another solution for my auto CL guys
Old Jan 5, 2010 | 09:28 PM
  #81
p.diddy's Avatar
Originally Posted by acura_dipset_tl
just ordered an 07 TL tranny with only 32,101 miles on it with 90 day warranty.
can't wait for it to get here.
lol that was fast.
Old Jan 5, 2010 | 09:35 PM
  #82
Silva-type-s's Avatar
Got your mom in
Paul. I've heard that the 3g Type S tranny is alot bigger than the 3g Base TL is that also correct?
Old Jan 6, 2010 | 12:36 AM
  #83
acura_dipset_tl's Avatar
AM To WDP In My Garage
Originally Posted by p.diddy
lol that was fast.
I know right lol I don't play no games I'm also planning on getting the whole car repainted as well and I'm on the works on getting a custom molded 2G aspec kit to fit the cls.
Old Jan 6, 2010 | 10:55 AM
  #84
p.diddy's Avatar
I'm half way done with my kit.
Old Jan 6, 2010 | 11:59 AM
  #85
Cool
Old Jan 6, 2010 | 02:04 PM
  #86
Rapture's Avatar
The only place that sells the transmissions I'm looking for, are over 100 miles away from me Some place up in Washington is selling a '05 Odyssey trans with a little over 60k miles for $1000.
Old Jan 6, 2010 | 02:12 PM
  #87
YeuEmMaiMai's Avatar
Originally Posted by NVA-AV6
Could be done,.........
what parts did you need besides the o7 TL AT and drill the two holes in the trans casing?
Old Jan 6, 2010 | 04:44 PM
  #88
MrFluffy's Avatar
To many cars in my garage
I think he said you have change the filter housing but I would like to know all the stuff you have to do too
I would take my car to NVA but he is far away!
Old Jan 6, 2010 | 06:33 PM
  #89
NVA-AV6's Avatar
BANNED
06+ is and the bell housing bolt pattern is completly different.
Old Jan 6, 2010 | 07:50 PM
  #90
Got your mom in
o.ok
Old Jan 6, 2010 | 07:53 PM
  #91
MrFluffy's Avatar
Its a 3.5 so that makes sense
Old Jan 8, 2010 | 09:24 PM
  #92
Allen-'s Avatar
is out, so the
So, the 07 3.2L TL trans will physically bolt up to my 02 3.2 Type-S engine without modifications? I understand it may not function, but it actually fits on the engine?
What is "trans range switch, trans filter housing that need to be transferred"
Are those things found on my 02 5A/T? How exactly do you transfer a filter housing?
What are we making extra holes for?
If I get an Odyssey trans, can it be modified to enable SportShift mode?
Thanks.
Old Jan 8, 2010 | 10:07 PM
  #93
friesm2000's Avatar
B A N N E D
Thanks.
ss mode is ALL ELECTRONIC, so nothing inside the tranny is actually different for that
Old Jan 9, 2010 | 10:55 AM
  #94
Allen-'s Avatar
is out, so the
I understand its all electronic. My question was geared more towards, will the transmission shifter slide to the left to use the +/- gate.
Old Jan 9, 2010 | 11:02 AM
  #95
Allen-'s Avatar
is out, so the
p.diddy,
Are you still using your 2G shift gate? What about your 2G gauges? Does 1, 2, D3, and D4 still work with the 07 trans? I thought the 07's only had D5, D3, and L...
Old Jan 9, 2010 | 12:03 PM
  #96
NVA-AV6's Avatar
BANNED
Ok guys, just did some research thru my Acura parts dealer, mid-year in 07 they changed the block and tranny on the 07s (thanks Acura), so you have a 50/50 chance of getting a 07 TL tranny that will bolt up :rolleye:, I suggest sticking to 04-06 TL and Oddy......
Old Jan 9, 2010 | 03:03 PM
  #97
friesm2000's Avatar
B A N N E D
electronic means that nothing inside of the tranny actually moves when selecting SS (shifter is still technically in D5, just pushed to the side, so the computer know that you want SS mode)
and i don't see how a different tranny would block you from going into SS mode, cause all that stuff is on the shifter itself, so has nothing to do with the tranny
Old Jan 9, 2010 | 07:35 PM
  #98
Allen-'s Avatar
is out, so the
That makes sense. I was told that Honda/Acura's shifters aren't directly related to the transmission. I test drove a G37 and the shifter vibrated. Someone else told me that shifters in Nissan/Infiniti go directly into the transmission.
So, if the shift gate's positions are electronic, all of my 2G transmission functions will still work? (D4, D3, 2, 1) Even though the Odyssey may only have D5, D3, and L?
Any cons for putting an Odyssey transmission in over an 06 TL?
Old Jan 9, 2010 | 07:42 PM
  #99
friesm2000's Avatar
B A N N E D
was that g37 manual???, or are you talking about a manual on a nissan??? you also gotta remember a honda has a transverse mounted engine vs a longitudial (sp?)(front to rear), so the tranny is alot closer to the shifter, so vibrations don't have to go as far
and all the positions on the shifter are not electronic only the SS mode is, everywhere else has a shifter cable that moves which is linked to the tranny
Old Jan 9, 2010 | 08:05 PM
  #100
p.diddy's Avatar
p.diddy,
i never use the shitft gate so i couldnt even tell you. i havent even tried 1,2, d3 or d4. i jump in put it in d5 and go.
