The Ultimate Cooling Mod
Old Jun 16, 2010 | 03:37 PM
  #281
Inaccurate's Avatar
Originally Posted by Hi speed
How did you guys get the windshield wipers off? I am ready for the UCM, but can't get the wipers off.
They are usually stubborn to come off. Try some penetrating oil
Here is the section from the Service Manual. They make it sound so easy.
Old Jun 16, 2010 | 07:08 PM
  #282
I hate cars's Avatar
Originally Posted by Inaccurate
I got a new toy to take temps of my UCM.
Fluke 62 Mini Infrared Thermometer (click here)
I had the thermometer for a few months. So, I was able to get some temps of the UCM in cooler months and now these hotter days of early summer.
Consistently, my intake manifold is always approx 20* F hotter than the weather temps.
When the weather was 60* F, the manifold was 80*.
When the weather was 80* F, the manifold was 100*.
Today, the weather was 97* F.
My MID showed 98*. My wife’s car said 97*.
So, the intake manifold should be 118*. Let’s check…….
The sidewalk in the shade reads 103*.
The wood fence below
Shows a reading of 118*
And the intake manifold is reading
An average of 119*
This was taken immediately after I got home from my daily commute, which is a 45-60 minute commute of mixed city/hwy. These temps (119*) is representative of most things under the hood that are not in direct contact with the engine/trans cases.
Stay cool
Ok, got the results. I think your cooling mod helps... I forgot to mention the first time that I bypassed the TB coolant many years ago. Today was 86F according to the car. I had 40 minutes on the highway then 15 minutes around town including some drive-thru time.
Brake booster: 145F
Strut Bar 160
Plenum 148
TB 135
I should've gotten some extra data points. The fact that the brake booster was cooler than the strut bar surprised me. I know there's very, very little flow of vacuum through the booster and even then it's likely to be at least the 135 degrees of the TB.
Old Jun 16, 2010 | 08:44 PM
  #283
DC3328's Avatar
Your Garage
UCM reading was at 97 degrees ambient - Plenum 119
Stock reading was at 86 degrees ambient - Plenum 148
29 degrees cooler at a hotter temperature
Old Jun 16, 2010 | 10:45 PM
  #284
Inaccurate's Avatar
Thanks IHC
Conclusion
Stock
148* Plenum
86* Weather
62* Hotter than weather temp
UCM
119* Plenum
98* Weather
21* Hotter than weather temp
To put this in perspective, look at it this way. On a 90* day, the UCM engine bay is like a stock TL in 49* weather.
Old Jun 17, 2010 | 12:00 AM
  #285
phee's Avatar
I got the Shifts
u did this on your 2g?
Old Jun 17, 2010 | 12:04 AM
  #286
I think he was just comparing my numbers against Inaccurate's numbers. Thinking about being the first 2g to do this?
Old Jun 21, 2010 | 08:14 PM
  #287
Disbe's Avatar
By the way guys, If anyone needs replacement plastic cowls or if they want to buy a new one and cut on that one, you can get one from Tim for $128.01.
Old Jun 22, 2010 | 08:31 PM
  #288
Disbe's Avatar
Lose the fresh air intake for the climate control. I never use this feature. I always have my system on the recirculation. This feature would still be lost with a hacked cowl because there would be hot air from the engine compartment passing over the fresh air intake.
This is not entirely true. I am getting started on my mod which will basicaly be approx. a 10" cut out in the middle, and i will enclose it kind of like a pass through so air will not be able to get in the "gutter area" where the a/c recirculation intake is. I will work on it over the next week or 2 and post pics when i am done. I might actually do a 10" piece in the middle, then a 4" piece on each side.
Old Jun 22, 2010 | 08:54 PM
  #289
One other thing, and it might have been brought up earlier, but most cars on recirc still bring in a little fresh air to the cabin. I did something similar on my other car to help cool it and to relieve pressure at very high speeds but I left a strip near the cabin air intake. Maybe there's a way to box it in so that it's still functional?
Old Jun 22, 2010 | 11:19 PM
  #290
Disbe's Avatar
You could box it in, but you would have to drill holes or cut a section of the cowl out and maybe put in some mesh near the air intake as there is no area there to draw in air. The problem with that which i think is why Honda did not put a mesh area there in the first place is you may have a potential for water to somehow get into the air intake. I doubt it would happen but its possible. The way i am about to do it will prevent the need to do that. It will be the UCM without sacrificing the fresh air mode on A/C. Its really hard to explain how so i will just have to post pics when i am done.
Old Jun 23, 2010 | 06:49 AM
  #291
Inaccurate's Avatar
I agree with this assessment.
