Navigation Hack Guide: Welcome Screen Mod, Trip Computer, OK Button Nag Removal
Old 08-13-2009, 11:16 PM
  #1041
rollaaa's Avatar
Originally Posted by slick2404
Hey guys, looking for some help please:
Basically I have the 3.40c firmware, and was able to successfully update the background (thanks AcuraZine, KennyC and the Crew) but would also like to get rid of the nag screen. I followed the directions, and end up with a blank screen with the "GO" button replacing the nag text and "Okay" Button.
I've been searching all day and seem to think that I need the nonag-navi.exe file unless im looking for the wrong thing?
Any insight would be greatly appriciated.
I have the same thing.
I thought the "nag text/ok button" was suppose to be bypassed altogether and not just replaced with "blank screen/go button"
Is it suppose to have a blank screen and a GO button?
Old 08-14-2009, 01:18 AM
  #1042
8th Gear
Tos' 08-TL-S's Avatar
Has anyone tried to hack the white disc?
Have 08 NBP TL-S
Old 08-14-2009, 09:13 PM
  #1043
Unofficial Goat
The Dougler's Avatar
Maybe someone with a longer memory than myself can't point me in the correct direction. I did this like 3 years ago so things are foggy at best. I change my loading screen to say Please wait.......
Loading The Douglers Navigation
I know I did it in hex editor, but I can't remember which file I edited. Long story short, the car is sold and I'd like to switch the name for the new owner, rather than just loading up the factory one setup, or the no nag one. Maybe someone can point me to the right thread if it hasn't been deleted. Thanks.
Old 08-24-2009, 03:28 PM
  #1044
6th Gear
saguratus's Avatar
Hello everyone, Just wanted to stop by and let those who might be interested know that there will be a hack for the nag screen shortly. I just acquired a navigation dvd yesterday (6.72B), and I've already patched up the code. Just need to load it up and test it out before making a release.
For those who can't wait, here's the jump that needs to be patched
Old 08-25-2009, 04:40 PM
  #1045
nalek's Avatar
6.72?
Since you have no other posts, I cant tell if you're talking about the 2007-2008 navi systems or not, but I hope you are!
If so, alot of people are going to be thanking you!
Old 08-27-2009, 07:18 PM
  #1046
kakarot305's Avatar
I tried doing this but i can not find BNHH401A.BIN in my CD any helpsS?
Old 08-27-2009, 07:24 PM
  #1047
kakarot305's Avatar
Help hacking NAvi
So i red the guide i was going to do it but when it came to the step where i had to use BNHH401A.BIN that was it that file "BNHH401A.BIN" is not on my CD my CD is orange and the car its and 2005
Code:
BNHH401A.BIN
Need this file please
Old 08-27-2009, 10:20 PM
  #1048
AlexNYC's Avatar
anyone know how to use CEBIN?
or the files to kennynyc for version 3.40c
Old 08-28-2009, 11:25 PM
  #1049
kakarot305's Avatar
anyone can help?????
Old 08-29-2009, 04:43 PM
  #1050
'16 FBP Advance FWD
kfhughes's Avatar
Your DVD might have BN2HH12C.BIN instead of BNHH401A.BIN.
Old 08-30-2009, 12:57 PM
  #1051
unr1's Avatar
do these modifications (OK screen mod for example) work for 2009 White DVD Map Update v4.73A ?
Old 08-30-2009, 01:46 PM
  #1052
unr1's Avatar
after some reading, it seems like the nag screen can't be removed for 07-08s
Old 08-31-2009, 01:03 PM
  #1053
kakarot305's Avatar
then how do i hack it?
Old 08-31-2009, 09:41 PM
  #1054
6th Gear
saguratus's Avatar
Originally Posted by nalek
6.72?
I am, just got an 09 with navi. And for the person above who said "it can't be removed", I assure you, it can.
I'll make a release once I get around to rebuilding the image and testing it out.
Old 08-31-2009, 10:15 PM
  #1055
GeezerB's Avatar
If you can pull this off, you will be thanked every time I start my car
Old 09-02-2009, 09:01 AM
  #1056
nalek's Avatar
I must be confused, I thought the 2009's were not DVD Based. And the 2007-2008 models use 4.XX version number.
