D-100: The Official "Does This Wheel and/or Tire Fit My Car" Thread
#1002
94 DC4 RS LSV/Turbo
07 Base TL 5AT
Questions on Wheels
Wheel Make/Model:Ace Strada
Wheel Size (**X**):19x8.5 F - 19x9.5 R
Wheel Offset (+**): +38
If lowered (amount): None yet but coilovers in future.. would like 0-1 finger gap
Any tire reccomendations? Would like some wheel protection but more concerned about fitment and rubbing.
Questions on Wheels
rears 245/35-19 without fenders rolled
255/30-19 with the fenders rolled
225/35-19 fronts
23535-19 rears
rolling the rear fenders will be needed
ps. no fat chicks will rub
#1004
Question on Brembo/Big Brake Clearance
Transmission (Manual or Auto): Manual
Year/Trim (04-07, Base or Type S): 04 Sport
Wheel Make/Model: MB Wheels / Weapon
Wheel Size (**X**): 18x9
Wheel Offset (+**): +38 or +45 both available.
If lowered (amount): 1 1/2"? Plan on having a 2 finger gap all around
Will the wheels clear the brembos and will the offset be flush with the fenders or at least closer to flush than stock? And which offset would be better for flushness?
#1005
Transmission (Manual or Auto): manual 6speed with brembo
Year/Trim (04-07, Base or Type S):06 TL 6speed
Wheel Make/Model: 19 ASPEC EPZ-AR5 chrome (made for '09-'10 RDX)
Wheel Size (**X**):19x8J
Wheel Offset (+**): 45
If lowered (amount): NO stock
will I need spacer? if so how big?
Questions on Tires
Tire Make/Model: need recommendation- please give your thoughts
I really dont like the look of these rims on this TL (http://sfbay.craigslist.org/eby/pts/1534260163.html)
Would a different tire and no mudflaps make it look better without a drop?
Width/Sidewall-Diameter (***/**-**):
Need a spacer?
For 5mm H&R/Eibach or Ichiba work
For 5mm or greater visit wheeladapter.com (custom widths available)
Extended Wheel Studs are always the best way to go
Questions on Tires
Need a spacer?
#1006
TL
Just curious but will my speedo be off with the 245/35/19's? Also, what would be the benefit of going with 255/30/19 in the rear vs the 245's? I'm fairly certain I'll be rolling my rear fenders since my buddy is buying the tool and we're going to get a bunch of people together and do them all at once.
#1007
i have an 05 6 speed with brembo's and the A-spec lip kit
Wheel Make/Model:axis super hiro
Wheel Size (**X**):19x8.5 front/ 19x9.5 rear
Wheel Offset (+**): +45, i believe
If lowered (amount):stock hight right now might do tien h-tech springs
i wanna know if this will fit and what size tires i should do, but i'm also not positive what offset the wheels come in can u recomend what i need/ can do with out rolling the fenders. thanx
#1008
2004 TL auto
Wheel Make/Model: IS-F wheels
Wheel Size:19x8.5
Wheel Offset: +45 (i believe)
lowered to no wheel gap all around. also i believe the bore on the isf wheels are 60.1 and ours is 64? so would that mean it wouldnt fit?
Wheel Size:19x8.5
#1009
2004 TL auto
Wheel Make/Model: weds tc005N
Wheel Size:17x8
Wheel Offset: +49
Wheel Size:17x8
Wheel Offset: +49
#1010
94 DC4 RS LSV/Turbo
5mm to 10mm spacer would be required
Questions on Tires
Width/Sidewall-Diameter (/**-**):
245/35-19
Need a spacer?
Questions on Tires
245/35-19
Need a spacer?
255/30-19 gives you more lip protection on a wider wheel
in the rear throw 255/30-19 is fine no fender rolling required
as for the hub center bore... you'd have to take it to a machine shop to bore out the opening to 64.1mm
#1011
thanx for the response, one more quick question, i called wheelsnext.com up and they said that i can run a 275/30/19 tire in the back on the 19x9.5 at stock height with out rolling the fenders is this true?
#1012
94 DC4 RS LSV/Turbo
run 245 front and nothing bigger than 265 in the rear otherwise it will just look funny
#1015
alright so i've asked this question before and it seems as though i had the specs of the wheel incorrect. i'm asking this, for a wheel that is 20x8.5 ET35, what is the max tire size i can use without rubbing? the car is on h&r race springs on koni yellows, i can play with the perches if need be. i also like the staggered look tell me what you guys think, pros and cons? this is the wheel on my car without a tire.