Disbe - Thank you for the contributions.
Old Jun 23, 2010 | 02:59 PM
  #292
Inaccurate's Avatar
Click pic to see larger size.
Above is the data logging for my IAT (Intake Air Temp Sensor) from this morning.
As the data logging begins, the is engine is cold. The weather temp was 76* F.
The first thing that I questioned when I starting logging any IAT readings is if the IAT sensor is accurate. Over night, I left my hood open in the garage. This morning, I used my infrared gun to take the temp of the manifold surrounding the IAT sensor. The infrared temp reading was 89.5* F. Upon starting the engine and the logging session, the ecu reported that the IAT was 90* F. So, the IAT sensor appears to be accurate.
Although the logging session shows an initial IAT temp of 90* F and the weather temp was 76* F, this is accurate. The 90* is from the residual heat in the engine from yesterday evening commute home.
The ambient temperature abruptly jumps from 76* F to 82* F. This is not a gradual warming up. I was surprised by this too. The 76* F is on a country road surrounded by open grass fields. The 82* F is on a very huge freeway surrounded with traffic and city buildings.
As this data logging reveals, my IAT are approximately 9* F higher than ambient while moving.
Showing math work -
85* - 76* = 9*
91* - 82* = 9*
Compare this to the temps that Opel sees with his supercharger. Opel stated that his IAT would reach 150-165 while sitting and will not drop once moving again. (click here for source)
Above is the data logging for the IAT (Intake Air Temp Sensor) from yesterday evening.
Speed ranged from approximately 4 mph to 12 mph...... for a whole hour. During this time of stop-n-go, the IAT sensor registered mainly between 109* F to 115*F. This is 24* F and 30* F higher than ambient, respectively.
Once my speed reached 60 mph, the IAT dropped to 93*, which is 8* F higher than ambient. I estimate that if I had been able to hit 60 mph immediately after the stop-n-go, that the IAT temp would had dropped from 115* to 93* within 5 or 6 minutes.
Old Jun 24, 2010 | 08:39 PM
  #293
Disbe's Avatar
So what you are saying is that with the UCM, you are getting cooler air into the intake. And as we know, cooler air is more dense.
Yea baby!
By the way, as i am modding my plastic cowls, they are completely removed. 2 days before i removed them i did a complete Seafoam job. I do not know if it is 1 or the other or a combination of the 2, but i have all the pep back in my step even as it was in the high 90's yesterday and mid 90's today. Thats all the proof i need!
Old Jun 24, 2010 | 10:08 PM
  #294
Showing math work -
85* - 76* = 9*
91* - 82* = 9*
That's very neat to see. The IAT inversely follows the vehicle speed nearly perfectly.
Please refresh my memory, your IAT is in the stock location and you do or don't have a CAI?
What relationship have you seen between the ignition timing and IAT? I'm trying to figure out if it's worth me trying to fool the ECU into retarding timing slightly by moving the sensor to a hotter location.
Old Jun 25, 2010 | 08:43 AM
  #295
Inaccurate's Avatar
The IAT Sensor is in the OEM location. Later, I do plan to relocate the IAT Sensor however. I do have a CAI, which is insulated. Plus many other cooling mods which are linked below.
Custom insulated AEM CAI (click here)
Outlaw Engineering Thermoblock Spacer (between runners and manifold) (click here)
Throttle body coolant bypass (click here)
Ultimate Cooling Mod (no click, you are there already)
With the data logging, I have not noticed a difference in timing as the IAT fluctuates. Because the ecu is constantly and wildly varying the timing with the slightest movement of the throttle, it is difficult to pick a single numeric value for the timing to make any comparisons.
Also, my IAT's stay in a fairly narrow operating range, which is approx 10* F above ambient. So, it is difficult for me to see any correlations of how the timing changes as a function of the IAT.
For my comparisons during R&D, I look to see what the timing is only under wot conditions. Even then, the timing varies with the RPM. But under heavy throttle, the timing is consistent and not wildly functioning. So, I can pick a numeric value for the timing only under wot (or, approx >60% Absolute Throttle Position) and as a function of RPM.
I have given up on trying to use data logging to quantify drivability, or even acceleration rates, under light throttle conditions. For the same reasons, it is too difficult to reliably pick numeric values (timing, acceleration rates) under light throttle. The best way by far, in my opinion and experiences, is to just experience and evaluate the drivability as I am driving under light throttle. For me, I can easily spot changes in drivability under light throttle than looking for it in the data logging.
