Navigation Hack Guide: Welcome Screen Mod, Trip Computer, OK Button Nag Removal
#1001
yes! worked!
confirmed working with 3.30f version, 3.40 trip computer and navi hack provided by kennyc, and custom boot image.
i'm happy.
easiest way to do it with CEBin if you don't have 3.4 or 3.5:
put CEBin, the bin file to patch, and the three files you want replaced (back.bmp, navi.exe, hmimanager.exe).
make a text file with the following (replace BN2HH12C if needed, this is for 3.30 fversion)
image BN2HH12C.BIN
replaceFile navi.exe C:\navihack\navi.exe
replaceFile Back.bmp C:\navihack\Back.bmp
replaceFile HMIManager.exe C:\navihack\HMIManager.exe
you have to replace the filenames (C:\ whatever) with your own. Then run CEBin from the command prompt:
cebin yourfile.txt -s tempfile.bin
then rename this file to the original image name, put it with the loader on a disc, and burn away as detailed in the other posts.
i'm happy.
image BN2HH12C.BIN
#1002
http://rapidshare.com/files/24597285...i_and_trip.rar
for 3.8 Orange disc. Navi Nag hack + trip computer. Just burn the files into a cd and load it up on your TL. It got Top Gear welcome screen and I tested with my 04TL.
Thanks for angrydad hard works and "chau" providing the files i needed.
#1003
#1004
Hi everyone
I'm a new 2006 TL owner - just picked it up this weekend - all I can say it that it's an awesome vehicle - especially with the 6 speed.
I was looking for these patch files (AngryDad's OK button removal and the Trip Computer patch) and the links on vistabug's forums weren't working. I emailed the administrator there and now the links are back up for anyone who is interested. Can't wait to try out the patches!
#1005
http://rapidshare.com/files/24758025...ura_screen.rar
here is the link. trip computer + ok nag hack with acura greeting.
#1006
Help!
Does anyone have the files that would eliminate the nag screen and add the trip computer for Navi's on ver 3.30?
It seems like 3.30 is the toughest to come by... I'd appreciate any help on this!!
#1008
Thanks to Bibo136 and alot of trial and error, I finally have my Gators startup screen, trip computer and NO OK BUTTON (hated that) working with the 3.80 DVD.
As it turns out, my biggest problem was the media I was using, and possibly the burner.
FWIW: My experience tells me that Memorex DVD+RW, Kypermedia DVD-R and HP Lightscribe CD-R media do not work with my Nav unit. However, a standard HP 52x CD-R worked fine.
So if you are getting a "Please Check Disk" error when trying to load the hacks, try a different brand of media and maybe a different burner.
Thanks again Bibo136, AngryDad, kennyc, et al.
#1009
Thank you guys. I thought this would be so hard but the great write up and hard work of Angery Dad and Kennyc made it a snap. I did all the mods and everything is working great. You guys are awsome.
#1010
Fire/medic
I have been trying to do this for a week or so and nothing seems to work. Most of the links are dead or corrupted.. I'm trying to hack a 3.30D version. Can someone help me out with me????
this is my email rydac2@hotmail.com
thanks
thanks
#1011
i have been trying to do this for a week or so and nothing seems to work. Most of the links are dead or corrupted.. I'm trying to hack a 3.30d version. Can someone help me out with me????
This is my email rydac2@hotmail.com
thanks
thanks
can any1 tell me where i can download the navi dvd for a 2005 tl i think it is the 3.80 version
#1013
I hope you follow the instruction on how to load the cd from page one. Couple of users from acurazine tried my files and all of them said it works.
Below is the instruction (slightly modified to the corrected file names)
1. Extract the RAR file and burn the 2 extracted files (BN2HH12C.BIN and BN2HHMLD.BIN) onto a blank CD.
2. Go to your car.
3. Turn your car's ignition to ACC
4. Open the trunk and pop out the NAVI disk (if it's in there)
5. Insert your newly burned CD.
6. Go back to the driver seat, the display will show some dvd read error, now press and hold "GUIDE" "MENU" and "CANCEL" for approx 5 seconds to bring up the diagnostic menu.
