Turbo Kit for Acura TL '04-'08
#5721
1) crankcase vent: http://boombaracing.com/cv.html 12mm?
2) brake booster hose: http://www.usplastic.com/catalog/ite...3369&catid=489?
2) evap hose: http://www.usplastic.com/catalog/ite...3369&catid=489?
#5722
after many hours of playing with this idle issue, i got it figured out. after speaking with gerzand about smoothing out the timing and fuel tables, i adjusted these tables many different ways and had no luck.
i kept thinking about that damn oem pcv valve and tube. i always figured the stock pcv valve was not up to task of holding 18psi from entering the crankcase. however, since i already had -10an fittings welded to the opposite side of each valve cover and connected to a separate vented catch can, i thought that was enough to prevent boost from pressuring the crankcase.
at this point i simply removed the stock pcv tube, capped off the manifold with a rubber nipple and let the front valve cover vent to atmosphere from stock pcv location (while leaving the vented catch can connected to the opposite side)
idle was back to 850rpm, was not hunting and did not stall. looks like the problem was solved. even though this looked like a solution, I believe I found a better route.
i thought about running a oil separator from the stock pcv location but knew the pcv valve wouldnt hold back the boost from entering the crank case. boombaracing makes a nice aluminum check valve that can hold 100psi but will crack open with as little as .25psi allowing the manifold to breath
with this check valve in place, it also solved my oil drain issue from the turbo. prior to the check valve, it believe the pressure getting into the crankcase was causing a flow problem. pulling the feed line from the turbo and there was literally oil filled inside the turbo. after enough time, the pressure would bleed off and the turbo would drain.
so i give you my solution to a high idle. that black tube in the hose coming from the manifold is the check valve
So you basically use the stock location from manifold via boombaracing check valve to the catch can? Did you drill out the stock location similar to this S2000:
#5723
18psi
What are the part #s of the check valves you're using?
3/8 checkvalve for both evap and brake booster
i left the stock pcv valve in place. I would like to remove the pcv valve itself but I havent figured out how to plug the hole yet
bTwix (09-13-2012)
#5724
http://www.namotorsports.net/detail....d/BHBSH20TPCV1
http://www.namotorsports.net/docs/BHBSH20TPCV1.pdf
#5725
18psi
Would a block off plate similar to this do the trick?
I tried to hollow out the stock pcv valve but I wound up destroying it. At 15$ each, Ill just have to buy a few and try again.
#5726
With the boombaracing checkvalve to catch can in place for crankcase vent, what's the downside to just leaving the existing PCV valve in place vs. deleting it? Do we expect it to fail, or actuate in addition to the boobaracing check valve?
Here's a PCV delete thread on the honda tech forum:
http://honda-tech.com/showthread.php?t=3026220 (esp. see posts #9-17)
Originally Posted by MalcolmV8
Cool thanks for the info guys. I ordered the accura "joint" for lack of better term from the Honda dealer today. It's the piece you push into the black box once removing the PCV valve. It should be here tomorrow.
#5727
18psi
Maybe something XLR8 or others could fab? Seems like something the turbo crowd would want.
The stock pcv will fail. Mine did twice. If it fails and gets stuck closed (or open, depending how you look at it), i believe the crankcase wont be able to vent under vacuum....but Im not sure on that.
#5728
So issue with stock pcv is too much boost pressure would eventually break it, but you want to retain vacuum when not under boost to clear crankcase gasses, so why not add a check valve between intake manifold and stock pcv to prevent boost but allow vacuum?
Could you use the same check valves as the evap and brake booster?
http://www.usplastic.com/mobile/item...3369&catid=489
#5729
The answers are a few pages back.
#5730
Ah, so the boomba check valve IS on the line from crankcase pcv to intake manifold. I thought stock pcv had a separate line, but liberts setup is: crankcase -> stock pcv valve -> tube -> oil separator (not vented catch can so vacuum is maintained) -> tube -> boomba racing check valve -> tube -> intake manifold, correct?
So in this setup the boomba check valve prevents the stock pcv from seeing boost, and the stock pcv will only see vacuum. The boomba check valve and oil separator essentially make the the stock pcv redundant, but if boomba check valve prevents stock pcv from seeing boost, why would stock pcv fail?
Seems like it would be nice to delete the stock pcv (since its entire function has been replaced by the boomba check valve and oil separator) but what harm would it cause leaving it in there, if only used to vacuum out crankcase gases? If it failed closed, you'd get degraded oil life? If so, could we just replace stock pcv as a regular maintenance item?
Sounds like the part we'd want is a pcv assembly that is simply an open pipe, or a cover plate, which would have the same effect.
Since existing pcv is held on by a single screw, can we just cut it off after the 1st o ring, to delete it?
http://www.rockauto.com/catalog/x,ca...,parttype,5052
#5731
Build is almost done, need to get check valves and oil separator now though, and possibly stock pcv delete.
#5734
libert69's can is a custom build by one of Rodney's guys.
