The motor mount thread
Old Apr 8, 2011 | 09:19 PM
  #441
StreetKA's Avatar
Originally Posted by friesm2000
grinding a little bit of that bracket (which does NOT get replaced with excellerate's mounts as far as know), should make the headers fit without an issue
btw the mount should not have to be removed (or bracket), especially if you got a dremal tool, with like a "sanding drum", once the stock manifold is pulled, plug up the exhaust ports with some paper towels (just to keep every thing out possibly); sand/grind a little bit away of the bracket, to clear the new header, and you should be good
x2
grinding bracket not mount will make it fit
Old Apr 9, 2011 | 11:58 AM
  #442
phee's Avatar
I got the Shifts
update? its the end of the week and im waiting on these to put my new clutch in.
Old Apr 9, 2011 | 09:44 PM
  #443
Neejay's Avatar
are you changing them at the shop or at home?
Old Apr 9, 2011 | 09:57 PM
  #444
StreetKA's Avatar
mounts probably yes but clutch i dont think so
Old Apr 9, 2011 | 09:59 PM
  #445
Rapture's Avatar
So wait, if you do go DC Headers, you WILL need to grind the bracket, or (according to that other thread) you can just remove the mount, install the header, then reinstall the mount?
Curious about this since I was actually pretty close to getting a set of DC Headers.
Old Apr 9, 2011 | 10:03 PM
  #446
Neejay's Avatar
Yep. I don't trust grinding brackets (well, I don't trust myself doing it), so I had to remove (I loosened it) the bracket, mount the rear header, then put the bracket back on.
Old Apr 9, 2011 | 10:15 PM
  #447
friesm2000's Avatar
B A N N E D
fair enough, i guess.....
and as far as what excellerate's mounts is replacing, has nothing to do with that bracket and even then it is like only a one time ordeal even then, if you don't constantly remove your headers (j-pipe maybe... but not the upper part)
Old Apr 9, 2011 | 10:29 PM
  #448
Neejay's Avatar
I mean, if I saw a pic of how much/where to grind, I would have (trust me, it was a bitch to do the bracket by myself)...but I didn't want to take any chances on grinding too much.
Old Apr 9, 2011 | 10:50 PM
  #449
friesm2000's Avatar
B A N N E D
grind a little, test fit, if it goes awesome if not grind a little bit more , and recheck the fit, and repeat as needed
and even then with the headers fitting afterwards, it can't be that much needed, my best guess would be an 1/8" maybe max (and making sure all the grinding has smooth transitions, to not cause a stress riser
BTW you should see my ingall's front adjustable upper arms i had to clearence those quite a bit to make it, so they did not hit the strut tower anymore
Old Apr 10, 2011 | 07:18 AM
  #450
StreetKA's Avatar
My mechanic installed the ebay headers on my friends cls6
And he said he had to grind about 8-10mm off the bracket. Its doable but not for everyone. I would not touch that. I belive there is a picture of this grinded bracket on our forum.
Old Apr 10, 2011 | 10:02 AM
  #451
friesm2000's Avatar
B A N N E D
did not realize that much would have to be taken off, so yeah either loosening or removing the bracket would probably be best
Old Apr 10, 2011 | 10:33 AM
  #452
StreetKA's Avatar
I belive that 6-7mm is enough but then it will be really tight.
Whats up with these mounts i hope i will receive them this week.
Old Apr 10, 2011 | 11:18 AM
  #453
phee's Avatar
I got the Shifts
me too. just bought a new flywheel and clutch. 13's here i come...depending on mounts
Old Apr 10, 2011 | 07:09 PM
  #454
2003TL-S's Avatar
I need them badly too
Old Apr 11, 2011 | 03:25 AM
  #455
Rapture's Avatar
Well about the DC headers issue again... is the rear piece going to be rubbing against the mount bracket? In that other thread the guy showed he had a couple scuffs on his set, that I'm assuming came from the bracket. Hate to have it end up causing a fracture or anything in the long run.
Old Apr 11, 2011 | 08:05 AM
  #456
phee's Avatar
I got the Shifts
I'm pretty sure there is a header thread.
