Navigation Hack Guide: Welcome Screen Mod, Trip Computer, OK Button Nag Removal
Old 01-11-2008, 10:35 AM
  #721
Binx57's Avatar
Gvn 53
Originally Posted by ajbiggie
WAIT A MINUTE!!! . . . I'd love to hear more!!
Sorry, I should have included this link for you to read more on the GVN53 (http://www dot gpscentral dor ca/products/garmin/gvn53.htm) . Just so everyone knows I have nothing to do with nor am I associated with Garmin. I simply use several of their GPS units and find they work well - which is all I ask of a GPS unit.
Old 01-11-2008, 12:55 PM
  #722
ReenoSX's Avatar
Id' like to help out with some of this code search. I consider myself somewhat savvy when it comes to figuring things out. I'm a Java programmer foremostly so I'm not intimately familiar with HEX searching and bin decompilers.
If anything, I do have a 4.62 silver Canadian DVD that I got with my 08 TL-S if anyone needs me to try anything out with it.
Old 01-12-2008, 08:20 AM
  #723
jvinhj240's Avatar
Does any one successful on disc 4.56?
Old 01-12-2008, 02:00 PM
  #724
AZ Community Team
Bearcat94's Avatar
Received 7,771 Likes on 4,342 Posts
Found this in another thread. Don't know if it means anything or not, but thought I'd post it for you developer/programmer types just in case.
Originally Posted by lumpydog
I'm not sure that's entirely true. Bysin stated the following when explianing why he did not include the file he was able tocreate (that skipped the "OK" button):
"I didnt include the navi-nonag.exe or any other modified files with the zip because its copyrighted by Acura. All files that you wish to update you'd have to modify yourself. But I'm sure anyone with a SH-4 disassembler and a hexeditor can figure it out how to remove the nag screen. I'll give you all a hint, 0x0900 is nop."
Old 01-12-2008, 11:20 PM
  #725
Acura Newbie
blipszyc's Avatar
I think Bysin was talking about the 3.x hacks.
Anyway, I'm exahausted and heading to bed, but if anyone wants to continue, I found the Nag Screen text in the file - hmimanager.dll. It starts around offset 000A8D00. There is a bunch of other text too, so I'm sure something is calling this file for the screen, just haven't figured out what yet.
Old 01-13-2008, 04:53 PM
  #726
cocokola's Avatar
Although much that is posted here is already known / published elsewhere, it's good to have it all in once place. Typically there is text listed there, but it's just a string. One needs to find where this data is read into or used to be displayed. That should get you close to where the logic is looking for a keypress.
It would be helpful to know what is called in the OS to get screen coordinates, or if it's making a call to a known "click ok" dialogue box in the OS. We would just change the call to a NOP instruction, or a return or JMP as appropriate.
Old 01-16-2008, 10:10 AM
  #727
Binx57's Avatar
Navigation DVD Drive-Update
In post #711 I asked if anyone had disconnected their DVD drive unit in the trunk to see what effect it had on the rest of the features. I had been led to believe that everything else would work . . . well it turns out that if you disconnect the DVD unit the entire Navi screen goes black and stays black until the drive is hooked up again. So much for that idea.
Here's a to the Acura Techline guy that passed on this little tidbit.
Old 01-16-2008, 04:03 PM
  #728
onyx1121's Avatar
You found the strings table most likely; you need to find who is loading that string from that address. I assume this would be a load instruction in the assembly. Use IDA Pro Disassembler to pull apart things and see if you can figure it out from there. I believe the unit uses the SH4.
Old 01-17-2008, 11:21 PM
  #729
Acura Newbie
blipszyc's Avatar
Anyone from Europe on these boards? Do they even sell similar Acura's in Europe? If you're out there, PM please.
Old 01-18-2008, 08:46 AM
  #730
Binx57's Avatar
Acura in Europe - Not
. . Do they even sell similar Acura's in Europe?
Honda does not sell - nor do they plan to sell the Acura brand in Europe.
See this news release:
http://asia.news.yahoo.com/060228/3/2glg0.html
Old 01-18-2008, 02:21 PM
  #731
TeknoKing's Avatar
(08 TLS)
If I have to press that OK button on more time, I'll go gladiator on it, unleash on it with a hammer, sob.
Any solution for the OK hack for the new version?!?! I can't take this OK nonsense no more, no it is not OK! freaken my own car harasses me every time I start it.
Old 01-19-2008, 11:25 AM
  #732
Binx57's Avatar
Ok - Not Ok
Originally Posted by TeknoKing
(08 TLS) Any solution for the OK hack for the new version?!?! I can't take this OK nonsense no more, no it is not OK! freaken my own car harasses me every time I start it.
