The motor mount thread
Old Mar 29, 2012 | 06:38 AM
  #1001
Neejay's Avatar
Originally Posted by Karanx7
I don't think it will feel like a pos car, but it will definitely take any luxury out of the drive. You will feel the vibrations through the steering wheel for sure.
Has anyone tried a combo of XLR8 and OEM? Like XLR8 front and side mounts, with OEM rear mount. Using an OEM rear mount significantly helped the excessive innovate mount vibrations, maybe it can help this setup too.
Seeing that the OEM rear doesn't fail until the front and side aren't able to handle their load, it should hold up pretty well too.
Originally Posted by brian6speed
More than 1 person has already posted their experience doing this(oem rear). It reduces the vibration alot according to them.
I'm not sure if they were NEW OEM rear mounts though. I'm doing it, but it's the original rear mount.
I'll probably keep this setup until the rear one craps out. I re-installed the Ingalls Stiffy as well. I don't see any engine movement when shifting the gears + holding the brake pedal down, but I sure feel it.
Old Mar 29, 2012 | 08:15 AM
  #1002
gnuts's Avatar
3.5 psi
i will have the XLR8 front and side and oem rear. i can post reviews in a few weeks when the cars back up and running.
Old Mar 29, 2012 | 09:39 AM
  #1003
brian6speed's Avatar
Lone Wolf
Another setup I am thinking of that would be the best compromise would be: Innovative front mount(vertical design), XLR8 side, and oem rear.
Old Mar 29, 2012 | 11:46 AM
  #1004
kdawg8526's Avatar
13.2@106mph G37 RWD Sedan
Originally Posted by INSPIRE 32V
any thoughts on the 62a? i really dont want to feel like im driving a pos car due to the vibrations
i had the 62a you get quite a bit of vibration steering wheel and seat and dash would vibrate but that was only when i was stopped. i got used to it but people that sat in my car thought something was broken in my engine
Old Mar 30, 2012 | 03:58 AM
  #1005
INSPIRE 32V's Avatar
Glacier Frost Mica CL-S
Thanks kdawg for the info.
So what is the advantage of having the innovative front vertical mount compared to xlr8 front mount..
Old Mar 30, 2012 | 12:17 PM
  #1006
Lone Wolf
I am not gonna say which is better because I don't have experience with both yet. It basically comes down to will it hold up/last. A few people already complained of play in XLR8 front mount after only a few k miles, whereas reese has reported no problems with his innovative front.
If my XLR8 front starts getting play in it, then my next step is replacing with innovative.
Old Apr 23, 2012 | 09:38 PM
  #1007
Neejay's Avatar
After finally getting my rear mount in, I can say that the OEM rear + XLR8 front and side definitely reduced vibrations.
+1 to this. It's only when stopped/coming to a stop.
Old Apr 24, 2012 | 03:41 PM
  #1008
clpassenubye's Avatar
ABP-KBP-CBP & ME
Glad to hear that I think that will be my next move also.
Old Apr 25, 2012 | 03:44 AM
  #1009
FwC's Avatar
FwC
So what are you guys torquing these mounts at? Is there anyone with an FSM or a Helms that can list the OEM torque specs vs what you actually torqued to?
Old Apr 25, 2012 | 11:09 AM
  #1010
kdawg8526's Avatar
Originally Posted by Excelerate
We recommend 35-40 ft lbs of torque.
Old Apr 25, 2012 | 11:13 AM
  #1011
FwC's Avatar
FwC
... that's your catchall torque for all 14 or so bolts?
Old Apr 25, 2012 | 11:19 AM
  #1012
kdawg8526's Avatar
thats from the supplier himself so i guess so
Old Jul 28, 2012 | 06:18 PM
  #1013
azeezp13's Avatar
shifting at 7k
It seems like the guys that reported vibrations with the XLR8 62a inserts were all auto. Did the vibrations go down when the car was in neutral compared to drive mode at a stop? If so, then us 6-speeders should be ok.
Old Jul 28, 2012 | 07:09 PM
  #1014
kdawg8526's Avatar
if i remember correctly it did go down in vibrations in neutral
Old Aug 24, 2012 | 04:18 AM
  #1015
FwC's Avatar
FwC
I've only driven on these for one week, but would recommend them to anyone having problems with a shaky engine. BUT the amount of vibration throughout the cabin is a bit annoying. I have the 74A bushings. I find it helpful when sitting at idle for long periods of time to put the car in neutral or park.
I was going to write to XLR8 and give an opinion of two but since I'm already writing about it I'll just do it here.
1. The powder coat/paint on the upper mounting bolt for front and rear mount made it excessively hard to screw on the nut when securing the engine to the mount. It was at the point where I turned the nut a few turns and removed the nut to find it super hot from the friction. This could cause a few problems as my torque was at 40 before the nut even made contact with the engine mounting bracket. I think you should recommend to buyers a way to remove that stuff from the bolt or have your manufacturer not powder coat/paint that bolt.
