Navigation Hack Guide: Welcome Screen Mod, Trip Computer, OK Button Nag Removal
#842
Black DVD Version 2.50 For 2002 TL-S
I know this is changing the subject but I have a 2002 TL-S and was wondering if someone had a hack for version 2.50 Black DVD, and instructions on how to down load and then install into the nav system. Any information. I currently have the original which I think is version 2.05.
Thanks.
Thanks.
#844
Originally Posted by xen-cuts
v3.7. HELP!
For some reason the DVD that I get for the Accord has features that the Acura DVDs don't have.
#846
Originally Posted by KN_TL
If anyone is still interested, AD has posted the ok nag and HMImanager hack for version 3.70.
I tried it and it works like a charm.
#850
Slow Paper> No Paper
Man I'm having a hell of a time trying to do the Navi hack for the trip computer. I can't seem to use (dos) every time I try it I get this: 'dumpnavi' is not recognized as an internal or external program or batch file.
I have download everything that I need for the mod but I have been having no luck for the past week now. I have done the wallpaper Mod but this one is kicking my ass. If anyone has an Idea of what I'm doing wrong please help! I am using the 3.50 disk in an 05 TL.
#853
Thanks! Can't wait to get rid of the nag.
#854
Does anyone have the Modified Bin Files for the ok nag and trip computer hack for the 3.50 disk? If so please let me get them from you. I'm freakin dieing over here. I have been on this damn cpu for 13 hrs trying to figure this shit out and I just can't. Please help.
#856
Originally Posted by zoostation
I'm not getting along well with the command prompt. There are several people with V3.30F that are having problems. Any chance of someone loading the files to a server so we can pull them directly to a CD?
Thanks!
Thanks!
Thanks again!
#857
8. Use the dumpnavi tool to extract the files on the
BIN file that was on your car, ex:
dumpnavi BNHN404A.BIN extract
okay so when i do that why do i keep getting a
Unable to open bootloader file
Bootloader file is the BN2HHMLD.BIN one right?
I have a 3.30D 04 TL
Im using DumpNavi by Bysin
http://www.linuxkiddies.com/projects/navi/
Help
Help
#858
Also, Can any of the 3 download extraction programs be used?
DumpNAVI - Graphical
DumpNAVI - Console
DumpNAVI - Console (source)
DumpNAVI - Console
#860
just completed my 3.30 orange disk hack and everthing worked perfectly. I just followed the instructions and all I included on the burned disk was 2 bin files not all like the instructions indicated.
Anyway it works great thanks for all the hard work putting this together!
#861
#862
Follow the instructions below exactly....
USE CEBIN!!!!
Get BN2HHMLD.BIN and BN2HH12C.BIN from your Orange 3.30 CD.
put CEBin, BN2HH12C.BIN, BN2HHMLD.BIN (back.bmp, navi.exe, hmimanager.exe) into a directory and unzip the zip files I used C:\TL for my directory.
Now go to Start-->Run and type in notepad.exe this will bring up notepad now copy the following into notepad
image BN2HH12C.BIN
replaceFile navi.exe C:\TL\Navi.exe
replaceFile Back.bmp C:\TL\Back.bmp
replaceFile HMIManager.exe C:\TL\HMIManager.exe
do a SAVE AS and give the file a name. (by default it will assign the file a .txt extension so don't name it TL.TXT or you will TL.TXT.TXT.
now go Start-->Run and type in cmd
this will bring up a DOS Prompt navigate to the TL directory by going to the root of C:\ and type the following
cd TL
now that you are in the TL Directory you will type the following which will run CEBin and change the bin files to the changes you want.
cebin yourfile.txt -s tempfile.bin
now rename tempfile.bin to BN2HH12C.bin
burn a disc with your now change BN2HHMLD.BIN and BN2HH12C.BIN.
Now to load the files into the NAVI unit with the instructions on the first page of this thread and your done.
USE CEBIN!!!!
image BN2HH12C.BIN
cd TL
#864
USE CEBIN!!!!
image BN2HH12C.BIN
cd TL
USE CEBIN!!!!
image BN2HH12C.BIN
cd TL
#866
yourfile.txt can be TL.txt or whatever you want to name it.
