Turbo Kit for Acura TL '04-'08
#5441
runnin a little boost
I am running the Hankook ventus V12 evo's and they hold pretty well even with heavy boost in 3rd-4th gear. You are running 100+ whp more than me, but these tires have tollerated some pretty heavy acceleration. Maybe keep wot to 5 gear, I have been getting some crazy acceleration from 5th.
#5442
I wish I could help you with a good tire for a FWD car where you need to maintain a decent sidewall stiffness but I've only dealt with slicks and FWD personally. Drag Radials supposedly handle pretty well on FWD but you'll have to use your foot as the fuse if you feel like they're hooking too well. Are they breaking free badly at triple digit speeds or is it just enough that it makes the car spaz out?
Even though I hated to see it go, it looks like getting rid of the auto was a good choice, huh?
#5443
That is the nice part of high compression, spool in almost instant. I am able to keep it fun and safe on the street while unleashing the monster when space allows. The car is extreamly civilized and easy to drive as a DD, much more quiet that the SC with the same exhaust and a lot of low rpm TQ. The car is easier to drive (except for the 6 puck disc ) than stock because of the extra power everywhere in the rpm band. I think the more gradual transition into boost also allows more timing to be run since the car doesn't just slam into boost and allows the ecu to better manage knock.
I will most likely not go past 450 whp even in a race tune, because I just don't think the transmission will handle it well, but with a slowed boost transition 500 whp will should be very manageable ( traction wise ) as long as you rarely use it and only when space and conditions allow. I just think asking more than double HP/TQ from a transmission made for fuel economy is asking for problem. If you are not hard launching or shifting the tranny and staying somewhat smooth with power application 450 whp seems fine to me.
Has anyone really destroyed one of the 6mts besides the Accord guy (no disrespect, I can never remember his username).
After reading your post, I bet you would love a twin turbo setup. ALL ELSE BEING EQUAL which it rarely is, the twin setup will spool slightly slower than a larger single but it will be more linear. Although nowadays with all of the new turbo technology most of the old rules are being rewritten.
#5444
The 6162 turbo is very nicely matched to the j32. The feature I am really liking lately is the knock box and indicator led. Even durring the day I can see the led flash against the gauge face and it makes pushing the car hard much safe for the engine since you can keep it from knocking. It has also allowed me to see the effects of a race gas mix and changes in methanol jet size. The led is just bright enough for the driver to see without having the passenger notice. I have taken a few of my Ford enthusiast buddy's out and they are looking for a warning light to take away from how good it runs. None have noticed the led blinking, but we were picking up speed pretty fast any time the knock led is flashing.
#5446
shit bert.. I think your speedo is going to snap off soon. 50-90 was a blink.
![what](https://acurazine.com/forums/images/smilies/what.gif)
#5447
takin care of Business in
Received 4,732 Likes
but if you see again from the 5 second mark, he goes from 60-85-ish in a flash and then takes the foot off the gas and drop down to 75-ish in a flash as well....the speedo was looking more like a tacho LOL
#5448
Awesome vid, Bert, looks like you're ready to play with the big boys. Your car goes from 100-140 quicker than mine goes from 0-40 lol.
#5449
After watching it closer, you can see the car shaking from the wheel spin in what was that, 3rd gear? Looks like it's still on the verge of spinning in 4th. I think you can even hear a little tire squealing in 3rd or maybe it was Bert
That boost comes in quick, what a great street car!
![Chuckle](https://acurazine.com/forums/images/smilies/chuckle.gif)
#5450
holy shit !!!! i want
#5451
That's pretty badass. It spins, hits the limiter and as he shifts the tires catch traction and the speedo drops back to actual vehicle speed. That's why I've always said, 500hp is the range where the car will be having traction issues at any legal speed.
#5452
^^^ yup....
but that video is pretty bad ass....i wish he can figure out the perfect tire size/type/brand coz if not for the spinning, he would have hit that 145mph mark wayyy quicker....