If you do get it for the 07 and 08's, it would be great.
Old 09-02-2009, 10:55 AM
  #1057
GeezerB's Avatar
He must own another model as he quoted disc version 6.72B. Hopefully the method will be the same.
Old 09-02-2009, 03:17 PM
  #1058
9th Gear
hubtech's Avatar
Ohhhh - I can't wait!
Old 09-02-2009, 10:54 PM
  #1059
6th Gear
saguratus's Avatar
Unfortunately bad news if you've got an 07-08, as this hack is only for 6.72B. I'd be willing to crack earlier versions if someone will work with me to get the binaries that need to be modified.
Old 09-03-2009, 09:24 AM
  #1060
9th Gear
hubtech's Avatar
I've recently gotten a '09 MDX with version 4.73A DVD in it. My understanding is that we would need the 09Touch2.BIN file but I could get any of them. Or if you are referring to the the dll or exe files within them, I can get those too. Let me know which ones, once you're ready. Obviously you'll want to finish up with your version and release it first.
Old 09-03-2009, 09:34 AM
  #1061
6th Gear
gman07's Avatar
I can get you the binaries for the 4.55 07 disk. There are lots of members here that are looking for the OK nag hack for the 07-08 systems. Let me know what you need and I will get them to you...thanks for the offer...as stated above, you will make lots of 07-08 owners very happy...
Old 09-03-2009, 08:45 PM
  #1062
win63dow's Avatar
This may not be the place to ask this , but is there a less expensive way to get a new disc for my 04 TL . mine gets lost real easy and a lot of old streets are "undesignated areas" .
Old 09-09-2009, 02:39 PM
  #1063
Freshjive360's Avatar
Is this hack possible for V 3.3??
Ok, so I tried reading through this thread a little but since it's so lengthy could someone either inform me or point me to the correct post number? I have an '04 TL with the V 3.3 CD (if i remember correctly it's 3.30c?) and I want to know if this hack is possible, and if so, how? Any direction would be appreciated. Thanks.
Old 09-10-2009, 03:06 PM
  #1064
redsox04tl's Avatar
having same problem. have v3.3 dvd
is the same nav hack process used for the v3.3 dvd?? and its also missing the BNHH401A.BIN files...help needed. thx
Old 09-10-2009, 03:07 PM
  #1065
redsox04tl's Avatar
if you get an answer pls let me know. have same problem. thx
Old 09-10-2009, 04:11 PM
  #1066
Well I haven't yet received an answer for certain, but upon reading the thread a little closer I stumbled upon a few posts (i.e. #46, #241, etc) which led me to think that it is possible to do the hack on the 3.30 disks, or at least the 3.30f version. But not for sure on earlier 3.30 versions. Anyone??
Old 09-10-2009, 08:56 PM
  #1067
Ok, so I'm a dumbass. Apparently I have Ver.3.30F and according to the postings, IT CAN BE DONE!! Sorry for my earlier ignorance.
Old 09-10-2009, 09:26 PM
  #1068
I need to download Kenny's files HMIManager.zip and navi.zip but when I click on the links on pg. 1 I get directed to a savefile.com's website which is upgrading its system. Does anyone have these .zip files saved on their computer and can send them my way?? Thanks.
Old 09-14-2009, 11:42 PM
  #1069
Phmbm12
Phambam12's Avatar
lol i totally need help just MAKING the picture itself. i dont have any photo editing programs. can someone do it for me please?
Old 09-15-2009, 09:15 AM
  #1070
3rd Gear
James7Bond007's Avatar
6.72?
The 6.72 disc is from the '09 Honda Fit (and possibly other models). It's the turquoise-colored disc.
I'm a s/w engineer (with an '09 Fit) and am interested in writing some custom software for the Nav system. I recall reading a while back that someone was able to get a simple Hello World app to run on their Honda navi, so the possibility to add additional software exists.