OK...... I'm getting an error unable to find Navi.exe. Where does this file come from? Let's say I need all mods (ok bypass, temp control, image update and trip update). Can you give me all setps to do this in sequence? You are saying use Cebin but how do I generate or pull Navi.exe from the bin file?
Explain this like you're talking to a 3 year old....because when it comes to computers....you are.
I'm able to follow your steps....I'm just not sure what steps I need from page1.
Thanks!
#867
so download the following items from the first page of the thread
cebin.zip
navi-console.zip
navi.zip
put them all in your C:\TL folder and unzip them
now copy BN2HHMLD.BIN and BN2HH12C.BIN from your OEM Navi DVD into the C:\TL directory
go into a command prompt navigate to your C:\TL directory then run the command below:
the txt file you created listed the following items if not copy directly from here:
image BN2HH12C.BIN
make sure you have all items listed below in C:\TL
Navi.exe
HMIManager.exe
BN2HH12C.BIN
now if your successful, you will have a file named tempfile.bin now move BN2HH12C.BIN somewhere else and rename tempfile.bin to BN2HH12C.BIN.
burn a CD with
BN2HHMLD.BIN and BN2HH12C.BIN(the one you just made and named BN2HH12C.BIN)
then follow the instructions on the first page to load your now hacked cd into the Navigation Memory etc.
cebin.zip
navi-console.zip
navi.zip
image BN2HH12C.BIN
Navi.exe
HMIManager.exe
BN2HH12C.BIN
burn a CD with
#869
yeah the navigation loading piece i believe is always going to be there, unless someone else on here knows how to remove it but from what I read it has to remain. as far as the upper vents I just didn't worry about it. I mostly just wanted the OK button gone and the splash screen changed.
#870
NBP+Wash=Full Time Job!
Originally Posted by Porkipine
This is for the v4.55A navigation disk. I assume you know some basics about using the command prompt. I can try to write a step by step version with pictures if someone really needs it.
What you will need:
V4.55A navi DVD
1 blank CD
Bysin (program from first post)
8to16 (program taken from http://www.guicide.com/cars/2006civic/nav/hacks/)
A 480x234 picture saved in 256 bmp
Go into your C: and create two folders: ToBurn and NaviHack. Search through your Navi DVD for the following files(make sure you are copying the one off of the DVD):
07Touch.bin
07Touch2.bin
A0000_00.MNG
DCA0.reg
PRG_INFO.MNG
UPDATE_APL
Copy it into the ToBurn folder. Next also copy the “07Touch2.bin” file into the NaviHack folder. From the Bysin program, copy "Bysin.exe" and "CECompressv4.dll" file both under "release" into the NaviHack folder. Then go to the 8to16 program and copy the “8to16.exe" file into the NaviHack folder too.
Take the picture you want to use, rename it as “replace” (should already be in bmp format) and copy it into the NaviHack folder. Go ahead and open your command prompt (Start -> run ->type “cmd”) and get into the NaviHack folder (typing “cd\NaviHack” should work). Now type in these lines one by one. It should take maybe 1 minute between each command. Be patient.
Now to check if the image in the bin file is replaced, type the following:
A folder named 07Touch2 inside the NaviHack folder should appear. Drag the picture inside (should be named Opening1.bmp) the 07Touch2 folder into IE and it should be the picture you want to use. If that’s right, copy the 07Touch2.bin file from NaviHack into the ToBurn folder to replace the old 07Touch2.bin file.
Now burn all the files (6 files total) onto a CD. Just a regular CD will work. Now go ahead and follow the steps to load it onto your navi from the first post. Good luck. Let me know how it goes.
What you will need:
V4.55A navi DVD
1 blank CD
07Touch.bin
07Touch2.bin
A0000_00.MNG
DCA0.reg
PRG_INFO.MNG
UPDATE_APL
Example: 07Touch2.bin would need to be 08Touch2.bin..Have Fun!!
P.S. Thank you Porkipine
#871
Originally Posted by kennyc
There are a lot of reading one got to go through to find the answer on how to hack the navi. I want to combine all the thread and condense it so one can find how to do it by reading this thread. This guide is mainly written for people with the 3.40c and 3.50 orange navigation disks who also are familiar with a computer. UPDATE: There is a slight difference for 3.60 as noted in this thread. If you don't know what a command prompt is please do not try to do the following yourself. Talk to your kids or your neighbor's kids and see if they can help you!
