Turbo Kit for Acura TL '04-'08
#4561
In the pic below, the resistance will vary to voltage being sent back to the ecu. The voltage can vary from 0.1 to 4.8 V depending on how much resistance there is in the circuit.
![](http://pic80.picturetrail.com/VOL836/1216349/22626587/380691549.jpg)
![](http://pic80.picturetrail.com/VOL836/1216349/23495320/393995925.jpg)
![](http://pic80.picturetrail.com/VOL836/1216349/23495320/393995923.jpg)
![](http://pic80.picturetrail.com/VOL836/1216349/23495320/393995924.jpg)
![](http://pic80.picturetrail.com/VOL836/1216349/23495320/393995922.jpg)
In the pic above, it is interesting to see that the system is designed to read as low as -40 degrees.
#4562
18psi
However, this idea just jumped into my head so you guys tell me if this makes sense.
The manual says that voltage for the IAT sensor will measure between 0.1 - r4.8volts. For arguments sake, say 0.1volts is equal to -40°F and 4.8volts is equal to +200°F. Or vice versa depending on how the sensor reads the voltage to temperature relationship
While idling, remove the IAT sensor from the TB but keep it connected. Connect you OBDll scanner and monitor the temperature of the IAT sensor. Take a multimeter and measure the voltage from the sensor. Hit the sensor with a hairdryer or whatever until you reach a steady 75°F on the scanner. Read the voltage on the multimeter and you have your proper voltage for 75°. Or just let the car idle until your sensor reads 75° and check the voltage.
Would that work? I have no idea what to do after that though lol. Obviously you need to send the same voltage to the ecm using the resistor but I have no idea how stuff like that works.
I'm looking forward to the teardown, Bert.
Also interested in seeing how clean your 100,000 mile engine is. I bet the combustion chamber is extremely clean with your water/meth injection. Mine were always new looking with only a light tan tint to the pistons.
Also think it's a GREAT idea to eliminate variables. Keeping the IAT sensor at a constant value is very good.
#4563
Your idea is sound. A person can use a multi-meter to measure the resistance of the IAT Sensor at the temperature that one wishes to mimic. Then, a resistor of that same resistance value can be substituted in place of the IAT Sensor.
#4564
^^ no need to go crazy ill post which resistor to get to lock iat at 75 degrees i dont mind sharing info, on the other hand ill have to check with mods on this but we are working on our own ecu which will be able to control timing fuel ,basically a standalone incorporated with the stock ecu so all functions will still work and detonation should be a thing of the past as we would have full timing control and fuel control in cloosed loop..
i know libert and myself have been waiting on something like this as well as the supercharged community at an est 1275 plug and play .
#4565
runnin a little boost
Here are some pics of the oil cooler if anyone is looking to draw some extra heat away from the engine. It's 13 inch long, 4 in tall and 2 in thick. I bought it from Summit racing for about $100. The lines are Earls nylon black braided 8 AN line and the fittings are Russel all black also from Summit. The sandwich adapter is from Be Cool and was around $30. A little over $200 in all, but a good investment especialy with the turbo.
![Name: Sandwichadapter.jpg
Size: 100.0 KB](https://acurazine.com/forums/attachments/3g-tl-performance-parts-modifications-112/53171d1501294238-turbo-kit-acura-tl-04-08-sandwichadapter.jpg)
![Name: 06TLOilCooler.jpg
Size: 93.2 KB](https://acurazine.com/forums/attachments/3g-tl-performance-parts-modifications-112/53172d1501294238-turbo-kit-acura-tl-04-08-06tloilcooler.jpg)
#4567
![](http://i286.photobucket.com/albums/ll108/acura_photo/Sandwichadapter.jpg)
![](http://i286.photobucket.com/albums/ll108/acura_photo/06TLOilCooler.jpg)
Have you monitored oil temps before and after?
Just curious to know the difference.
This is also a bit beneficial from just having more oil circulating around.
Would you say maybe now your motor holds almost an additional qt? 3/4 of a qt perhaps. I can't tell the capacity of the rad, but even an additional 3/4 qt is pretty goodl
#4568
Anything can be fitted with a few tweaks and such..The mechanical part is the easy part, so to speak.
The bigger issue is tunning, since there would need to be some R&D into that aspect all over again. Rodney (J&R) can answer these questions better and let you know if there will be such plans
#4569
That's really neat! I like the exposed rad on the lower vent. Looks small enough for good exposure.
I am running an extra quart, so about 6 QT in all. I don't know what the temps were prior to the cooler or pre cooler now, but I know it's around 160 at the cooler on the warm side after I park. I did the cooler and the UCM at the same time so the drop in manifold temp was amazing. 50-60 degree drop.
#4570
Stand alones go for more than that I believe, and still have to crack them and wire them into the system.