7. Wait another 5 seconds to let it load up completely. Press "version" button on the screen
8. Press "LOAD DISC" to load your custom bin into the navigation.
9. Wait until it's completely done and it will then display another error message about can't read the navi dvd, now take out your bin CD and insert your Navigation disc and you are done!
2. Go to your car.
#1014
Follow these steps to determine which file the navi unit loads:
Originally posted by bysin
1. At the main screen of the navigation system, hold down
the Map/Guide, Menu, and Cancel buttons for 5 seconds.
2. Hit the "Version" button on the touch screen.
3. Hold down the Menu button for 5 seconds.
4. Write down the filename next to the words "Loading
Filename" (ex. BNHN404A.BIN).
#1016
#1017
Assuming you currently have the 3.80 DVD. It maybe that your car, like mine, loads a different file than the one bibo136 posted, OR it could be the media, burner or method that you are using.
My unit loads the file BNHH401A.BIN not the BN2HH12C.BIN that bibo136 posted. If this is the case, you will have to extract some files from bibo's BIN file and put them into the BIN file that your unit loads. At least that's what I did. If it turns out that your unit loads the same file that bibo posted, then I would imagine it's the media you are using, the burner or the method of burning. See my post about 6 up from this one (#1008) for my experiences with certain media.
#1018
Hey guys, looking for some help please:
Basically I have the 3.40c firmware, and was able to successfully update the background (thanks AcuraZine, KennyC and the Crew) but would also like to get rid of the nag screen. I followed the directions, and end up with a blank screen with the "GO" button replacing the nag text and "Okay" Button.
I've been searching all day and seem to think that I need the nonag-navi.exe file unless im looking for the wrong thing?
Any insight would be greatly appriciated.
#1019
okay i feel like a total moron. This should not be a mystery but apparently I am running into a brick wall.
I have the 3.3g DVD and when i go to grab the files off of the DVD, one of them is missing. I have bn2hhmld.bin but there is no 401 file...
Am i missing something. Here is a screenshot of the directory:
http://i32.photobucket.com/albums/d24/NNatic/navdvd.jpg
I am reading the instructions on the first page but without that file i assume that i am going nowhere... can anyone assist??
#1020
well i think i am getting somewhere but not too fast.. i used a file called bn2hh210.bin ( i know the numbers are right.. not 100 percent on the rest) and used the command line dump navi to edit it.
i burned it to a cd and then popped it in - it says it cant read the disk... i tried doing it again with no luck. I may just need to use a different type of cd.. maybe these dont speak well with the navi drive.. they are just tdk cdrs
any other ideas.. .am i on the right track here?
#1021
Kudos likewise to Bibo136; I decided 3 years was long enough to wait on the new navi DVD, but had resigned myself to losing AD's OK hack and the trip computer. I downloaded his RAR files, extracted navi.exe and HMIManager.exe from his BN2HH12C.BIN file and updated my BNHH401A.BIN, added my custom Back.bmp file, burned onto a Office Depot DVD_RW 4x with the Brasero disk burner in my Ubuntu distos, and I'm back in business.
#1022
#1023
If you're using the same version that I am (and I think you are) the files that you need are BNHH401A.BIN and BN2HHMLD.BIN.
If you think you have the right BIN files, then try using a different brand of cd, or a different burner.
#1024
Yeah, mine loads the same file, but when I try to use his navi.exe on my .bin file, it says it's too big. How did you get past this problem?
#1025
Or, to be more descriptive:
>dumpnavi.exe BNHH401A.BIN update navi.exe
Updating navi.exe ...
The size of the updated file must be less-then or equal to the size of the old file.
This feature might be introduced in a newer version.
Updated file (COMPRESSED): 3028772 bytes Old file (COMPRESSED): 3027804 bytes
#1027
If you don't mind, that would be great. I just tried to use CEBin to update my bnhh401a.bin with the navi.exe that I extracted out of one of your other posts, but the navi system just crashed when it came up (although the Top Gear image did show, so it partially worked).
