ATLP J-Pipe Dyno
#881
312 HP 271 TQ Dynapack
Originally Posted by VanPelt
As in with an ets 58 trim on meth it made 400 horse at the wheels.It was solid in stock form as well since I need to clarify that I am not one of "those guys" Also since you would regard me as an idiot for trading it in and havent ever owned one yourself.I will explain . An evo is fun ride but there are some serious issues from a maintenace point of view.Insurance goes up every year due to the fact of street related racing.Horrible for gas milage,Anyone with a riced out civic always wants to race and I have been pulled over more times in the evo than in all my other cars combined ![Doh](https://acurazine.com/forums/images/smilies/doh.gif)
![Ignore](https://acurazine.com/forums/images/smilies/ignore.gif)
#882
Originally Posted by mrlunecy
HAHAHA! Well, I feel like a f@ckin idiot!
Sorry, Van, you didn't say anything about a freakin BeeBee58 on crank! I thought you were just another one of those kids posting crap about an EVO they never had. Didn't mean to offend you, bro. Be more specific next time. Welcome to the TL fam.
No problem,I dont get offended easily.I also understand your point of "evo related stories" as well.
#885
Mine didn't come until today. I couldn't get the third cat bolts to brake loose, so I'll have to wait. The place where I took my car to have the pulley put on, couldn't get the bolt off, so I ordered the pulley tool and will have them install the j-pipe when they do the pulley. I'll try to get it done next week. The pipe looks great and the quality is outstanding. I look forward to seeing the test pipe, hopefully soon.
#889
MY KBP IS BTR THN URS...
UM I GOTS A PROBLEM ONE OF THE NUTS STRIPPED COMMING OFF I THINK ITS THE CAT, I GOT TWO ON THERE, SHOULD THIS BE OK FOR THE TIME BEING? ,I HOPING ITS JUST THE NUT AND I CAN RE THREAD THE BOLT BUT IF NOT ANY BODY HAVE ONE THEY WANN GET RID OF...WILL I BE OK TO DRIVE THE CAR WITH ONLY TWO NUTS ON THERE?
![Cuss](https://acurazine.com/forums/images/smilies/cuss.gif)
#890
My Dyno Results;
![Name: tl_dyno_hptq_part2001.jpg
Size: 51.8 KB](https://acurazine.com/forums/attachments/3g-tl-performance-parts-modifications-112/84911d1501791993-atlp-j-pipe-dyno-tl_dyno_hptq_part2001.jpg)
![Name: tl_dyno_part2002.jpg
Size: 47.9 KB](https://acurazine.com/forums/attachments/3g-tl-performance-parts-modifications-112/84912d1501791993-atlp-j-pipe-dyno-tl_dyno_part2002.jpg)
S/C, PROCATS & REFLASH.....+GREDDY CATBACK & ATLP J-PIPE............GAIN (J-PIPE AND CATBACK)
............294 HP..........................312 HP.................18 HP
............261 FT-LB......................271 FT-LB.............10 FT-LB
............6.4 PSI..........................4.6 PSI................-1.8 PSI
weather; 74 F and 47% humidity (VERY CLOSE TO FIRST DYNO)
Remember this is a dynapack pull, (power at wheel hubs), not to be compared with dynojet pulls.
You can compare the two runs on the charts as before and after, since my 1st run, 10 months ago, yielded similar numbers to the ones in yellow (thin purple line)
Overall I am very satisfied, but's it's pretty much what I expected. The 2 psi drop in boost pressure is sweeeeeeet! I think I need to be in the 330 HP range with all my mods, though. But for being a normal boost 5AT...I can't complain!
#891
tehLEGOman
Received 1,982 Likes
^^Impressive!
My brother and i installed the j-pipe today and it's definitely a power maker for the supercharged TLs.
#893
2005 Acura TL w/ Navi
recieved my jpipe today ..it looks sooo sexay..hope to have it on by this weekend..i will def get some shots of before and after with greddy exhaust and then with greddy + jpipe - not to mention im dropped/slammed realllllln low now (about 2.25in)
#897
94 DC4 RS LSV/Turbo
#898
94 DC4 RS LSV/Turbo
Originally Posted by minkl81
wasn't batches sent last week had oil pan clearance issue fixed?
mine got installed today and they were touching eachother with no room to play whatsoever.. will post pics soon
for the gain.. improved throttle response and low-end torque was instantly noticeable
![Annoyed](https://acurazine.com/forums/images/smilies/annoyed.gif)
#899
THANKS, IT LOOKS LIKE THE NUT IS COMPLETLY TRASHED BUT THE STUD COMING OUT THE CAT APPEARS TO BE OK, HOW MANY OF U GUYS DID THIS INSTALL WITH HAND TOOLS? WELL I'LL TRY AGAIN TONIGHT...