Old Jan 9, 2010 | 09:05 PM
  #101
I hope my 07 TL tranny is one of the ones that will bolt right up. if not ......
Any way to tell the difference?
Old Jan 9, 2010 | 09:37 PM
  #102
NVA-AV6's Avatar
BANNED
Pics of the bell housing, I can tell the difference.
Old Jan 9, 2010 | 11:33 PM
  #103
Rajca's Avatar
wham bam thank you ma'am
do u have a 4spd tl? if so u cant use the 5spd trans. u need to use the 4spd
Old Jan 10, 2010 | 06:53 AM
  #104
NVA-AV6's Avatar
BANNED
^Or update the ECU and harness to a 00+ TL
Old Jan 10, 2010 | 02:42 PM
  #105
Rapture's Avatar
Alright I dunno how I missed it but there are quite a few odyssey and TL transmissions around my area now... A lot of the transmissions with an A grade are about 1200-1450 or so... would I be fine with a B grade one? Of course I'm assuming the B grade only concerns the mileage and not any physical damage.
by the way out of curiosity, how are you guys transporting these transmissions out of the junkyard? Or do some yards have transportation services as well?
Either way I really dunno if I could even find a shop that would be able to install it.
Old Jan 10, 2010 | 04:12 PM
  #106
NVA-AV6's Avatar
BANNED
Usually grade B is based soly on milage unless other wise specified where a mounting boos may have been broken off in the collision, but if you are going thru all this trouble do you really want to start out with a tranny that already has 80K+ miles???? I could see doing that if your plan is to just fix it and dump it, but if you are keeping her I would pay the extra to get the lower mile unit.
Old Jan 10, 2010 | 05:36 PM
  #107
I got mine shipped from the yard near new york to baltimore for an extra $150 and only 32,101 miles on it.
or you could rent a truck and pick it up with that if the yard is close to you.
Old Jan 10, 2010 | 05:44 PM
  #108
friesm2000's Avatar
B A N N E D
and make sure to have a cherry picker with you when you try to move it, they are not light suckers at all, takes at least 3 people to even remotely be able to pick it up comfortably, and at least 4 would be better
Old Jan 10, 2010 | 05:48 PM
  #109
NVA-AV6's Avatar
BANNED
AT=180lbs
MT= 80lbs
I have picked both up by myself, the AT you do without the TQ converter which is a good 40lbs by itself and remeber to lift with your legs, not your back......
Old Jan 10, 2010 | 05:50 PM
  #110
Rajca's Avatar
6spd, all u need is one arm. their so light
Old Jan 10, 2010 | 06:05 PM
  #111
friesm2000's Avatar
B A N N E D
AT=180lbs
MT= 80lbs
taking it out does expose it to potential contamination, and putting it back in there is the potential of cutting the seal and such
and when you do get shipped a tranny from honda (an 01 odyssey tranny, so only a 4 speed) they do not want you removing the torque converter, but yes the TQ converter is a good chunk of that weight
Old Jan 10, 2010 | 06:08 PM
  #112
friesm2000's Avatar
B A N N E D
we don't even use a jack for them at work, one person holds it against the block while the other one loosens the last bolt, then both people lift (actually drop; and it is up on a lift also) it out and set it on the ground
and only one person is needed to move it if needed
Old Jan 10, 2010 | 06:12 PM
  #113
friesm2000's Avatar
B A N N E D
AT=180lbs
MT= 80lbs
btw: that weight for the AT seems offley low too, i am thinking somewhere closer to 300, cause i have trouble even dragging it across a smooth concreate floor
Old Jan 10, 2010 | 06:26 PM
  #114
NVA-AV6's Avatar
BANNED
That was the shipping weight on one that was shipped into me a while ago, actually the ticket said 19X, but that was including the pallet.
Old Jan 10, 2010 | 07:55 PM
  #115
civicdrivr's Avatar
No way does it weigh nearly 300.
Old Jan 10, 2010 | 08:00 PM
  #116
friesm2000's Avatar
B A N N E D
never said exact , i just know that it is a heavy f***er and a pain in the ass to move around, and a whole lot easier to move around with a cherry picker (also on the bad tranny, the torque converter would have at least been partially filled so add that weight in too, and the new TQ converter was proably at least partially filled too)
Old Jan 10, 2010 | 10:37 PM
  #117
  • Originally Posted by friesm2000
Mine has the shipping label saying 270 pounds but I think that includes the pallet weight.
Old Jan 10, 2010 | 10:46 PM
  #118
friesm2000's Avatar
B A N N E D
i knew i was not that crazy,
but lets say 20 pounds for the pallet (i know it is not going to be a full size one ethier)(and knida hard to find an exact weight)
you are still looking at 250 pounds+ for a AT that is ready to go into a vehicle (plus the fluid weight too)
Old Jan 11, 2010 | 11:45 PM
  #119
Hey guys not to go off topic but the other day I went to advance auto part the get my check engine light checked out because it was on and they said I had 6 codes all read "cylinder miss fire" 1-6. could that be because the tranny is done?
Old Jan 11, 2010 | 11:49 PM
  #120
friesm2000's Avatar
B A N N E D
proably not, try searching for cleaning out your egr passages for the misfire codes
