Computer Building Thread
Old Dec 3, 2020 | 11:37 AM
  #1001
nist7's Avatar
Finally upgrading my case as the start of a slow but gradual desktop upgrade process.
After looking at diff options and being now an "old man"...I have no interest in RGB or frills or glass windows....so got this basic Cooler Master N400: https://www.newegg.com/midnight-blac...82E16811119277
Still has the external drive bay for old man optical disc drive or expansion stuff if I want in future. And plenty of 120mm fan slots for good air flow.
Gonna transplant rest of my desktop into this case, and then upgrade next year with new mobo/CPU/GPU.
But for cooling, calling on those who are more recent to the PC building game on what do you guys recommend as great 120mm fans? I want MASSIVE CFM and huge air flow...I can tolerate some noise, but obviously nothing super crazy.
I heard Noctua is a good brand? This will be my major system upgrade in like 8 years so been out of the game for a while now. Thanks for advice!!
Old Dec 3, 2020 | 11:42 AM
  #1002
Mizouse's Avatar
ive only heard of noctua for being good and silent.
but ive been out of the game alot longer. I last built a system in 2006
Old Dec 3, 2020 | 11:50 AM
  #1003
nist7's Avatar
This/Next year is good time....great CPU and GPU leaps from AMD and NVIDIA. I think systems built on current gen should last for 5 years at least? (for when Ryzen 7 5000s and RTX 3000s are finally in normal stock and not scalped like crazy anymore....)
Old Dec 3, 2020 | 12:07 PM
  #1004
Mizouse's Avatar
Well thats because i switched to a Mac in 2014.
gave it a try since it was like $600 for a refurbished by Apple, 2012 i7 Mac Mini.
I also just picked up a 2018 Mac Mini back in October (right before the new one came out too )
I have been thinking about building a budget gaming only PC. But then I just got a PS5
i have no idea what I'm doing
Old Dec 3, 2020 | 01:47 PM
  #1005
Costco's Avatar
Noctua is among the best for cooling both with their case fans and CPU coolers. Read good things about Silent Wings too.
If you don't like the colors, you could always get Chromax covers.
I don't really care about RGB either. Still, it's harder to find non-RGB stuff. Last time I upgraded I bought RGB ram because it had the clock speeds I was looking for, and was on sale. Spent time tinkering with the timings, but never touched the RGB settings even once. My case does not have a glass window, and my next one won't either.
Old Dec 3, 2020 | 01:58 PM
  #1006
Costco's Avatar
Just keep in mind when looking at reviews to see if noise is normalized with thermals and vice versa. No point in having quiet fans if they suck at cooling or are only good at cooling at higher RPMs. As usual, Gamers Nexus is a good YT channel to refer to.
I skimmed around and seems like this video does a good job comparing sound in addition to thermals.
See how other people with your case set up their fans. Generally, bigger fans can spin at lower RPM and still move lots of air, thus are quieter. But, that depends on your case.
More generalizations - positive case pressure is better (lower maintenance with dust). Try to keep your case pretty open inside by removing drive bays you don't use, and run airflow in from front, and maybe one exhaust fan out the back. Don't forget that the intake fans push air out through the holes on the rear panel, too.
Stock fan curves on GPU coolers are usually very conservative to prevent noise. There are tutorials on this, but the idea is to set them to ramp up sooner than later in order to prevent temp spikes.
Old Dec 3, 2020 | 02:22 PM
  #1007
nist7's Avatar
Dang, thanks man!
Interesting advice on the air flow physics with intake/exhaust and whatnot. So basically, put more fans from the intake/front side and don't need as much exhaust fans? Any specific reason why we want more air to be pulled in from front vs sucked out?
I think my case also has top and side fans as well. Would it be stupid/useless, to max out all fan slots and blow as much CFM as possible with all fan slots?
Old Dec 3, 2020 | 02:36 PM
  #1008
Costco's Avatar
I am no aerodynamicist, but I would think there's diminishing returns. Your case is different from the one I am looking at, so I don't wanna make any assumptions about optimal fan placement pertaining specifically to the N400. Mesh front bodes well for intake airflow, but you don't want it to be a turbulent mess inside.
This is hyperbole, but more fans are not always better. TL;DW this case sucks ass at cooling
Old Dec 3, 2020 | 02:39 PM
  #1009
Mizouse's Avatar
Theres also having positive/neutral/negative pressure too.
