and found a suitable high contrast focusing image it probably would have worked.
http://www.the-digital-picture.com/P...Explained.aspx
Old Aug 20, 2012 | 04:01 PM
  #4846
JLatimer's Avatar
Probably before all this I should get a light meter.
I have a light meter, it gets some use but not a lot. I use it when using my vintage cameras - it takes out the guess work. I also use it when I setup a 'photobooth' for wedding receptions.
I don't use it for 'normal' shooting.
Where is shines is the photobooth stuff. I set the strobes and backdrop up and then take a few lighting samples with the meter and make manual exposure adjustments until I have what I want - I dont use auto exposure at all. Where it becomes an advantage is it doesn't matter what the subject is wearing and I have the right exposure every time. In a photobooth I am shooting a hundred different people wearing black, white, and every other color and shade. Because the light is right I don't have to worry about the in camera light meter metering a white dress as 20% grey and throwing off the exposure.
Note though that a grey card can be used with the in camera meter to setup and then going from there but the convenience of a meter is much easier.
Bottom line though is with digital and the ability to use trial and error for the setup you can get by without a meter and spend the money on glass.
Old Aug 20, 2012 | 05:44 PM
  #4847
einsatz's Avatar
I miss my 03 CL-S :(
I did - switching to center AF is probably the first thing that came to mind since it can't get simpler than that for the AF system.
I went to Penn Camera on Friday evening to get another CF card... When I told the guy behind the counter what lensrentals said, his reponse was "baloney, we've sold tons of them and never had that problem".
They promised a CC refund which may take a few weeks to show up.
Old Aug 22, 2012 | 08:11 PM
  #4848
is300eater's Avatar
this is what they mean when they say you get a shallower DoF on FF
so, I was just messing around today and decided to do some comparison shots between:
200mm f2.8 @f2.8 on a Full Frame vs 135mm f1.8 @f1.8 on a APS-C
Can you guys tell which one is which (w/o cheating?)
Old Aug 22, 2012 | 08:19 PM
  #4849
Sarlacc's Avatar
The Third Ball
Bottom one is the 200mm @ 2.8.
were the ISOs the same???
Old Aug 22, 2012 | 08:22 PM
  #4850
Sarlacc's Avatar
The Third Ball
They couldnt be, because than the 135 would be a stop and 1/3 over exposed...meaning you had to go to a faster ISO....which would decrease your DoF....making your comparison "test" void.
You need to do it with both at a 2.8 at the same iso.
  #4851
is300eater's Avatar
no, on one camera it was ISO100 and the other was ISO200
Old Aug 22, 2012 | 08:53 PM
  #4852
Sarlacc's Avatar
The Third Ball
Well, thats a stop difference... I actually reverse my answer based on that.
The bottom picture looks abut a 1/3 more brighter...so that the 135mm.
A stop and 1/3 aperture more open, plus the ISO change = less dof.
Old Aug 22, 2012 | 09:03 PM
  #4853
Sarlacc's Avatar
The Third Ball
Of course the other side to the problem is no two digital cameras treat ISO the same way.
Example...iso 3200 on the Nikon D800 is vastly different than the same iso on the 5d III.
Shoot the test on your FF camera, and switch it to crop mode. Use the same lens. Best way to do this.
Old Aug 22, 2012 | 09:10 PM
  #4854
Mizouse's Avatar
changing ISO would change DOF?
new to me. good to know.
Old Aug 22, 2012 | 09:13 PM
  #4855
Sarlacc's Avatar
The Third Ball
ummm yes.
Going from a iso200 to iso100 means you have to open 1 stop to compensate, which = less dof.
Same thing as using ND filters to help shallow your dof.
Old Aug 22, 2012 | 09:17 PM
  #4856
Mizouse's Avatar
ohh thats what you meant.
i dont know what i was thinking there.
