Clutch pedal soft or returning slowly in extreme cold
Hello fellas I have a 2008 TL Type S 6MT and for the past few days the weather has been below 10 degrees in Germantown Maryland
crazy cold!!!!
I noticed that the clutch pedal is soft and not stiff in when I turn the car on in the mornings but when the car warms up the pedal goes back to normal again. Could this be due to the extreme cold weather? If it's above 20 degrees it doesn't do this but anything below 20 it does it especially when it's below 10 degrees. Could it be Master cylinder seal shrinking and causing this or just normal for the extreme cold weather? Any input or advice would be highly appreciated.
crazy cold!!!!I noticed that the clutch pedal is soft and not stiff in when I turn the car on in the mornings but when the car warms up the pedal goes back to normal again. Could this be due to the extreme cold weather? If it's above 20 degrees it doesn't do this but anything below 20 it does it especially when it's below 10 degrees. Could it be Master cylinder seal shrinking and causing this or just normal for the extreme cold weather? Any input or advice would be highly appreciated.
I too noticed this as soon as I pulled out of my driveway this morning (it was around 0F according to the car). I totally messed up pulling out onto the road because I couldn't really feel the engagement point like normal. It made me look like a fool revving my engine and peeling out
It was soft until after a few minutes of driving then it went back to normal.
Maybe I'll bleed the fluid on an upcoming weekend and see if I notice any change.
It was soft until after a few minutes of driving then it went back to normal.Maybe I'll bleed the fluid on an upcoming weekend and see if I notice any change.
It's normal when it gets really cold. If it's not that cold and it still do it I would replace fluid.
This morning it was -13F or so, power steering and brakes were a bit rough upon startup. After the car has warmed a bit it becomes better.
I might be wrong, but I don't see why removing the slave cylinder check would make the clutch pedal feel less like "molasses" in very cold temperatures.
Maybe godfather's explanation of soft wasn't spot on or I misinterpreted it. When you remove the slave cylinder check it makes the clutch pedal less spongy feeling even at operating temperatures and make the clutch engage in a more traditional way rather than softly.
In very cold winter temperatures, things don't feel more soft, but rather anything hydraulic seems harder to press down or doesn't return as quickly as usual. Brakes feel "slow to engage" upon startup (but get normal quick) and until the motor is warm power steering can feel a bit harder. Clutch pedal doesn't have the usual "spring" to it too.
Hate to revive an old thread, but had the same experience this AM (~15 degrees F). is the consensus here that this is normal in the cold? got progressively better as the car got warmer but never totally returned to "normal" in my 30 min commute, as in i could still beat the clutch to the top of its travel if i was sitting in neutral, pushed the clutch the the floor and then pulled off as fast as i could
As other's stated, have you flushed the brake fluid out of the clutch hydraulics? Brake fluid is hygroscopic and absorbs water; I'm guessing the water is freezing in the lower end of your clutch line down by the slave cylinder.