Originally Posted by stillhere153
when I did the procats install I found 1 of the 3 bolts on each cat would stay on and you would have to use 2 bolts to torque it loose... if it is stripped, drill it out... no biggie and just get a replacement of the same size
#900
94 DC4 RS LSV/Turbo
hand tools is the sure bet, don't worry yourself and just see if you can drill the stud coming out of the cat no problem... well aslong as you know what you are doing
#901
Oderint dum metuant.
I used hand tools, but had to replace two nuts (one I had a shop get off with an impact wrench). I could probably replace a couple of more, but I was still able to get my sockets to work on them so I used them. I also put a good coating of anti-seize on the bolts and nuts before I put the new j-pipe on.
#902
WELL I WENT TO NAPA TO TRY AND FIND A REPLACEMENT NUT, NO LUCK. SO I WAS LIKE LET ME CALL ACURA, THEY WANT 13.00 FOR THE 1 NUT.
I GOT SOME MORE PLACES TO TRY...
![ugh](https://acurazine.com/forums/images/smilies/ugh.gif)
#905
It's important that everyones used grade 5 hardware on all these exhaust connections to avoid any future grief when removing or swapping parts. I had all grade 5 hardware between pro cats and j-pipe for almost a year, before I installed the ATLP pipe, and the hardware came off without any problems.
#908
![](http://i72.photobucket.com/albums/i171/el_lunatico/tl_dyno_hptq_part2001.jpg)
![](http://i72.photobucket.com/albums/i171/el_lunatico/tl_dyno_part2002.jpg)
#910
TL-S with OEM Exhaust
Mine were barely touching eachother with the pipe pushed out furthest away from the oil pan. Pipe has been dented in where it touches the pan and now it clears by a hair.
Now ECU adjusted to extra flow and throttle response is very instant and torque gain is close to putting in aftermarket headers. Felt little sluggish after getting bigger wheels but this mod negated that power loss. Great mod for the money.
Stillhere, don't just assume that its install error when jpipe doesn't clear the oil pan. When car's lifted on the lift, jpipe pushed out furthest possible and if it doesn't clear, it'll not clear.
Here's my pics
![](http://img517.imageshack.us/img517/2058/5zigen1vk3.jpg)
![](http://img232.imageshack.us/img232/985/5zigen2ni6.jpg)
Here's my pics
![](http://img138.imageshack.us/img138/6036/5zigen3ws2.jpg)
#913
Originally Posted by erick3
WOW, you're hitting OVER 300 hp?! those're some IMPRESSIVE numbers man...
But remember, that's HP at the rotors. power to the ground would be a little less than 300....prob 285-to 295 HP, hopefully.
I like using this dyno because it's good for keeping track gains from tuning upgrades and parts add-ons, accurately, without any error associated with wheel slip or tire pressure.
#915
Turd Polisher
I'll be sending in a deposit soon, when I get my check that is.
#916
I have car ADD
simple hammering ![Tomato](https://acurazine.com/forums/images/smilies/tomato.gif)
im still gonna heat wrap mine.. and from now, synthetic oil only... it holds up better against thermal breakdown of oil...
#917
THE J35A2...
https://acurazine.com/forums/showthread.php?t=179433
i thought you did 330hp that day
![Sad](https://acurazine.com/forums/images/smilies/sad.gif)
nice to meet you BTW
#918
347hp/300tq @ 4psi
not in all cases. i actually dyno'd 2 hp more one time going from shawns to a dynojet. i'd say when you car is nice and cool, you'd probable be around 300-305whp , cause the SC gets gets pretty heatsoaked on the dyno.
#919
Originally Posted by SIRSIG
Mario, this is Siggy man! got your car pictures on this thread...
guess what? i think i blew my HG after the dyno
i'll check it out tomorrow. I'm also not happy on my e-cutout so that's going out of the car pretty soon...
nice to meet you BTW![Thumbs Up](https://acurazine.com/forums/images/smilies/thumbsup.gif)
That sucks about your HG, man
Nice meeting you too, Siggy!
#920
