D-100: The Official "Does This Wheel and/or Tire Fit My Car" Thread
#1681
Stock 2005 TL with nav...what is the widest tire I can fit without rubbing anywhere? Right now I am driving on Goodyear Eagle GT's: 255/40-18 and they feel great. I definitely do not trust tire stores because many told me not to do 255's, and they could not have been more wrong. I am not too concerned about handling, pretty much just want the fattest tires I can possibly fit on the car without hindering clearances. Wheels are as follows:
Wheel Make/Model: Enkei AKP
Wheel Size (**X**): 18x8
Wheel Offset (+**): 40
THANKS!
THANKS!
#1685
Hey man. Lookin for new wheels, based on the guy who has a milder setup in the link below, you think the spokes will clear the brembos?
Transmission (Manual or Auto): 6mt
Year/Trim (04-07, Base or Type S):04
Wheel Make/Model: Work Emotion XT7
Wheel Size (**X**): 18x9.5
Wheel Offset (+**): 30
If lowered (amount): 0 finger wheel gap rear 1 finger front
http://www.acura-tsx.com/forums/show...4&postcount=15
#1686
fitment gurus I need your help. Which spacers should I get to get the best fitment (no rubbing) for my new setup? I'm going to run 18x8 +40 wrapped with 235/45/18 for the front and 18x9 +40 wrapped with 255/35/18 for the rear. It will be lowered probably with a one finger gap front and rear. Thanks in advance.
#1687
94 DC4 RS LSV/Turbo
Answers
Can you advise if this setup will fit without rolling or alignment modification?
Transmission: Auto
Year/Trim: 07 Type-S
Wheel Make/Model: XXR 502
Wheel Size: Front 18x8.5 Rear 18x9.5
Offset: 35 front and rear
Not lowered no plans to lower
Tire Make/Model: Continental ExtremeContact DWS
Size Front: 235/40-18 or 245/40-18
Size Rear: 265/35-18 or 255/40-18
Transmission: Auto
if you go up to 255 you have to do 255/35-18 and same goes for 265/35-18
Transmission: Auto
Year/Trim: 2006 Base TL
Wheel Make/Model: Axis Pentagons
Wheel Size: Front 19x8.5 Rear 19x9.5
Offset: +35 front and +40 rear
Lowered: As low as I can go on F&F Type 1's
Tire Make/Model: Nitto NT555's
Fender Roll: Yes, I plan on fender rolling. No pulling though.
Size Front: 225/35-19
Size Rear: 245/35-19
THANKS!
THANKS!
#1689
Year/Trim (04-07, Base or Type S):05
Wheel Make/Model: Gram Light 57Pro
Wheel Size (**X**): 18x8 front 18x10 rear
Wheel Offset (+**): +43
If lowered (amount): 1.5 inch
What offset would i need in order to clear brembo?! Would the rears clear w/o mods!?
#1690
Happy Holidays!
Quote:
Originally Posted by Silver_Surfer View Post
Hi guys! I appreciate the help.
07 TL Type S
stock height
ACE Stada
19x8.5 38
and
Privat Reserves
19x9.5 40
Thanks!
both will require spacers, the Ace will need a 5mm the privat probably a 10mm or 15mm
Stillhere....Thanks for the help. I found this old thread with the same wheels and specs, Ace Strada 19x8.5 38 offset:
https://acurazine.com/forums/car-parts-sale-361/closed-fs-ace-strada-wheels-393336/
From that thread the OP said that it cleared his 08 type S with brembo. Could you please double check? Would I still need that 5mm space? Thanks!
07 TL Type S
stock height
ACE Stada
19x8.5 38
and
Privat Reserves
19x9.5 40
Thanks!
#1691
Stiihere,
Sorry about so many posts but apparently I am not allowed to edit my posts. I just wanted to be clear on your recommendation. In regards to the rear fitment: The XXR502 wheel in 18x9.5, +35 offset, if I use a 245/40-18 tire I will not need to roll rear quarters. However, if I go to a 255/40-18 or a 265/35-18 I will have to roll the quarters, is this correct?
Maybe it would be better to go with 18x8.5 all the way around, instead of the staggered fitment, and use a 245/40-18 tire. Car is a Type-S not lowered and will not be lowered.
#1693
Wheel Make/Model: BBS LM
Wheel Size (**X**): 18x9 F 18x10 R
Wheel Offset (+**): +42 F +50R (+32 +40 if reverse mounted)
If lowered (amount): 1 finger gap
With some slightly stretched tires like a 265 or maybe even a 255/35, think I'll encounter any issues as far as hitting the coilover in the back or wheel well? Also caliper clearance issues?
#1696
Transmission (Manual or Auto): Auto
Year/Trim (04-07, Base or Type S):07 Type S
Wheel Make/Model: SSR Type F
Wheel Size (**X**): 19x8.5 F 19x9.5 R
Wheel Offset (+**): +42 F +38R
If lowered (amount): none now, but looking at aspec suspension for a small drop.