Another thing, I am not responsible if you blow your navigation system up yourself. By using this article you take full responsibility of your own action.
Tools that you might need
DumpNavi - DumpNAVI by bysin, it extracts and replaces files within BIN file.
Improved DumpNavi - Works with 4.xx NAVI software.
CEBin - CEBin, more feature and less limitation, but harder to use.
Navi-GUI - GUI front end for the DumpNAVI program.
TLPatch401a.com - AngryDad's trip computer patch.
HMIManager.zip - Kenny's modified trip computer for v3.40c (password: kennyc)
NaviOK401a.com - AD's OK button patch for Navi 3.50
navi.zip - Kenny's modified OK executable for Navi 3.40c (password: kennyc)
How do I change my wallpaper??
Things that you need
Your favorite photo editing software - I like photoshop
DumpNAVI program
A picture you like
Your navigation DVD.
Instruction
1. Create your wallpaper. Not artistic? Too lazy? Try here
2. Resize/crop the wallpaper down to 380x234 with 256 colors
3. Resize the wallpaper to 480x234 so it will "stretch" the wallpaper horizontally.
4. Save it as "Back.bmp" - make sure your photo editing software converts the picture from RGB to Indexed (img->mode->indexed color in photoshop) and enter 173 in the colors field. Also make sure it is saved as 8-bit bitmap. So your wallpaper will be the same size as the original. (113,068 bytes, 114688 bytes on disk) Make sure your wallpaper is the same size or smaller than those numbers, or else it will not work!
5. Copy 2 files off your orange navigation disk. (IMPORTANT!!! if you did the wallpaper and/or the trip computer already. You want to use your modified BNHH401A.BIN instead of the one copied off the navigation dvd)
7. Go to a command prompt by start-> run, and type in "cmd" and press enter.
8. Say I put all three files in the "navi" folder on the c drive, I will type "c:" (without the prompt) and press enter. Then type in "cd navi" and press enter.
9. Now you should see "C:\NAVI>" Now type "dumpnavi BNHH401A.BIN update Back.bmp" and press enter. The pc will prompt you when it's done.
10. The new wallpaper is now in the bin file.
If you want to add AngryDad's trip computer please go to the next section, if wallpaper is all you want find the section named "How to load my custom bin back into the car?"
How do I load AngryDad's trip computer mod??
Your navigation DVD
DumpNavi Program
AngryDad's trip computer patch (for v3.50)
or
Kennyc's modified version (for v3.40c)
Instruction
For version 3.50:
1. Download AngryDad's trip computer patch.
2. Copy two files off your orange navigation disk. (IMPORTANT!!! if you did the wallpaper and/or the trip computer already. You want to use your modified BNHH401A.BIN instead of the one copied off the navigation dvd)
3. Go to a command prompt and change into that directory.
4. Type "dumpnavi BNHH401A.BIN extract" This will extract everything within that BIN file into a folder named BNHH401A
5. Find a file named HMIManager.exe in that folder and copy it out to the same folder as AD's TC patch.
6. Run the patch.
7. After patching, type "dumpnavi BNHH401A.BIN update HMIManager.exe" This will load your patched trip manager back into the bin.
For version 3.40c:
I trimmed the HMIManager.exe for v3.50 so it will fit in the v3.40c's bin.
1. Download my navi.zip from the link above
2. Extract the HMIManager.exe into the same directory as your dumpnavi program (password: kennyc)
3. Copy two files off your orange navigation disk. (IMPORTANT!!! if you did the wallpaper and/or the trip computer already. You want to use your modified BNHH401A.BIN instead of the one copied off the navigation dvd)
4. Type "dumpnavi BNHH401A.BIN update HMIManager.exe" This will load the modified v3.50 trip computer into v3.40c Bin.
A note from AngryDad:
When you do the trip computer patch, you might as well benefit from replacing diag.exe from the 401a bin with diag.exe from the 404a bin. It enables trip computer screen in diag menu (where you can log data to the card if interested). Holding "Menu" for 5 sec on that screen, gets you to "Trip Computer calibration" menu.