#5453
https://acurazine.com/forums/showthr...09#post8687209
#5454
Damn bert ... that's wicked. Are you WOT in between shifts? Spool is a function of load right, so are you able to modulate throttle so avoid wheel hop or does it happen too fast? I'm wondering if we can retard peak boost/TQ to avoid wheel hop automatically under normal dry conditions.
#5455
Turns out I'm 10.5:1 with CP pistons, which should help with off boost power and spool as pointed out. Bert's at 9. Will 10.5:1 help offset the transient response hit from the 200 cell cat? Also, Rodney's using .82AR off the 6262.
#5456
![](http://s15.postimage.org/o18s0rrm3/Limit_peak_TQ.jpg)
#5458
Either way will get the job done and a lot of it is personal preference but I'm very set in my ways when it comes to pump gas street cars. Low compression is not the best for every car but it is for the majority.
#5459
Not sure if this is possible or desirable, but instead of lowering the whole band, is it possible to lop the peak portion off TQ to eliminate the wheel hop at WOT, while not otherwise affecting the curve? Does ECU know what gear you're in, e.g. so you could lop this off 3rd, but not 5th?
bTwix (06-28-2012)
#5460
Do you have a pic of your knock LED? I'm thinking of putting knock led next to the radar/laser led to the left of the clock. Does knock have an audible alert as well? I did a 2.1 audio setup and radar speaker where center used to be, so could put a piezo buzzer in there for knock as well. How often does knock led come on? Maybe a piezo buzzer would be too annoying.
Here are some pics of where I mounted the knock led. Knock led is red on the right and the meth injection led is green on the left.
![Name: 06TLknockindicatormountingpoint.jpg
Size: 154.1 KB](https://acurazine.com/forums/attachments/3g-tl-performance-parts-modifications-112/50612d1501288069-turbo-kit-acura-tl-04-08-06tlknockindicatormountingpoint.jpg)
![Name: 06TLknockindicatorlight.jpg
Size: 118.1 KB](https://acurazine.com/forums/attachments/3g-tl-performance-parts-modifications-112/50613d1501288069-turbo-kit-acura-tl-04-08-06tlknockindicatorlight.jpg)
As far as the hi flow cat, I don't see what you will get out of it. Yes the 10.5 to 1 comp will help keep the spool with a restriction like the cat, but the smell is not bad (given I spend much of my free time working on vintage mustangs with no cats ) and the car will not pass smog with the cat. As you can see from Berts video, unrestricted the car accelerates very well, with a cat no one knows since it hasn't been tried. Plus with all the extra fuel going into the engine, that cat can't last very long
#5461
One thing to keep in mind is the car should be tuned for zero knock at all times under boost and even more importantly so on a stock bottom end and/or at higher hp levels. If there is some knock, it will eventually cause an engine failure. If it knocks regularly, it needs more octane or less boost.
#5462
![Racing](https://acurazine.com/forums/images/smilies/racing.gif)
![Popcorn](https://acurazine.com/forums/images/smilies/popcorn.gif)
#5463
I'm in the city a lot and it with wife in the car a lot, need something that at least smells stock. If it's a problem, I have this hanging out.
![](http://s14.postimage.org/505jgtsip/IMG_0520.jpg)
#5464
18psi
without dumping major money into the auto to try and make it handle the power, the 6spd is definitely the way to go. Although, driving this thing in traffic or even light to light sucks sometimes. The clutch is definitely not street friendly. But, if you want the power, there has to be some tradeoffs
vsa is permanently disabled on my car
if you feather the throttle here and there it will grab, but my tires arent the greatest either
you can do boost by gear with the ms3.
bTwix (06-30-2012)
#5465
That gives me hope since you're running Invos. There are definitely better "regular" summer tires out there. The NT05 is definitely at the top of the list. Treadwear is 200 fwiw. No matter what you put on there, they're going to spin, short of a drag radial.
