*** Official Uni-Chip Group Buy ***
Old 06-22-2004, 02:25 PM
  #1481
rmarin2's Avatar
Just got off the phone with Todd. I'll be getting mine by the end of the week. Can't wait!!
rmarin2 is offline
Old 06-22-2004, 03:07 PM
  #1482
Revving at 9K...
CLS2001_97124's Avatar
Whoever gets 100+ Oct gas and Dyno it first on race setting wins!!
btw, just had a chance to read the instructions. Here is the little section about the racing setting:
Accessory Cable Functionality
a. The normal position for ECU Pwr is on ( I ) and the normal position for the Map
A/B switch is off ( 0 ) and unless you are either resetting the ECU or desire to run Map B, these switches should remain in these positions.
To change either switch, turn off the ignition key before actuating the switch.
b. With the ignition key off and removed, selecting the on ( I ) position on the Map A/B switch selects timing Map B, which can be verified by illumination of the red LED when the vehicle is started. Using Map B may result in a CEL on some vehicles; the CEL results from that particular vehicle’s increased sensitivity to detonation. If Map B produces a CEL in your vehicle, select reselect Map A and use the ECU power cut switch to clear the CEL as outlined below.
Note: (1) More is not always better… adding more timing can actually reduce power in a particular vehicle if that vehicle is sensitive to detonation. If the stock ECU detects detonation, it will reduce timing to protect the engine; if you’re car doesn’t seem to be making more power than stock and you’re running Map B, switch back to Map A and
you will feel the power increase. This condition can and does occur even without a CEL.
So I say, lets just take the Map B with as an Unknow for the time being. But Map A (daily driving Map), we know for sure works!
CLS2001_97124 is offline
Old 06-22-2004, 03:15 PM
  #1483
withoutcomp1's Avatar
did everyone that got the call pay allready? i have not heard anything!
withoutcomp1 is offline
Old 06-22-2004, 03:24 PM
  #1484
Revving at 9K...
Quick note from Todd. Please send him info if you see your name on this list!
Brian,
We have started shipping the Acura CL PnP Kits for the Unichip. I still need the following people to contact me so I can authorize payment and ship out to the members.
1. Bill Covert
2. Sundy Hin
3. Paul Tadler
4. Richard Marin
5. E. Joel Rivero
6. Steve Ashby
Thanks for your Help on this.
Regards,
Todd Brainard
Unichip of North America
http://www.unichip.us
Toll Free: 1.866.643.7400
Tel: 503.640.7465
Also, there is one spot open on this GB, someone has backed out due to money issues. So if anyone still interested in this, please contact either me or Unichip. I have a few emails of people that are interested. I will try and contact them for this final spot.
Thanks,
Old 06-22-2004, 03:40 PM
  #1485
dj5
dj5's Avatar
Does anyone have any pictures of where the ECU is located? Is it in the same location in the TL-S as in the CL-S? My understanding is the ECU is located on the passenger side close to the radio and all we need to do is pull the carpet back and it will be exposed.
dj5 is offline
Old 06-22-2004, 04:17 PM
  #1486
mrsteve's Avatar
Okay so given the following senario, will this be correct.
1) I put a few gallons of 100+ in my near empty tank.
2) With the ignition off and the key out, I flip to "Map B"
3) Start car
4) CEL turns on
5) Turn off car, remove key
6) Flip to "Map A"
7) Flip ECU reset switch
8) Start car again
Is this correct? Once the car is started will I switch off the reset switch? Or is it the type of switch where it doesn't stay in the 2nd posistion? Like I flip it up and it returns to the down posistion when I let off the button.
mrsteve is offline
Old 06-22-2004, 05:18 PM
  #1487
Revving at 9K...
Nope.
Its like a light switch. When you flip it on, its on Map B (led on), off its on Map A (led off).
So once you have 100+ in your tank, you would have the key out, turn on Map B, turn on the car, the LED should come on. Now you are in B mode. No need to go to A, until you go back to pump gas. Or if your ECU is throwing a CEL, then follow their instructions to reset everything back to A mode.
Old 06-22-2004, 05:19 PM
  #1488
Revving at 9K...
The instructions will have pictures.
