Turbo Kit for Acura TL '04-'08
Old 09-26-2009, 11:20 AM
  #2121
BANNED
NVA-AV6's Avatar
Originally Posted by I hate cars
I think that was you. Look at this...
http://www.bobistheoilguy.com/forums...gonew=1#UNREAD
I think everyone missed the last line in the quote. It's a tough crowd over there and they think 0w-20 is the best thing to ever come out so if you say anything negative, be prepared as I have.
It would be interesting to hear your teardown results. In fact, I'm very interested in what you've found on stock J32s on a 20wt. I've had mine on a 30wt since it's first oil change. I've never torn into one so real world experience would be a nice change from all the theories over there.
Well when I posted that on the other forum I was real clear that these were my observations, not that these were "Lab Ceritfied Results" or anything of the type.
Old 09-26-2009, 02:16 PM
  #2122
I hate cars's Avatar
Received 1,812 Likes on 1,283 Posts
I'm agreeing with you. I've had similar results in the GN and they blasted me for that. Mine were with 20w-50 vs a 10w-30 but same concept.
My biggest problem is I believe the 20wts were made only for fuel economy at the expense of engine wear.
Old 09-26-2009, 02:42 PM
  #2123
Originally Posted by Silva-type-s
^ they should change your user name to "knowledge". You have consistently proven that your user name is the real definition of sarcasm or irony.
Ive been helping my uncle built his car part time for some time now and almost every point you make is like another chapter in "engines for dummy's". I though i knew my stuff but obviously its not enough.
Thanks! Like I said, I only know it because I've screwed so much stuff up. I've put the top rings on upside down and ruined the new block, pistons, and rings. I've blown the crankshaft and torque convertor out of the engine and trans and popped a rear tire when I ran over the pieces. That was expensive, new engine, convertor, and trans and tire. I learned the value of a good tune at that point. I degreed the cam wrong (a pushrod engine is as easy as it gets) because I had a hangover and bent all the intake valves on my new engine.
Old 09-26-2009, 03:38 PM
  #2124
BANNED
NVA-AV6's Avatar
^LOL, done my share of that stuff too, doesn't it make you want to kick yourself when you screw up and flush a couple hundred or thousand worth of parts, not to mention the time.....
Old 09-26-2009, 07:03 PM
  #2125
Opel's Avatar
thats not a problem at all...no matter what the 20 wts were made for...at least the simple fact of manufacturers recommending that for their engines, Honda being one of them, it is the core reason why they do that to begin with.
wear wont show during testing, and even for a while down the line, enough time after cars are outta warranty.
its all about the CAFE, and you know that
Old 09-27-2009, 08:20 PM
  #2126
18psi
libert69's Avatar
can anyone tell me a good shop that they would recomend for installing this kit? im located in nassau county new york
thanks
Old 09-27-2009, 08:35 PM
  #2127
I agree. The cars will make it out of the warranty period easily with a 20wt. If the car is used for short trips or in a cold climate and driven like a grandpa car, the 20wt can even be an advantage. But in a normal climate with the way most of us drive, it's a bad thing. After hearing about the hot idle oil pressure with a 20wt, I know I made the right choice with a high quality ester based 30wt. Seeing how the supercharged TLs hit 240 degree oil temps pretty easily, that effectively thins the 30wt to the viscosity of a 20wt at the normal 200 degree temps.
One thing is for sure, when the turbo goes on, mine will either stay with the Redline 10w-30 since it protects and has a HTHS like most 40wts or do a 10w-40 in the summer and 10w-30 in the winter. The J32 and most Honda engines were spec'd for a 30 and 40wt in other countries anyway.
Old 09-28-2009, 09:08 AM
  #2128
pass427's Avatar
thanks
John is located in nj I can have him do installation for u or even a& g auto in Irvington Newark nj area .. And I'm sure there are shops in by also I just gave you those two name because there afffiliated with jandr...pm me if u need more info
Old 09-28-2009, 09:58 AM
  #2129
pass427's Avatar
I'll post Dyno sheets up later or tommorow but on Friday we went up to 10.5 lbs of boost which brought us up to 479whp & 470 lb tq no water injection and pump gas , my only problem now is our clutch package thats been made thru competition clutch isn't completed as yet our setup was originally designed for 350 hp which isn't slipping but we know with a full clutch package and flywheel we would be better off ...
Old 09-28-2009, 10:03 AM
  #2130
pass427's Avatar
Our knOck box was delayed so we didn't recurve it Friday but fortunately we have recieved a tracking number , and delivery date is thursday so we will be installing it on Thursday I'll keep updating as we progress....