My yahoo.com address is mattalbright .
#1028
Here is the link for mod. BNHH401A.BIN file for 3.8 DISC
#1031
4th Gear
I have a 2009 Honda Accord with ("White") DVD version 4.73. I have spent hours searching and as far as I can tell, it can't be done yet, but has anyone been able to get rid of the nag screen for version 4.73?
#1032
need a map for accord 2006 navi sys
I bought accord 2006 4 cylinders 4d with navigation system from US , I use it now in middle east but I can’t see maps so I bought pc card with 2GB SD memory card to install the new map in it. I want to know which file type my unit can read of if I can put a map from GARMIN, TOMTOM, MAJILAN or others, or if i can hack the original orange dvd disc by removing US map and put middle east map from garmin or others
advice me
advice me
#1033
Someone help
having some trouble here... I have 3.40C and i tried updating my files...
i turn on my car.
i get to the diagnostic screen.
i eject the navi cd.
i put in my new cd with all the files i just updated.
it says please check navi disc.
i press the 3 required buttons to get back into the navi diagnostics.
i press load disc.
after it gets done pass the progress bar saying its loading the files. the screen just turns blank.. any ideas what i am doing wrong??
i turn on my car.
i press load disc.
#1035
I just got an 04 TL on Saturday, but the maps seem like they were never updated, is there any way someone with an updated working custom 04 TL navi disc send me an ISO to burn? Or at the very least let me know what tips they had to doing so, besides different media brands and burners.
Any help would be appreciated, thanks guys
#1036
Hi,
I have the 3.5 version and that navi was not able to update the navi.exe from my disk so I used the navi file that Kennyc uploaded here and applied the ok patch from funkymitt and it worked....Am I going to loose anything for not using the navi.exe from my 3.5 disk?
#1037
After trying to update my naviagation system my screen went blank and nothing shows up. I've tried holding GUIDE/MAP MENU and CANCEL for five seconds to get to the dianogistic screen but that doesn't work either. Is there any other way to reset my navi. Any help would be appreciated. Thanks
#1038
Hello. I'm from Russia so I hope my english will allow me to explane my problem. I got US Accord 2d. Since 03 Accord's dvd unit has no video inputs, i bought 07 TL dvd with wihte disk 4.55. It has the same connectors that my old dvd. I started to try different codes from 0000. Soon I found it. Thank God it was "0971" so Itried only 971 variants of codes. When navy started, I found out that it loaded TL version of OS. Since I have 7" display I cant see the bottom of the picture. Also it doesn't give a signal to the clock on sub display so it shows wrong time and also I lost my trip comp. That's why I came to this forum))
I installed a Pioneer DVH-P500UB as a Dvd & USB player. I swithed audio in AUX , Video into the Back Camera in on DVD. I sent 12 v to the back light connector and made a knob to activate Back Camera input. I also control Pionner tv-tunner GX5700 thru DVD player's IP-BUS. So i have now dvd and USB and TV but I'd like to load accord's drivers into the dvd unit.
As far as I know there'is just one genreal DVD for all honda & acura dvd units. There is no a special disk for accord or TL. When I put the disk into the unit it loads drivers for tl. How does it know that dvd is out of TL. I think it get messages from hardware flash memory that is oriented on TL load files. So does any body know how to change it? May be I should take a rom dump from 06-07 accord and dump it down to the tl unit?
If you didn't anderstood what you just read let me know, i'll try to explane in another words))
Thanks.
Thanks.
#1039
Hack help please
I wanted to no if someone could do the hack for me and send them in a email I would like all the hacks but I would like a ohiostate sign for my startup screen for navi Im willing to pay money.I have 3.60 version plus I work for Honda at the marysville plant that makes your guys is cars I just want to show it to a couple of big wigs out here on what people are doing with our product!thx for any help
#1040
7th Gear
I've spent hours and hours spinning my wheels scouring the forums for this. Can anyone point my in the right direction for modding a 4.63 disc?
Thanks in advance.
Thanks in advance.
