QUESTION: Is this reliable? 2004-2008 ACURA TL DIRECT IPOD INPUT+ AUX - LEVEL #4
#601
PXAMG GuRu
Yes, we ask you to first go through the original place of purchase to return or exchange the module. If its an exchange then that is something that we can do if you have exhausted all means through the original place of purchase and have a copy of your reciept.
Everyone should be aware of the return policy of any product they buy from a retailer.
#602
PXAMG GuRu
what seems to be the problem? are the new harnesses wired differently than the one you installed or have it been compared pin by pin to make sure there is no difference between them. Maybe it can be the way people are installing them,could there be some sequence that after the install that the system has to be powered up or settings on the Head Unit.....either way can"t wait till somebody figures this thing out. It works on just about every other vehicle except our TL's..
yes they are diferient connectors and wired differiently.
#603
3GTLS
I think this is a bit harsh!! Especially, considering that Peripheral (the user and the company) are doing to address the new TLs. Most other company's reply to our problems would have been "Sorry, we don't support it". Peripheral, however, has been helping us for a while now.
#604
PXAMG GuRu
I appreciate the kind words!
#605
That is not true,
Everyone should be aware of return policy. Everyone should also expect manufacturer support.
#606
So, I let my XM expire. I may renew it, may not, but I won't bother adding the nav traffic. Will the existing peripheral unit work if i dont use nav traffic, what if i do not renew XM (without issues), or is it because we have an 07 / 08 that i need the new harness?
#607
I have the new harness to test and so far the SAT method is not working. Not sure if it will be fixed either. (BTW, I might have a good deal on the module if interested.)
#608
And you wont get the Acuralink messages (if you care about those).
#609
GREAT NEWS for Type S, the new harness works!
I got it installed tonight. It's a little tricky to learn, but it definitely works. (don't know if you can tell how damn excited I am?). Peripheral helped me out, so as far as customer service is concerned he has me sold!
Next on the list is a manual. It has the ability to flip through artist, genre, playlist, etc. but I am not sure how it works exactly. I only played with it for a half hour. And yes the XM1, XM2 and regular AUX still work. IT also gives you an AUX2.
PM me if you have any questions.
BTW - It sounds great too.
#610
#611
i give peripheral a big
#614
#615
Peripheral,
Thanks for the good news and all the efforts developing a solution. When do you think the new cable will be available ? Care to give a timeframe? Please sign me in for the group buy.
Are you guys also thinking about a solution for the iPhone 3G and new iPods charging issues?
#619
how did you guys get it to work;and if anyone that got it to work can you post a video of how it work's and looks in the type s.thanks p.s.what do you guys think a bout it so far.let the group buy start
#620
^initially the harnesses were bad- miswired. And then peripheral figured out we were turning on the wrong dipswitch on the module. Instead of turning on dipswitch 1, dipswitch 2 should be ON and the rest should be off.
it looks good, not much to see its just as if you were playing an mp3 cd - all info is displayed and can be controlled via steering wheel and head unit. now ive only used it for a whole 20 minutes or so, so i cannot give you a full review, but let us play with it some more and we'll keep you guys up to date. so far so good though, im really happy with it
#621
Well things are not looking good. The harnesses are back to the guys and there having complications. of course im there so i can only help so much. but ill try what i can. So far this harness has only helped one person and its one i installed in the vehicle. he still has nothing but good things to say about it.
hhmmmm....
No we are not testing it in a TSX. in the TSX it works behind the radio no need for a trunk harness. pull the pocket out from under the radio and your done. the plug is right there.
hhmmmm....
#623
#624
Sounds like this is the solution that i came online to find today... i want to use my steering wheel to control it...
So just to be clear the ipod itself is now in the trunk? or are you running a wire into the cabin and the ipod is there but the connection is in the trunk..?
If you need to have cables made up (production or prototype) I am a manufactureres rep and cable assemblies is something that i do alot of. If i can get a drawing i can get it quoted for (whoever) the owner is... i didnt read this whole post because i dont have that kind of time but i think it would be periferal?
Just throwing it out there...
Last ?- so if i went online and purchased today which cable harness would i get?
#625
Peripheral makes the module and the harness. I think they (the harness) are in production now (peripheral would have to answer for sure). Three of us received the new harness to test out, and that's what we have done.
As far as the steering wheel controls it only controls the volume, at least that's all I have tested. But the new setup allows everything else, hfl, XM, etc. to work as usual.
#626
3GTLS
The steering wheel controls work not only for the volume. You can change songs using the Channel up/down buttons but you have to hold them down, instead of just hitting it.
#627
The iPod is not in the trunk. The module is in the trunk and a wire runs into the vehicle to connect the iPod wherever you want.
#628
using the channel up/down does change the song. as voidtrance said, you have to hold down the button for a second before it changes the track - i find it much easier to just turn the tuning knob to change the track.
voidtrance - when you turn off your car does your ipod turn off? mine just pauses and i have to turn it off manually.
#629
Any updates on the changes for the iPhone 3G? I really really want one of these, but only if it charges my phone as well! I have an '06 TL w/navi and I HATE not being able to listen to my music!!
#630
3GTLS
Mine just pause too. But that is the default behaviour even if you are using the ipod with headphones. It should turn itself off after some time. (of course, I have an older IPOD and the new ones might have newer power features)
#631
PXAMG GuRu
#632
PXAMG GuRu
Ipod will shut off after it has been paused for 5 mins or so.
#637
PXAMG GuRu
This module only has two ports. No there is talk about maybe in the future comming out with a secondary circuit board to allow for another source. So unfortunately at this time only two sources at a time.
#638
I have a 2008 TL Type S w/NAV. I also have a 3G iPhone AND an iPod Classic (80GB).
Will this new interface work with both devices and charge them both? I'm not sure if the classic uses 12V or not.
Is there an ETA for the newest revision of this interface, other than 1Q2009? I'm dyin', man!! I HATE using that stupid AUX interface wire, the sound sucks going through that thing.
I am a little unclear - is there an interface I could buy today that works 100% with the iPhone 3G, just won't charge? I thought I read that there is, but I want to re-ask the question specifically. Also, current customers will receive the updated interface once its finished? Or will receive an adapter?
#639
Oh, and forgot to mention - a VERY willing test case, as well. Not sure if there's a difference between '07's and '08's, but if you need mine, I'm game! I already have the trunk molding half-way out due to being a complete freak and having to replace the factory amp with JL's.
#640
I'm aware that this is a TL forum, but after an exhaustive search around the internet, I can't find anyone anywhere who has posted the results of a Peripheral adapter working in a Acura RL (mine is a '05 to be exact). A couple of local resellers where I live insist that Peripheral's iSimple PXAMG/PGHHD1 "should work", but some of what I've read about the TL and RL says the mere existence of the Nav traffic feature (which this vehicle has but I don't subscribe to) creates functionality issues.
Peripheral (or anyone), can you tell me if any of your products are compatible with the '05-'08 RLs?