2. The factory bolts to secure the mount to the subframe are too short. The base plate of the front and rear mounts are about 1/4" thick which I would estimate to be about 3 times thicker than the OEM base. This means the securing bolts aren't threading all the way through the nuts on the subframe. Perhaps you should include longer bolts or recommend to buyers to buy them from a local parts store. They are M10 1.25 bolts.
Old Aug 26, 2012 | 09:18 PM
  #1016
StreetKA's Avatar
i have set of used XLR8 60a mounts for sale for 6MT
Old Dec 31, 2012 | 04:37 AM
  #1017
Neejay's Avatar
So, after having all 3 mounts installed for a little under a year, I'm probably going to buy a new OEM rear mount and install it. I find myself getting annoyed/aggravated from the vibrations when stopped (redlight, drive-thru, etc.) and I only have the 62a ones...guess I'm not hardcore enough lol Everytime the seasons change, I get a different area and type of vibration noise.
If I still get annoyed, then I'll just get a new OEM front one as well since the side-mount doesn't affect the engine load that much.
Old Dec 31, 2012 | 11:18 AM
  #1018
FwC's Avatar
FwC
I just did this last week. And I'll tell you that it makes it night and day. I got XLR8 front and side with a Beck Arnley rear that doesn't have the hydraulic line. Since this was available I removed all that tubing and the little actuator for the hydraulic lines and plugged up that little hole on the intake manifold.
RockAuto.com - Beck Arnley rear engine mount:
http://www.rockauto.com/catalog/more...218&cc=1364925
I was able to drive on it without any noticeable vibrations, but then I put the Ingalls TQ damper on and it brought a little bit of vibration back but not enough to be irritated about. I have the 74A bushings on my mounts.
LOL You'll be happy when you use the AC too. The vibrations with AC was scary before.
-Frank
Old Dec 31, 2012 | 11:44 AM
  #1019
Neejay's Avatar
-Frank
That's great news! Even better, because I never sold my ingalls stiffy, even though it's not on my car...so if I want it a tad bit stiffer I could throw it back on. Thanks for the heads up man.
Old Dec 31, 2012 | 02:12 PM
  #1020
Neejay's Avatar
On second thought, did a little searching, and I see people recommend NOT to get the non-vacuum assisted mounts...ugh.
Old Jan 1, 2013 | 11:11 AM
  #1021
FwC's Avatar
FwC
^^^ damn. Oh well. It's working alright so far, I'll update if it fails soon or something.
Old Jun 3, 2013 | 11:59 AM
  #1022
termo001's Avatar
is there a big difference in the automatic and manual mounts? i was wondering if i can fit the manual mounts on my auto for now im planning on doing a 6 speed swap soon...my tranny is slipping i have 150,000 miles on my car
Old Jun 3, 2013 | 12:37 PM
  #1023
Excelerate's Avatar
Former Sponsor
Front and side mounts are the same. Rear is different.
Old Jun 7, 2013 | 03:46 AM
  #1024
YeuEmMaiMai's Avatar
Just thought I would chime in here.....
My front and side mount finally bit the bullet at 118+K. These were the original mounts that came on the car. I elected to replace them with stock mounts as I do not drive my car aggressively. The car is nice and smooth now with no noticable issues. shifting seems to be much firmer on the auto and the engine does not move around like it used to.
If you are hard on your car, get stiffer mounts, if you use it as a DD with some occasional spritited driving OEM should be fine.
Old Jun 7, 2013 | 07:16 AM
  #1025
sabohead's Avatar
Any updates or news on those "vertical" mounts? I might have to research this more. I am hard on my car. Hell, I am hard on everything I drive/drove.
Old Sep 26, 2013 | 08:58 PM
  #1026
Neejay's Avatar
It's been about 1.5 years now with the 62A mounts.
Has anyone else had this issue?
Rear:
I can literally move the collar up and down with my fingers.
Old Sep 27, 2013 | 12:18 PM
  #1027
Excelerate's Avatar
Former Sponsor
We've had very few bushing deformation issues but you may want to upgrade to the 75A bushing to be safe. Email us for more info.
Old Oct 1, 2013 | 11:11 AM
  #1028
Neejay's Avatar
This weekend, I'm going to double check my front mount as well before making any moves.
Old Oct 11, 2013 | 03:31 PM
  #1029
kingofdust's Avatar
In search of excitement
Okay so my mounts are shot and its time to do a swap. I drive my car pretty hard but I also daily it. I don't think I will have a problem with vibrations as long as I know its not vibrations from the mounts being broken. I just need the basically cheapest way to get the power back to the wheels so is that xlr8 or rock auto mounts? Its a 6mt.
udelslayer
1G RDX Problems & Fixes
May 6, 2016 12:27 PM
wilztlxs
Dec 1, 2015 09:16 AM
BKSleeper
Oct 7, 2015 10:20 AM
ghuns
Sep 16, 2015 04:26 PM
mossman77
1/2G MDX (2001-2013)
18
Sep 16, 2015 12:21 PM