Old 06-22-2004, 06:03 PM
  #1489
mrsteve's Avatar
Originally Posted by CLS2001_97124
Nope.
I was refering to the ECU reset switch. So to reset the ECU I would switch it ON then OFF??
mrsteve is offline
Old 06-22-2004, 07:00 PM
  #1490
Not Asian
phipark's Avatar
I would only assume it is a typical reset button that will automatically spring back.
phipark is offline
Old 06-22-2004, 09:11 PM
  #1491
///M POWER
darrinb's Avatar
i am going to dyno on 100 octane race gas as soon as i get the chip installed, i am actually gona schedule an appointment asap
darrinb is offline
Old 06-22-2004, 09:13 PM
  #1492
///M POWER
darrinb's Avatar
i'd like to thank everyone who put this project together, expecially brian and matt for giving up there cars for testing.
big ups to the 35 members that participated and got this GB rollin, w/o a great forum like this doing this would be impossible
props to acura-cl.com
darrinb is offline
Old 06-22-2004, 09:30 PM
  #1493
mrsteve's Avatar
I will be making an appointment to get dyno'd tomorrow on my lunch break for Friday afternoon. I will have results posted by 7:00pm EST
mrsteve is offline
Old 06-22-2004, 09:32 PM
  #1494
///M POWER
darrinb's Avatar
good news steve
darrinb is offline
Old 06-22-2004, 11:05 PM
  #1495
I have not been contacted to pay or anything was everyone contacted?
Old 06-22-2004, 11:19 PM
  #1496
///M POWER
darrinb's Avatar
i think so, call up todd tommorw
darrinb is offline
Old 06-23-2004, 10:04 AM
  #1497
mrsteve's Avatar
Dyno Scheduled
3:00pm Friday. I rented it for the hour so I'll have plenty of time to get multiple pulls in. Most likely I will do 2 baselines, 2 setting A, and 2 setting B; try and get the most out of my hour.
I'll be there with a gas can full of 100+
I'll let you all know how it turns out Friday evening.
www.alteredatmosphere.com
mrsteve is offline
Old 06-23-2004, 10:41 AM
  #1498
Revving at 9K...
Nope. Its an on/off switch. Don't worry, the instructions explains it all very clearly.
Old 06-23-2004, 10:45 AM
  #1499
Jonesi's Avatar
Thanks again for all your work Bri...!!
Jonesi is offline
Old 06-23-2004, 11:03 AM
  #1500
///M POWER
darrinb's Avatar
any one guessing on what the gains will be from the race gas??
darrinb is offline
Old 06-23-2004, 11:05 AM
  #1501
derelict's Avatar
I can't imagine it's that significant... I thought the primary use of the "B" setting was for N2O
derelict is offline
Old 06-23-2004, 11:22 AM
  #1502
mrsteve's Avatar
No gains will come from running race gas. The reason for running 100+ octane is for safety reasons (i.e., preventing knock)
mrsteve is offline
Old 06-23-2004, 11:24 AM
  #1503
mrsteve's Avatar
It is my understanding that the "B" setting on our chip is different than the "B" setting on Matt's chip. Our "B" setting was tuned on Brian's car for N/A applications. Matt's "B" setting has the Uni-chip take control over the Zex system's control of the NOS.
mrsteve is offline
Old 06-23-2004, 01:40 PM
  #1504
Audi S4 driver
blader's Avatar
This doesnt make sense to me .. so your saying the unichip won't be safe unless running 100+ octane ALL the time? I'm pretty sure the timing is set safe enough on the 'A' map to prevent knock on daily driving. But if the race gas setting (Map B) won't yield any gains over running the street map .. why did they bother to put it on? It doesnt make sense that using a more aggressive timing map with 100 octane won't yield SOME type of gain...
blader is offline
Old 06-23-2004, 02:09 PM
  #1505
One who Laps
sonor kid's Avatar
Mine is coming!
sonor kid is offline
Old 06-23-2004, 04:04 PM
  #1506
But I just got here
Nitin's Avatar
Got mine today but I don't have time to install it. I'm leaving for the Orioles/Yankees game soon. Oh well, I'll have plenty of time tomorrow evening to do it.