How do I load AngryDad's OK button crack??*
Your navigation DVD
DumpNavi Program
AD's OK button patch (for v3.50)
or
Kennyc's modified OK button executable (for v3.40c)
*See updated notes below
Instruction
For version 3.50:
1. Download AngryDad's OK button patch.
5. Find a file named navi.exe in that folder and copy it out to the same folder as AD's OK patch.
6. Run the patch.
7. After patching, type "dumpnavi BNHH401A.BIN update navi.exe" This will load your patched navi.exe into the bin.
For version 3.40c:
As with the trip computer, I trimmed the navi.exe for v3.50 so it will fit in the v3.40c's bin.
1. Download my ok button excutable from the link above
2. Extract the navi.exe into the same directory as your dumpnavi program (password: kennyc)
4. Type "dumpnavi BNHH401A.BIN update navi.exe" This will load the modified v3.50 navi.exe into v3.40c Bin.
1. Burn your custom bin (BNHH401a.BIN) and the loader (BN2HHMLD.BIN) onto a blank CD.
2. Go to your car.
3. Turn your car's ignition to ACC
4. Open the trunk and pop out the NAVI disk (if it's in there)
5. Insert your newly burned CD.
6. Go back to the driver seat, the display will show some dvd read error, now press and hold "GUIDE" "MENU" and "CANCEL" for approx 5 seconds to bring up the diagnostic menu.
7. Wait another 5 seconds to let it load up completely. Press "version" button on the screen
8. Press "LOAD DISC" to load your custom bin into the navigation.
9. Wait until it's completely done and it will then display another error message about can't read the navi dvd, now take out your bin CD and insert your Navigation disc and you are done!
Troubleshooting and Tips
I found the navigation system is pretty tolerant of mistakes. If you screw something up (and you probably will) All you need to do is reinsert your original navi dvd back into the drive, press and hold "GUIDE" "MENU" and "CANCEL" for 5 seconds and it will take you to the diagnostic menu EVEN if your navigation system is in a loop! Once you're in the diagnostic menu just go into "version" and press "load disc" and everything will be back to factory state.
This will not erase your phone pairing, phone books, nor presets.
One last tip,
Make sure you keep a backup copy of your custom bin file. That file contains your wall paper, trip computer and the ok button mod. If you lose it you would need to redo everything again.
Thanks goes out to everyone, especially to AngryDad and datmrman for their hardwork and write ups. You guys are what make this board better than "the other board"
edit by datmrman
Great job summarizing everything kennyc! I guess it is time for my summarized hack thread to retire.
That thread is now locked. For future reference, the thread is here: Hack Your Navi Summarized! (Change pics and remove nag screen)
UPDATED NOTES:
How to change the map background color.
A couple of members have found ways to circumvent the two initials "AD" from appearing on the navi.exe mentioned above. Here are their threads:Click Here for Minor Differences with 3.60
'07 TL Instructions on Post #250
Canadian '07 TL Splash Screen Notes on Post #625
Revision History
2006.10.03 Updated the post per kennyc's requests
2006.10.12 Added link on how to change the map background color
2006.10.17 Fixed a typo with a command
2006.11.07 Added links to "AD-free" threads.
2006.11.17 Added link to '07 specific notes.
2007.01.13 Added link to thread specifying minor differences with version 3.60.
2007.09.27 Added link to Canadian '07 TL splash screen notes
DumpNAVI program
A picture you like
Instruction
BNHH401A.BIN
BN2HHMLD.BIN
6. Copy DumpNAVI.exe, your wallpaper, and BNHH401A.BIN into the same folder.BN2HHMLD.BIN
Your navigation DVD
DumpNavi Program
or
Instruction
For version 3.50:
BNHH401A.BIN
BN2HHMLD.BIN
and put them in the same directory as the dumpnavi and the AD's TC patch.BN2HHMLD.BIN
6. Run the patch.
For version 3.40c:
BNHH401A.BIN
BN2HHMLD.BIN
and put them in the same directory as the dumpnavi and HMIManager.exeBN2HHMLD.BIN
Your navigation DVD
DumpNavi Program
or
Instruction
For version 3.50:
