Microsoft: Xbox 360 news
Old Dec 11, 2008 | 08:37 PM
  #1841
AznX TL's Avatar
where is....
awesome, i got E74.....on my way to the 6th 360 in 3 years......
Old Dec 11, 2008 | 09:32 PM
  #1842
Mizouse's Avatar
Old Dec 11, 2008 | 11:05 PM
  #1843
AznX TL's Avatar
where is....
so far my original launch 360 has been to the repair center 3 times, once for dvd rom problem then 2 rings of death.
i also have a 360 arcade i got for the hdmi port, now it seems like the hdmi port is the source of the problem for E 74. and this is the 1st time its been out there.
Old Dec 11, 2008 | 11:17 PM
  #1844
dom's Avatar
dom
Thnaks Miz. So I go to 'My Xbox', select the 'Video Library' option correct?
I got that working in that I can see the folders and files on my PC just fine but they still won't play as it says not supported.
The movies I published in movie maker using the Xbox option play fine. As do all the MPEG 4 clips.
Old Dec 11, 2008 | 11:22 PM
  #1845
sho_nuff1997's Avatar
I disagree with unanimity
Do you have divx player? I had the same problem, then I downloaded divx player for my PC and it installed the proper codecs. AVIs play great through the video library.
Old Dec 11, 2008 | 11:28 PM
  #1846
Mizouse's Avatar
is your xbox updated?
what kind of xvid files are you trying to play?
'd movies online? cause mine seem to play fine
Old Dec 11, 2008 | 11:40 PM
  #1847
dom's Avatar
dom
The movies play fine on the PC. so I should have the proper codecs, I think.
Old Dec 11, 2008 | 11:42 PM
  #1848
dom's Avatar
dom
Yup, I had some Top Gear avi's on a USB key and they now play fine. Before I played them it said you need the update and it went and got it. No such message for these ones.
Which I guess means the Xbox just doesn't support them.
Old Dec 11, 2008 | 11:45 PM
  #1849
Mizouse's Avatar
really? my top gear issues play fine.
what codec are you using on the computer?
Old Dec 12, 2008 | 02:55 AM
  #1850
Sarlacc's Avatar
The Third Ball
try another hdmi cable.
hdmi is a very wonky system...so far I am not a fan.
Old Dec 12, 2008 | 08:17 AM
  #1851
dom's Avatar
dom
Your 360 probably had the update. After it installed the update it was fine.
Apparently you need a Fall 07 update for the 360 to play AVI's.
Old Dec 12, 2008 | 11:48 AM
  #1852
cM3go's Avatar
Originally Posted by Sarlacc
mine has freezed up a couple times after the new update. or it seems like it freezes but it hung up for a minute.
hopefully theyll fix that.
Maybe I should wait longer... Mine just seems hung. The power button doesn't respond all the time either when hung, I have my Xbox programmed on my Harmony so I use that to shut it off. Glad I'm not the only one... Hopefully I don't have to swap my Xbox.
Old Dec 12, 2008 | 12:56 PM
  #1853
is300eater's Avatar
I Shoot with a Camera
I'm just using component cables and the picture's excellent (optical for audio)
Old Dec 12, 2008 | 02:07 PM
  #1854
Mizouse's Avatar
i see, thought you had installed that updated. so everything is working fine now?
Old Dec 12, 2008 | 02:54 PM
  #1855
Doom878's Avatar
+1 on HDMI's wonkiness. God forbid it gets disconnected. Then you gotta reset everything sometimes.
Old Dec 16, 2008 | 11:53 AM
  #1856
dom's Avatar
dom
Nope, I still can't play the home movies that are in an AVI format.
But I've given up. I have them all burned to DVD so I'll just use those.
Old Dec 16, 2008 | 12:08 PM
  #1857
Lister00169's Avatar
Yes, he did that
I might go HDMI if I get a 50"+ TV, but component looks awesome on both the 360 and PS3.
Old Dec 16, 2008 | 12:57 PM
  #1858
Doom878's Avatar
I'd say only go HDMI if you upgrade/purchase a receiver that does TrueHD/DTS-HD. If not, then just stick with component even on a new TV.
Old Dec 16, 2008 | 03:25 PM
  #1859
Mizouse's Avatar
maybe its because you are in ??
thats all ive been doing with my elite lately, just streaming movies from my computer
Old Dec 16, 2008 | 03:27 PM
  #1860
dom's Avatar
dom
I can too, like I said, its just the home movies that don't work.