I picked up one similar to his that is a little bigger and also baffled. Very much like this but a little less expensive.
http://www.ebay.com/itm/Pro-Series-O...e41c1d&vxp=mtr
I chose one with fittings on the bottom along with the top so if I find it filling up too fast, I may connect is to the turbo drain so it goes right back into the pan.
#5735
The important part is that you're not pressurizing the crankcase which will lead to the problems that Bert was experiencing like oil leaks, turbo not draining correctly, oil in the intercooler. Everything else is minor. The main downside of getting rid of the positive scavenging is you will have to change the oil more often but if you're running meth injection you should already be using a 3,000 mile OCI.
bTwix (09-16-2012)
#5736
#5737
runnin a little boost
I am looking at connecting the front and back crank case vents to an oil / air separator with it attached to the front IM vacuum port. I am hoping the IM will provide enough Vaccuum to evacuate any blow by I am getting. My filter is attached straight to the turbo and I don't want any oil going thru it so the IM will be my only source of vacuum.
Here is a pic of the separator I was looking at from Jegs and at $50, it's cheaper that other options I have looked at.
I am also picking up boost from the top of the IM near the throttle and noticed Bert is using a port on the rear of the IM. Am I using the wrong location to pick up boost from? I will be doing my check valves soon and am wondering if I should pick up boost from Berts location so I can put a check valve on that port.
#5739
I think it's a good idea to clarify that pre-turbo is a source of filtered air but it is not a source of vacuum. Post turbo has pressure but no vacuum. And obviously post throttlebody is both vacuum and boost.
#5740
10mm (3/8) crankcase check valve: http://boombaracing.com/cv.html
3/8 check valve for both evap and brake booster: http://www.usplastic.com/catalog/ite...3369&catid=489
http://www.summitracing.com/parts/MOR-85496/
http://www.moroso.com/catalog/catego...?catcode=18549 (scroll all the way to the bottom)
#5741
18psi
If I can delete the pcv valve then I wont need the additional oil separator on there.
What do you mean "picking up boost?" Are you talking about the vacuum lines? If im reading what you wrote correctly, your saying that you are using the nipple that is on top of the manifold right after the inlet for your vacuum lines? If so, then where is your evap line connected too? You should be using the nipple on the rear of the manifold that was intended for the oem motor mounts vacuum lines.
Judging by the look of the PCV oil separator it's Moroso 85496:
Hi speed (09-17-2012)
#5742
Just to confirm my understanding, we need breather tubes from the valve covers to the vented catch can:
- when IM has vacuum: so PCV can suck in clean air through crankcase => increased oil life
- when IM has boost: to relieve any crankcase pressure since boomba value may be forced shut by boost in IM => prevent oil going places it's not supposed to and keep your rings happy
At idle, we'd expect the IM to be sucking air from the vented catch can -> crankcase -> PCV -> IM (vacuum). However, since PCV is only on the front bank only, will only the front bank have gases scavenged? Or does the rear bank deposit blowby into the vented catch can, which then is sucked through the front bank, and into PCV -> IM, and then burned up? It doesn't seem like you'd have clean air flowing over the rear bank unless the opposite end of the rear valve cover had a PCV -> IM as well.
#5743
For something more permanent, maybe remove the valve cover and use some JB Weld putty to plug up the hole? Spare valve covers are $113 if you ever need to go back.
#5744
Boosted...
I ultimately wanted to delete the stock pcv valve and tube because I already have a vented/baffled catch can coming off both valve covers. However, when I pulled the stock tube and capped the manifold and valve cover, the car would stall while idling. I have a feeling that if i can delete the pcv valve itself, and put some kind of block off plate on the opening, then I will be able to cap off the valve cover and the car wont stall. I think it was stalling b/c the valve was forced shut due to lack of vacuum from the IM pulling it open.
bTwix (09-19-2012)
#5745
IMO, this is how it should go one of two ways on pretty much any car.
1)A breather on each valve cover. No true PCV (POSITIVE crankcase ventilation) which implies scavenging via vacuum in the IM. This provides a vent at all times for blowby. Nothing hooked to the air ducting including the IM, nothing to go wrong. The downside is you don't get a whole lot of fresh air in. I personally run this setup on my turbo car. I actually run an enclosed breather on one side, with an opening for a 3/4" hose that runs underneath the car in the hope that the low pressure area under the car will help to pull vapors from the open breather on the other side of the engine.
2)Fresh air taken pre-turbo delivered to the valve cover just like stock. Stock PCV routing from the other valve cover through a separator (optional) with no breather, a big aftermarket check valve, to the IM. The fresh air opening pre-turbo will give pressure (blowby) a place to go when under boost since the PCV valve shuts completely down and flow ceases through the valve when the IM goes under pressure. Basically it will backflow but only under boost. This is acceptable because the amount of oil vapors going through the intake tract will be minimal, only when under boost. I like this setup better but I chose the super reliable, simple way.
bTwix (09-19-2012)
#5746
If you want to fully delete the factory PVC system, check out a front valve cover from the 2000-2003 Tl's. It has the same bolt holes and tubes but no PCV. I know they fit, as i have done the swap myself (only inverted). I used an 04 rear valve cover to delete the PVC on my SC setup. And an extra bonus to removing the PVC it added a breather port on both valve covers (on the trany side). I was actually curious about your vented catch can, as it is what i need for mine as well.
http://www.oemacuraparts.com/parts-c...der-head-cover
#5747
For #1, do you connect your draft tube to both front and rear valve covers, or just a single cover (front or rear)?