Old 09-29-2009, 05:35 PM
  #2131
Chapter Leader (San Antonio)
TheChamp531's Avatar
!! Gj !!
Old 09-30-2009, 11:05 AM
  #2132
Inaccurate's Avatar
Originally Posted by pass427
on Friday we went up to 10.5 lbs of boost which brought us up to 479whp & 470 lb tq no water injection and pump gas , my only problem now is our clutch...
You are at 470 lb tq, and your only problem is just clutch?
470 lb tq is a huge amount of force. Please refresh my memory. This is with oem pistons?
Old 09-30-2009, 11:30 AM
  #2133
pass427's Avatar
^^^^^^You read right and the knock box isn't installed yet it will be in on Friday , clutch itself isn't slipping but like Opel mentioned a while back pressure plate doesn't have the clamp force way foo soft ,now we know we have to go with a a stronger mount we only have 60 in right now after 2 wrong delivered mount kit from innovative and then to tell us they don't have any Tl mounts in stock excellerate had the last set of mounts which were 60a .. Now we need a 90 or better .
Old 09-30-2009, 12:02 PM
  #2134
Way to go! The hp is great but I really love the torque numbers. What's traction like at this level?
Old 09-30-2009, 12:14 PM
  #2135
KN_TL's Avatar
Good to know. Josh @ excellerate said there would be another mount player but I haven't seen anything yet.
Old 09-30-2009, 12:42 PM
  #2136
pass427's Avatar
I'll hurry up and post dyno sheet asap... Traction whats that u lol ihc there's none till end of second into third and I still spin third but were going to setup the car properly drag radials ect ksport full coilover right after the holiday ........
Old 10-01-2009, 10:34 AM
  #2137
KN_TL's Avatar
i'll hurry up and post dyno sheet asap... Traction whats that u lol ihc there's none till end of second into third and i still spin third but were going to setup the car properly drag radials ect ksport full coilover right after the holiday ........
wow wow wow wow!!!!!!
Old 10-01-2009, 10:36 AM
  #2138
Under construction
alexSU's Avatar
that's insane torque for the TL!! shit that's amazing torque for any car lol awesome
Old 10-01-2009, 12:43 PM
  #2139
Opel's Avatar
what kinda tires are you on? i have a feeling, once u get some good street tires, ur gonna feel that clutch more lol.
Old 10-01-2009, 06:21 PM
  #2140
Got your mom in
Silva-type-s's Avatar
ok folks the numbers are in... lol
read em and weep...
Old 10-01-2009, 06:27 PM
  #2141
bzyrice's Avatar
WTH!?! NICE!!! numbers went up from last time! What was the difference this time? Up the boost? Sorry I havent been following the thread as much since I cant afford the turbo for another few years now because I have to save up for a wedding.
Old 10-01-2009, 06:29 PM
  #2142
Got your mom in
^ nice. we should do a meet at the wedding....... bring the S2K. lol
he's at 10lbs not.... at the meet he was at 8.6lbs
Old 10-01-2009, 06:33 PM
  #2143
Damn! Image a TL at 26 psi of course you have to change internals and maybe fix the transmission, but 700WHP+ maybe? Crazy 700WHP on a FWD.
Old 10-01-2009, 06:41 PM
  #2144
read em and weep...
LOL. You hit the factory hp numbers at 3,500rpm and factory torque at 3,000rpm. That's a nice usable powerband.
By 4,000rpm you're making more power and 140lbs more torque more than most supercharged TLs.
You could race a stock TL and not have to shift above 4,000rpm to destroy it.
Are you rolling along in 3rd and then punching it? If so, that turbo looks like it has excellent spool characteristics. In my experience they spool faster in real life than on a dynojet unless the owner knows how to properly load it down for a turbo car which most don't. That thing needs load to spool.
Old 10-01-2009, 06:56 PM
  #2145
Got your mom in
yup..
this is going to be me on sunday........ I lost a race to a car that didnt leave third gear. lol
Old 10-01-2009, 07:18 PM
  #2146
zaino'd
jmkiang's Avatar
Wow crazy numbers!
Old 10-01-2009, 11:17 PM
  #2147
pass427's Avatar
thats exactlt how i race it 3rd gear floor it and it stil spin those nexen but pull is crazy so crazy i havent visited 160mph again no need to but ill make an in car video pull over the weekend ,,running it without slicks is gonna be useless at this power level,.. and we are getting dog cut gears for the car by june well be at 700 with tranny and a fully built motor ....
