The definitive LED thread: All you'll ever need to know about LED's 3G Garage #G-076
Old 08-30-2008, 12:26 AM
  #241
The Dark Knight's Avatar
Originally Posted by playa4real
yeah i thought they would be 194 bulbs..but i checked out the 2008 tsx bulbs on sylvania's website and they were not, so its really a toss up of whats used in the 09.
Dark Knight - its probably easiest to pull out the ones u have in there now and see which are used. you call also try the TSX part of this site
i'll pull out the bulbs tomorrow and get what info i can
(i just hope i dont break the plastic covers )
any tips on removing the door light cover? i felt around it tonight and it looks like there's no space for me to shove a flathead into...
Old 09-02-2008, 01:22 PM
  #242
One or Two?
chuanger's Avatar
Read through most if not all the LED threads and couldn't find an answer so i'll ask....
From what i've read the 07-08 TLs use 1157 front turn signal bulbs instead of the 7443.
My dilemma:
There are two types of 1157 switchbacks for the 07-08 front turn signal bulbs.
1.) V-LEDS TYPE 1 DUAL COLOR WHITE/AMBER 60 M-SMT BULBS 1157 2057
2.) V-LEDS TYPE 2 DUAL COLOR WHITE/AMBER 60 M-SMT BULBS 1157 2057
Does anyone happen to know which of these if any will work with the 08 TL-S?
V-leds clearly says type 1 and 2 are different but doesn't say in what way or how they are different. Thanks!
Old 09-02-2008, 01:43 PM
  #243
playa4real's Avatar
if its anything like the TL, look at it closely, u should see little tabs that keep it in place. IIRC for the TL, you remove it from the top or side and then pull..the bottom acts kind of like hinges. sorry i couldnt be of more assistance.
Old 09-02-2008, 01:50 PM
  #244
playa4real's Avatar
My dilemma:
when i bought mine there wasn't a type 1 or a type 2..there was just one kind and that was the one i bought. you may want to call them up and see if they can tell you what the difference is. They looks the same to me, except in the specifications it says the Type 2 is a 6000K color while the Type 1 does not state what it is
Old 09-02-2008, 05:31 PM
  #245
One or Two?
chuanger's Avatar
Ok just got clarification from Jake York at V-leds.
"Either one will work, they just operate differently.
Type 1 alternates white and amber when the turn signal is applied
Type 2 only the amber flashes when the turn signal is applied.
Hopefully that helps!
Thank you,
Jake York
Velocity Distributing Inc."
Old 09-02-2008, 07:27 PM
  #246
playa4real's Avatar
^^thanks for the info
Old 09-07-2008, 11:04 PM
  #247
2008 Acura TL
Rounder's Avatar
Put some blue LED lights in... looks better in person, obv...
Easy to do, but the passenger side front wouldn't come out! Had to use pliers and ended up breaking the acura bulb. Oh well.
Old 09-08-2008, 10:54 AM
  #248
Stickr Mstr
sk8ter4life's Avatar
*I can't seem to pop those vanity covers off..any tips?
I am using a really fine flat tip screw driver. The map lights were simple.
thanks!
Old 09-08-2008, 11:58 AM
  #249
07 NBP TL-S
JLJL's Avatar
vanity covers are tricky. It's really hard to straight up describe it =X
you just gott play it around theres one thing that clicks and u pull it off after that
driver side you approach it from the right and passenger from left
just be careful not to use too much strength cause later on when u put it back it might
get lil loose
sorry for being so vague its been so long since ive done the thing haha =/
just tape ur screw driver, and when i did it i used 2 tools one flat metal to open up the gap and a paper clip (open it and make it longer) to get in there and snatch the thing out
Old 09-08-2008, 10:52 PM
  #250
Stickr Mstr
thanks, the image below helped.
It still was a bitch, I think it was a bad design. There's no way you can remove that thing without scratching, the plastics..
Old 09-14-2008, 12:21 AM
  #251
cangbang's Avatar
i just installed 921-x9 leds from superbrightleds.com for my interior, reverse, and license plate lights. they all looked incrediable, but i am aware that many members on here have problems with leds for their license plate. Does anyone have issues with these 921-x9 bulbs for their license plate?
Old 09-17-2008, 10:23 AM
  #252
HuKaShI's Avatar
Originally Posted by sixsixfour
this is the brand that i use for the 4 domes, door and license plate:
http://www.brm21.com/US/bulb_e.html
i use the type 194.
rear:
inside:
door:
So, I called up the company that you ordered these from and asked if I could place an order for these bulbs over the phone. They told me that I couldn't but if I emailed them, they would make it available online for purchase. A few days after emailing, they sent me this link
http://www.e-bacs.com/usashop/produc...oducts_id=1139
So, I just placed my order, and it is a bit pricier than the ones at superbrightleds.com but according to your pictures, they seem to be alot better.
If anyone wants to order and doesn't live in Socal, you can order using the link above! The shipping is very expensive however, but I'm willing to pay it as I don't think I'll ever have to replace it like I used to with the ones from either superbrightleds.com or autoillumination.com
Enjoy!
Old 09-17-2008, 10:33 AM
  #253
sixsixfour's Avatar
thats the place where i bought them from locally. that bulb will fit the 4 domes, the door, the license plate and even the reverse lights (although its not bright to be reverse lights). if you can force it in a bit, it will also fit the trunk and the two vanity lights behind the visors.
this is what it looks like on the license plate housing:
Old 09-18-2008, 08:35 PM
  #254
playa4real's Avatar
For glovebox and center console LED talks.. check out this thread
https://acurazine.com/forums/showthr...6#post10007496
Old 09-19-2008, 02:04 PM
  #255
3zero3kid's Avatar
Hey Kenney I was just curious how u moded the memo and the security lights to be blue. Also is it possible to do the window switches the same? Thanks!
