Strange sounds in the engine: O - video
Old Feb 7, 2019 | 11:31 AM
Mial187's Avatar
Angry Strange sounds in the engine: O - video
Hello, everyone. For some time I have a problem with strange knocks in the area of ​​the timing - the head from the side of the cockpit. Valves adjusted. I know that the video is difficult to diagnose but maybe someone had a similar problem. It does not look like a pan In Poland, it's hard to diagnose such an engine because it is not very popular. Please help !
Old Feb 7, 2019 | 11:40 AM
check the crank pulley underneath the timing belt area, may have to remove passenger wheel.
sounds like the damper on the pulley is coming apart....soon it will separate
end result will look like this:
Old Feb 7, 2019 | 12:37 PM
Mial187's Avatar
The question is whether if the pulley falls apart during the ride, will the timing not shoot?
Old Feb 7, 2019 | 12:44 PM
losiglow's Avatar
No. There's a different gear from the crank that the timing belt feeds off. The harmonic damper / crank pulley is only for accessories.
So your biggest risk is losing power to the alternator, PS pump and AC. As well as potentially damaging something from when it self destructs. But it won't be your valves or piston heads at least
Old Feb 7, 2019 | 12:56 PM
and this is assuming it is the crank pulley that is separating that is making the noise.
one needs to check.
Old Feb 7, 2019 | 12:57 PM
losiglow's Avatar
Right. Still sounds like valves to me. Then again, when I adjusted my valves on the J32 it still sounded "clicky".
Old Feb 8, 2019 | 10:54 AM
Mial187's Avatar
Thanks for the suggestions, of course, check the pulley tomorrow.
It's not valves to exclude them, I was regulating last weekend and they were ok.
Old Feb 23, 2019 | 07:35 AM
Mial187's Avatar
=leftI checked the pulley, no play, the whole rubber.
The sound was still louder with time.
Any suggestions ?
=left
Strange sounds in the engine: O - video-uk2txx4.jpg
Old Mar 28, 2019 | 03:20 PM
Mial187's Avatar
The worst thing is that a lot of people have this problem and no one can put up a proper diagon. For me, I still knock on the cold most. With a stethoscope, I detect the upper head from the driver's side.
Old Mar 28, 2019 | 05:34 PM
^we cant diagnose over the internet, we are guessing.
Lift the car and go over it with a fine tooth comb. That's the ONLY way you'll be able to find where the noise is coming from
Old Mar 31, 2019 | 09:17 AM
srg818's Avatar
Are all your spark plugs tight?
Old Nov 11, 2019 | 06:10 AM
Mial187's Avatar
yes!
Old Nov 12, 2019 | 01:56 PM
90foxnotch's Avatar
Have you ever had the timing belt/water pump replaced? Sounds like it could be the timing belt tensioner. If not that then possibly valves or lower end. Good luck
Old Nov 12, 2019 | 08:50 PM
Ta-da acura's Avatar
Have you checked your oil level bro that's alot oil in that pic
Old Nov 14, 2019 | 06:18 AM
WDPanda's Avatar
Usually that clicking noise is wear on cam lobes (high pitch tick/tap noise) or fuel injectors (click noise)
Black Tire
Motorsports News
Mar 24, 2025 08:09 AM
trev0006
Dec 12, 2018 04:45 PM
cbrose
Mar 15, 2010 01:11 PM
May 10, 2006 01:44 PM
Crazytree
Oct 21, 2003 06:27 PM