#1016
#1018
94 DC4 RS LSV/Turbo
2004 Acura tl Auto
Wheel Make/Model:Konig Runaway 18inch
Wheel Size (**X**):18" x 8"
Wheel Offset (+**):35mm
If lowered (amount):0
Tires: HTR Z II at 245/40Z
Thanks in advance
Thanks in advance
ps. there might be some trimming required of the plastic on the aspec lip ( if you have one )
#1019
can anyone verify (stillhere lol) that i can safely run 235/30/20 front and 245 rear with my setup? slammed on 20" x 8.5" 35ET? thanks guys....and how do we all feel about staggered setup on a fwd car?
thanks for the response horsepowercrzy18 i appreciate the help
#1021
What's the widest tire I can put on my TL-S with the stock Type-S wheels and stock suspension? Would 255's all around work? If someone can provide some info along with exact tire specs, I'd really appreciate it! My TL-S needs new tires so I figure I'd get something wider than stock. Thanks for any help.
#1022
#1023
2004 Acura tl Auto
Wheel Make/Model: BBS wheels
Wheel Size (**X**):17x8
Wheel Offset (+**):38mm
If lowered (amount): pretty low about 1/2 finger wheel gap
Tires: HTR Z III 235/45/17
will i rub without fender rolling? do i need to raise my car a bit to fit these.. since the offset is +38
#1024
Questions on Wheels 04 acura tl automatic
Wheel Make/Model:bbs
Wheel Size (**X**):17x8 front 17x9 rears staggered
Wheel Offset (+**):38mm i think
If lowered (amount)0
Tires=Sizes are 224/45/17 front 245/40/17 rear.
#1025
for your car the wheels will fit fine. I would recommend using 235/45/17 in front and 255/40/17 in back
#1026
#1028
4th Gear
2008 TL AUTO BASE
Questions on Wheels
Wheel Make/Model: Volk GT-S
Wheel Size (**X**): 19 X 8.5
Wheel Offset (+**): 34
If lowered (amount): Will be lowered about 2.5 inches
What tires do you suggest to have a slight moderate tire stretch??
Questions on Wheels
#1029
Nevermind, just finished reading the 17 page thread about 255/40/17's and I'll be going with this setup then. Hopefully wheel gap won't bother me too much. Thanks horsepowercrzy18!
#1033
CBP 6MT
Year/Trim (04-07, Base or Type S): 08 Type S
Wheel Make/Model: RJ Inspyre
Wheel Size (**X**): 19x8.5
Wheel Offset (+**): 42
If lowered (amount): soon to be 1.5"
I'm sure they fit, because they're RJ's, but thought I'd make sure here before I bought them. More curious about what tires I should put on?
#1034
Year/Trim (04-07, Base or Type S): 2007 Type S
I'm considering 3 options
1)
Wheel Make/Model: Enkei Pf01 (New for 2010)
Wheel Size (**X**): 17 x 8
If lowered (amount): Not Lowered
2)
Wheel Size (**X**): 18 x 8
Wheel Offset (+**): +40
3)
Wheel Make/Model: JIC Magic J-force 05
Wheel Offset (+**): +30 (Pretty aggressive I think)
I like to know if they would clear the brembo brakes at the front and if it will rub the fender as I don't want to roll the fender.
For 17 inch I'll be using the stock tire size (235/45R17), and for 18 inch it will be 235/40R18. Thanks.
1)
2)
3)
#1035
Down for a photoshoot?
Hey what's up stillhere,
I've been running 18x8, +20(f) +25(r) with 245/40/18 tires for a while and decided to go with the following instead:
2006 TL
Wheel Make/Model: 5Zigen ZR+520
Wheel Size: 19x9.5
Wheel Offset: +30
If lowered (amount): Tein Basics (1/2" thread left--top of tire sits parallel with fender ... maybe little tuck)
Rear fenders are already rolled, portions of the front have already been cut lol
Planning on stretching tires with 235/40/18's
Should work right?
2006 TL
Wheel Size: 19x9.5
Wheel Offset: +30
Should work right?
#1036
Dont Lemme Cacha Peekn in
Hello everyone,
I've pressed the search button repeatedly, but I just wanna be extra extra extra sure about this wheel setup that i have in mind!
2005 Base 5AT
Option 1 = 20x8.5 (+35 offset) All Around with 225/35/20 or 235/35/20
Option 2 = 20x8.5 (+38 offset) All Around with 225/35/20 or 235/35/20
Will be dropped on either TEIN Basic or TEIN SS...
Will I need spacers?
Will I need to roll the fenders?
2005 Base 5AT
#1038
94 DC4 RS LSV/Turbo
1)
offset to high will need a 10mm spacer
2)
needs like a 3mm spacer
3)
fits fine
1)
2)
3)
fits fine
2006 TL
Wheel Size: 19x9.5
Wheel Offset: +30
Should work right?
2006 TL
Wheel Size: 19x9.5
Wheel Offset: +30
Should work right?
Hello everyone,
2005 Base 5AT
FITS FINE
FITS FINE
2005 Base 5AT
FITS FINE
FITS FINE
answered near choices
#1040
Thanks for the response Stillhere!
For the 07 TLS with 17 x 8 wheels. What's the lowest offset we can go without rubbing the fender?
