another solution for my auto CL guys
Old Jan 3, 2010 | 05:22 PM
  #41
p.diddy's Avatar
Originally Posted by acura_dipset_tl
im looking now to see if a can find at 3g tl tranny for this swap.
my tranny on my cls is completely shot.
car-part.com. i got mine in virginia
Old Jan 3, 2010 | 06:40 PM
  #42
friesm2000's Avatar
B A N N E D
Originally Posted by NVA-AV6
Ok guys......
Preffered would be a 04-06 oddy trans, since it is a mom mobile there is much less chance it has been beaten on and they are plentiful in the yards.
It is not completely a direct drop in there are some parts (trans range switch,trans filter housing) that need to be transferred and a couple holes that are cast into the housing need to be tapped, the bosses are there they just need to be drilled and tapped.
Triptronic is all a matter of ECU, the physical trans has nothing to do with it.
other advantage is that it was designed for a heavier vehicle too, so going to be designed that much stronger
and for soccer moms, they seem to be the ones that will just drive the vehicle and ignore it till something breaks vs trying to do preventitive maintence, and fixing something before it gets major (,had i known i was buying my car, i would have kept the crank and rods, from the one that i did like 3 years ago [bought my car only like 3 months ago], would've been a dirt cheap stoker too; she ran it out of oil, from really over extended oil changes)
Old Jan 3, 2010 | 06:41 PM
  #43
p.diddy's Avatar
lol never though about that.
Old Jan 3, 2010 | 06:50 PM
  #44
friesm2000's Avatar
B A N N E D
yeah, i would almost rather have one that has been taken care of, even though it might have more WOT runs on it (or mileage), then one that was never looked after
but kinda hard to tell it's previous life with it being in a salvage yard (and proably already pulled out of the vehicle too)
checking the fluid is about all you can do, but even then when you pull the axles out of it, basically all the fluid drains out, so no really way to even check that
Old Jan 3, 2010 | 07:05 PM
  #45
NVA-AV6's Avatar
BANNED
[QUOTE=friesm2000;11615965]other advantage is that it was designed for a heavier vehicle too, so going to be designed that much stronger
[QUOTE]
You would think, but not, they are all the same series tranny, only the ECU is programmed a bit different to provide slower gear engaugment to not stress it as hard.
Old Jan 3, 2010 | 07:13 PM
  #46
`ill*tl's Avatar
Sweet!
NVA-AV6, other than what you posted needed to be done, it should bolt-up with no fitment issues correct?
Old Jan 3, 2010 | 07:44 PM
  #47
NVA-AV6's Avatar
BANNED
Yes
Old Jan 3, 2010 | 08:29 PM
  #48
MrFluffy's Avatar
To many cars in my garage
It says that the 04-06 oddy trans is for a 3.5 is that correct
Old Jan 3, 2010 | 08:41 PM
  #49
NVA-AV6's Avatar
BANNED
Yes, but it has the same bell housing bolt pattern and is also a member of the BXMA tranny family.
Old Jan 3, 2010 | 08:43 PM
  #50
MrFluffy's Avatar
Thats pretty weird, thanks
Old Jan 3, 2010 | 08:51 PM
  #51
p.diddy's Avatar
looks like theres going to be more swaps coming.
Old Jan 3, 2010 | 09:27 PM
  #52
MrFluffy's Avatar
as soon as mine goes im swapping it but I have to find someone to do it for me , which is going to be difficult but I honestly think that this is the greatest solution to the problem and the easiest and cheapest I found two or three trannys for $800 with undr 3000 miles on them
Old Jan 3, 2010 | 09:38 PM
  #53
friesm2000's Avatar
B A N N E D
[QUOTE=NVA-AV6;11616009][QUOTE=friesm2000;11615965]other advantage is that it was designed for a heavier vehicle too, so going to be designed that much stronger
I was thinking along the lines of maybe a little grippier clutches, stiffer springs for the valves, and along that line, but yeah basically all the same tranny just modded for each vehicle
Old Jan 3, 2010 | 09:39 PM
  #54
CL-S progression 01's Avatar
lowrd on tein CS biatch
if mine ever takes a dump I'm damn glad there is a solution and someone did it to prove it.
very nice p.diddy
Old Jan 3, 2010 | 09:49 PM
  #55
p.diddy's Avatar
very nice NAV-AV6
fixed.
lol he did all the work i just paid for it. im very happy with the outcome though.
Old Jan 3, 2010 | 11:15 PM
  #56
phee's Avatar
I got the Shifts
Originally Posted by YeuEmMaiMai
Obviously you haven't seen soccer mom drive, have you?
x2 fucking minivans zippin around like the autobahn
Old Jan 4, 2010 | 12:27 PM
  #57
SG81's Avatar
Missing My CL-S
i could have sworn the Oddy's have/had the tranny problems.
either way, nice work diddy/NVA
Old Jan 4, 2010 | 02:49 PM
  #58
friesm2000's Avatar
B A N N E D
the older ones do/did (i think about 99-04 or so, but not totally sure), but i don't think the newer ones do
Old Jan 4, 2010 | 02:57 PM
  #59
rondog's Avatar
Former Sponsor
Ok, now the real question is how hard would it be to swap a 6 speed SH-AWD and 3.7 V6 into the CL... Seriously, what do you think NVA-AV6?