Nitin is offline
Old 06-23-2004, 04:07 PM
  #1507
Not Asian
phipark's Avatar
^^You already got yours? Holy shit that was fast.
phipark is offline
Old 06-23-2004, 04:09 PM
  #1508
But I just got here
Nitin's Avatar
I asked for overnight delivery, that's why I already got mine today. The installation instructions look kind of complicated though, doesn't seem to be as easy as I thought it would be.
Nitin is offline
Old 06-23-2004, 04:48 PM
  #1509
mrsteve's Avatar
No no, on the "A" setting 93 octane, or 91 for the Cali guys, will be just fine. On setting "B" the timing is advanced even further (aka more hp) thus the need for race gas to help against detonation.
The reason why setting "B" may not yield gains for everyone is that every car is a little different. Some might be quirky and see that significant timing increase and go nuts. The ECU itself will then DECREASE timing (aka less hp) as a safety precaution to prevent knock.
So basically there is the possibilty of setting "B" being too extreme for some cars. If your ECU isn't a prude you should see gains on setting "B" with 100+ race gas only for added safety.
mrsteve is offline
Old 06-23-2004, 04:54 PM
  #1510
///M POWER
darrinb's Avatar
so if you baby your car the b setting might not work??
darrinb is offline
Old 06-23-2004, 05:16 PM
  #1511
mrsteve's Avatar
Don't really know what you mean by "won't work"
Also I wouldn't see a need for the "B" setting unless you were racing at the track or doing so "spirited driving" on the street. Babying the car on the "B" setting really is pointless
I'd just switch it back to "A" while on the street for everyday use.
mrsteve is offline
Old 06-23-2004, 05:27 PM
  #1512
Beware of leakage
Chopsie's Avatar
hmm, reading last couple of pages, I have learned that:
1--the unichip has different settings, from what I understood in the beginning was that you just plug it in and go.
2-- In the race setting 100+ Octane is needed for the prevention of knock.
Interesting
Chopsie is offline
  #1513
Revving at 9K...
Good call, mrsteve.
Remember guys, the A setting is the map we really are paying for! This is the map that gives us the gains we saw in both Matt and my car. Consider B as a bonus for the extream, you still come out head with this deal.
Old 06-23-2004, 05:30 PM
  #1514
Revving at 9K...
Its really not that bad at all.. After you actually pull out the carpet and look at the ECU and the way harness are plugged in, you'll realize that it is ver straight forward. If anything just post pics here, and I'm sure we'll are help you out if you need it.
Old 06-23-2004, 05:35 PM
  #1515
mrsteve's Avatar
I plan on installing it Thursday night (unless the FedEx dude gets here really late) or Friday morning/afternoon. I'll take pics of the install and the dyno. Video is possible too.
mrsteve is offline
Old 06-23-2004, 06:14 PM
  #1516
BC
nearsighted visionary
BC's Avatar
Chip is in. Nice buncha guys at Unichip. Thanks.
On the 40 mile drive home, traffic and construction was not condusive to spirited driving so I can't report on perceived gains. No CEL.
Since when does rush hour start at 2 PM?
Sieze ya.
BC is offline
Old 06-23-2004, 09:25 PM
  #1517
///M POWER
darrinb's Avatar
Sieze ya.
go take it for a spin right now and report back to us
darrinb is offline
Old 06-23-2004, 10:07 PM
  #1518
juice's Avatar
Sieze ya.
What kind of crap is that? I would have rathered you not even tell us that you have it in. Hurry up and go around the block and let us know what you think!
juice is offline
Old 06-23-2004, 10:16 PM
  #1519
Has anyone else not heard from Todd? Other then me! I e-mailed him this morning and still no response SOME HELP PLEASE GUYS! This is my third post and noones answered me! I know everyones excited they got their chip, But i don't feel like getting fucked!
Old 06-23-2004, 10:22 PM
  #1520
Jonesi's Avatar
Deep breathe.. Have you called Todd? Where you one of the people that was on the list provided by Brian? Just call them up.. I'm sure they're not looking to fvck you..
Jonesi is offline
Quick Reply: *** Official Uni-Chip Group Buy ***
