another solution for my auto CL guys
Old May 16, 2010 | 04:06 PM
  #481
DC2*&*CL-S's Avatar
I'm getting the P1706 CEL when driving at times. Around the time I get the code, 2 and 3rd gear shift hard and the rest are smooth.
I did a search on it and they are saying it means the computer doesn't know what gear its in so since I don't have a manual for this car can anyone help me out?
Old May 16, 2010 | 05:29 PM
  #482
NVA-AV6's Avatar
BANNED
DTC P1706: Open in Transmission Range Switch Circuit
NOTE: Record all freeze data and review General Troubleshooting Information before you troubleshoot.
1.Test the transmission range switch. Is the switch OK ? YES - Go to step 2. NO - Replace the transmission range switch.
2.Turn the ignition switch OFF.
3.Check for continuity between body ground and PCM connector terminals B20 and B22 individually. Is there continuity? YES - Go to step 4. NO - Repair open in the wires between PCM connector terminals B20, B22 and ground (G101). Repair poor ground (G101).
4.Turn the ignition switch ON (II).
5.Shift to the D5 position.
6.Measure the voltage between PCM connector terminals D9 and B20 or B22. Is there voltage? YES - Repair open in the wire between PCM connector terminal D9 and the transmission range switch. NO - Go to step 7.
7.Shift to the R position.
8.Measure the voltage between PCM connector terminals D6 and B20 or B22. Is there voltage? YES - Repair open in the wire between PCM connector terminal D6 and the transmission range switch. NO - Go to step 9.
9.Shift to the P or N position.
10.Measure the voltage between PCM connector terminals B14 and B20 or B22. Is there voltage? YES - Repair open in the wire between PCM connector terminal B14 and the transmission range switch. NO - Go to step 11.
11.Shift to the D4 position.
12.Measure the voltage between PCM connector terminals D8 and B20 or B22. Is there voltage? YES - Repair open in the wire between PCM connector terminal D8 and the transmission range switch. NO - Go to step 13.
13.Shift to the D3 position.
14.Measure the voltage between PCM connector terminals D14 and B20 or B22. Is there voltage? YES - Repair open in the wire between PCM connector terminal D14 and the transmission range switch. NO - Go to step 15.
15.Shift to the 2 position.
16.Measure the voltage between PCM connector terminals D15 and B20 or B22. Is there voltage? YES - Repair open in the wire between PCM connector terminal D15 and the transmission range switch. NO - Go to step 17.
17.Shift to the N position.
18.Measure the voltage between PCM connector terminals D4 and B20 or B22. Is there voltage? YES - Repair open in the wire between PCM connector terminal D4 and the transmission range switch. NO - Check for loose terminal fit in the PCM connector terminals B14, D4, D6, D8, D9, D14 and D15. If necessary, substitute a known-good PCM and recheck.
One of a couple things here.....
1) Lose connection at the range switch.
2) Bad range switch
3) Mis-adjusted range switch
Old May 16, 2010 | 06:30 PM
  #483
DC2*&*CL-S's Avatar
Thank you ! ! ! ! !
Old May 17, 2010 | 02:56 AM
  #484
eggyhustles's Avatar
DC2
know of any good transmission shops in the bx? or the tri-state area?
Old May 21, 2010 | 09:47 AM
  #485
DC2*&*CL-S's Avatar
http://car-part.com/... thats were I got mine from.
Old May 21, 2010 | 10:03 AM
  #486
DC2*&*CL-S's Avatar
2) Bad range switch
Well I have been looking in the Acuraoemparts.com catalog to use the diagram for the location of the "Transmission Range Switch"
I think I have been through the entire catalog for the Acura Parts on tghe 02 CL-S and cannot find this?
Can anyone tell me if the transmission range switch is the cable that links the gear selector to the transmission?
I think this cause I may have not properly attached the cable on the transmission end after noticing the gear selector has been not shifting as easy as its supposed.
An Example of this is shifting from "P"to "D5", when shifting back from "D5" to Park it feels like the alignment is off.
The selector will get stuck at "N" and won't go past unless I pull it down to "D4" and then go from "D4" to "P".
Which leads me to believe the problem is coming from this issue as when the shifter is in "P" or "R" the lights on the cluster come on.
Or this is an actual electrical connector or Sensor?
[IMG]file:///C:/Users/noeld/AppData/Local/Temp/moz-screenshot-3.png[/IMG]
Old May 21, 2010 | 10:10 AM
  #487
NVA-AV6's Avatar
BANNED
Part 25
http://www.acuraoemparts.com/delray/...All&vinsrch=no
Old May 21, 2010 | 10:53 AM
  #488
DC2*&*CL-S's Avatar
Thanks again NVA-AV6!