But please don't misunderstand. The data logging is a great (invaluable) tool for quantifying performance under heavy throttle. Just not under light throttle.
Soon, I will be moving the IAT Sensor to the front lower grille. So, I probably will not have any insight into how elevated IAT temps affect the timing.
Old Jun 25, 2010 | 10:49 AM
  #296
Thank you. That makes it even more interesting with the CAI. It answers a question I've had for a long time. I've always wondered in a cramped engine bay like the TL's, how much heat is transferred to the intake charge via conduction. The only thing I have to wonder still is if the sensor is picking up some of the intake manifold's heat from the threads on the body of the sensor.
It's nice knowing the computer is constantly optimizing timing for the best mpg and power at part throttle. I remember on my old data logs if I didn't set the buffer to something readable, the numbers were literally a blur.
Old Jun 25, 2010 | 02:46 PM
  #297
Inaccurate's Avatar
I have been concerned with this issue for many years, especially with the UCM. I have felt that this is one of the prime benefits of the UCM.
Is the IAT sensor recording just the incoming air? Or, is the sensor recording how cool the incoming air is able to keep the sensor cool from heat migrating into the sensor from the manifold that the sensor is screwed into? I have always firmly believed, and still do firmly believe, that the sensor is influenced by heat which migrates into the probe from the manifold.
Slightly different topic - Below shows how quick I can make the IAT drop down. Below is an instance were I was able to quickly get up to speed after sitting in traffic. After sitting idle for 4 minutes, the IAT hit 117* F. Within approx 1-1/2 minutes at normal speeds, the IAT dropped back to normal, which is usually approx 10* F above ambient.
Old Jun 30, 2010 | 06:52 PM
  #298
Hi speed's Avatar
runnin a little boost
I am fully UCMed. I took the easy route and had someone else pull the wipers for me.
I will try to get some temp reading to compare to pre UCM readings.
The car does look ugly standing next to it but the cooling effect far out weighs the lack of cosmetic appeal. I'm still trying to figure out how I want to seal up the fresh air intake. Tape for now but I will trace it and see if Tap plastics can help me with a more durable solution.
Old Jul 1, 2010 | 01:26 PM
  #299
Inaccurate's Avatar
Hi Speed, "Way to go"
Don't worry too much about the unsightliness. Give it a few months and you won't even notice it anymore. I felt the same way at first. Now, I don't even notice the ugliness (seriously). But, the pull when I barely touch the pedal never goes unnoticed (seriously).
At first, I felt like you do about making a nice fiberglass or CF cover for the vent opening. That feeling too wore-away. I just taped over it with some thick aluminum tape. The aluminum tape has held-up great. I recommend trying the aluminum tape route until (or if) you get the nicer cover created.
The aluminum tape is purchased at Lowe's or Home Depot. It is in the Heating/Air conditioning section. Cut enough length to form a 1 inch overhang around the opening. Gentle push the overhang over the edges. Use a razor cutter to trim it closer to the edge of the opening as shown in the pics.
You be cool now dude. And for the being the first person to do a full-blown UCM.... This one is for you Hi Speed !
Old Jul 1, 2010 | 02:49 PM
  #300
InFaMouSLink's Avatar
Chapter Leader (NY/NJ)
Innacurate. I dont know which style of the UCM ima do yet but can you can take a picture of the pieces that people are cutting out at the bottom of the cowl that exposes the cabin filter since you still have one full intact. i dont know what it looks like from the bottom yet and i just wanted to see before i remove anything. Def not hardcore enough for the UCM. but i'd try the other styles. That exposed lower windshiel is a little too much for me lol
Old Jul 1, 2010 | 10:17 PM
  #301
Inaccurate's Avatar
Originally Posted by InFaMouSLink
can you can take a picture of the pieces that people are cutting out at the bottom of the cowl that exposes the cabin filter.... what it looks like from the bottoml
Old Jul 1, 2010 | 10:43 PM
  #302
Thanks inaccurate. Can i get one more of the back of the center piece.
Old Jul 1, 2010 | 10:52 PM
  #303
is this cutting needed??
Old Jul 1, 2010 | 10:54 PM
  #304
The whole thing is coming off tomorrow until i figure out which style i am going to do.
Old Jul 1, 2010 | 11:20 PM
  #305
Inaccurate's Avatar
Yes. This cutting in one of the most important. This is the only primary route for the air to exit.
With the way people have been doing the UCM with the cowling still present, the air exits in two steps.
First step is for the air to enter into the Grand Canyon via the cutting in the above pic, highlighted with red box outline.
Second step is for the air to travel from the Grand Canyon to the outside. This steps is executed with cutting in this area shown in pic below.
