AcuraZine Dallas/Ft.Worth Crew
#2281
Beware of leakage
#2282
Honda+Blue=My garage
As for the axles, I found some good deals on ebay, new 2010 EMPI axles. I'm wondering if I should replace the wheel hubs while I'm at it since they come with wheel bearings. Thoughts.
Regarding the poly fill approach, while it's an option the long term results are not any better . . not to mention that the idle is rougher . . and not up for that. Anyway, XLR8 is working on an aftermarker performance mount. He'll be sending me the pre-production mounts as soon as he gets them.
Ruf
I have had the polys for a lot longer than the originals lasted, and have noticed no real difference in the idle. Just my experience.
#2283
Well, I have good news and bad news...the rims came in earlier, but my tires have to be replaced so my car is resting at the shop til tomorrow or Thursday. Also I got in a minor fender bender but my car is BARELY damaged.
#2285
car problems
So i found out today that i have to replace my rear main seal, my oil pan, my hot water valve, clutch, and flywheel. Super bummed out since this will cost an arm and a leg. It has to be done though, because i cant drive the car right now. Its leaking oil and tranny fluid all over the bottom of my car causing a hazard chance to catch fire. Gona have the guys at north dallas imports do the work since they are a reputable shop and cost half of what the dealership would cost. Does anyyyone know where i can get an aftermarket clutch and flywheel?
![what](https://acurazine.com/forums/images/smilies/what.gif)
#2286
Clutchmasters is your only choice...UNless you want to run an Exedy OE or OEM. I would recommend buying a new flywheel also since you cannot machine a dual mass...The good part about the CM kit is that it comes with a flywheel...The only thing is make sure they give you the proper 123 tooth ring gear. but if you go the oem route the flywheel will run about 450 or so. Oil pan and hot water valve should be easy. Well oil pan a slightly more bitch but the hot water valve should be easy. But I would look into excelerate performance since they carry the CM kit and they can prob get back with you with the right part.
#2287
#2288
Lead Footed
Ruf
#2289
Lead Footed
So i found out today that i have to replace my rear main seal, my oil pan, my hot water valve, clutch, and flywheel. Super bummed out since this will cost an arm and a leg. It has to be done though, because i cant drive the car right now. Its leaking oil and tranny fluid all over the bottom of my car causing a hazard chance to catch fire. Gona have the guys at north dallas imports do the work since they are a reputable shop and cost half of what the dealership would cost. Does anyyyone know where i can get an aftermarket clutch and flywheel? ![what](https://acurazine.com/forums/images/smilies/what.gif)
Ruf
#2290
IMO people say Clutchmasters has fixed it I would just buy that kit and see whats up. With what I plan to do sadly that seems to be my only option. I calculated my costs and with an OEM replacement along with a flywheel it will ccost me around 6-700 or so.
You also have to keep in mind you will be needing to run a Dual mass with a factory clutch if you go that route...This main reason is because our factory clutch is not a sprung hub so it will not absorb the abuse and eventually break down and make it wear faster...Its great for performance but not for longevity. The dual mass on our cars cushions the blows so it acts like a sprung hub on the clutch disk.
IMO the clutchmasters kit comes with a lightweight flywheel, a heavy duty pressure plate, and a sprung clutch disk so that would honestly be your best bet. I dont know if excelerate is doing any other deals but i think its 1200 something on the site.
#2291
Regions Leader
Regions Leader
how in the fuck? wait, I dont even wanna know
#2292
Dammit NAiL, they removed the fella who was offering 30% off Enkei wheels at CCM. Thought I was gonna finally grab something legit.
#2294
#2295
flywheel
so i just ordered all my parts. ordered the aasco lightweight flywheel and clutch. should run better. will be taking the car in on monday to get everything fixed.
#2297
wellll it allll started when i bought the car. went to do an oil change and the previous owner tightened the drain bolt on the oil pan too tight and stripped out the threads. i have had to retap the oil pan twice since then and it still leaks. so thats where i need the new oil pan. also did not know that my transmission only had a quart and a half of fluid in it when i bought the car so i blew the rear main seal. also somehow my hot water valve is leaking(have no idea how that could happen). im not suprised that the clutch went out considering i have 100,000 miles on it.
#2303
Now that I reread it I did lol. But let me rephrase myself since I was pretty tired. Low fluid level doesnt really cause a leak. You transmission has nothing to do with the rear main seal leak unless they somehow magically installed it wrong. Few reasons are either pressure in the crankcase forcing out the oil (PCV might not be working properly) or just old age or it couldnt take the abuse.
Unless its your input shaft seal thats leaking which can cause low trans fluid levels.
#2304
Looks like someone wanted my license plate...
So today I was at the Galleria mall and as I was walking towards my car...I realize someone really liked my license plate...so much they decided to RIP IT OFF.
The bad:
I need a new license plate, I need a new chrome license plate cover, and I need a new black plastic bracket, also somehow, there is a hole on my front bumper where nothing was screwed into.
The good: I can all these things for cheap, and the hole on my bumper will be covered by the new black plastic bracket.
What puzzles me the most...is that there is this hole, and nothing was screwed into it or anything. I am really pissed though.
The bad:
#2307
#2308
Ya but I have a separate hole above the driver's side plug. It is about 1-1 1/2 inches above the plug, so if I don'y get a front license plate...it is visible.
#2309
#2310
Lead Footed
The bad:
The bad:
Ruf
#2312
The first thing I did this morning was cancel the membership with tolltag people. While I was at school, my mom got me new plates (the new 7 letter ones) and a black bracket. You can see maybe half an inch of the whole, rip in the bumper with the bracket covering it, but it really doesn't bother me. The license plate it now void.
#2313
Ya, I guess the person before me decided to use the hole on top of the bracket. It really pisses me off. This whole past two weeks have been shit for me. Same for horsepower and his screwed up axle problem or w/e.
#2314
If it makes you feel any better, my battery just died so it's time to get a new one tomorrow.
#2319
Why when Acura just gave me a free one? ![Tongue](https://acurazine.com/forums/images/smilies/tongue.gif)
BTW, do we have a vendor on here who can supply A-Spec suspension? Or better yet, a way to tell which is for a manual & which isn't? Thinking I'll just get the complete A-Spec option & call the car near-done.