I'm going to pull it apart today and see whats going on.
Old May 24, 2010 | 09:31 AM
  #489
DC2*&*CL-S's Avatar
Much Thanks and Props to NVA-AV6 for ALL THE GOOD INFORMATION he supplied me with to finish the project.
As I troubleshooted the code I figured the Transmission Range Switch needed to be set at at the same gear as the shift lever is in.
I didn't notice this cause #1 I'm new to working on these Auto trans with all this
After noticing them out of place. Once this was set I was able to shift smoothly down the gears and all the selected gears were lit on my cluster.
So today I was able to take it with me to work for the first time since owning it car and it drove like a champ.
If it wasn't for this thread I would probably have a huge headache and lots of debt right now trying to complete a 6 speed swap.. Would have been fun though! but I bought this car to realx as my other car is 5speed Poor Man Type R
Old May 26, 2010 | 12:12 AM
  #490
i mean to install
Old Jun 7, 2010 | 02:28 PM
  #491
ironsurfer129's Avatar
CL-Pride
Anyone know anyone who know/will do the swap in SoCal if I get an ody tranny?
Old Jun 7, 2010 | 06:32 PM
  #492
Hybridc24k's Avatar
Car junkie
Im putting in a 06 TL tranny in mine hopefully this week. I know Raceline could do it but Elton is on vacation for the next 2 weeks.. Im trying to find another shop to do it..
Old Jul 14, 2010 | 06:36 PM
  #493
RoccoRock's Avatar
what exactly needs to be drilled and tapped (and to what size) on an 05 odyssey transmission? I saw a thread with pics and red arrows pointing o the bosses but cant find it anywhere.
Old Jul 14, 2010 | 07:29 PM
  #494
Rajca's Avatar
wham bam thank you ma'am
pm nva-av6
Old Jul 19, 2010 | 08:23 PM
  #495
sl168's Avatar
2002 TL
Well,it looks like my luck just ran out.I was driving on the interstate today when my tranny decided to take a powder.Fortunately,there are traffic lights on the highway and I was taking off after the light turned green.I was accelerating but the car just revved up without changing gears.I had to goose the throttle back and forth to try and get it to change gears.It's been doing that for a few weeks now on occasion.This time I got the ol check engine and tcs lights.The car is still driveable so I made a beeline for the house.Earlier I thought I could detect a faint smell of some kind.Now I know it was the tranny.So much for being out of debt,lol.I found some 06 Odyssey trannies online through car-part.com.There's a place in Michigan that has one with 9k miles and one with 16k.They're asking just under a grand for them.Then there's one in Kentucky with 17k miles for less than $870.Since some of you have bought trannies and had them shipped to you,what kind of money are we talking about for shipping?Meanwhile,I guess I'll start shopping around for a mechanic who can do the swap.
Old Jul 19, 2010 | 08:50 PM
  #496
richardparker's Avatar
3.7L Nitrous Breathing CL
What I've seen 150-200 for shipping
Old Jul 28, 2010 | 03:26 PM
  #497
sl168's Avatar
2002 TL
I took my TL to the dealership this morning so the service manager could test drive it.He confirmed the bad tranny with the test drive and checking the trouble code on the machine.I left it with them and caught a ride home.They said it would cost about $4k to replace the tranny and let me know they would talk to Acura about my car.The service rep just called a few minutes ago and said that Acura would pay 75% of the cost.So I'm only going to be out a grand for it.What's more,I'll get a 3 year,36k mile warranty.They should have the tranny tomorrow,and I should have my car back Friday afternoon.No salvage yard tranny for me.My thanks again to Don Carlton Acura in Tulsa.These guys are great.Oh,and thanks to Acura for helping me out.
Old Jul 28, 2010 | 06:12 PM
  #498
How many miles are on your car ?
Old Jul 29, 2010 | 10:16 AM
  #499
sl168's Avatar
2002 TL
A little over 50,400.I've put less than 16K miles on it since I bought it more than 5 years ago.They started pulling the tranny yesterday in anticipation of receiving the new one today.Turns out they found a cracked engine mount as well which will cost me another $265.This is still much better than I could ever have hoped for.
Old Jul 29, 2010 | 11:22 PM
  #500
sl168's Avatar
2002 TL
The dealership called this afternoon and said my car was ready.That's one fast changeout.In any case,it cost me $1,380 and change.Not bad for a tranny with 3 year,36K mile warranty and a new engine mount.The service manager said they had changed out a lot of these trannies and had encountered few problems after doing so.So fingers crossed that it lasts me a nice long time.They also changed out the ecu.Apparently this new one does a better job with the shifts.I wonder if others who have had multiple trannies got a replacement ecu.If not,maybe this could explain some of the problems with multiple replacements.In any case,I'm back on the road again.