Old Jul 3, 2010 | 02:26 PM
  #306
Took everything off (Full UCM). i am gonna start taking temp readings and see what happens. NYC stop and go really really sucks so we feel it over here. Removal took approx 5 minutes to do. i already took readings earlier and without the UCM the rear part of the IM was 144 lower was 156. After a 4 minute drive (highway) 122 rear 116 front, 88 outside. One thing i noticed was the IM "view port" on the front was 156 and the rear 133. ima get the p2r IM thermo spacer for that. The TB was 126. the CAI pipe, top side 101, side near fender 130. I have an OBD2 reader that i can use an a data logger so i will also start doing that. Innacurate- Thanks for the "PUSH" so start doing all this.
Old Jul 4, 2010 | 08:02 AM
  #307
Esper.ice's Avatar
I finished forming and installing my variant of the UCM but ran into a problem. My wiper motors appear to have died. I'm about to check through the related fuses to see if that's the issue but I think its unlikely since my side mirrors have full functionality. I'll upload pics of my mod soon.
Old Jul 4, 2010 | 07:06 PM
  #308
Inaccurate's Avatar
This thread would lose a lot of its meaning without the pics. So, I will copy and host (at my hosting service) a duplicate set of the pics in this thread.
In this way, this thread can be more meaningful for a longer period of time with the backup set of pics. I hate it when I find an interesting forum thread that is several years old, and the pics are no longer available like this
Old Jul 4, 2010 | 07:07 PM
  #309
Inaccurate's Avatar
Below are the pics from Post #221 by "HQTL6SPD" on Page 6.
Old Jul 4, 2010 | 07:08 PM
  #310
Inaccurate's Avatar
Below are the pics from Post #234 by "Liquidflex81" on Page 6.
Old Jul 4, 2010 | 07:09 PM
  #311
Inaccurate's Avatar
Below are the pics from Post #244 by "t0talacuratl" on Page 7.
Old Jul 4, 2010 | 07:10 PM
  #312
Inaccurate's Avatar
Below are the pics from Post #252 by "Sezniko" on Page 7.
Old Jul 4, 2010 | 07:12 PM
  #313
Inaccurate's Avatar
Below are the pics from Post #258 by "libert69" on Page 7.
Old Jul 4, 2010 | 07:18 PM
  #314
Inaccurate's Avatar
Below are the pics from Post #276 by "7.5AV6MT" on Page 7.
Old Jul 4, 2010 | 07:24 PM
  #315
Inaccurate's Avatar
Below is the pic from Post #303 by "InFaMouSLink" on Page 8. The red box illustrates where the cowling needs to be cut.
Old Jul 5, 2010 | 05:35 AM
  #316
jchcmax's Avatar
Registered VTEC junkie
What tools do you guys use to cut the vents?
Old Jul 5, 2010 | 12:12 PM
  #317
ABP_04TL's Avatar
6-SPEED LOVER
^ Dremel!!
Old Jul 5, 2010 | 02:43 PM
  #318
Inaccurate's Avatar
The following is not high tech, but has worked wonderfully for me in the past for similar type of cutting.
Make sure that the lady of the kitchen is elsewhere. In the kitchen drawer, find an old butter knife. Find one that is preferably all metal with a metal handle.
Go outside and fire-up the propane grill, or other source of an open flame. Place the blade of the butter knife into the open flame. Allow the blade to get moderately hot.
Push the hot blade thru the plastic, and then push the blade along the length to be cut. I am usually able to cut 3 or 4 inches at a time before needing to heat the blade again. Just put the blade over the open flame again for about 20 seconds and then cut another few inches.
The butter knife is not really “cutting” the plastic. The blade is melting it’s way thru the material. This has always worked great for me. It cuts the plastic “like a hot knife through butter.”
Safety –
1) Do not breath the smoke coming from the workpiece being melted.
2) Do not do this indoors. The smell from the burnt plastic is strong and will linger indoors.
3) Never, ever allow the lady-of-the-house to see that particular butter knife again. Hide it somewhere in the garage.
Old Jul 6, 2010 | 07:54 PM
  #319
davewhodavedunn's Avatar
How does drilling holes in the wiper cowling work for ppl who live in canada where snow ice slush build up in there?
Also what about the 2 lower grille air diverters, removing must it must cause problems?
Old Jul 6, 2010 | 08:28 PM
  #320
ChucksCL-S's Avatar
I would think that is not a concern to Inaccurate as he started this thread and is from Houston, Texas. You are from Canada where it is cooler and this mod isn't needed in the first place, right?
