Old Oct 2, 2012 | 05:39 PM
  #2201
Rick_TL-S's Avatar
Just imagine if Rick wasn't an insider. The average person has no chance other than their common sense.
Maybe I'm reading it wrong, but I take it that's a quick little dig at my uncertainty.
I deserve it.
Old Oct 2, 2012 | 06:49 PM
  #2202
charliemike's Avatar
Fahrvergnügen'd
I deserve it.
Not at all! They tried to screw you and you knew better. The average person would have gotten screwed.
Old Oct 2, 2012 | 08:53 PM
  #2203
ttribe's Avatar
Notable cars seen on the road today during my travels - 2 FR-S, 1 BR-Z (first one I've seen), 1 9G Accord Sport, and 3 Panameras.
Old Oct 3, 2012 | 10:12 AM
  #2204
RPhilMan1's Avatar
2024 Honda Civic Type R
I think I'm set on the ST...
Damn impressive gains with just a tune. Look at the torque!
253/324 to the wheels! Peak torque at 2346RPM...
SCT vs Stock Calibration Notes:
Same SCT calibration was tested on both 87 and 93....power is down about 15fwhp on 87 vs 93.
NOTE: SCT recommends 93 or 91 octane.
The big deal is the power gain when the car is "hot" and at normal drive temp (99% of your time)
Stock Boost Levels- Stock the ST will make spikes of boost around
21.5 psi and then holds between 20psi - 17psi, depending on the commanded torque.
SCT Calibration Boost Levels - SCT 93 Octane Calibration the ST will make spikes of boost around 23.5 psi and then holds between 22.5psi
Air Inlet Temps are very good.....after 10 minutes of idle time and
7 runs in a row they climbed from 80F (run 1) to 110F (run 7).
Stock Speed Limit is 186mph
Stock Rev Limit is 6700rpm
SCT Calibration Rev Limit is 7300rpm
Torque Truncation has been eliminated
Now, the car remains an ANIMAL on the street after it has some heat in it.
I am also putting together a group buy for the SCT X3 programmer $ 399 through October.
Old Oct 3, 2012 | 10:49 AM
  #2205
Fahrvergnügen'd
Dammit, I am trying not to go trade my cars for this!
Old Oct 3, 2012 | 11:38 AM
  #2206
Aman's Avatar
Your Friendly Canadian
Wow that shoots up fast
Old Oct 3, 2012 | 11:40 AM
  #2207
CLtotheTL32's Avatar
Old Oct 3, 2012 | 11:48 AM
  #2208
chill_dog's Avatar
Oderint dum metuant.
Impressive.
Old Oct 3, 2012 | 11:52 AM
  #2209
StreetKA's Avatar
Now you guys make me want it lol
But it looks like powerband falls on its face after 5.5k rpms. Is it exhaust or timing is beeing pulled
Old Oct 3, 2012 | 01:11 PM
  #2210
crazyasiantl's Avatar
thats how my car is.
cobb accessport seems to cure it
Old Oct 3, 2012 | 02:07 PM
  #2211
Fahrvergnügen'd
I can't remember when was the last time I saw 5500+ on the tach.
Old Oct 3, 2012 | 03:19 PM
  #2212
Aman's Avatar
Really? I love winding it up, especially when a light turns green on a high speed-limit road or highway on-ramp.
Old Oct 3, 2012 | 03:20 PM
  #2213
civicdrivr's Avatar
Its probably the size of the turbo.
Old Oct 3, 2012 | 04:09 PM
  #2214
+1. The Turbo in my car spools up super fast, but falls flat at 5k. And IIRC, the Turbo is only the size of my fist
Old Oct 3, 2012 | 04:20 PM
  #2215
speedemon90's Avatar
GTI's fall off too, i think turbos just do that in general?? They run out of air up top.
anywhoo, you think that tune will yank at your steering wheel?? It is still a fwd car.
Old Oct 3, 2012 | 04:24 PM
  #2216
Fahrvergnügen'd
Winding up your 2.0?
