The Official Honda S2000 Thread
#1841
Received 2,329 Likes
#1842
Congrats!
#1844
Whats up with RDX owners?
$1k for a 15 month rental is pretty good
mrsteve (01-12-2012)
#1846
If you're gonna swap, do it right (skip to 1:40):
<object style="height: 390px; width: 640px"><param name="movie" value="http://www.youtube.com/v/hyKUvOSJG90?version=3&feature=player_detailpage">< param name="allowFullScreen" value="true"><param name="allowScriptAccess" value="always"><embed src="http://www.youtube.com/v/hyKUvOSJG90#t=100s?version=3&feature=player_detail page" type="application/x-shockwave-flash" allowfullscreen="true" allowScriptAccess="always" width="640" height="360"></object>
Costco (01-13-2012)
#1852
civicdrivr (01-13-2012)
#1853
Turd Polisher
I just got news that my Mom is looking for S2000s.
It won't be such a drag going home after all .
#1854
And if you went boost, you are adding weight as well. Thats weight on the front wheels. The J, being a V6, ends up sitting further back in the engine bay compared to the F. There are plenty of high dollar F builds out there that put out some serious power, but for a regular over the counter kit, an NA J puts out just the same hp and more torque.
If you want to stay 4 cylinder with a high redline, swap in a K series. Its a better engine then the F *flamesuit on*.
As Ken said, it has no exhaust. Just straight pipes.
BTW - from what I heard, the J37 swapped HFP S2k was scrapped.
#1856
Better response to mods? True
Better engineering? um.. last time i checked there was no stock K that revs over 9k with 240hp, yah you can mod it to go over but that goes back to ^
#1857
-Iron sleeves (K) vs FRM sleeves (F)
-iVTEC (K) vs VTEC (F)
I will agree that the F is better engineered from the factory, however the downside is it does not take mods very well, unless boosted - but its volumetric efficiency is null and void in a boosted application . My K20Z3 (Si motor) has a cam (and stiffer valve springs), header and KPro. It put down ~250/170 at the wheels with a shit tune. It revs to 8k rpm. I didn't touch the bottom end. There are no oversized valves. There isn't any port work done to it.
A K20 longblock is also slightly lighter then the F20 longblock - but Ive seen conflicting reports on the F. The K longblock is around 280lbs, Ive seen the F20 longblock weights range from 290 to 335lbs.
Stock for stock, sure, the F may have an edge in power, but Id still rather go with the K since it has a higher ceiling.
And dont get me wrong, Im not bad mouthing the F series. I love that motor. But it does have its downsides.
#1858
Meh, if you're gonna swap with the S2000 might as well do the LS-series. If you're feeling like a baller, get an LS3.... bolt-ons (intake, exhaust, underdriven pulley) and a tune, you'll make close to 430 RWHP. And probably get close to or over 30 mpg on the freeway, with a very reliable setup.
I can't remember the exact figures but some guy did an LS1 + T56 swap in his AP1... I DO remember that after relocating the battery to the trunk, his car was lighter in the front. Also, the LS1 was closer to the firewall than the F20 was.
#1859
Yea, those are pretty sick swaps. You definitely need to upgrade the rear diff though. There is a company out of Texas that retrofits the Ford 8.8" IRS into the S2k.
#1861
12 out of 12
#1863
12 out of 12.
#1865
I recently found a pristine set of SSR GT1 wheels in 18", with appropriate offset for an S2000 with stock suspension. I immediately bought. Now I have real (as opposed to replica) wheels, and very light wheels (19-20 pounds on all four corners), to put on my S2000 in the spring.
I have wanted a set of these since I bought my S four years ago, but they are no longer produced; sets in good shape are rare. Apologies for the lousy iPhone picture. The Rotas I have on now will be sold once the GT1s are installed in the spring. Can't wait!
#1867
S2000 widebody. 10.5 front, 12 rears.
Hope it's not a repost..
#1868
White S2K's are nearly impossible to find...
Check is in hand!
Check is in hand!
#1869
I drive a Subata.
They are really hard to find..
#1871
I drive a Subata.
Lucky!
#1872
#1875
I drive a Subata.
#1878
I love that widebody S2k.
#1880
How about this '07? Its a bit pricey but lower mileage:
http://www.cars.com/go/search/detail...nal&listType=1
EDIT - I believe thats the same dealer that you said had the white/tan S2k.
Ken1997TL (01-26-2012)
