Factory IM Spacer - 17108-RDJ-A00
Old 07-25-2009, 10:42 PM
  #561
Former Whyner
RonJonTL757's Avatar
Originally Posted by gerzand
Is there an emoticon for "oh sweet baby jesus in heaven?" This thread needs it.
Old 07-25-2009, 11:12 PM
  #562
practicing nihilist
NedShneebly's Avatar
If there's a fire under the hood, that blanket certainly isn't going to put it out. Damage is done by that point. Carry a fire extinguisher if you're that worried about it.
Old 07-28-2009, 09:57 AM
  #563
Ryan Christopher
Black_05_TL_6SP's Avatar
Finally got the time to install the spacer last night.
I actually milled the factory IM spacer down 7mm. I also purchased 100mm bolts(they were from Fastenel and have used a Allen wrench to tighten) and the studs from the dealer, as well as 7 washers.
Factory spacer = 1 5/8" (41.275mm)
After milling = 1 3/8" (34.275mm)
~16% reduction in height.
I removed the liner on the bottom of the hood. I was able to connect the brake booster hose back on with no issues (I have the RV-6 strut bar) as well as the sensor next to it. It clears the strut bar, but is pretty close. During testing I have not heard any bumping on the strut bar. I was able to close the hood as well without it hitting. Testing also showed that it did not hit the hood. No other mods to the hood other then removing the liner. I have not attempted to put the engine cover back on yet.
You can tell there is a gain in tq. This is very evident when in 6th gear and you get on it.
Old 07-28-2009, 11:15 AM
  #564
Green Machine
t0talacuratl's Avatar
Glad the milling worked out! Were you able to keep your Outlaw spacer on? I took mine off during install to prevent issues.
Old 07-28-2009, 01:09 PM
  #565
Ryan Christopher
I actually left it off. Not all that worried about it. It actually stayed pretty cool after the test run. I think it is able to circulate more air around the IM now.
Old 07-28-2009, 01:16 PM
  #566
jerome736's Avatar
So can this be installed without leaving off engine covers or removed hood insulation, etc? I'm interested in doing this too, but my mechanical know-how is...on the sub-par level :P
Old 07-28-2009, 01:26 PM
  #567
Chapter Leader (NY/NJ)
InFaMouSLink's Avatar
read the whole thread and you'll see all that can be done for your needs, raised hood, cutting.etc good info to know in here b4 you just think your gonna swap out a piece
Old 07-29-2009, 09:02 AM
  #568
6-SPEED LOVER
ABP_04TL's Avatar
+1 i agree, ull need to read page by page
Old 07-29-2009, 10:23 AM
  #569
Inaccurate's Avatar
jerome736,
Not trying to be disrespectful, but just trying to give you a clear answer.
Don't try this mod. This mod requires custom work, not a simple "remove old part, bolt on new part". There are too many gotcha's (pitfalls) if you are not mechanically inclined.
Old 07-29-2009, 02:23 PM
  #570
jerome736's Avatar
Originally Posted by Inaccurate
jerome736,
Thanks! That was kind of the response I was looking for. I did read page to page to a certain extent, but it seemed like people were trying different things. I'll keep my hands off my spacer for now :p
Old 07-29-2009, 02:27 PM
  #571
Mjakaz09TL's Avatar
not to mention what it will do to your warranty as i ever so recently discovered
i was at 50,700 at the time so whooopppeee i missed out on the extended lawsuit wrnty by 1800 miles. plus i have an extended wrnty thru a 3rd party so no worries
Old 07-30-2009, 04:07 PM
  #572
Modding my TL in
xcelir8TL's Avatar
All is good. It cannot void your warranty (blah blah blah).
Still happy with the results. No engine cover though.
Old 08-04-2009, 07:54 AM
  #573
Ryan Christopher
After having this on for a week now and the ECU finally relearning everything, not to mention some cool temps outside, it is so much fun! I could really feel the TQ difference with it. I was playing around last night and WOW! The pull in 1st through 3rd is insane.