I think you want positive pressure as that helps keep dust out.
Old Dec 3, 2020 | 03:24 PM
  #1010
Yvuru's Avatar
noctua is a fantastic choice. im running some 140mm noctuas with the chromax. blacked everything out for a cleaner look
generally speaking you want more intake than you do exhaust. i believe this to be the positive pressure setup, and it is better for dust control. in this setup you have more intake pressure from the case fans, and less exhaust. the reason for this is so you can force all the air coming into the case to go through the dust filters (ideally there are dust filters, usually a mesh material)
on the flip side if you have more exhaust than intake. the air coming into your case will come from the intake fans and "gaps" in the computer case. this is because the case is exhausting more air than the intake fans are putting in. so the extra air comes from the gaps in the case which are unfiltered and dust gets in easily from these areas
edit: this matters to some people more than others. but the temps generally work out ok as long as there are adequate fans and air flow. i got carpet in my room so its a big deal to me
Old Dec 3, 2020 | 03:37 PM
  #1011
nist7's Avatar
Dang, awesome guys. Thanks so much. The More You Know!
Old Dec 3, 2020 | 06:42 PM
  #1012
#1 STUNNA's Avatar
Sanest Florida Man
I think I'm waiting for AMD to support USB 4 before upgrading, so probably next year when they drop to 5nm
Old Dec 4, 2020 | 11:35 AM
  #1013
doopstr's Avatar
If you are looking for an upgrade path with AMD and can wait until next gen, it's probably best to do so. Next gen AMD CPU is supposed to be on a new socket.
Old Dec 4, 2020 | 11:44 AM
  #1014
svtmike's Avatar
The whole positive pressure thing and keeping dust out of the case is bullshit.
If there is dust in the intake air stream, it will come into the case right along with the air. You have to have a filter on the intake fans to keep dust out.
  #1015
Ken1997TL's Avatar
Waiting for the new generation AMD and then I'll build a tower. I'm currently enjoying a nice HP AIO that plays the games/runs apps quite nicely. I ordered a Mac Mini M1 last night.
Old Dec 4, 2020 | 11:47 AM
  #1016
Mizouse's Avatar
that’s the whole point of positive pressure. All the intake air is coming in from intake fans that presumably have a dust filter.
with negative pressure air can seep in from any small gaps or holes in the case that typically don’t have a filter.
Old Dec 4, 2020 | 04:12 PM
  #1017
Costco's Avatar
In addition, cases designed for different intake locations tend to have filters where intake fan placement is likely - usually the front, bottom, and top.
Old Dec 4, 2020 | 05:39 PM
  #1018
stogie1020's Avatar
Needs more Lemon Pledge
You guys and your positive/negative pressure... Lol.
I run an i9 hard on air cooling with fans in some kind of configuration and I blow the case out about every 6 months (let's be real, about once a year) with a $4 can of compressed air. Everything works fine and runs for a long time.
I mean, if you really want to obsess over something, obsess over Rhode Island. It is neither road, nor island. Yeah.
Old Dec 4, 2020 | 07:14 PM
  #1019
Costco's Avatar
idk, a long time ago I used to put my tower directly onto carpet. Also never paid attention to fan configuration
After putting it on my desk or on an elevated platform, plus fans in positive pressure config, the inside seems to accumulate less dust. I've never tested either individually though
Old Dec 4, 2020 | 07:54 PM
  #1020
Costco's Avatar
to add to this, hopefully AMD continues the trend of having the sockets compatible with successive generations of CPUs.
Needing to buy a new motherboard to upgrade your CPU (a la Intel) is BS.
Old Dec 4, 2020 | 08:11 PM
  #1021
Mizouse's Avatar
i'm in not rush to build a new computer. so maybe i'll wait for zen 4 (or whatever the next one is)
Also curious what Apple's M1X will bring. but Costco wont spill any beans about it
Old Dec 4, 2020 | 11:23 PM
  #1022
nist7's Avatar
Yeah current Ryzen 5000 CPUs are going to be the last supported on the current socket.
Tempted to wait for next gen AMD that should be late 2021/2022?
Old Dec 5, 2020 | 12:19 PM
  #1023
Costco's Avatar
I haven't worked on anything Mac-related in over a year and a half, so at this point I know more about AMD than Apple ARM
Old Dec 5, 2020 | 05:40 PM
  #1024
#1 STUNNA's Avatar
Sanest Florida Man
What's going on with AirTag?