Thanx!
Thanx!
#1697
bump.
Wheel Make/Model: VOLK GT7
Wheel Size (**X**): 18x8.0
Wheel Offset (+**): +50
#1699
Alright so I seem to like a few rims here haha I am looking for opinions just sharing... I like to hear input... I really like number 6 and I would go with them hands down.... BUT! They only make them in 20" PLUS! =( I don’t want dubs on my TL... 19" is my max!
Thoughts?
PS I used a photo I googled for the side shot... Not sure if this is a members car! But if it is I hope you dont mind!
For a better res go to http://i1116.photobucket.com/albums/...g?t=1299040356
Thoughts?
#1701
Transmission Auto
Year/Trim 2008 Type S
Wheel Make/Model: Varrstoen ES2.2.2
Wheel Size 19x9.5 front 19x10.5 rear
Wheel Offset +22 all around
If lowered on Tein SS
#1703
Anyone have PERSONAL experience with 18x9.5 wheels with 235 or 245/40/18 tires? The offset is 48mm and I can do spacers, but I don't want to have to modify the fenders. I'm on stock suspension, but may do A spec in the future. From what I've found the 235s will work no problem, but can I do 245s, and what offset to not have to modify the fenders?
#1704
Transmission: Auto
Year/Trim :07 base
Wheel Make/Model: Linea Corse Dynas
Wheel Size: 19x8.5 All around
Wheel Offset: +28
If lowered (amount): 1.7"
Tires: 235/35/19
Would like to know if I'll need to roll fenders. If so, both front and back or just one? Also, why does ride height cause rubbing. Doesn't the suspension use any available travel while driving? Or is it just inclines that cause the rubbing?
I'm worried about these specs but I'm not interested in any other rims. Here is a pic of another aziner's setup:
https://acurazine.com/forums/showthr...t=19x8.5+%2B28
Year/Trim :07 base
Wheel Offset: +28
Tires: 235/35/19
#1707
Rock Chalk JayhawkZ
Transmission: Auto
Year/Trim :05 TL
Wheel Make/Model: Works T1s
Wheel Size: 19x8 front 19x9.5 rear
Wheel Offset: +36 front +38 rear
If lowered (amount): no finger gap with a rear camber kit
Tires: ??
Would these fit? What size tires would I run dropped on Teins SS with no finger gap? And would I need to roll my front and rear fenders?
Year/Trim :05 TL
Tires: ??
#1709
Chapter Leader (Houston)
Transmission: Auto
Year/Trim: 2004 Base TL
Wheel Make/Model: XXR 522
Wheel Size: Front 18x9.5 Rear 18x9.5
Offset: +25 ALL AROUND
Lowered: Going to go 2 inches all around
Tire Make/Model: not sure
Fender Roll: No
Size Front: 245/40-18
Size Rear: 245/40-18
I am not sure how the whole offset thing works. Should I get 25mm or 48mm offset in these wheels?
Fender Roll: No
#1711
Transmission: Auto
Year/Trim :04 base
Wheel Make/Model: JLB Apollo (TE 37 Reps)
Wheel Size: 19x9.5 All around
Wheel Offset: +22 (I think)
If lowered (amount): Tein SS (~2in.)
Tires: 245/45/19
Was wondering if I would be rubbing and how flush I would be sitting. Have Tein SS installed but not lowered to max settings. Dropped maybe 1.5-2 inches.
Year/Trim :04 base
Tires: 245/45/19
#1712
What's the smallest size rim I can run while still clearing 6 speed brembos? Reason I'm asking is because I want to buy a pair of lightweight rims to put a drag radials/slicks on for the track.
#1714
Transmission: Auto
Year/Trim :07 base
Wheel Offset: +28
Tires: 235/35/19
Year/Trim :07 base
Wheel Offset: +28
Tires: 235/35/19
#1715
Aaron... How about this one?
Transmission: Auto
Year/Trim :04 base
Wheel Size: 17x9 All around
Wheel Offset: +18
If lowered (amount): stock
Tires: 225/65/17
thanks- i'm kind of worried about the 9" wide in front... and the +18 offset...
Transmission: Auto
Year/Trim :04 base
Wheel Offset: +18
Tires: 225/65/17
#1717
yes, they are Falken HS439 (eurowinter model) -mainly All season- I live in MinneSNOWta, where there are 5 months of winter. Taller tires = easier to get through snow. This is the wifes car and she doesn't need a lot of performance, so the sidewalls are not an issue... just fitting them in, and the offset sounds like my biggest concern (still reading up on it)
thanks aaron
thanks aaron
#1718
thanks aaron
thanks aaron
#1719
I guess I'm going to get 17x7's with a normal (40/45) offset. Thanks for all the help.