BNHH401A.BIN
BN2HHMLD.BIN
and put them in the same directory as the dumpnavi and the ok patch.BN2HHMLD.BIN
6. Run the patch.
For version 3.40c:
BNHH401A.BIN
BN2HHMLD.BIN
and put them in the same directory as the dumpnavi and navi.exe.BN2HHMLD.BIN
2. Go to your car.
One last tip,
edit by datmrman
UPDATED NOTES:
Revision History
- changed link to HMIManager.zip
- changed Navi.exe -> navi.exe
- added AngryDad's note about the trip computer
#872
DumpNAVI program
A picture you like
Instruction
Your navigation DVD
DumpNavi Program
or
Instruction
For version 3.50:
6. Run the patch.
For version 3.40c:
Your navigation DVD
DumpNavi Program
or
Instruction
For version 3.50:
6. Run the patch.
For version 3.40c:
2. Go to your car.
One last tip,
edit by datmrman
UPDATED NOTES:
Revision History
DumpNAVI program
A picture you like
Instruction
BNHH401A.BIN
BN2HHMLD.BIN
Your navigation DVD
DumpNavi Program
or
Instruction
For version 3.50:
BNHH401A.BIN
BN2HHMLD.BIN
6. Run the patch.
For version 3.40c:
BNHH401A.BIN
BN2HHMLD.BIN
Your navigation DVD
DumpNavi Program
or
Instruction
For version 3.50:
BNHH401A.BIN
BN2HHMLD.BIN
6. Run the patch.
For version 3.40c:
BNHH401A.BIN
BN2HHMLD.BIN
2. Go to your car.
One last tip,
edit by datmrman
UPDATED NOTES:
Revision History
#873
help getting started; some questions
Hi,
I want to try this on my 04 tl. has original orange dvd (never updated)
when I copy the 9 .bin files they are different thenwhat others have mentioned?:
add.bin
bn2hh110.bin
bn2hh120.bin
bn2hh12c.bin
bn2hhmld.bin
bn2hh12b.bin
bn2hh18b.bin
zzz10.bi
zzz100.bin
Also, when I press version i get 3.1 and others seem to mention 3.4 and above.
Can I still do this...do I need some update first?
thanks,
Jack
add.bin
bn2hh110.bin
bn2hh120.bin
bn2hh12c.bin
bn2hhmld.bin
bn2hh12b.bin
bn2hh18b.bin
zzz10.bi
zzz100.bin
thanks,
Jack
#874
wtf....i cant get the CMD prompt to display C:\NAVI>
its stuck on C:\Documents and Settings\Owner>
last time i did this hack was a while ago...dunno wats goin on...please help
#875
#876
anyone want to sell or barter?
i'm usiing 3.3 with the great patches on my o4 tl. Would just like some more mapage. looking for 3.7 (orange) copy (3.6 if .37 is not patchable). pm me if want to discuss possibilities. maybe I have something you could use or reasonably purchase copy?
#877
editing the navi loading text?
Hi,
I love the picture and ad trip comp info I've now got with AD and kennyc modified patches.
Can I still change the orange text that says "Navigation loading.....please wait"which pops up after the picture?
I don't want to change my other patches. I'm assuming I will just make changes to the updated/patched .bin that I loaded with the cd?
Anyway,
step by step appreciated.
thanks,
Jack
Anyway,
thanks,
Jack
#878
Hello,
Okay I am new here and I have just bought a TL-Type S that is amazing, however I bought it in the States and have no nav for in Canada. I have an MDX with the orange disc and was wondering is it possible to take the map files from the orange disc and created a new Grey Navigation disc for my TL?
If so which are the map files.
Any help would be great.
#879
Question related to this topic - I can't seem to find clear answers on the newer models.
Are there any additional hacks that can work on the 4.52 Navi DVD? I have an '08 TL Type S, and other than some hints that the OK nag can be erased, is that all there is? Mainly, I'm after the Trip Computer hack, or something like it. I'd like more information displayed, such as instant MPG, decimal places, silly things like that! Seems weird that it's not an option to begin with straight off the menu. I've seen suggestions that it's because they need to limit the amount of memory in use - but c'mon, is that really the case? How hard is it to throw more memory at it and make it feature rich? Sheesh.
Anyway - I don't care about customizing the background or startup graphic. Really, the OK nag doesn't bother me that much either, although it'd be nice to get rid of. Mainly, I just want the better readout of Trip Computer.
