*** Official Uni-Chip Group Buy ***
#1281
Originally Posted by mrsteve
As discussed months and months ago, for supercharged applications the GReddy E-Manage is the way to go for you guys. The Uni-Chip is better suited for us N/A folks.
#1282
Originally Posted by blader
does anyone know what matt dynoed at NA before the chip?
i only put down like 212whp. but i had 89 octane in the tank, and others were complaining about low numbers as well.
#1283
With his mods he should have been about 230whp.
i can't remember what the pre-chip numbers on the dyno chart were, but the after chip whp was 244.
#1284
Originally Posted by mattg
actually, jack was just saying yesterday that there is nothing the e-manage can do that the unichip can't do better.
There are a couple of things like directly extending the injector pulse width. Unless they changed the unit, it could only help the blown application though adding injectors.
Plus, they have to program it. :P
#1285
It's true we don't directly drive the injectors, but that isn't at all an issue with your cars... even the SC ones. The car comes so rich from the factory the required adjustment is well within what the Unichip can do. It's not true that we can't control the OE injectors, we just control them through a different scheme. We sell lots of stuff to lots of SC and turbo cars and have no issues what so ever perfectly controlling mixture. The reason we have the ability to directly drive additional injectors is for applications where the OE injectors simply can't get the job done... i.e. their at 100% duty cycle. In that case, adding additional injectors is possible, and we can control them but often the car won't idle properly because the injectors are too big.
and not everyone is a performance guru like you and allmotor, who can program the e-manage.
it's lucky we have you guys around or we wouldn't have an e-manage or a unichip.
#1286
With that said Jack has made claims with are unfounded. He doesn't know how rich or lean these cars get under boost and as such made an incorrect statement. Plus, some of what he said above didn't make sense. If you add injectors for under boost situations your idle is let unchanged.
Why it won't work is that they can't alter the primary load sensor signal for our cars to add fuel; the MAP sensor. If they don't clamp it and hold it below about 2.95 VDC (or just below barometric pressure) the ECU will freak and kill power. In other words, they can't change that signal.
When I last spoke to them the tech guy understood this limitation and said they would have to run additional injectors. Maybe things have changed but not according to their literature.
#1287
i don't know enough about it to comment further. :o
#1289
to take full advantage of the unichip, yes.
#1291
Originally Posted by darrinb
so i have to send it back to them and pay some more to tune it??
I would assume so yes, but they would need to have a car there with the same mods (i.e. RES and cams) to put on the dyno and map things out. I don't think you could just call them and say "Yeah I got this and that" and they will know what to do with it. Something like having pulleys doesn't affect it enough to warrant a different map for those without them which is why you and I will have the same chip even though I don't have the UR pulley.
Are you as anxious as me?
#1293
Revving at 9K...
Matt, when we going to the tracks? I'll bring the digital recorder!
I'm glad everything worked out so well for you! Did they run any additional fuel injectors or recommend it? I take it that you have a switch that comes with your unit right? for NA and FI.
My S2K is going for tuning sometime soon, I need at least one car that can "keep up" with you on the way to the tracks.. :o
#1294
i'm going to woodburn june 19th. you should definately go.
they said nothing about needing additional injectors, so i must still be within the limits of the stock ones. i did upgrade my fuel pump though.
they used my exhisting nitrous arm switch for the chip. when the n2o is off, the street map is on. when the n2o is armed, the n2o map is on.
did you get the intercooler on the S yet?
#1295
Audi S4 driver
Matt did they actually give you a date that they would be shipping to the rest of us? You said you go back thursday .. so assuming everything goes good with your car .. can we expect to see them ship friday?
#1296
Revving at 9K...
Aftercooler on the S... not yet.. my work killed me for the last 5 month.. /sigh I need to schedule an appointment to bring it in for the install.
Side note:
I talk to Jack today. I'll be bring in my car in around Thursday'ish, because they plan on testing every single harness on my car, and start it up to make sure everything is all good for people who bought them. I won't have my car from Thursday until Monday.
My poor poor starter.... :'(
#1299
i guarantee you guys will be impressed when you open the box.