I'd like to improve the USB MP3 player, as it only shows the first 10 or so characters of the track title and artist. When browsing folders, the system shows all folders as if they were right off the root folder.
The iPod functionality supports playlists, and the PCMCIA card slot supports searching by artist or track name, but the USB player has neither of these features. I'm not complaining, as I love having access to 16GB of music from my car stereo - but there's always room for improvement
If anyone has any tips on how to create custom software for the Navi system, please let me know.
Old 09-15-2009, 01:49 PM
  #1071
2012 TL SH-AWD
NICKFRAZ's Avatar
I got a question reverting back to the origial post about the trip computer hack...it may sound like a dumb question but what exactly does it do? i understand the wallpaper and ok hack but i dont quite understand this one. Thanks in advance
Old 09-15-2009, 02:43 PM
  #1072
6th Gear
saguratus's Avatar
Well, I went ahead and fully patched HMIManager.dll. Use at your own risk! I can't promise this will work, they do everything they can to make sure you see that warning screen. In fact, they employ so many tricks that they have special code just to remove all the duplicate instances of it.
For 6.72B ONLY!
http://saguratus.com/nick/Navi/HMIManager.dll_patched
If you want an earlier system patched, contact me on Aim -- aim(at)saguratus.com
Old 09-15-2009, 04:25 PM
  #1073
6th Gear
saguratus's Avatar
File removed, turned out to be a partially corrupted copy from the main package.
I've instead directly modified 09AVN2.bin with the changes, I'll be testing shortly.
Old 09-15-2009, 04:43 PM
  #1074
3rd Gear
saguratus, thanks for all your work. What files (besides 09AVN2.bin, if any) do we need to put on the CD to update the firmware?
Old 09-15-2009, 05:38 PM
  #1075
6th Gear
gman07's Avatar
saguratus, you think you can crack the OK nag for the 4.55 disk? If so, what binaries do you need?
Old 09-16-2009, 12:07 AM
  #1076
6th Gear
saguratus's Avatar
I could, but I'm unfortunately extremely short on time. I'll look into other versions after I get a fully working patch for 6.72. Right now I've got a patched up 09AVN2.bin, but I still have to fix the checksums by hand before it'll take it.
James7Bond007: You need:
09AVN.bin
09AVN2.bin
A0000_00.MNG
DCA0.REG
PRG_INFO.MNG
UPDATE_APL.exe
Currently there's no way to update new modules in a CECompressed binary, such as the one on 6.72, since it utilizes XIP (Execute-In-Place). The most you can do at this time is change the graphics.
Old 09-16-2009, 08:13 AM
  #1077
6th Gear
gman07's Avatar
09AVN.bin
09AVN2.bin
A0000_00.MNG
DCA0.REG
PRG_INFO.MNG
UPDATE_APL.exe
Cool...completely understand. Post when you have the time to look at it...thx
Old 09-16-2009, 08:15 AM
  #1078
Back to my post on 9/10: I need to download Kenny's files HMIManager.zip and navi.zip but when I click on the links on pg. 1 I get directed to a savefile.com's website which is upgrading its system. Does anyone have these .zip files saved on their computer and can send them my way?? Thanks
Old 09-17-2009, 12:55 PM
  #1079
ACURAACT2's Avatar
along with freshjive360 i'm lookin for working links for nag removal and trip hack. anyone have URL or files for v3.4. not the programs but the actual modified *.bin i can download, copy to cd and upload to car.
Old 09-19-2009, 08:30 PM
  #1080
Extremistpullup's Avatar
I just bought a 2006 TL and I my Orange disk is a 3.5 I was able to change my splash screen but unable to find the links to do the \\"ok\\" button and Trip computer hack. I\\\'ve tried to load the two file from \\"38navi_and_trip\\" and they wouldn\\\'t load so I saved them over the old ones with all 9 Bin\\\'s it loaded but didn\\\'t take care of the OK and trip computer options My Loading Filename is BNHH401A.BIN and My Version is 3.10.04 Orange Disk 3.5 please help any advice?
Quick Reply: Navigation Hack Guide: Welcome Screen Mod, Trip Computer, OK Button Nag Removal