Old Aug 23, 2012 | 12:10 AM
  #4857
asianspec's Avatar
http://www.youtube.com/watch?v=uIRBx...ature=youtu.be
Old Aug 23, 2012 | 12:32 AM
  #4858
Mizouse's Avatar
in the iphone thread
Old Aug 23, 2012 | 02:14 AM
  #4859
asianspec's Avatar
but im not on the iphone thread
Old Aug 23, 2012 | 09:24 AM
  #4860
Mizouse's Avatar
Old Aug 23, 2012 | 09:01 PM
  #4861
Mizouse's Avatar
Srika, new faster FB app is out.
Old Aug 23, 2012 | 09:02 PM
  #4862
srika's Avatar
Moderator Alumnus
got it earlier........ it is SWEET!!!!!!!!!!!!!!!
Old Aug 23, 2012 | 09:05 PM
  #4863
srika's Avatar
Moderator Alumnus
nice iphone 5 video............ LOL!!!!!!!!
Old Aug 26, 2012 | 04:26 AM
  #4864
srika's Avatar
Moderator Alumnus
<iframe width="560" height="315" src="http://www.youtube.com/embed/0YnhJk4hoq8" frameborder="0" allowfullscreen></iframe>
Old Aug 26, 2012 | 06:25 AM
  #4865
MWalsh9152's Avatar
all work and no play
I'm surprised that Henry didnt include a Sony in that test
Old Aug 26, 2012 | 10:58 AM
  #4866
is300eater's Avatar
Sony's new FF comes out later this year.
Old Aug 26, 2012 | 01:22 PM
  #4867
Mizouse's Avatar
they got rid of the blue LCD backlight
now its the same color as the lower level models
Old Aug 27, 2012 | 09:59 PM
  #4868
srika's Avatar
Moderator Alumnus
I'm finding some good deals (I think) on 1Ds Mark III's. Does anyone have anything to say about buying one now?
Old Aug 28, 2012 | 01:12 AM
  #4869
Mizouse's Avatar
What's the price on them?
Old Aug 28, 2012 | 01:16 AM
  #4870
srika's Avatar
Moderator Alumnus
well I decided against it. I decided I want current generation NR and DR performance.
2500-3000
Old Aug 28, 2012 | 01:26 AM
  #4871
Mizouse's Avatar
At that price I'd spend a little more coin on a mkIII
Old Aug 28, 2012 | 01:30 AM
  #4872
Mizouse's Avatar
http://www.dxomark.com/index.php/en....(brand3)/Canon
Old Aug 28, 2012 | 01:45 AM
  #4873
Mizouse's Avatar
i wonder how much a 1D mark IIN, 24-70, 70-200 2.8 and 580ex II would each sell for
Old Aug 28, 2012 | 05:44 AM
  #4874
asianspec's Avatar
probably around 3500 or so
Old Aug 28, 2012 | 11:37 AM
  #4875
srika's Avatar
Moderator Alumnus
Thanks man. I think that's what exactly I need. Pair it up with a avengers lightstand and maybe umbrella reflector or westcott apollo soft box and I'll be good
what about the 1-3 second recycle time? is that "OK"? asking generally, to anyone who has any comment on it
Re: http://www.calumetphoto.com/eng/prod...system/cf0506k
Old Aug 28, 2012 | 11:40 AM
  #4876
srika's Avatar
Moderator Alumnus
thanks - what is this Dynamic Range about... those numbers look jacked.......
Old Aug 28, 2012 | 11:43 AM
  #4877
srika's Avatar
Moderator Alumnus
uhhhh................. this sucks
http://www.dxomark.com/index.php/Cam...rand3%29/Canon
Old Aug 28, 2012 | 11:56 AM
  #4878
Sarlacc's Avatar
The Third Ball
My camera rules!!!!!
Old Aug 28, 2012 | 11:57 AM
  #4879
jupitersolo's Avatar
nnInn
Originally Posted by srika
Then you're going to hate this one as well.
http://www.dxomark.com/index.php/Cam...(brand3)/Nikon
Old Aug 28, 2012 | 12:02 PM
  #4880
Sarlacc's Avatar
The Third Ball
Now thats just harsh!
