Strange sounds in the engine: O - video
Hello, everyone. For some time I have a problem with strange knocks in the area of the timing - the head from the side of the cockpit. Valves adjusted. I know that the video is difficult to diagnose but maybe someone had a similar problem. It does not look like a pan In Poland, it's hard to diagnose such an engine because it is not very popular. Please help !
check the crank pulley underneath the timing belt area, may have to remove passenger wheel.
sounds like the damper on the pulley is coming apart....soon it will separate
end result will look like this:
So your biggest risk is losing power to the alternator, PS pump and AC. As well as potentially damaging something from when it self destructs. But it won't be your valves or piston heads at least
The worst thing is that a lot of people have this problem and no one can put up a proper diagon. For me, I still knock on the cold most. With a stethoscope, I detect the upper head from the driver's side.