Old Aug 12, 2010 | 03:13 PM
  #501
thevikas87's Avatar
Your mom is in
Can someone please PM me Paul's number?
I've been communicating with him through PM's but need to just call him. Thanks!
Old Aug 12, 2010 | 04:43 PM
  #502
p.diddy's Avatar
pm sent.
Old Aug 12, 2010 | 11:09 PM
  #503
YeuEmMaiMai's Avatar
hope your replacement lasts longer than mine did. I have 24K on mine and it is done
Old Aug 17, 2010 | 11:37 PM
  #504
thevikas87's Avatar
Your mom is in
The CLS will be in Paul's shop hopefully by this Friday evening! I can't wait to pick it up and drive it down here.
Old Aug 19, 2010 | 07:34 PM
  #505
p.diddy's Avatar
figured id give an update to this thread. so far ive put 20k on my '07 TL tranny since i got the swap done.
Old Aug 19, 2010 | 07:47 PM
  #506
Rajca's Avatar
and......
Old Aug 19, 2010 | 07:49 PM
  #507
p.diddy's Avatar
^and she is running great. no problems at all. im think im due for tranny fluid change though. the tranny had 42k on it when i bought it.
Old Aug 19, 2010 | 08:11 PM
  #508
Rajca's Avatar
change the trans filter also.
ive heard of ppl changing out some pressure switches. something about getting smoother shifts or something
Old Aug 19, 2010 | 10:39 PM
  #509
Sohcisme's Avatar
just picked up my ody tranny from the local lkq. about to do the sweet swap in a couple days.
Old Aug 20, 2010 | 10:54 AM
  #510
p.diddy's Avatar
^nice. let us know how it goes.
Old Aug 21, 2010 | 04:54 AM
  #511
NVA-AV6's Avatar
BANNED
CLS did not show up.....
Old Aug 21, 2010 | 12:05 PM
  #512
e30cabrio's Avatar
LFG RANGERS!!!!!!!!!!!
Irresponsible CLS!
Old Aug 21, 2010 | 04:16 PM
  #513
civicdrivr's Avatar
Irresponsible CLS!
The CL likes to be fashionably late.
Old Aug 23, 2010 | 08:07 PM
  #514
thevikas87's Avatar
Your mom is in
I know, that's why I said hopefully...I hate JMN Logistics by the way...switched shipping companies, I am hoping to get it there by this Friday August 27, the car will be leaving Pittsburgh this Wednesday August 25. Give me a call back when you get a chance, thanks Paul.
Old Aug 24, 2010 | 10:13 AM
  #515
pits200's Avatar
Vik,
JMN Logistics, Im definitely boycotting them after how they half-assed things and put both you and I way behind schedule. But it seems like United Transport is ontop of things, they were calling me left and right yesterday trying to setup the Wednesday pickup.
So it's a definite good to go on Wednesday(Not sure if it's a.m or p.m yet). I'll make sure to include the new water pump and any other CL things I have laying around my garage.
Good luck on the tranny swap, and let me know if you ever have any questions about the car.
Old Aug 24, 2010 | 01:11 PM
  #516
bluedc2's Avatar
had no idea u could do that... thanks alot
Old Aug 24, 2010 | 11:59 PM
  #517
thevikas87's Avatar
Your mom is in
Originally Posted by pits200
Vik,
Thanks Bill, I appreciate everything. I'll keep in touch for sure.
Old Aug 25, 2010 | 12:29 PM
  #518
rudeboyride's Avatar
hey got a question you guys... BTW thanks for this post to everybody posting in here, espcially Pdiddy and NVA. U guys have giving some ligth at the end of this dark MF tunnel. My tranny started slipping a couple weeks ago, has done it 3 times, but drives good now, but i know its going, wont even try to fool myself. But i called a junk yard and they said that the EX and LX Odessey 05-06 tranny are the same, but different from the touring and EX-L. I want to make sure here before i buy. Please any input would be great.
Old Aug 26, 2010 | 03:14 PM
  #519
aznboi2424's Avatar
why would it be different? same engine, same drivetrain.
Old Aug 31, 2010 | 07:24 AM
  #520
well i Messaged NVA-AV6 and he told me that the EX-L has a different bolt pattern on the Bell housing so stick with the EX/LX...... I trust this man's word Big time...