#1300
Not Asian
i believe they are just waiting to test fit on Brians car. then they will be ready to ship.
#1301
Audi S4 driver
Originally Posted by phipark
I hope I'm impressed when I open the throttle.
I'm sure the box looks nice matt.. but the box won't get me my 13 second slip
#1302
i'm just saying the equipment looks nice.
i'm also hoping for a 13 sec. slip n/a. and a 12 sec. slip on the gas.
the chip provides a noticable gain, but don't expect it to feel like a s/c or nitrous. it's probably more like adding headers.
#1303
Audi S4 driver
more like adding headers!?!? seriously!??! I hope your right .. cause the first time I opened it up after installing CT headers it put a huge smile on my face
Where do you feel it the most matt? (NA of course) Midrange? VTEC?
#1304
Revving at 9K...
Man, you guys. I hope you guys don't get the hopes too high, the chip WILL react differently depending your motor and your mod setup.
To be honest, most people who know matt would agree that he just has one of those Wednesday car, he's car just seem to have a lil more compare to the rest.
But by all means, the chip does help, but how much.. really depends on everyone's butt dyno, since most people here judges by feel. (myself included)
btw, Matt did you also notice that the car is a bit more responsive? At least in the NA form.
#1305
4000 on up. it definately pulls harder than before.
#1306
jack told me a car w/ less mods would actually feel the gain from the chip the most.
#1308
to give me an idea of what where talkin, right now i have headers & a k&n drop in filter. ok say i'm running a 14.8 @ the track, what can i expect after the chip is installed.. The track & time is totaly fictisous, I'm just trying to get some kind of an idea of the change i can expect. I too am very excited. since i dont have my chip yet, want to keep at least talking & learning more about it.
#1309
I/H/E/Tires gets me 14.2 consistantly.
I'm hoping i'm one with a "freak" engine that really takes well to the chip... so far my engine has loved every other mod i've done. Icebox gained me 3/10ths headers gave me another 3/10ths off that. I'm shooting for another 3/10ths
#1310
like i said my numbers were fiction, never been to the track or know what i would do in the quarter. thanks for your info. If your ice box gave you 3/10 any idea IYO would the k&n filter give? 1/10 2/10?
#1313
Originally Posted by Nashua_Night_Hawk
Just to mention as a rule of thumb, 1sec improvement in 1/4 miles above 95 MPH is worth 100 HP!
#1315
any news on when were gona send paymnet??
I wouldn't expect to be paying until Matt's car is taken back to Uni-Chip at the end of this week and until all 35 harnesses are tested over the weekend. Looking like we might have them in under 2 weeks
#1318
Revving at 9K...
Don't want to get peoples hopes up.. but I'm suppose to get my car back by Monday, so all harness testing will be done by this coming weekend.
I'll update you guys later, Jack is suppose to call me to setup car drop off time.
#1319
Revving at 9K...
If you see your name list here, please contact UniChip. Todd either needs more info on Mod, or payment info. Please contact him ASAP. Thank you.
No Telephone numbers for > (I need these so I can verify payment with everyone)
1. Anthony Pennisi
2. Ryan Chung
3. Justin Tassin
4. Bill Pongratz ( Need Modifications)
5. Richard Marin ( Need Modifications)
6. Louis Lasch
7. Bill Covert
8. Joseph Schelly
9. Darrin Boji
10. Steve Pello
11. Frank Pletcher ( Need Modifications)
12. E. Joel Rivero ( Need Modifications)
13. John Chan
14. Randy Schultz
15. Paul Tadler ( Need Modifications)
16. Stephan Geraci
17. Matthew Garner ( Need Modifications)
18. Carl Martins
19. Jonathan Zmuda
20. Yen-Wei Liu
21. Sundy Hin
1. Anthony Pennisi
2. Ryan Chung
3. Justin Tassin
6. Louis Lasch
7. Bill Covert
8. Joseph Schelly
9. Darrin Boji
10. Steve Pello
13. John Chan
14. Randy Schultz
16. Stephan Geraci
18. Carl Martins
19. Jonathan Zmuda
20. Yen-Wei Liu
21. Sundy Hin