Old Jan 4, 2010 | 02:58 PM
  #60
friesm2000's Avatar
B A N N E D
, but would be god damn sweet though
Old Jan 4, 2010 | 03:16 PM
  #61
detinater's Avatar
Hey NVA, trans just blew up in my 03 tl-type S, I would like to know more about the Oddy trans replacement or possibly a 6sp manual conv. My post is here, https://acurazine.com/forums/2g-tl-1999-2003-98/time-has-come-758367/, would really like some expert advice from you and other members.
Thanks a ton!
Old Jan 4, 2010 | 03:22 PM
  #62
friesm2000's Avatar
B A N N E D
Originally Posted by detinater
Hey NVA, trans just blew up in my 03 tl-type S, I would like to know more about the Oddy trans replacement or possibly a 6sp manual conv. My post is here, https://acurazine.com/forums/showthread.php?t=758367, would really like some expert advice from you and other members.
Thanks a ton!
holy shit, you are local to me
Old Jan 4, 2010 | 03:24 PM
  #63
NVA-AV6's Avatar
BANNED
Could be done, but one hell of alot of work and $$$$, the car would have to be converted to basically the donar vehicle including the ECU ,cluster, ABS in order to control the AWD, need the complete rear end and re-work control arms and rear subframe to mount it up and the gas tank should be fun.
A estimate to do this would be between $12K and $17K when all was said and done. Of course it would be the ONLY 3.7L SH-AWD 6spd CL I have heard of..........
Old Jan 4, 2010 | 05:13 PM
  #64
MrFluffy's Avatar
NVA you should do a simple write up on how to do the conversion (trans conversion) I would help us out alot
Old Jan 4, 2010 | 05:20 PM
  #65
NVA-AV6's Avatar
BANNED
^It isn't that simple and I have bills to pay, nothing against you guys but I am up to my eyeballs in work and a proper write up would take a day with pics, ect....
Old Jan 4, 2010 | 05:24 PM
  #66
Rajca's Avatar
wham bam thank you ma'am
^x2 fsstyms did the closest thing to a diy on the 2nd gen tl side
Old Jan 4, 2010 | 05:25 PM
  #67
richardparker's Avatar
3.7L Nitrous Breathing CL
Anyone offer any performance upgrades for the 07 tl tranny.
like a higher stall convertor or diff upgrades.maybe ligher axles
Old Jan 4, 2010 | 05:39 PM
  #68
rondog's Avatar
Former Sponsor
You're confident you could pull it off and it would work without problems? n After all that, might bet easier to buy the TL that way, lol.
Old Jan 4, 2010 | 05:46 PM
  #69
NVA-AV6's Avatar
BANNED
Anything CAN be done, but is the cost justified? Granted it would be a uniqe one of a kind weight almost 1000lbs less than the TL......
Old Jan 4, 2010 | 05:47 PM
  #70
civicdrivr's Avatar
Dont get me thinking about this now...
Old Jan 4, 2010 | 05:48 PM
  #71
Rajca's Avatar
sti/evo killer
plus, would help out with traction off the line
Old Jan 4, 2010 | 05:53 PM
  #72
friesm2000's Avatar
B A N N E D
and the tl is a 4 door too, were the cl is only a 2 door
Old Jan 4, 2010 | 07:11 PM
  #73
Rapture's Avatar
Meh, the only ones around me are in the $1200 range, and that's just for the trans. I guess I'll have to hear more about this before I feel like going for this kind of swap.
Old Jan 4, 2010 | 07:52 PM
  #74
p.diddy's Avatar
in the long run i feel like its better than putting in another "rebuilt" cl tranny.
Old Jan 4, 2010 | 09:44 PM
  #75
NVA-AV6's Avatar
BANNED
I would only do this swap if there is a real issue with your current trans.....
Old Jan 5, 2010 | 12:58 PM
  #76
acura_dipset_tl's Avatar
AM To WDP In My Garage
just ordered an 07 TL tranny with only 32,101 miles on it with 90 day warranty.
can't wait for it to get here.
Old Jan 5, 2010 | 01:15 PM
  #77
Rapture's Avatar
Well I dunno, I keep thinking about a 6MT swap... but then again nothing on car-part.com shows any spare M/Ts out there... Aren't there Honda Accord manual trans' that fit a CL...? I remember hearing there are...
Well I dunno, I'd do something like this if I could actually find someone who knew how to fit this onto the CL, and could do it well.
Old Jan 5, 2010 | 02:01 PM
  #78
TheWeez's Avatar
I Wanna Beer
Seems easier to just throw a 2nd engine in the trunk. Guy on the SHOForum.com did that. Put another SHO engine in the back to drive the rear wheels.
Old Jan 5, 2010 | 02:05 PM
  #79
Rajca's Avatar
The 7th gen accord trans will work with the cl. But they don't have lsd. And u need lsd to put some power down
Old Jan 5, 2010 | 02:08 PM
  #80
TheWeez's Avatar
I Wanna Beer
Too bad Quaife doesn't make an ATB diff for any Hondas other then a could four bangers.