Old Apr 11, 2011 | 09:41 AM
  #457
StreetKA's Avatar
Its monday amd i'd like to hear some good news about product beeing shipped
Old Apr 11, 2011 | 11:58 AM
  #458
friesm2000's Avatar
B A N N E D
monday updates needed
Old Apr 11, 2011 | 01:14 PM
  #459
fsttyms1's Avatar
The ONLY headers that fit the Manual trans CL were the Comptech and the XS. They had the bend in the header to clear the mount bracket. In order to get any other brand to fit you have to grind away at the mount BRACKET. It doesnt matter what mounts you run, they arent the issue. Again its the bracket. If you have a AUTO trans you have no problems and can just install them (though with the DCs i have installed i had to remove the bracket to get them to go on, then reinstall the mount. They didnt touch the mount at all (and it wouldnt cause wear on any thing if they did as that part of the exhaust is rigid and doenst move, just like the bracket)
Old Apr 11, 2011 | 05:41 PM
  #460
civicdrivr's Avatar
Updates on mounts?
Old Apr 11, 2011 | 08:24 PM
  #461
Neejay's Avatar
The scuffs were due to me trying to install it and it rubbing the mount (reason I kept trying to install was because I thought I was doing something wrong). Once you remove/move the mount, you can slide the header on to the head, and rebolt the mount without problems or rubbing.
lol
Old Apr 11, 2011 | 08:44 PM
  #462
Karanx7's Avatar
Unregistered Member
Man, I really want to order these mounts, but it doesn't seem like anyone has gotten them yet. I'm hoping that you guys will give your impressions of the mounts when you get them.
Old Apr 11, 2011 | 08:45 PM
  #463
StreetKA's Avatar
^ nice avi !
Old Apr 12, 2011 | 04:11 AM
  #464
Rapture's Avatar
and I'm pretty sure there's a TL subforum
only kidding.
Old Apr 12, 2011 | 04:55 AM
  #465
Rajca's Avatar
wham bam thank you ma'am
only kidding.
lmao
Old Apr 12, 2011 | 07:42 AM
  #466
phee's Avatar
I got the Shifts
I'll leave
Old Apr 12, 2011 | 08:46 AM
  #467
phee's Avatar
I got the Shifts
ok im back.
wheres the update?
Old Apr 12, 2011 | 08:01 PM
  #468
friesm2000's Avatar
B A N N E D
YES I NEED UPDATES, just relised the track here opens up next week on wensday (and need time to install them also )
Old Apr 12, 2011 | 08:30 PM
  #469
StreetKA's Avatar
Someone please call him and ask whats up
Old Apr 12, 2011 | 09:08 PM
  #470
Neejay's Avatar
Yeah, I need to start planning when I want to install these too.
Old Apr 12, 2011 | 11:32 PM
  #471
friesm2000's Avatar
B A N N E D
i PM'd him earlier, have to wait till the mourning to call lol
Old Apr 13, 2011 | 09:32 AM
  #472
Excelerate's Avatar
Former Sponsor
The mounts came back from powder coat last week but the powder coater threw them all in a big crate and scratched a bunch of them up. They had to go back out to powder coat so that delayed the shipment a few days. We are expecting the shipment to leave the fabricators by Monday.
Old Apr 13, 2011 | 12:02 PM
  #473
Neejay's Avatar
I can handle that...not your fault. Thanks for the update.
Old Apr 13, 2011 | 12:06 PM
  #474
civicdrivr's Avatar
Thanks for the update. Hopefully everything else goes as planned
Old Apr 13, 2011 | 02:50 PM
  #475
friesm2000's Avatar
B A N N E D
so i am guessing i won't have them by next wensday then (unless of course you can rush a couple of sets through )
Old Apr 13, 2011 | 03:26 PM
  #476
phee's Avatar
I got the Shifts
Xlr8 I'll take a scratched batch. Im losing too much money waiting and I need to be running no later than may 1st
Old Apr 13, 2011 | 05:34 PM
  #477
Neejay's Avatar
Actually, I will too. I'm not trying to win any engine-bay awards. Plus, the scratches can't be THAT bad.
Old Apr 13, 2011 | 06:24 PM
  #478
Rajca's Avatar
^agree. but sounds like he already sent them out to get re powdercoated
Old Apr 13, 2011 | 07:47 PM
  #479
friesm2000's Avatar
B A N N E D
or as others have said scratched ones are fine too (probably get scratched anyways, especially trying to get that rear one in)
Old Apr 18, 2011 | 08:38 AM
  #480
clue036's Avatar
I hope we can get some good news today.