Old 09-19-2008, 05:04 PM
  #256
3zero3kid's Avatar
Also I was looking at V-leds.com trying to put together an order and noticed that I don't really know the difference between for example an 18 led tower and a 24 led tower. No I know that how many leds are on there but I guess I just don't know which is better? Is it better/ brighter to have the most LEDS possible or somewhere in between? Please help.
Old 09-19-2008, 06:01 PM
  #257
playa4real's Avatar
more LEDs = more output. whether you choose one or the other, just make sure that the LED bulb will fit wherever you are trying to install it
Old 09-23-2008, 01:17 AM
  #258
techguy's Avatar
Enjoy!
I get an item not found. Tried searching their site, no LED.
Old 09-23-2008, 08:39 AM
  #259
HuKaShI's Avatar
They may be updating their site. Their seems to be some links that are broken now that weren't before. I'm sure it will be back up soon.
Old 09-29-2008, 11:37 AM
  #260
tehloxely's Avatar
Has anyone installed LEDs for the rear tail turn signals?
Old 09-29-2008, 12:33 PM
  #261
playa4real's Avatar
from post 7
Originally Posted by Kennedy
- Rear Turn Signals:
7443 V-Leds 27 SMT
http://cgi.ebay.com/ebaymotors/2-AMB...spagenameZWDVW
Old 09-29-2008, 01:29 PM
  #262
tehloxely's Avatar
Thanks. Any Pics? I couldn't find any.
Old 09-29-2008, 04:58 PM
  #263
playa4real's Avatar
not much to see my friend. the LEDs provide a sharp on and off as you see on many newer cars.
Old 10-17-2008, 10:20 AM
  #264
techguy's Avatar
Dome supervision wire
someone posted that the wire to tap for the dome supervision is the "green/red" wire that is part of the green 5 pin plug rear of fuse box. Can someone tell me what I need to remove to access this?
Old 10-19-2008, 02:49 AM
  #265
sdevils18's Avatar
superbrightleds.com is a good site to go for information but they sometimes have trouble matching the exact diaode color so you may have to send some back if they dont match. I had an issue when changing the license plate bulbs but they were very helpful and sent me a free replacement
Old 10-19-2008, 01:01 PM
  #266
techguy's Avatar
I got 2 sets (2 bulbs per set) of the Luxer LED made by BRM. It was $26 per set. Very pricy. I was expecting it to be brighter than the www.superbrightleds.com - WLED-WHP which I use for the domes. I was a disappointed that it was only a bit brighter. Side by side with the WLED-WHP, you have to look directly at them to see which one is brighter. You can't see the difference based on the light casted.
Old 11-01-2008, 08:38 PM
  #267
flip_side's Avatar
^I was looking for some WLED-WHP from superbrightleds.com and they're not there anymore..
Old 11-02-2008, 12:53 AM
  #268
flip_side's Avatar
do I order the WLED-xHP6 instead? or is there something im missing..
Old 11-02-2008, 03:48 PM
  #269
techguy's Avatar
http://superbrightleds.com/specs/bulb_specsHP.htm
http://superbrightleds.com/cgi-bin/s...gi?product=CAR
4.95 each
Old 11-02-2008, 03:52 PM
  #270
flip_side's Avatar
^WOW NOW I SEE IT.. thanks so much.
WLED-xHP High Power LED bulb
i noticed the difference for the doors is a 921x9 and 921x12. the differences are the viewing angles, are most people using the 12 or 9?
Old 11-02-2008, 03:53 PM
  #271
techguy's Avatar
It might work for the domes since it has reflectors. I have not tried it. I do not think it will work well for the license plate.
Old 11-02-2008, 04:06 PM
  #272
flip_side's Avatar
I'm going the cold cathode route
Old 11-02-2008, 04:21 PM
  #273
flip_side's Avatar
only thing to add to my order, 921x9 or 921x12
Old 11-02-2008, 06:42 PM
  #274
flip_side's Avatar
nvm just placed an order for wled-whp x 4 and 2 921x12 cool whites 37 dollars total. time to look for vanities/trunk/reverse/glove box, and switchbacks !!!
Old 11-02-2008, 08:20 PM
  #275
OnefastTL448's Avatar
anybody have the link on the 18 Bulb Towers for the reverse lights? Cant seem to find them at all on the site as per recomendation in Post 7?
Old 11-02-2008, 08:46 PM
  #276
flip_side's Avatar
^I'm also looking for those reverse leds
Old 11-02-2008, 09:39 PM
  #277
flip_side's Avatar
it seems that the vanity mirrors/trunk have changed as well.. ive been looking through autoillumination and there are so many types of smt towers, can someone direct me to the vanity mirror, trunk, and the reverse lights
Old 11-03-2008, 09:41 AM
  #278
techguy's Avatar
Go through the posts and see if they found issues with it as I think some had. I think some say they do not last that long. Make sure it is as bright or brighter than stock.
Old 11-03-2008, 12:30 PM
  #279
I am looking for the ones from Vleds and I dont see they anyware is that what everybody is using for the reverse lights the SMT series towers?
Old 11-12-2008, 09:44 PM
  #280
once you go black....
timb24's Avatar
Ok so im officially confused. I want to get super white LED replacements for my 4 dome lights. I have been reading through this thread and there are so many conflicting views/links. Does anybody have the links for these lights from superbrightleds.com or v-leds.com?
Quick Reply: The definitive LED thread: All you'll ever need to know about LED's 3G Garage #G-076
