Navigation Hack Guide: Welcome Screen Mod, Trip Computer, OK Button Nag Removal
#522
I know I am going to get roasted for this, but I did a search and did not see anything. I have disk 3.30, and I moved the BIN files to my hard drive (I only had six of them) and there is no BNHH401A.BIN file. What do I need to do??
Any help will be appreciated.
#523
Please Check Disc
I was able to modify the files, etc. Burned them to a cd as instructed.
After I hit the Load Disc button, the screen changes black and I get a green window with white text,
Please Check Disc.
I've tried 7 different cd-r and cd-rws, even a DVD-R.
What am I doing wrong? Any thoughts?
Please Check Disc.
#524
ZELL22...
BN2HH12C.BIN is the name of the file you modify on the navi disk version 3.30, BN2HHMLD.BIN is the other file you should have copied. You can use dumpnavi to change the splash screen but not to add any of the hacks, to do the hacks you need to use CEbin. hope this helps
#525
Originally Posted by tinley.geo
ZELL22...
Thanks again.
#526
Originally Posted by ZELL22
Hey, I really appreciate the response. I will try this as soon as I get off work tomorrow and report back here.
Thanks again.
Thanks again.
#527
Originally Posted by JD'S DubTL
Hey can you let me know if you get the nag screen mod... I have the 3.30 ver and can't seem to get it.
Most definately, I got you. Hopefully I'll be able to get it going.
#528
v4.55a problem
OK, I followed all instructions laid out earlier in this thread (thanks Bearcat94) - absolutely no error messages when at the cmd prompt. Extracted the new opening1.bmp from the bin file and it was the new image.
Went to load the new files, (used a CD-R) again no problems - screen showed the files being uploaded - but when it finished, I still had the old splash screen.
So, any suggestions? Maybe I'm getting too old for technology...
#530
I always wonder if it is possible to have a program for the tpms and backup sensor program into our navi display via the load function into our dvd navigation drive. so they can all share the same screen like the extra calculator, trip computer, etc... I won't mind writing a little code.... just need some direction. thanx
#531
Can I get a little help?
I've gotten the Back.bmp and the Trip Hack working but I can not get the OK hack.... I keep getting this error when I try to dump the navi.exe back to the bin:
C:\Acura>dumpnavi BNHH401A.BIN update navi.exe
Updating navi.exe ...
The size of the updated file must be less-then or equal to the size of the old file.
This feature might be introduced in a newer version.
Updated file (COMPRESSED): 3028352 bytes Old file (COMPRESSED): 3028315 bytes
#532
#537
Were u able to get it going?
#538
I got a 3.3 ..and have successfully gotten all 3 mods.. use the post on page 2 of this thread..i used Cebin..and it was really easy.. everything loaded just fine and only after my 1st try!! I was hesistant on doing it because of such an old version for nav..havnt tried out the trip computer gonna mess with it later...
#539
Nope, not yet. I have been unsuccessful at doing so. I PM'ed someone who said they got it working and was waiting on a response, but he hasn't yet. I will try the last suggestion here.
Have you tried it out yet using Cebin??
Let me know.
#540
What are you having problems with...i assume you have 3.30g, have you been able to get the trip computer hack?, i have tried getting the OK button/trip computer hack but keep getting a warning saying " some records have been resized. Address will be recalculated", im doin this on CEBin..you got any suggestions?
#541
Originally Posted by dr mikeylu
i got the same warning sign in dos..and right under it ..it said "done." So i just renamed the edited bin to the original file name .bin..burnt it with the MDL.bin and it worked.
#542
hmmm...when I loaded mine I just got a blank screen...im gonna try it again though...thanks for the info.
#544
I have a 06 Honda Odyssey with ver 4.31 navi disc. My problem is that I get "Please check your disc" error. I tried burning on to dvd-r, dvd+r, dvd-dl, cd-r, cd-rw, different brands of discs. I've used nero on pc and toast on mac with udf and iso options. All resulted in "Please check your disc". Then I tried to install from the original disc and the result was "Please check your disc". I've read on earlier posts that some people got the same error but they modded the wrong bin file. I believe I did mod the right bin file because I extracted all the bin files on the original disc and checked out all the bmp files to find out the splash file the navi used. If anyone have any other ideas, I would greatly appreciated.
#545
what version..and what program do you have..if you have 3.30 and are using Cebin..i could post a step-by-step for you that i used ..Im no expert at this stuff but i'll tell you what i did and hopefully you'll have similar success
#546
Does anyone have the "BNHH401A.BIN" file thats already extracted/updated with angry dad's trip mod available for download? For some reason when i go to extract both my background modded BNHH401 file and the original one from the Orange DVD i keep getting a message that says "Unable to Open BIN FILE" in cmd prompt, Thanks
#548
Originally Posted by PPatel247
Hey i need some help with angry dads trip mod
i can extract bnhh401A
also does any one have it extracted
thnxs
thnxs
#549
Ok, I've read most of this thread.
Do you need any specific model nav system to do the wallpaper hack?
I just bought an '05 TL with Nav system. I would love to put a new wallpaper up.
Also what is the Trip hack? Can someone explain?
#550
thnxs Parth Patel
#551
#554
Hey TL310
Do you have BNHH401A extracted and updated with angry dad trip mod because i cant get my bnhh401a extracted and it shows "Cannot open BIN."
so i was just wondering if you had it like that and like i could download it
Thanxs
PPatel247
Thanxs
PPatel247
#558
Originally Posted by TL310
Yea I have one Maybe I can download it somewhere. But you have to redo the pic if u want another one.
