D-100: The Official "Does This Wheel and/or Tire Fit My Car" Thread
#1281
boost 3G
enkei rpf1
Size- 18x8.5
Offset- +30
Drop-about 2 inches up front and 1.75 in rear
(neuspeed on sport springs last perch)
what kind of fitment will this give me and what size tire do you recommend? beefy the better. fenders rolled front and rear
Size- 18x8.5
Offset- +30
#1282
Will 235/50/R17 be ok to put on stockies? They are blizzaks and I am planning to use them in winter only. Can anyone tell me if those measurements are ok? Thanks!
#1284
i have an 07 TL-S. im looking at the axis penta. will the staggered fitment of 19x8.5 40mm offset in front and 19x9.5 35mm offset in the rear fit? or what will i have to do for the fitment to be correct?
#1286
94 DC4 RS LSV/Turbo
not bad at all... dial in a bit of negative camber and you're golden... course if you slam it that's gonna require more than just a tiny bit of negative camber
likely needs a 5mm spacer
18x8 +40
18x8.5 +40 wrapped on 245/40-18
needs 5mm spacer... either tire works
on fitment
tire size
245/35-19
that's gonna be about flush with the fenders, I'd run them with 235/40-18
if it is solely for the winter and you don't plan to do any spirited driving, you can get away with it... it will throw off your speedometer
they fit w/out modification
no need to post same question multiple times thank you
the fronts do not clear the brembos, so you will need a 10mm spacer in the front
run them with 225/35-19 tires up front and 245/35-19 tires in the rear should not require any modification at all
18x8 +40
Enkei RPF1
Which setup would be more ideal for my TL-S on a minor Eibach drop?
18x8 +35
or 18x8.5 +40?
And what is ideal tire size I can run with either of the above setups without any modification? Or what is the widest I can run?
Looking to buy soon so once again, any help would be greatly appreciated! Thanks
18x8 +35
or 18x8.5 +40?
Would these clear the Brembos? if not what size spacer should I get 5 or 7mm?
08 TL-S
1.Brand of Rim - Tenzo Cuzco V1 Flat Black
2.Rim size (diameter and width) - 18X8 Front and Rear
3.Offset - 37 (front & rear)
4.Drop Type and Amount - None
5. Fenders Rolled - No
http://www.elementwheels.com/proddet...n-cuzcov1188bk
Which tire?
235/40/18 or 245/40/18?
Any and all suggestions please. I am trying not to roll the fenders either.
08 TL-S
Which tire?
tire size
245/35-19
#1287
What do you mean it will throw off the speedometer? So this isn't a great idea huh? It's hard looking for winter tires in the OE size. What about 245 40 R 17? Would that be better?
#1288
#1291
Hello I have WDP 2008 TL-S lookin to put Vossen VVS-085 20.9 X 20.10.5, also lookin to put Tein ss to lover the car. Can this be done and if yes the what size tire and offset. Thank You.
#1292
Wheel Make/Model: Work Euro Line KH
Wheel Size (**X**): F 19x8.5, R 19x9.5
Wheel Offset (+**): F +38, R +42
Drop (amount): Tanabe DF210 (1.6"F, 1.4"R)
As for the tire size...Throw me some sizes that would save me from rolling the fenders (if possible), if not then, throw me a size for rolled fenders, thanks man
#1293
The obstacle is the path.
[quote=horsepowercrzy18;11537717]
Sorry for the late reply but yes they will fit perfectly. Im getting mine setup tmrow, and ive asked the garage guys. It'l be a perfect fit, no spacers needed. And it would deff look great on a nbp..like mine :p pics should be up soon
2004 6MT TL
Wheel Make/Model: TSW Donington
Wheel Size (**X**): 19x8 Front / 19x9.5 Rear
Wheel Offset (+**): 42 front / 40 rear
If lowered (amount): A-Spec Suspension
Will they fit?....dont like tire streching.