Old Dec 6, 2020 | 12:10 AM
  #1025
Mizouse's Avatar
but there is a rumor that something will be released on Tuesday via press release
Old Dec 6, 2020 | 12:44 PM
  #1026
Costco's Avatar
TL;DW when mounting AIOs, don’t mount radiators on the bottom of the case. Pump should be at the lowest point of the cooling loop, or at the least not be the highest. Tubes should be at the bottom.
Didn’t know about this until recently. My friend showed his radiator mounted on the front, with tubes up and it reminded me
Old Dec 6, 2020 | 12:48 PM
  #1027
Costco's Avatar
dunno, NDAs forbid us from saying anything even if we knew.
I work on software anyway
Old Dec 6, 2020 | 01:12 PM
  #1028
svtmike's Avatar
OK, I kind of understand that but I think the pressure differential is going to be miniscule. Has anyone done a real experiment with a negative pressure case with small air leaks and another with all air leaks sealed to see if this is true in the real world?
Old Dec 6, 2020 | 02:20 PM
  #1029
Costco's Avatar
Another TL;DW: It depends. If you're consistent with maintenance, imbalanced airflow won't matter too much. But nobody would run all intake or all exhaust.
To me, optimizing airflow and filtration is going to cost little to no money (assuming you have a case already). If anything, it might save you money from buying an extra fan(s) that will hinder airflow.
Old Dec 6, 2020 | 02:26 PM
  #1030
Mizouse's Avatar
i wish you wouldve told me this so i could stop bothering you
actually i think ill still bother you
Old Dec 6, 2020 | 02:28 PM
  #1031
Mizouse's Avatar
https://youtu.be/BbGomv195sk
i think this was mentioned recently on one of linus' videos as well.
Old Dec 6, 2020 | 02:33 PM
  #1032
Costco's Avatar
Yeah, I was fortunate enough to be able to move to a different team.
If I were still in hardware, I would have to go in to work.
Old Dec 8, 2020 | 10:54 AM
  #1033
Costco's Avatar
Really nice website for budgeting and piecing out your build. Shows expected performance and FPS differences too.
https://www.logicalincrements.com
Normally I use PC part picker but they don't show prices for sold out items
Old Dec 8, 2020 | 11:45 AM
  #1034
Mizouse's Avatar
Yea I hate that about pc part picker.
also last I checked they still don’t have the NZXT H1 listed for a case.
Old Dec 8, 2020 | 06:16 PM
  #1035
#1 STUNNA's Avatar
Sanest Florida Man
Can you compare it to your current build and see estimated performance improvements?
Old Dec 8, 2020 | 06:28 PM
  #1036
Mizouse's Avatar
That would be sweet.
Old Dec 8, 2020 | 07:16 PM
  #1037
Costco's Avatar
I was trying to see if you could, but didn't see any option to do so. Sucks.
The GPU and CPU they use (1080ti, 3900x) seem to be popular performance SKUs, not being TOTL and not new-new, so still feels like a decent baseline.
Old Dec 27, 2020 | 04:08 PM
  #1038
#1 STUNNA's Avatar
Sanest Florida Man
Miz now you got me interested in the LG 27GN950.
I'm a PPI snob I won't got lower than 1440p 24in, but I might replace my 24in 1440P with that 4K LG. Though all the new monitors are about to get announced so let's see what happens.
My Dell G-Sync 144hz 1440P monitor has a TN panel so off axis viewing is bad, the gamma was bad until I fixed it in Nvidia control panel, and it's got a bad color banding issue, Seems like the LG IPS don't have these problems. And I get that pixel ghosting thing. I foolishly thought that the 144hz would fix that but I learned later that that's a pixel response issue.
Old Dec 27, 2020 | 10:35 PM
  #1039
Mizouse's Avatar
Ghosting on a TN panel?
TN panels are known for their faster response times.
IPS panels while faster (maybe fast enough) can’t quite match up to TN panel response times.
most IPS panels that claim 1ms or faster response time have the display set at the fastest overdrive setting which causes a ton of overshoot. Which doesn’t look good.
Old Dec 27, 2020 | 10:36 PM
  #1040
Mizouse's Avatar
I’ve heard good things about the LG 27GN950. Only thing that sucks is no HDMI 2.1, but that really only sucks for console players.
but doubt there would be many titles that can hit 4K 120fps.