Old 08-04-2009, 08:04 AM
  #574
maharajamd's Avatar
Received 1,544 Likes on 1,197 Posts
JUST TO CLEAR THINGS UP
I'd say the insulators primary purpose may be fire safety, but it does offer a lot of sound dampening.
lol
Old 08-04-2009, 08:22 AM
  #575
ml3456's Avatar
Black -05,
Well done. If I was to do it I would go down this route also. Looking for some more low end tq with the manual trans. Do you think this would work with the stock bar or is it to low? And did you try the engine cover back on yet?
Thanks, ML
Old 08-04-2009, 08:40 AM
  #576
Green Machine
Originally Posted by ml3456
Black -05,
Thanks, ML
There is no denying the extra tq gain. You will be pleased!
If you only use the stock gaskets with the spacer, it will fit. It might be a snug fit, but it's doable. At least for me anyway.
You can forget about the engine cover, it won't fit.
Old 08-04-2009, 09:43 AM
  #577
Ryan Christopher
Black -05,
Thanks, ML
It would work with the stock bar, but you would need to leave one of the sensors unbolted. It is only bolted to the manifold so a short hose can get to it. You can zip tie it up to something rather then bolting it to the manifold. The brake booster hose may be your only issue. I have not put the engine cover back on. I have a feeling the manifold is VERY close to the hood, but is not touching it.
Old 08-04-2009, 10:04 AM
  #578
Green Machine
I got the sensor to fit, but it was very close to the bar. I cut the booster hose shorter so it was not too snug. Others say their having issues; not sure if my motor mounts change the position of the motor at all.
Old 08-04-2009, 10:23 AM
  #579
Ryan Christopher
All mine fit with the RV-6 bar and the 7mm shaved off. This is why I could not give a definitive answer on it fitting with the stock bar.
Old 08-04-2009, 01:15 PM
  #580
practicing nihilist
All my sensors and hoses bolted back up, although some of the hoses were a bit stretched and my AEM throttle body boot barely made the reach.
Old 08-04-2009, 05:39 PM
  #581
Modding my TL in
xcelir8TL's Avatar
I mod'd the brake booster line, though I have an RV-6 bar. Now, there is a 1/4" gap between the brake booster hose and RV-6 bar. Also, yeah, no matter what - no cover. I tried it again and it rubbed (even with my modified hood attempts). The car is so great now. I had to get a new radar detector with longer range.
Old 08-05-2009, 09:30 PM
  #582
cschell's Avatar
I am thinking about adding this mod to my list. If I do decide to do it I will get milled down much like acura_05 did but maybe just a little more as I have the fat stock strut bar and plan on leaving the P2R on. How thick is the underhood insulator? if I have to trim it to fit under the strut how much more do you think I would have to go to be able to leave on the hood insulation? would the mod be worth it at that point? I want to keep my car looking as oem as possible. Also we saw a change on the dyno with the full thickness of the spacer, I am curious to see if the gains drop linear with the thickness or even pick up or what.. any insight please
thanks
Old 08-05-2009, 09:38 PM
  #583
Modding my TL in
xcelir8TL's Avatar
thanks
Toss the insulator - if cut will just make a mess and lose it's rigity.
Old 08-07-2009, 02:21 PM
  #584
cschell's Avatar
sorry for the miss understanding i meant trimming the spacer....
Old 08-07-2009, 02:59 PM
  #585
Inaccurate's Avatar
thanks
As a rough estimate (in light of nothing else), I would very much use this as a guideline. The gains would change in proportion to the change in length (runner length).
or even pick up
Not in this case. Only in an extreme case of using a longer and longer spacer where you would find the optimum runner length. But, not in this case.
Old 08-07-2009, 05:14 PM
  #586
cschell's Avatar
I was thinking the same thing, thanks for the input!
