Turbo Kit for Acura TL '04-'08
#1801
just kinda throwing the concept out there.... that was some of the manufactures concern with using thick oils at first, in the fuel injection vehicles, as they will start no matter what, even at very cold conditions... concerns of thick oil not offering enough protection at cold starts due to limited flow.... it reminds me of why in the winter time...when i first start the car in cold weather, i only idle for about 30 sec to one min...and start driving....put load on the motor and make it warm up faster ( i dont mean redlining it, just normal driving at low revs), which would warm up the oil faster, rather than sit there for 10 mins, running a cold engine
#1803
My Dearest Opel,
I am not positive, but pretty sure on the following. On the 5AT, the throttle-by-wire does temporarily close the butterfly between shifts, even when at WOT.
DRIVE-BY-WIRE THROTTLE CONTROL SYSTEM
The throttle system works with the available SportShift 5-speed automatic transmission to make shifts faster and smoother than has been possible before. By coordinating the throttle opening with the transmission's shifting functions, engine power can be precisely tailored to the needs of the transmission at every point during the shifting process. That means less shift shock and delay, no matter the driving situation.
SOURCE: http://corporate.honda.com/press/article.aspx?id=3783
COOPERATION BETWEEN TRANSMISSION AND DRIVE-BY-WIRE™ THROTTLE SYSTEM
Shift speed and smoothness are enhanced as a result of cooperation between the Drive-by-Wire™ throttle system and the electronically controlled Sequential SportShift transmission. During upshifts and downshifts, the engine can be throttled by the engine management system, reducing peak forces (shift shock) on transmission components, thus improving component reliability and decreasing driveline harshness.
SOURCE: http://www.hondacarforum.com/acura-t...owertrain.html
#1805
Got your mom in
and to answer ur questions, i tried but everytime i pull up next to him, i hear him spooling and he takes off
#1807
Got your mom in
by they way i have a few in car vids that he asked me to film with the same camera. i'll post later
#1808
....just dancing in
Thank Silva-Type-S for the vid's....but yes the quality is lacking. IHC is right, try getting a rolling side by side shot. Or even better, ride shotgun with Rodney for a more personal feel for the power it is producing. Nice sound this car is making minus the wind noise from your camera......
#1809
My Dearest Opel,
im aware of all of that....but there's nothing that tells me, the throttle temporarily closes between shifts..... maybe you meant , "partially"
heres what happens to reduce tranny shock and all that...it all depends on the gear ratios,,, at the end of one gear, as it shifts into the next, the throttle will close as much as it needs to match the RPM of the next gear, so the tranny isn's shocked with 100% of the engine power...
you can think of it as the difference between lift throttle shifting, and full throttle shifting......but the throttle wont close temporarily, because the way id translate that is as if it shuts to idle opening , and then it opens back up
#1810
HEy guys be curtious this wasn't a planned video shot or else it would be better , we met up & ended up hanging out he had a camera so we just went for it plus yesterday we were testing , just beating the snot out of it with dump tube open under the simulating a heat wave with the ac running ..( Uh ) what we did was run an open wastegate with just a2" turn down , drive car under full boost this way all the hot air gets trapped under the hood with ac on to make sure thatheat gauge wouldn't creep up , ... Why well put it like this u decide to run car all day then just head home then boom u hit the highway and there's a bad accident highway is shut down for 30 min we were just making sure we wouldn't encounter any cooling issues .....thanks silva types .... Next time well have good videos ....
#1814
#1818
SHAWD 04TL is in
those flashes dont look like reflected light.... it happens around the same time... a few seconds after he punches it? plus what are the odds of the flashes happenning in 2 videos(the last two)... flames out he exhaust...hmmm (dont flame me cuz im a noob at these blown mods)
#1819
#1820
I understand and he is running rich. He changed the plugs the same morning and they were burnt.