I can just hook up the PC to the TV with a VGA cable if I really need to anyway.
Old Dec 16, 2008 | 03:31 PM
  #1861
Mizouse's Avatar
oohh thats what you meant by home movies, where are these home movies coming from?
probably the 360 doesnt support the codec that your camcorder/camera is recording in.
Old Dec 16, 2008 | 03:40 PM
  #1862
dom's Avatar
dom
Exactly what I'm thinking. I've tried video from 2 different camcorders and same thing.
If I publish it in "Format for XBox 360" its fine. But I can't do that with the old video anymore.
Old Dec 16, 2008 | 10:52 PM
  #1863
AznX TL's Avatar
where is....
already did, even tried to switch back to component but still gave me the error.
Old Dec 23, 2008 | 11:38 PM
  #1864
ChodTheWacko's Avatar
Moderator Alumnus
Xbox 360: 120GB the cheap way
Rock Band has totally eaten my 20Gb drive, and so I tried this out:
http://forums.xbox-scene.com/index.php?showtopic=660096
This will corrupt some saved games (like Rock Band 2), but otherwise,
it works great. I can live with that, for saving $100 or so.
It does kinda suck losing all my high scores on RB, but uhhh, oh well.
I got the hard drive from newegg.com for $55.
Finally some breathing room to install games to disk!
- Frank
Old Dec 25, 2008 | 07:27 PM
  #1865
cM3go's Avatar
Originally Posted by cM3go
My Xbox 360 Elite has been randomly locking up (not the RROD) after installing NXE. What do I do? Could be during a movie or a game, not necessary the same game or movie either.
So I think it finally bit the bullet. Got the red ring of death. Now what? Do I lose all my saved games?
Old Dec 25, 2008 | 10:20 PM
  #1866
Gnate's Avatar
Custom User Title
The new on demand-like movie availability on the 360 is freakin awesome!
Old Dec 25, 2008 | 10:33 PM
  #1867
AznX TL's Avatar
where is....
no, you only send in the system. you keep the hard drive.
Old Dec 25, 2008 | 10:49 PM
  #1868
is300eater's Avatar
how's the picture tho?
Old Dec 26, 2008 | 01:02 AM
  #1869
BstonBruin's Avatar
Go B's Go
Its great on netflix depending on the connection that you have. We have FIOS at home and you can't tell the difference between a regular television hd channel and a movie streaming
Old Dec 26, 2008 | 11:00 AM
  #1870
phee's Avatar
I got the Shifts
i got an xbox 360 arcade for christmas. should i trade it up to a pro? i think the elite doesnt have a hard drive. anyone know what i should do?
Old Dec 26, 2008 | 12:21 PM
  #1871
Doom878's Avatar
Just buy a hard drive and HDMI cable. Get the HDMI from monoprice.com for like $7 shipped. The Elite is the top of the line with HDMI, 120GB hard drive, some games, and it's black. But it's over $400.
Old Dec 26, 2008 | 12:40 PM
  #1872
is300eater's Avatar
^^^and 120GB is sooooooo redundant imho
Old Dec 26, 2008 | 12:49 PM
  #1873
Gnate's Avatar
Custom User Title
It's really not bad at all, I didn't use the netflix one either.
Old Dec 26, 2008 | 11:54 PM
  #1874
Mizouse's Avatar
to me i find it useful, well when i get more games since id rather have them run off my HD than the disc.
Old Jan 8, 2009 | 12:32 AM
  #1875
Sarlacc's Avatar
The Third Ball
Apparently, Netflix and Xbox made some kind of deal...Sony movies are now showing up in my instant que.
Old Jan 8, 2009 | 12:36 AM
  #1876
Mizouse's Avatar
i wanted to try out netflix on my 360 but i didnt like the fact that i had to set up a paying account first and then cancel it after the trial.
Old Jan 8, 2009 | 01:13 AM
  #1877
is300eater's Avatar
question regarding netflix... is the regular account and the XBox account the same? in other words, if I sign up the regular account, do I get to use the XBox netflix too? or is it completely different?
Old Jan 8, 2009 | 01:55 AM
  #1878
Sarlacc's Avatar
The Third Ball
same
Old Jan 8, 2009 | 02:54 AM
  #1879
Costco's Avatar
Anyone know if Blu-Ray is eventually coming to the 360 or not? Or do they still have their heads up their asses?
Old Jan 8, 2009 | 02:12 PM
  #1880
AznX TL's Avatar
where is....
doubt microsoft will ever admit that defeat.
but i finally got my 360 back from microsoft