Old 08-25-2009, 12:55 PM
  #587
6-SPEED LOVER
ABP_04TL's Avatar
gettin mine installed this week... lets c how it goes
Old 08-30-2009, 10:20 AM
  #588
6-SPEED LOVER
ABP_04TL's Avatar
got it installed and holy moly... i feel the extra pull... dis is a must especially if u have a 6spd!!!
Old 08-31-2009, 02:27 PM
  #589
Nismo TL yo!
6spdtl-s's Avatar
who has done this to a stock motor? are the gains still that noticeable?
Old 08-31-2009, 03:23 PM
  #590
practicing nihilist
mine wasn't stock when I did this mod, but I did have to take the spacer off for a while. The low and mid range punch is noticeable. Got better results with the debatable ECU reset. I based this simply on the 'spinning tires' test. they rolled easier post reset.
Old 09-24-2009, 10:36 PM
  #591
J36Twingt28r's,nextgt30r
tenzingsherpa's Avatar
does anyone know if this mod can be done to a j30a4 from a 7th gen accord v6? i have a 03 v6 accord and would love to do this!! will this fit? please help me acurazine gurus. thanks
Old 09-25-2009, 06:30 AM
  #592
practicing nihilist
you'll have to wait till the pro's with the schematic views start replying. Start by finding the exploded view of the J30A4's intake manifold. usually it will be pretty apparent just by the shape of your gasket if it's gonna work. you could print out one of the ga'zillion shots of the spacer in this thread and hold it up to your broken down IM section.
Old 09-25-2009, 03:59 PM
  #593
TEAM INFIDEL!
Actrite04's Avatar
Ive had this done for bout a month....figured i would drive it some b4 postin. I must say it seems to bring the torque back. I only have the auto so its prolly gonna b diffrent than the 6 spd guys.
IM impressed with it too say the least. Im runnin pretty much a free flow on the exhuast. It will def help u if ur modified.
My car is at the paint shop and sooo ready to get it back....missin it.
Old 09-27-2009, 12:20 PM
  #594
wham bam thank you ma'am
Rajca's Avatar
if it works for the 3rd gen guys, i guess im gonna be a guinea pig and do it for the 2nd gen tl/cl guys (unless someone does it before me). my engine has bent valves so dought that its gonna have any good gains
Old 09-28-2009, 11:15 AM
  #595
gerzand's Avatar
Ive had this mod since this thread started, installed the precat deletes on friday. Ive ive got an Autotragic, but this motor feels beefy as shit now. See my sig for my list of mods. Cat FREEEEEEEEEEEEE!
Old 09-28-2009, 01:32 PM
  #596
CleanCL's Avatar
It won't clear the hood on the 2G TL/CL guys from what I've read.
Old 09-28-2009, 02:26 PM
  #597
takin care of Business in
swoosh's Avatar
Received 4,732 Likes on 4,064 Posts
an honest question to you.....i dont feel comfy cutting the hood or taking the insulation off....do u think it will work for me ???
I dont mind milling down the spacer but dont want the gains to disappear !!!! what do u suggest ??
Old 09-28-2009, 03:09 PM
  #598
Rajca's Avatar
Taking off the insulation won't harm ur car or engine in any way. But mill it down if u feel more comfortabe.
Old 09-28-2009, 03:28 PM
  #599
Ryan Christopher
Milling cost = $0 (More then worth it to try and see how it does.)
I took a wild guess at the 7mm based on all the info provided in this thread, so I am grateful to everyone that gave input into this thread. Once I get some time, I am going to install it. I also picked up some M8x100mm socket head bolts from fastenel. I hope to get some time this weekend to get it done and post some pictures. I do hate that I am not going to be able to use my lovely MB carbon cover anymore!!
With the milling, you can take off the 7mm like I did. I still had to remove the insulator, but everything else cleared fine. Well worth the money!
Old 09-28-2009, 03:30 PM
  #600
Ryan Christopher
As mentioned above, you will need to remove the insulator and leave off the engine cover (reduced weight!!! ), you won't notice. 7mm seamed to be the magic # for me.
Quick Reply: Factory IM Spacer - 17108-RDJ-A00