I understand needing a street tire with good manners and wear but a drag radial is still a very street friendly tire. The sidewalls are reasonably stiff and depending on which drag radial, treadwear is usually from 0-100. My experience on them has been about 10-15,000 miles but that's also heating them up on occasion. I could do a 50-130mph pull and pull over and they're all roughed up, the rubber is really soft. If you need a longer lasting tire then they're not for you but just in case you weren't considering them due to other reasons, you might be surprised at how good they drive on your daily commute. Traction between the best summer tire on the market and these is not in the same league. Good luck with your search.
#5466
Sounds like it *should* never happen. Perhaps I should put a piezo on there, with a kill switch. Would only be a few mA draw. Then I could keep my eyes focused on the road.
Nice. Must be very easy to see. I'm going for the completely stealth look, so can't have anything visible surface mounted like that.
FWIW, I have a piezio element for daily driving when I don't have the laptop on it. It's loud and scary but it makes you lift quickly. My tune is ultra conservative but you never know when a fuel pump might start failing or the meth doesn't kick in, etc.
#5468
libert69 (06-29-2012)
#5472
18psi
i made my own. it attaches to the passenger head rest and basically sits eye level over the center console arm rest
yes, i took the check valve out. i went back and forth debating if i should and it boiled down to this (after talking to a 2 people that have had the twin disk for a while)...
heres their words
TLDREAM (N/A j35 swapped prelude)
I love the clutch. On my prelude it kind of killed the streetability of the car. I had the check valve removed at first, and with solid mounts, it made it a little rough to drive in stop and go traffic.
I just put a new slave cylinder on the car with the check valve still in it, and it returned much of the driveability. I would leave the checkvalve in. With the TL's built in dampaner in the master cylinder, and the checkvavle intact, it will make for a much less harsh engagement. Shouldnt be to bad for stop and go.
BMEYER (built j36 motor w/turbo)
I could see Rich's (TLDream) view about the check valve, but keep in mind that he's not pushing the sort of numbers that we are. He can afford to deal with a little bit of slippage because it's an all around stronger clutch than the stock setup. In our case, if we try to apply the power before the clutch is fully hooked up, we're going to burn up parts like crazy. That's the last thing
I want to do with a $2k clutch and flywheel.
so after that, i decided to have no check valve from the beginning. it is a little rough to drive this thing in stop and go but i guess thats another trade off if you want big power.
heres their words
#5473
18psi
so heres little problem I ran into. ill make it real easy with pics.
![](http://img151.imageshack.us/img151/7167/turbos.jpg)
I noticed on the cast iron portion of the center housing (#5), there is oil leaking from where I made that red circle. There is a bolt located there. There are 4 total bolts. Only the bottom 2 are leaking. I saw this a little while ago and figure it was the drain fittings. I cleaned the area real good with brake cleaner, went for a drive and found it like this when I came back. The drain fittings are not the problem.
im running a -3an feed line and -10 drain line. i, not running a restrictor either. i really dont think im over oiling the turbo and it cant drain fast enough. this leak happened recently.
as you can see here, the 2 top bolts are dry.
![](http://img836.imageshack.us/img836/2249/topboltright.jpg)
![](http://img195.imageshack.us/img195/1278/topboltleft.jpg)
the drain plug is dry also
![](http://img221.imageshack.us/img221/5057/drainplug.jpg)
heres the left bottom bolt. you can see how its wet around the bolt and leaking downward. you can tell its leaking from both sides b/c the wet mark thats closer to the compressor housing is higher then the actual bolt
![](http://img849.imageshack.us/img849/2750/bottomboltleft.jpg)
heres the whole right side. dry on top, wet on bottom
![](http://img856.imageshack.us/img856/4927/rightsidea.jpg)
closeups of the right side lower bolt and drain flange. it doesnt appear to be leaking from the drain gasket
![](http://img849.imageshack.us/img849/1949/bottomboltright.jpg)
![](http://img62.imageshack.us/img62/2104/bottomboltright2.jpg)
![](http://img821.imageshack.us/img821/3876/bottomboltright3.jpg)
is there a internal gasket that could be leaking? are those bolts supposed to have teflon tape on them?
