another solution for my auto CL guys
Old Jan 17, 2010 | 04:37 PM
  #161
NVA-AV6's Avatar
BANNED
All will deliver to a shop, most will not delive to a residence.
Old Jan 17, 2010 | 04:51 PM
  #162
friesm2000's Avatar
B A N N E D
x2, and maybe not all, but i would say at least 95% of them will deliver, and if not they will ship it by UPS/Fedex or somebody
also for getting a truck, you can also go rent a home depot truck, for like $20 for 75 minutes if it is close enough, or rent a uhaul
also as said a van will work too (including a mini-van [side-door with seats removed], just lay a tarp down first), just not as easy as a pick-up, cause you gotta watch the overhead clearence when useing a cherry picker and such
even your own car will do it, but the back end really be sagging though, and GL trying to get it in and out without damageing anything, but it more then likely will pyhiscally fit in there though
Old Jan 17, 2010 | 06:17 PM
  #163
NVA-AV6's Avatar
BANNED
LOL, I carried 3 Js and a tranny in my pilot at one time.......
Old Jan 17, 2010 | 06:36 PM
  #164
friesm2000's Avatar
B A N N E D
an suv can work too, just a matter of proably being harder to get in and out, even compared to a mini-van (higher door opening)
and i bet your pilot rode real nice with that much weight in there, let alone the amount of sagging it proably had
Old Jan 17, 2010 | 07:23 PM
  #165
NVA-AV6's Avatar
BANNED
It wasn't that bad since I laid plywood down and had the weight more in the middle of the vehicle.....
Old Jan 17, 2010 | 07:35 PM
  #166
friesm2000's Avatar
B A N N E D
still the whole vehicle proably look lowered instead just the back sagging
Old Jan 17, 2010 | 08:21 PM
  #167
NVA-AV6's Avatar
BANNED
Well, lets see 3- Js @ 350lbs each= 1050lbs and then a 6spd tranny for maybe 100, so only 1150lbs total, the Pilot can esily take that without drastic lowering.
Old Jan 18, 2010 | 05:44 PM
  #168
NVA-AV6's Avatar
BANNED
Well guys I am just finishing up a 6spd swap into a 03 AV6 sedan, the AT is in good shape with 56K miles, the owner wants $600 for the tranny if anyone is interested. I did drive tyhe car before starting the swap and it shifted well and no slipping, the guy just wanted a MT put in.
Old Jan 18, 2010 | 05:58 PM
  #169
e30cabrio's Avatar
LFG RANGERS!!!!!!!!!!!
How much does the 6mt swap run?
Old Jan 18, 2010 | 07:09 PM
  #170
Rajca's Avatar
wham bam thank you ma'am
around 2.5-4k depending where u get ur parts, new/ used, who does the work and if u have a type s engine or not
Old Jan 18, 2010 | 07:10 PM
  #171
e30cabrio's Avatar
I meant what did his job run.
Old Jan 18, 2010 | 07:50 PM
  #172
NVA-AV6's Avatar
BANNED
Labor and some other small stuff it came to about $3K
Old Jan 18, 2010 | 07:59 PM
  #173
e30cabrio's Avatar
I may need to bring you my car.
I want a motor build like Civic got and I know eventually my AT will be going.
Old Jan 18, 2010 | 08:12 PM
  #174
civicdrivr's Avatar
Ooooooo, Ive always wanted to do that to a 7th gen, and I dont like the back of the 06-07 sedan so thats not an option.
What shifter did you use? The 06-07 6MT or the 5MT shifter from the 4 cylinder?
Old Jan 18, 2010 | 08:13 PM
  #175
civicdrivr's Avatar
i may need to bring you my car.
I want a motor build like civic got and i know eventually my at will be going.
do it!!!!
Old Jan 18, 2010 | 08:23 PM
  #176
NVA-AV6's Avatar
BANNED
03-05 AV6 MT shifter, pedals, ect.., the only real hairy thing about is is re-working the fire wall where the clutch pedal goes, you have to pull the brake booster to get at it from the outside and pull the drivers fuse box and some other stuff to get to it from the inside.
Old Jan 18, 2010 | 08:27 PM
  #177
NVA-AV6's Avatar
BANNED
Best three things to do for your AT----
1) Lift off the gas when it is shifting, the high tourqe when the next gear is engauging is what kills
2) Regular fluid and filter changes, yes there is a filter cartridge right on top of the tranny part number 9 in the link below...
3)Add a trans cooler and get rid of the heat exchanger.....
Old Jan 18, 2010 | 08:36 PM
  #178
civicdrivr's Avatar
Haha, I completely forgot about the coupe parts
I know the 03-05 Accord I4s were available with the 5MT, so I would assume all the mounting bosses and holes were already there on the V6 models, right? Or did Honda not use the same firewall?
Old Jan 18, 2010 | 08:45 PM
  #179
e30cabrio's Avatar
I have swapped the fluid 2x and replaced the filter 1x in the last 20k, I have a trans cooler (same one Comptech marketed but not from them)
I did not know about the lift off.