Even if we get this idiot button bypassed the minute you update your CD - you will have to start all over again. If you want a permanent solution go here - it is a hardware solution - most expensive model is $50. To date it is the only solution.
http://kptechnologies.com/
Old 01-20-2008, 07:28 AM
  #733
TeknoKing's Avatar
Binx thanks! but I don't think I'll be upgrading the dvd. In regards to buying a hardware solution, 50 bux just to press an OK button is not a fix, that's simply a macro.
Is there a specific file I have hex to falsify the OK button input?
My main question is this, if I take the Navi DVD, and I image it, and reburn it on a DVD-R, our TLs will still recognize it??? Thanks.
Old 01-21-2008, 08:14 AM
  #734
Binx57's Avatar
Hex Edit OK Button?
To gain some perspective on the OK button, I would suggest you go back a couple of pages in this form - 2-3 will do. Then you will know about as much as the rest of us do on a Hex edit.
I have copied the DVD onto a dual layer DVD-R but it wouldn't run. It seems that, at least on my 4.55 there is some type of copy protection that isn't copied onto the new DVD.
I have not tried imaging the disk though. Give it a try and let us know what happens.
Old 01-21-2008, 08:53 AM
  #735
TeknoKing's Avatar
Binx57 sounds, good, I will give it a try... I just need to purchase some dual layer dvds.
I think I can image it... Thanks for the info!
Old 01-21-2008, 09:55 PM
  #736
onyx1121's Avatar
Ok, first off, a hex editor is not going to be very helpful in hacking the OK button. You need to start with a disassembler that works for the Navi. processor (SH4 I believe). All you will find with the hex editor is the strings table, and change that won't do anything. So stop wasting your time.
Second, the 4.55 DVD can be copied - I've done it. Just image it. May take a couple burns depending on your burner.
Old 01-22-2008, 02:36 PM
  #737
TeknoKing's Avatar
Yes, it can be copied, I imaged it, and it worked fine.
onyx1121, do you know which disassembler for sure? damn, I haven't touched this stuff in years, I guess it's time to remember my college days of machine language, lol.
Old 01-22-2008, 02:58 PM
  #738
2007 TL NAVI
pg_rider's Avatar
Someone should put up a "reward" for the first person to crack the "OK" nag -- gotta get these smart guys motivated! Kinda like the X Prize...
(willing to donate $10 to the cause...)
Old 01-22-2008, 05:33 PM
  #739
Acura Newbie
blipszyc's Avatar
pg_rider - great idea - I'll throw in $10.
Old 01-23-2008, 09:36 AM
  #740
Lenny
Lenny11's Avatar
TeknoKing, Was there anything special you had to do to make the working copy of the DVD from the ISO image? Can a copy be made with any ISO image copier such as DVD Decrypter onto a dual layer DVD? I was under the impression that you needed a manufacturing DVD burner to recreate a working copy. I am interested in having a backup copy of my current disc to fall back on, as I'm sure a lot of people in this forum are too. Please let us know. Thanks.
Old 01-23-2008, 10:09 AM
  #741
TeknoKing's Avatar
I just used MagicIso, DVD43 running in the background, I imaged it, and burnt it on the dual layer, I can't remember whether it was DVD+R or DVD-R... I believe I've used DVD+R.
I do have a plextor dvd burner, where it automatically sets the bits as the original dvd, so it depends on multiple things, but it should work.
Old 01-24-2008, 07:50 AM
  #742
rookie1011's Avatar
I'll drop $10 as well
Old 01-24-2008, 08:05 AM
  #743
Binx57's Avatar
Disassembler
Ida Pro works fine. There may be others, but I have not tried them.
Old 01-24-2008, 06:26 PM
  #744
wgambella's Avatar
Exclamation Fixit Fee
I offer $100.00 to the brave soul that can kill my OK nag button, and change my welcome screen on an 08 TL with 4.62 navi disc. I am in North GA if any brave soul can pull it off.
Old 01-24-2008, 08:23 PM
  #745
Acura Newbie
blipszyc's Avatar
Changing the welcome screen is easy, and there is a device to "click" the button for you for only $50. Sooo, I'll stop by next time i'm in the area and make a quick $50!
Old 01-25-2008, 05:17 PM
  #746
onyx1121's Avatar
Just get IDA Pro and make sure whatever version you get has support for the SH4.
