Factory IM Spacer - 17108-RDJ-A00
#601
takin care of Business in
Received 4,732 Likes
prompt motherfuckers !!!!
thanks a lot both of u for being prompt !!!!
#603
so thats like shaving off 7mm of 37-38mm.....dont think this will be too bad !!!
#604
has anybody done this with the throttle body spacer? my cai already had some issues with rattling, and what is the effect on top end? i just installed pcd's and i love the highway power and would like to keep that
#605
AZ Community Team
Received 7,770 Likes
Is this the cause of your rattle?
https://acurazine.com/forums/showpos...05&postcount=3
Posting just in case it might help.
#606
Green Machine
#607
Modding my TL in
1 Post
Update:
Engine still going strong. I am very happy with the mod.
HOWEVER, the brake booster line rubbing on stock strut bar and even Richie's that I got after time really starting pissing me off. I spent a great deal of time, money, and effort into trying to make it perfect. I cut stock hose, added a different hose on angle, replaced that hose when wore out and split, replaced that hose with another that kinked due to heat and made me lose my brakes almost causing me an accident to replacing the hoses again to buying a new OEM hose (slightly different design from my stock one from Honda for our TL) to it working out but touching to finallly....
Notching Richie's Strut Bar (note: It is not purely hollow. The center one inch is solid and the outer edges are hollow about less than a corner of an inch (so rigidity is not compromised). I covered the notch in velcro (for looks) and well, no more rubbing, all is good and the pic below:
![](http://www.heagney.net/cars/acurapix/strutbarnotched.jpg)
Now, I'm super pleased, FWIW!
#611
Green Machine
Do you have any additional spacer (P2R or Outlaw)? I don't have this problem with the stock strut bar. It touches but no rubbing. Also I have Innovative Motor Mounts, so that probably helps as well.
Update:
#614
i think that may be the cause, i just tightened the screw that attatches to the rubber piece on the fender and that has stoped the rattle, but i think if it comes back i will try the padding.
should i use my tbs or remove it when i do this mod????
#618
^^^ wanna sell it to me LOL....
dude can u get like another one for me ???
#620
i spoke to them a while back and they didnt....lemme see if they have it now !!!! if not imma hit u up !!!
#628
wham bam thank you ma'am
for the 2nd gen tl/cl we need to cut more and put in a bigger spacer.
pic of mine installed
http://s252.photobucket.com/albums/h...Picture025.jpg
![](http://i252.photobucket.com/albums/hh9/trviper03/DY%20intake%20spacer/Picture049.jpg)
![](http://i252.photobucket.com/albums/hh9/trviper03/DY%20intake%20spacer/Picture050.jpg)
![](http://i252.photobucket.com/albums/hh9/trviper03/DY%20intake%20spacer/Picture057.jpg)
but i can feel the power. breaks the tires loose at any mph in 1st gear. longer peel out in 2nd and rpm raise faster.
#630
Chapter Leader (NY/NJ)
thats it!! im tired of having these on the floor of my rear driver seat. gonna install THIS WEEK! had these things for over 4 months now. evan - rain FTL!!! i see the water marks LMAO congrats on the RV-6 too. also you have too much power steering fluid LMAO! hows that o-ring. $1.00 fixes FTW!!
#631
6-SPEED LOVER
oh btw lil vid of the spacer
http://www.youtube.com/watch?v=nQ1B_Y-3PL8
#634
lmaooooo
Wooo hooo!!! Lex holla at me gots to c that happenin!! P/S fluid is fine want it to b nice and lubed lmao, O-Ring FTMFW!!!!
2 in the PINK son not the gap
#637
J36Twingt28r's,nextgt30r
hey so i found out this can work with my 7th generation accord!! however milling down the spacer is needed. I have a question for anyone, how do can i give my hood a hood lift? u know where the back of the hood is lifted up a little. i really don't want to mill down the heads and was hoping that anyone with knowlegde on how to lift the hood can help. thanks.
ps. if i can get this done i am going to do a comparison dyno test between having this on and off.
#640
Hey guys just a lil update....
Since installing this spacer I have installed precat deletes.
I am now about to bolt on a junkyard Intake Manifold and Intake Runners that I had PnP'd.
After talking on the phone with P2R, they said that after much experimentation and dynoing with the J32A3 with/without the RDX/RIDGELINE spacer in a high flow top end setup, it is best NOT to use it any longer because of more than acceptable losses to the top end. How much exactly, I do not know. But this will be getting removed this week from my car.