The car has 179520 or so, the trans went in under recall at about 65k currently works like a charm but that could change anytime..
I want to rebuild when the Tbelt interval comes (about 40k from now as it was done late at 118k by the PO)
I'd think the best way for me to do it with you would be to truck it to you and drive it home.
I sent you a pm.
Old Jan 18, 2010 | 08:56 PM
  #180
friesm2000's Avatar
B A N N E D
why not use the same fire wall???, just have to cover the holes; even the 2g TL's already have the "HOLES" for the clutch, they just have to be drilled out
Old Jan 18, 2010 | 10:23 PM
  #181
civicdrivr's Avatar
Logic would say that, but this is Honda we're talking about
Old Jan 18, 2010 | 10:30 PM
  #182
friesm2000's Avatar
B A N N E D
Logic would say that, but this is GM/Ford/Chrysler we're talking about
FIXED, if you really want the truth
Old Jan 18, 2010 | 10:32 PM
  #183
NVA-AV6's Avatar
BANNED
Nope they did not, instead they have the chassis (headlight, ect) wire harness running right thru where the cluch goes, the hole does not even line up with the clutch, I end up making a adaptor base out of 3/8" aluminum and relocating the wire harness a few inches to a hole I make in the fire wall and gromnut. I know the CLs and 6th gens have dimples where it is all supposed to go, but not the 7th gens.
Old Jan 18, 2010 | 10:37 PM
  #184
friesm2000's Avatar
B A N N E D
WOW, that blows, something that you expect from a domestic, but not a honda
maybe look at a subaru clutch pedal instead the reservior itself, is on the opposite side of the gas pedal
Old Jan 18, 2010 | 10:40 PM
  #185
civicdrivr's Avatar
Old Jan 19, 2010 | 09:22 PM
  #186
Rapture's Avatar
Originally Posted by Rapture
Also, places near me have a few '06 TL 5AT transmissions, are those good, or would I need an 07 or 08? There's also an 08 here, but I wanted to make sure..
? Any advice?
Old Jan 19, 2010 | 09:43 PM
  #187
p.diddy's Avatar
Originally Posted by rapture
? Any advice?
06-08
Old Jan 19, 2010 | 09:45 PM
  #188
Rajca's Avatar
but nva av6 said that some 07 might not work bc of diff bell housing. he should clear this up a bit.
Old Jan 19, 2010 | 10:03 PM
  #189
p.diddy's Avatar
I would think you just have to check the bell housing before you buy.
Old Jan 20, 2010 | 05:11 AM
  #190
NVA-AV6's Avatar
BANNED
? Any advice?
Get the 04-06 to be sure, 08 is a no go and more than 1/2 of the 07s will not work eaither, apparently Acura had a good amount of the 06 powertrain left and used them into 07 before changing over to the new block and tranny, so 07 is a crap shoot.
Old Jan 20, 2010 | 06:44 AM
  #191
p.diddy's Avatar
oh ok didnt know the 08's were a no go. wouldnt it be better to stick with the 05-06 mainly because i kept hearing on the 3g side that the tranny issue didnt really get worked on until like the late 05 models.
Old Jan 20, 2010 | 12:21 PM
  #192
kdawg8526's Avatar
13.2@106mph G37 RWD Sedan
isnt the 07 auto tranny when they came up with the 4 shaft design instead of 3 shaft.. is there some way to make that 07 fit?
Old Jan 20, 2010 | 03:08 PM
  #193
NVA-AV6's Avatar
BANNED
LOL, yeah, get the 08 engine as well then replace all the timing gears and sensors so your ecu will run it.
Old Jan 20, 2010 | 07:51 PM
  #194
Rapture's Avatar
Alright, here are my choices on car-part.com...
05 Odyssey with 27k miles at $1400
or
06 TL with 75k miles (a little less than the miles I have now) at $1100
or
06 TL with 22k miles, description says "notes" and I have to call to see how much it is gonna sell for...
Right now I'm leaning towards the Odyssey, that 2nd TL trans gives me a bad vibe (maybe the trans was busted in an accident?)
Old Jan 27, 2010 | 05:08 PM
  #195
p.diddy's Avatar
or
or
yea id go with the oddy tranny.
Old Jan 28, 2010 | 06:32 PM
  #196
Rapture's Avatar
Alright, now what should my method be for choosing a good trans shop? Just pick a nearby place at atra.com?
Just wondering since I dunno how common or uncommon it is for shops to do this kind of thing, how experienced or comfortable they'd be, etc
Old Jan 28, 2010 | 07:11 PM
  #197
NVA-AV6's Avatar
BANNED
Where are you located?
Old Jan 28, 2010 | 07:15 PM
  #198
Rapture's Avatar
In Oregon. Just a little ways south of Portland, specifically.
Old Jan 28, 2010 | 07:42 PM
  #199
NVA-AV6's Avatar
BANNED
Ehh, don't know anyone out there I would trust......
Old Jan 28, 2010 | 07:53 PM
  #200
Rapture's Avatar
Meh, I guess I could just ask in the region section.