Its probably too early for you to disclose, or even for me to ask, but just curious about what system are you guys working on?
#4571
Oil cooler is an awesome mod for a super/turbocharger.
I can't believe I forgot his name but the guy with the supercharged Accord coupe (I think that's part of his name) has an oil temp gauge so you may find some rough "before" temps from his setup. He has posted them on here before but you may have to dig very deep.
#4572
#4573
Hey Opel always glad to see you around I'll be up in Ny feb for Libert and I'm doing a full types build for another guy in Ny ,right now it's a little soon for full info but rest assure as I feel confident after testing I'll post up all info specs and functions ,this will be needed for high horsepower application to be have absolute full control over all engine parameters ..
#4575
I've seen posts from you and Bert, about you shooting up here and helping with his tear down/build. I'm around as well, and I'd like to see his tear down. If you guys are up for the company, just let me know and I'd be more than glad to spin a few nuts and bolts lol
#4577
The jands safeguard and knock monitor was been used during our months of testing so no one is really avoiding the knock discussion or that it was not monitored it has been and with our findings it was not deemed necessary at the power level which the kit is offered since we are all forgetting about this which I even recommended since this topic has been addressed before . Just an advice for anyone that will be using these units this needs to be installed and tested on a dyno and fine tuned as this is where you'll need to get it perfect or else this can and will become a nitemare .
The unit came back like a homing pigeon about a week later, and on the bench some of the channels were not working, so the coils connected to those channels wouldn't fire. I knew what the problem was by then, but it was too late.
I ran a Black Friday sale on a Ford Lightning forum, so I'm working through those orders, but I'll send you another unit after the first of the year if you want to try it again.
JohnP
#4578
I try to give a date that will be reasonable to avoid dissapointments so if evryone can just give til january 5th ill can have a full update and most likely a release ...
THE unit would be able to control evry aspect of the motor while still maintaining all luxury function ,possibly rpm increase and mph limit removal also we are very close if evryone can work along with me for the next two weeks we will have a break thru ....
ill get some info as this will have some really nice feature example off boost air fuel target for cruising just a bunch of features that will come in very handy...
#4579
Rodney: You got SN 001, the prototype of our eight channel box. I didn't know it at the time, but it had a missing etch that supplied 5v to some of the logic. The unit passed tests even though some of the chips were not powered up. Leakage currents from 5v input signals were enough to power up the chips during test, but that can't be relied upon, as evidenced by the driveability problems you described at the time.
JohnP
JohnP
John glad to have you in the forum id love to get another box and test it out for high horsepower application and possibly setup a plug and play prewired unit for the tl, this would be great if you can email me at rodney@acratlturbo.com we can setup for me to try a new box thank you
#4580
#4582
![Poke](https://acurazine.com/forums/images/smilies/poke.gif)
#4585
@libert69
Any updates with your engine? Did you at least get the old pistons pulled and inspect the block for damage? PM me your email address sometime and we can exchange engine pics.
![Wink](https://acurazine.com/forums/images/smilies/wink.gif)
#4587
18psi
Not much going on right now except ordering a whole bunch of parts. Pistons, arp head studs, rod bearings, crank bearings, rod bolts, timing belt, washers, gaskets etc. Block is getting bored also
fuel rails, fpr, and a bosch inline with the walbro for a return setup. Plus a few other goodies...
Ill be sending/driving the car down to florida soon so rodney and his group can install everything in there shop. New turbo plumbing also
I know they are working with that new ecu and Im basically sold on that as well. Since im the only auto I want the car in their shop so they can test the compatibility of the new ecu with the auto. They have very high hopes for this new ecu.
Building boost off the line should be a thing of the past with this new unit
#4589
That's awesome Bert! Keep us updated!
#4590
MY KBP IS BTR THN URS...
So what is the statues of the boosted Type-S?
I read the posts for the silver one, kidyosh I think was the screen name, but on the site there are pics of a black one.
Thanks ...great work so far...
#4592
i will definetly get an update out for the weekend,forgive me for been off for a while but with the ecu testing and twin disc setup its been a little crazy..
innaccurate this ecu has some pretty cool features especially for your setup ,ill get updates asap ....
hi hate cars ,phee ,dave b,opel hows everyone cant forget you guys as everyone values your inputs........
#4593
037 Im pretty sure if we can get a car in we will fit one on it ...
if your interested you can email me at tl20046speed@yahoo.com
#4598
#4599
Nice Bert!
What compression will this come out to when all is said and done?
Looks like it's almost a full skirt and as Inacc said, lots of meat in the pin area.
Did you guys change the pin height and use a longer rod by chance? The main reason I ask is I figured there would be a slight dish if compression was lowered into the 8-9 range.
#4600
damn those look beefy.