I was planning on pulling the turbo off soon to have the housing polished so id like to know what im getting myself into
#5474
That's an oddball leak, I've never had one of mine leak from there but just about everywhere else though.
I have to assume the drain is clear and free...
The center section obviously has oil in it but with the ball bearing center, not a whole lot of oil. You can make sure there's a restrictor in the oil feed line, usually right at the turbo which is necessary with the ball bearing turbos.
Can you get a wrench on the bolts to make sure they're tight?
I believe there is a metal gasket between the center and the backing plate. You may want to pull an intercooler hose and make sure oil is not getting into the intake tract. If it's not and the leak is isolated right there, it's not nearly as bad. Teflon on the threads should do the job but if you have a blanket on the turbo, it could be destroying the teflon from the heat.
The drain size with the 90 is a little concerning. It's not absolutely too small, especially for a ball bearing turbo that uses less oil but the oil comes out of there in a froth and in theory it should be as large as the initial opening all the way to the pan or where ever it dumps. The dynamic seals along with the metal gaskets aren't made to seal against any real oil pressure and there will be leakage.
Unrelated, when you pull the turbo, replace the drain gasket, between the billet piece and the center section with a copper one. The fiber ones always leak over time and copper is reusable. Maybe it's already copper, hard to see.
The metal gaskets usually aren't serviceable by "us" depending on the turbo and if the compressor wheel has to come off. You'll probably be able to fix the problem by either tightening the bolts or with teflon which should hold up.
#5476
That's what I'm looking for. Do you recommend a kill switch for the buzzer, or if you get a bad tank of gas can you just baby it until you can find some toluene or xylene to mix in?
#5477
Looks like we'll be tuning for 92 octane: http://www.6speedonline.com/forums/n...available.html
#5478
However sounds like ball bearing option spools up a little quicker, so may opt for that instead. Bert, did you upgrade to the ceramic ball bearing version? Is yours air cooled or water cooled? Sounds like only the ceramic ball bearing version is air cooled.
#5479
18psi
![Wink](https://acurazine.com/forums/images/icons/icon12.gif)
ok let me clear this up. I was misinformed. This is a 6162 journal.
IHC,
I have not pulled the drain yet to check for a clog. will do that next
I am not running a restrictor. Precision says their journal turbos do not need restrictors. However, Ive read on a few honda forums that honda motors typically have much higher oil pressure then other manufacturers. Most guys running turbos on honda motors are using a .065 restrictor. when i first had the turbo, i was using a restrictor...now im not. rodney says my kit was the only one to ever use a restrictor. (we only ran one bc the guy who owned the first dyno shop we ever went to recommended one)
i put a wrench on those 4 bolts on the center housing and i was able to tighten each bolt about 3/4 to a full turn. But, the bolts were not necessarily getting much tighter. Only a little more snug. i did not want to snap a bolt or strip the threads so i stopped.
are those 4 bolts supposed to have teflon on them?
i do have a blanket on the turbo
i pulled the intercooler pipe that comes right off the turbo. there is a coupler on the bottom of that pipe that sits parallel to the ground. ithe pipes and coupler are completely dry. no oil in the pipes.
i was looking at that 90 drain plug. it doesnt really make sense to me why its even there. i think at the very least there should be a 45 there and not a 90. on the other hand, i dont even think i need a angled fitting. it looks like the braided line would fit right into the drain flange and provide a steeper angle to drain faster. make sense? or is there a legit purpose for the angled fitting?
dont forget that ive been running that 90 fitting since the beginning and this is the first time i have a leak. im sure hi speed and KN are running the exact same fitting and they are not leaking
IHC,