#5748
Boosted...
The 2003 front valve cover has no PCV but also no dipstick:
#5749
For #2, you suggest stock routing of breather tube from rear valve cover and stock routing of PCV from front valve cover, which is consistent with http://www.oemacuraparts.com/parts-c.../breather-tube and http://www.oemacuraparts.com/parts-c...head-cover--06. However, I don't see any tube that connects the front cover to the rear cover directly, so when IM sees boost and boomba checkvalue shut, how would blowby from the front cover escape to protect the rings?
So in #2, fresh air enters one valve cover and exits the other and into the IM during normal operation. When you go under boost, the crossflow momentarily stops and all venting is done through the fresh air side and goes through the turbo and intake tract which is fine.
In #1 it vents the same whether under vacuum or boost but you get no fresh air.
bTwix (09-21-2012)
#5750
With the front and rear banks connected, is there any benefit to running two breather tubes, one off each bank (like libert's setup, and probably the way mine is being setup now) if you're going to retain the pcv?
#5751
If you have the PCV and a breather on the same valve cover its just going to pull fresh air from the breather and send it to the IM. If you have only one breather and its opposite the PCV valve its forced to pull fresh air through the engine. The stock routing is perfectly fine with a turbo. The fresh air will come pre turbo or via a breather. The PCV valve gets upgraded, you can add a non vented catch can between the IM and PCV valve, and you have a functional PCV system.
#5753
If I want to retain the PCV function, I should be running the stock tube (or larger tube) from the rear valve cover to the pre-turbo intake (with no vented catch can in between - maybe oil separator?), and that will be sufficient to relieve blowby crankcase pressure while under boost, when the upgraded PCV boomba value is shut?
#5754
Is there an advantage to running the rear fresh air supply pre-turbo vs just having a filter on the fitting getting fresh air from under the hood?
I've got a vented can on the bench right now but if a non-vented can in the PCV loop works with the upgraded valve, I would rather go that way. I am running out of room to add stuff under the hood.
#5755
A separator should always be on the vacuum side, never the fresh air side unless you're worried about the few seconds you're under boost putting vapors through the intake tract when it backflows.
The main advantage of getting fresh air preturbo is if you have a lot of blowby. The breather filter can become saturated with oil. I've had that happen and the oil would drip on the headers and create small fires. As long as the engine is healthy there are no problems. Not that it's necessary but the preturbo will have a very slight vacuum under boost to help a little. Not really enough to matter and if it is your preturbo intake tract is too restrictive.
#5756
I'll ping Rodney and see about retaining the factory PCV routing, with fresh air directly from pre-turbo with no catch can, and then delete factory PCV value (cover plate or JB Weld), and adding an oil separator and boomba check valve on the manifold side to retain the PCV function.
Improved OCI, emissions, and this video series on blowby/PCV http://www.youtube.com/watch?NR=1&fe...&v=3JYut_eyw-k, all make a good argument for retaining the PCV function.
Sounds like entirely deleting the PCV system would make the car run more rich (less air drawn into IM), and an open pipe (no stock PCV valve/spring metering airflow) would make the car run more lean (more air flow), so sounds like the final PCV setup should be in place prior to the tune.
#5758
One additional idea on retaining factory PCV flow through the engine when not under boost, while retaining both front and rear valve cover breather tubes that libert and I already have in place, is to put an additional boomba check valve on the front valve cover vent tube so it's not used as a fresh air source, but could be used to relieve excessive crankcase pressure while under boost.
Also, having the front and rear valve covers vent to a vented catch can (liberts and my current setup) would only vent to atmosphere under major boost, in which case we're definitely not standing still so less of an issue.
Adding the 2nd boomba check valve seems like the best of both worlds, since it would retain factory PCV air flow from rear valve cover through entire crankcase, and then out the front valve cover to IM and then burned off, while providing an extra measure of protection for venting the crankcase while under boost.
#5759
EDIT: Just checked my little filter, it's got oil on it so I see what you mean. Not enough to be dripping but if I put my hand on it I get some oil.....
#5760
Here's a picture.
If retaining factory PCV air flow, there are three options for fresh air side:
a) keep setup in pic below, but add a check valve to front tube, so no fresh air in, but allow pressure out.
b) eliminate front vent tube entirely, so fresh air only enters rear cover, but keep the vented catch can
c) eliminate everything except single tube from rear cover to pre-turbo intake, which is the factory setup