Old 10-01-2009, 11:48 PM
  #2148
takin care of Business in
swoosh's Avatar
Received 4,732 Likes on 4,064 Posts
^^^ dude i wanna take the time out and say
i remember when banelba started off the thread and got bashed !!!! over the time you guys have proved that TL has a whole lot of potential in the horizon which we seek !!!
Old 10-02-2009, 01:48 AM
  #2149
Opel's Avatar
This is also a question for Rodney...but im pointing it out to you also ...what happened on that graph....is the powerband just shifted on the graph or what exactly happened...where did the cutoff happen? redline starts at 6800 and it hits 7000, cutt off seems at just above 6500 rpm on the graph, it peaked at 6250, which is right around the stock hp peak.
if set up right, that should shift the numbers over another 400 rpm or so...not that its bad as it is...its freaking awesome, but factory power would be around 4000 rpm...
also, i dont see vtec engagement, and that thing, always leaves a mark on the line, at least it did for me... take a look at my old graph, at 4000 rpm...by the way, im not questioning its authenticity...just wondering, cause if its just a simple powerband shift on the graph, then it would peak at around redline
Old 10-02-2009, 07:01 AM
  #2150
pass427's Avatar
^^^if u noticed on all my graph vtec engagement is always smooth and as far power band not sure what your getting at ???????
Old 10-02-2009, 07:18 AM
  #2151
pass427's Avatar
Think it's fair to say if your comparing your graph to mine it's going to be totally different ,I should be making power early turbo was bought with a specific and precise size so we wouldn't be waiting on this thing to spool , automatically I expect power band to shift evenmore as we go up in boost pressure more boost turbo wakesup even earlier , turbo is rated up to 800 hp witin effeciency range so 6 psi it spools but imagine what 15 psi will do...
Old 10-02-2009, 07:32 AM
  #2152
Inaccurate's Avatar
Rodney,
Just a suggestion here, so please take it as such.
Opel is right. We are not doubting the truth of what we are being told. But that graph is whacked. Please find someone else to prepare your graphs in the future.
Rodney, you *do* have a "case act" happening here. Everything that you have done is top notch. But, whoever is doing your dyno graph preparation is giving this project a black-eye.
I notice this exact thing a month (or so) ago when that first dyno graph was posted. But, I "played nice" and said nothing.
Here is the bottom line. The *very first* thing that I do when I see a dyno graph, I check to see if the HP and TQ lines on the graph intersect at exactly 5252 RPM. The two lines must intersect at 5252 RPM by definition. There is no way around this fact. Simple math.
If the lines fail to intersect at 5252 RPM, that graph losses all validity with me and the graph is suspect.
Old 10-02-2009, 07:43 AM
  #2153
Inaccurate's Avatar
^^^ BTW, When I said "Opel is right", I meant in so far as that is a fishy looking graph. Anyone that knows how to properly prepare a graph would cringe at that graph posted.
I did *not* mean to comment either way about the vtec engagement. Just the graph in general is the issue with me.
Old 10-02-2009, 09:06 AM
  #2154
pass427's Avatar
^^ hey Im never one not listen so what I'll do is join the dyno challenge on Sunday that way I have a graph from somewhere unrelated to developement of kit and post that graph ..
Old 10-02-2009, 09:15 AM
  #2155
Your Garage
DC3328's Avatar
^i hope you win! i'll be watching with some in my hand
Old 10-02-2009, 09:17 AM
  #2156
Inaccurate's Avatar
It isn't that we don't trust you. We fully trust you and the dyno numbers themselves. It's just the graph was made wrong.
Old 10-02-2009, 09:28 AM
  #2157
Looking at it, it looks like it does cross at 5,250 but the graphs are done is a weird way.
Old 10-02-2009, 09:40 AM
  #2158
....just dancing in
77donovan77's Avatar
Good observation...and constructive criticism InAc
Old 10-02-2009, 11:22 AM
  #2159
pass427's Avatar
Good news guys knock detection detection box is here and will be installed later
Old 10-02-2009, 11:29 AM
  #2160
pass427's Avatar
Guys if there's a problem please let me know and I'll get it fixed , like for instance the dyno graph if there's doubt or error which there shouldn't be I make the runs then print them out ...so I woundnt know how to prepare them or what seems to be the issue please explain were all here to learn
Quick Reply: Turbo Kit for Acura TL '04-'08