He does not want it to fail either, he explained to me that's why he been running the car so hard. he testing the reliability of the kit on the motor and so far (knock on wood) everything has been going pretty good. i hope it works out
He also walked all over a G37 the other night. i wanted to see the drivers face.
and the g37s arent that fast....assuming it was a stock .... 287 whp vs 437 whp.. and theyre 3700 lbs... u also made a comment as, no one's been able to leave u like that unless they were boosted or juiced..... ANY 400 hp NA car will leave you like that
#1821
Got your mom in
#1822
Got your mom in
what do you mean by burnt plugs? and what plugs is he using? how much colder?
i stated earlier that he was at 8 PSI, he wasn't even pushing 400hp
you're a real hater yo. flooded with negativity... i meant no TL. im pretty sure it will leave urs tha same way too assuming (since you do so much of it) those are ur real numbers
#1823
cant provide more clarity than that. burnt meaning black... they were NGK's
#1824
Got your mom in
8 psi brought him back to less than 400? and 9 brings him up to almost 440? thats one heck of a magical PSI... theres no reason for me to hate anything...and there's no negativity either...just simply saying beating a stock g37 isn't that challenging when he's pushing that kinda power, and the TL is lighter too, oh and it runs shorter gear ratios too.... but if ud said... the tl was neck to neck with a vette... then yes, that'd get my attention... i beat g35s when i was nearly stock...and g37s arent that much faster then their succesor ............ catch the drift? dont take it so personal, because i aint the guy's enemy (the one that started the turbo) ...besides, we're cool.
#1825
Being an Acha Bacha in
#1826
Since I got fans put in a day before the meet I had to get the car retuned the night before the meet @ around 8:00 pm street tuned, so we didn't get time to turn up boost I'll go back on the dyno in about two weeks let's see where that takes me , as far as flames we were rolling 8-9 cars I'm sure if I was spitting flames someone would have seen , but I can't see so I can't elaborate, but I very much doubt it like silva types noted we did a few night pulls which he would definetly see then ....
#1827
Well we"ll try this again next week or so , or come check it out at our dyno day august 29 at Aljaps performance sign up sheet is in regions south east ...
#1829
I'm pretty sure you're going to be removing your precats & probably run a high flow / gutted 3rd Cat.. If you're emission system is in a ready status then the OBDII check should be okay but a visual or sniff test will be a failure.. This mod is not for the mechanically squeamish or those apprehenisve over the smog test..
#1830
Hopefully tuner doesn't get mad at mr but tell me what degree of timing you would consider low and I'll confirm where we at on this tune..
#1831
Here's your answer.
The turbo TL will fail the visual and tailpipe tests miserably. No precats= no chance at passing, not worth trying.
Uninstalling shouldn't be that bad. The battery can stay where it's at, the oil feed and return can be capped off. It will be a quicker process than the initial installation.
#1832
I wonder what the limits of the stock ignition is..... I would guess pretty high but that's another thing to think about as the boost gets cranked up. At some point you may have to start closing down the gap on the plugs.
#1834
And now the million dollar question from a thread years ago, does the car have a governor or did you let off?
And I forgot to say in my other post, I don't think your tuner is going to want advice from some guy on the internet, it may make him mad.
#1835
well on those runs and ill admit videos werent great eithr no one to blame but me next batch will be better,i let off those runs ran out of space,but even b4 boost i use to take it to 160 pegged and keep going ,and ive had times at 155 governer kicks in......
#1836
And I forgot to say in my other post, I don't think your tuner is going to want advice from some guy on the internet, it may make him mad.[/QUOTE]
even if he doesnt which i didnt get to ask how much timing were running which he probably wont tell me,but your input is always appreciated and valued on this forum....
#1839
the fact that he has a good piggyback, it may have had that removed, or his tuner did so and pass isn't aware of it... but as far as them being governed, and its not drag limited either... they are governed...and if anyone ever said they're not...what speed did they reach? or did they say the car just kept going and they were about to hit 200 mph but they stopped.
as far as tuners not wanting advice...there's basic things that are applied to these things regardless of where the advice comes from. difference is...some tuners consider safety first and will stop a bit below that fine line, while some others will pull some extreme knife edge tuning
#1840
he should tell u...i dont agree with that...u need to know whats going on with ur car...besides, you should be able to log into ur f/i c and take a look at the map and see exactly whats going on.... aside from that...there's obdII scanners that will log all the data for a period of driving, as u set it.
i did this once...while i actually had a diff kinda scanner...it didnt record anything unless smth set off CEL, which i caused it to do so...in that case there's a freeze frame stored when that happens, which i was able to access... every piece of info...injectors, timing, coolant temp, air temp, engine load, and blah blah blah
for instance, this was with no boost.... timing was +10 (+-2)
just some ideas