  #2217
iSeeYouTwo's Avatar
What car/motor is that tune for?
Old Oct 3, 2012 | 04:25 PM
  #2218
Fahrvergnügen'd
2013 Ford Focus ST
2.0L Ecoboost 4-cylinder
Old Oct 3, 2012 | 04:30 PM
  #2219
I havent done it recently for certain reasons i'll explain later, but maybe before a month ago, i'd hit redline at least once a week in my car
Old Oct 3, 2012 | 04:37 PM
  #2220
Aman's Avatar
I thought it was mainly the size of the turbo, like Morgan said. That's why variable-vanes are popular, no?
It's part necessity
I do enjoy doing it in any car though.
Old Oct 3, 2012 | 04:54 PM
  #2221
^well i dont know too much about turbos, but i'm sure that size matters too. Just saying its a common trait of a turbo? And brb while i google variable vane turbos haah
Old Oct 3, 2012 | 05:09 PM
  #2222
SuperTrooper169's Avatar
In the Mid-South meow
My MS6 in stock tune falls flat on it's face after 5500 RPM too, but Cobb has eliminated that problem to my redline loving delight.
Old Oct 3, 2012 | 05:14 PM
  #2223
Aman's Avatar
On the topic of tunes, what are the downsides? All we hear are improved power, improved fuel economy, improved everything.
Is it just a little less reliable?
Old Oct 3, 2012 | 05:41 PM
  #2224
Fahrvergnügen'd
Too aggressive and the engine could go kaboom.
But most of the time I wouldn't imagine much risk other than perhaps some premature wear from being under more pressure more often.
My guess.
Old Oct 3, 2012 | 07:01 PM
  #2225
civicdrivr's Avatar
It depends. Smaller turbos spool faster but cant move as much air at higher rpms. Larger turbos spool slower aka turbo lag but make monsterous power up top. Just look at a single turbo Supra dyno graph.
There are ways to mix and match the halves as well, so you can tailor the snail to the motor.
Cost?
My guess.
Most of the off the shelf tunes are tame enough that you dont have to worry about blowing the engine.
For example: Subaru recommends at least 91 octane in my car since thats what the tune is setup for. The tune I have now is spec'd specifically for 93 octane, so timing is a bit more aggressive and the fuel trims are cleaned up a bit. I can run 87 octane in an emergency, but I have to drive real easy on the car.
Im sure that the ST can make another 20-40whp/tq on corn juice too.
Old Oct 3, 2012 | 07:16 PM
  #2226
Costco's Avatar
Most manufacturers very conservatively tune their F/I vehicles in order to maximize reliability *glares at Volkswagen*
Other times, it's baffling. I believe on early Mazda DISI motors (2.3 turbo, MS3/6), the stock tune is actually more prone than it should be to deonation, though I may be missing some details. It's prevalent enough to the point where MS owners even coined the term ZZB (Zoom Zoom Boom)
Nothing API or an Accessport can't fix!
Old Oct 3, 2012 | 07:24 PM
  #2227
Costco's Avatar
UA6's SRT-8 thread reminded me... whatever the hell happened to these? I'd imagine these are a lower-cost alternative to ventilated seats.
The crotch vent is just as important as well the other vents. Swamp crotch is more uncomfortable than anything else. Also found another name for these vents: ball blowers... heh
Old Oct 3, 2012 | 08:31 PM
  #2228
Rick_TL-S's Avatar
Drove our '07 Carrera S today & felt right at home surprisingly with it being a stick. Stiff clutch, yet still gives you enough feedback to know when its biting. Kind of surprised me because with the PDK transmission, you have to ease into the gas pedal to find the "bite" point I guess & it's tricky because the car will sometimes shudder a bit (as if stalling) & then just launch when you try to give it a little more throttle. The ones I've driven so far (par Boxster), I've yet to get the car to gently ease into motion; they always want to take off. So, it actually felt easier with the manual.
Afterwards, had a chance to drive '13 Boxster. It had the PDK tranny as well, but the throttle response was much easier without the car wanting to take off. I've never driven a previous Boxster before though, but I can't imagine just what kind of improvements were done because it's an amazing, little car.