As far as those talking about the "click" solution. Sure, it may work, but its what I would call a kludge; disabling it in software should not be too hard. It's just a matter of being familiar with things and being able to dedicate the time
Old 01-29-2008, 08:50 PM
  #747
2K8 CBP TL-S 6MT
P.R.E.A.M.'s Avatar
ok can someone help me
I am hung up at one point in doing the splash screen on my 4.62 white disc
when i get to this point i get this
any help would be great
BTW I'm using pics from this site and making sure they are in 256 bmp format
Old 01-31-2008, 02:37 AM
  #748
4th Gear
Unit-X's Avatar
Originally Posted by kennyc
If you screw something up (and you probably will) All you need to do is reinsert your original navi dvd back into the drive, press and hold "GUIDE" "MENU" and "CANCEL" for 5 seconds and it will take you to the diagnostic menu EVEN if your navigation system is in a loop! Once you're in the diagnostic menu just go into "version" and press "load disc" and everything will be back to factory state.
This will not erase your phone pairing, phone books, nor presets.
[/SIZE]
I am interested in trying out this hack. My question is, no matter how bad i screw up, I can always do the above instructions and it will go back to its original state regardless or what happens??
Old 01-31-2008, 07:10 AM
  #749
Acura Newbie
blipszyc's Avatar
You need to make sure the BMP you want to convert to 16-bit is exactly 113,398. I've found that Irfanview does the trick. I think its a free program. (google is your friend)
Old 01-31-2008, 08:24 PM
  #750
2K8 CBP TL-S 6MT
P.R.E.A.M.'s Avatar
Thank you very much got it all done now and uploaded into the car
now only if the "OK" will disappear
Old 01-31-2008, 11:22 PM
  #751
Anthracite226's Avatar
Help :/
Hey i have the 3.330D orange disc and when i use the dumpnavi program i get a INVALID XIP FILE error
Everything is in the same folder i just cant extract the BIN file
Any thoughts??
Old 02-01-2008, 10:01 AM
  #752
Smokin blunts w/ Tupac in
dumamei's Avatar
Can the welcome screen be changed on a 08 TL? 4.62 disc
If so, do i follow the instructions for the 4.55 or is there a set of instructions specifically for the 4.62 disc..
I havent seen any instructions specifically for the 4.60.. If there are instructions for the 4.62, can someone please specify the exact page and thread, so I do not have to search through 700,000 pages of content..
thanks for your input in advance..
Old 02-01-2008, 10:06 AM
  #753
Acura Newbie
blipszyc's Avatar
Yes, the same instructions for 4.55 will work on 4.62. Just did it the other day. If you're having problem, be sure the file sizes are EXACTLY the same size.
Old 02-01-2008, 04:34 PM
  #754
2K8 CBP TL-S 6MT
P.R.E.A.M.'s Avatar
same here . I just did mine last night
Old 02-01-2008, 07:17 PM
  #755
B A N N E D
Igor911's Avatar
I wish someone would figure out that OK button already
Old 02-01-2008, 11:04 PM
  #756
Acura Newbie
blipszyc's Avatar
Working on it - sit tight.
Old 02-01-2008, 11:19 PM
  #757
The Kinetics of Bleu
TLAdvanced's Avatar
You guys are awesome!! I almost feel bad reaping the benefits of your research. Thanks!!!
Old 02-02-2008, 01:21 AM
  #758
2K8 CBP TL-S 6MT
P.R.E.A.M.'s Avatar
I so agree. with out the great guys on here i would be so S.O.L.
Old 02-03-2008, 04:16 PM
  #759
FlyingSaucer's Avatar
Where does the Navi Hack(s) stand in 2008?
If you are new to this thread, like me, it seems the original hacks have evolved and it's not quite clear what does what anymore.
The original, by bysin, appears to do 3 things:
- Change the background image.
- Removes the "nag screen" at startup.
- "Change some of the words that pop up".
Questions:
1. What words?
2. If bysin's hack removes the nag screen, why do we need AngryDad's "OK" hack?
3. What's the point of people uploading images if they are not formatted to the required system specs?
Old 02-04-2008, 06:39 AM
  #760
Acura Newbie
blipszyc's Avatar
Questions:
1. What words?
I know the first post isn't that confusing, but here's a recap:
Bysin's program allows you to extract and then reinject files into the 3.x BIN files. This allows you to change the background image, enable hidden apps like Trip Computer and A/C Controls, and remove the nag screen with AngryDad's OK hack. (or the others that remove the "AD" text) Bysin's program is not the hacks themselves, just the enabler. As far as the words, I think its the nag screen words. AngryDad's hack doesn't get rid of the text, just the need to tap the OK button. If you want to change the text, you can.
For 4.x BIN files, bysin's program will allow you to change the background only. For now.
In regard to backgrounds, there is a nice thread with bmps and directons on how to make your own that meet specs. Most of the pics uploaded meet the 3.x specs, but not the 4.x specs. You'll need to either save the pic as a 16-bit bmp, or get 8to16.exe to convert the 8-bit bmps.
Good Luck!
Quick Reply: Navigation Hack Guide: Welcome Screen Mod, Trip Computer, OK Button Nag Removal