Will they look good on my NBP?....https://acurazine.com/forums/3g-tl-tires-wheels-suspension-97/ever-considered-these-tsw-rims-754069/
Much appreciated![/QUOTE
you will most likely need spacers in the front to make the wheel clear your brembos. should be fine with a 5mm spacer puting it at 37mm in the front
#1294
#1295
Would I have any problems running these rims on my '04 automatic TL w/ Aspec body kit? I'm at the stock hieght now but would like to drop it 1"-1.5".
fronts - 19x8 w/46mm offset & 235/35/19 tires
rear - 19x8.5 w/40mm offset & 245/35/19 tires
Could I run a 265/30/19 on the back without any issues?
Anybody got these wheels on their TL?
#1297
94 DC4 RS LSV/Turbo
you can but may rub with the fitment
depending on the offset... likely 245/30-20 rear 235/30-20 front
245/35-19 or 255/35-19 or 255/30-19 REAR
the wheels fit
#1298
Wheel and tire fitment
I just bought new wheels. They are 18X8'' 30 offset in front and 18X8.5" 33 offset in rear. i have nuespeed supercup kit with sport springs on lowest perch and rear fenders rolled. what size tires would you recommend?
#1299
axis elites
Hey guys i was looking into getting the Axis Elite 19 in rims. im looking at these two sizes as a possible root.
19x8 offset either 35 or 45
or
19x9.5 with an offset of 40
will both of these fit on my TL with about 1.5" drop?
or
#1301
#1302
whats up guys ? looking at a set of work vsxx wheels ... The size are 17x8 offset +47 and 17x9 offset +53 ... would i run into any issues ? how would it look as far as sitting inside the fenders , dont have the tires on them yet so thats not an issues yet and the car will be dropped on coilovers a reasonable amount ... thanx
p.s. what is the stock offset of our 17" wheels (06 TL ) ?
#1303
94 DC4 RS LSV/Turbo
so for your specific wheels I'd try to exceed factory fitment in terms of offset
in the front run a 5mm spacer and in the rear a 10mm spacer
#1304
wdp skyhawk
Hey i want to know if these will clear thanks
Question on Brembo/Big Brake Clearance
Transmission (Manual or Auto): auto
Year/Trim (04-07, Base or Type S): 08 type s
Wheel Make/Model:boss 339
Wheel Size (**X**):20"
Wheel Offset (+**):+38
If lowered (amount):1"
#1307
looking at putting axis penta 19x8.5 front, 19x9.5 rear, offset 40, tires 235/35 front, 265/30 rear, will that work? and if yes, will I be able to drop it later without camber? (presently stock height)
#1308
Hopefully someone can chime in on that one.
#1309
looking to put some 19s on my TL non brembo and was wondering if it will fit? btw I am on H&R coilovers currently
Front wheels - 19x9 et.30
Rear wheels - 19x10.5 et.29
**tire size if the wheel fitment works would be helpful also**
thanks
thanks
#1310
Questions on Wheels
Wheel Make/Model:-vossen/ vvs-082
Wheel Size (**X**):-19 x 8.5
Wheel Offset (+**):-32
If lowered (amount):i got tein ss coilover not yet installed
#1311
94 DC4 RS LSV/Turbo
19x8 +35 front
19x9.5 +40 rear
is ideal
that will fit perfect, no mods needed when lowered less than 2"
225/35-19 front
235/35-19 rear
will fit with 225/35-19 tires
#1312
tsw donington fit on 04 tl?
I have a 04 tl with stock wheels. I want to get tsw doniongton wheels for it and I am not sure if they will fit. The stock wheels i know are 17x8 and i know they make the doningtons in 17x8. does anyone know if they will fit? thanks
#1317
#1318
Wheel Make/Model: Rota P45R
Wheel Size (**X**): 19x9.5 (front and back)
Wheel Offset (+**): 30mm
If lowered (amount): Neuspeed Supercup Kit w/ sport springs: 2nd to bottom perch front/ bottom perch rear
Also wondering what tire sizes (if any) could make this work...
#1319
#1320
94 DC4 RS LSV/Turbo