Definitely made me want the Carrera S until I realized I can't afford a $57,000 car.
Old Oct 4, 2012 | 10:19 AM
  #2229
RPhilMan1's Avatar
Just put an order and deposit down for an ST - ST3 package with moonroof on Oxford White.
Old Oct 4, 2012 | 10:25 AM
  #2230
ttribe's Avatar
Old Oct 4, 2012 | 10:28 AM
  #2231
MarbleGT's Avatar
'08 MX5 GT 6spd.
My Mazda has crotch vents for both the driver and passenger.
Old Oct 4, 2012 | 10:37 AM
  #2232
RPhilMan1's Avatar
Old Oct 4, 2012 | 10:47 AM
  #2233
srika's Avatar
Moderator Alumnus
congrats!
Old Oct 4, 2012 | 10:56 AM
  #2234
The stock tune for the DISI motors are very conservative, but that's not the reason for being prone for ZZB. The stock tunes run rich to prevent knock but in turn create more fuel being dumped back into the valves. As well they're tuned with prevention in mind, so if some f*cktard puts 87 octane in it'll still run and not blow up. It'll run like crap but it will run. Also the stock spark plugs are basically at their heat range limit with the stock tune, so the very first thing you're supposed to do before tuning with an AP is get step colder plugs. The high flow fuel pump is also close to it's limit for holding fuel pressure with the stock tune/parts, so if you mod beyond the basic bolt-ons, such as installing a downpipe, mainfold, etc. you need to upgrade the fuel pump internals to be able to handle the increased fuel flow. I've decided to not go with a downpipe so I'm still using my stock internals but my logs show steady fuel pressure during WOT runs.
The real reason for ZZB though is the car being a relative performance bargain being put into the hands of kids just getting their license and thinking it's a race car. More often than not it's because of simple abuse, dropping the hammer on it constantly or boosting at too low RPMs causing all that excessive boost in the cylinders. There has been it happening (supposedly) to someone while just crusing at a steady speed out of boost, but I'm suspicious about that. But I personally run an off the shelf COBB tune simply because it's much better than the stock tune but still safe enough that I'm not pushing the limit since this is my daily driver. Some MS6/MS3 guys are tuning on E85 and making HUGE power. It's not uncommon to see 500+ hp out of the DISIs now, of course with big turbos, not stock units, but still that's insane for a sub-$30,000 car IMO.
Old Oct 4, 2012 | 11:18 AM
  #2235
Fahrvergnügen'd
Awesome! Congrats! When do you think it'll arrive?
Old Oct 4, 2012 | 11:22 AM
  #2236
StreetKA's Avatar
https://www.youtube.com/watch?v=MPTL...e_gdata_player
I wish they would being the astra to us as a buick
Old Oct 4, 2012 | 11:32 AM
  #2237
RPhilMan1's Avatar
Thanks! At the earliest, it could be 6 weeks. However, they do shut down for Thanksgiving. Thus, getting the order in now was crucial. I hope 6-8 weeks.
Old Oct 4, 2012 | 11:50 AM
  #2238
Fahrvergnügen'd
I was looking online and it doesn't seem that Ford is sending or dealers are ordering ST3s. You find that to be the case?
Old Oct 4, 2012 | 12:03 PM
  #2239
RPhilMan1's Avatar
ST3s were on material hold for a while due to the HID headlights. Ford confirmed that they started production on 10/1. They won't be hitting the dealers until the end of October.
My order will be the first ST3 that arrives at my dealer - needless to say my rep said they were anxious to see one!
On another note, I already ordered the SCT Custom Programmer and tune since it's on sale for the month of October. I'll also order the JBR rear motor mount to reduce wheel hop, the Steeda CAI when it is released, Steeda rear swaybar, and eventually a nice cat back exhaust. So it begins.
Old Oct 4, 2012 | 12:53 PM
  #2240
sweet!!! When can you expect it??
edit: just saw your post above
