Graphical User Interface (GUI) for Project "Free DVD-A"
Subscribe
Aug 24, 2006 | 01:57 PM
  #161
All of u2's discography just made my first DVDA
Adobeman, you've certainly made this whole process a lot easier. Much thanks goes out to you .
Question: Ive seen a few pictures where the Navi console screen shows text (title/artist) of the current DVD-A is this because they have added certain modules on their Navi or can this be done by burning the DVD-A a certain way?
Reply 0
Aug 26, 2006 | 04:09 PM
  #162
when i click on "Make DVDA" I get an error message saying "there was an error during processing. it has been logged in the error log"
i converted my mp3 to wav . i dont know what i did wrong?
please help
Reply 0
Aug 26, 2006 | 05:57 PM
  #163
nevermind i figured it out . . .
Reply 0
Aug 30, 2006 | 03:22 PM
  #164
Quote: I shut everything down as well, have made multiple ISO files, and the disc plays flawlessly in the PC in which I burn it, and also in my HTPC, so it can't be the ISO image.
It skips in different spots on different tracks in my car, and I can play a song again, which skipped at (for example) 6 seconds, and the next time it skips at 35 seconds, or not at all. And when I say skips, I mean it always skips to the next track.
I haven't had any other problems with CD's or the 1 DVD-Audio disc that I own skipping in my car.
Same here ... The DVD's I burn play flawlessly on my computer. Tried the Verbatim DVD-R last week - same skipping to next track problem
Now it seems that Brian and I have one thing in common - a 2006 TL without Navi
Can anyone confirm if anybody has had success in a 2006 model - the rest being the same?
Only one thing left to try on my front - a different burner - I have a really old (but extremely reliable) Lite-on 411s which burns DVD-R at 1x only ... will try burning on a newer burner and post the results.
Hope I can find the solution ... its really disheartening to hear tracks skip like that!
-Venky
Reply 0
Aug 30, 2006 | 06:19 PM
  #165
I've got a 2006 non-navi and have burned one DVD-R so far. First 2 times it played flawlessly. Was on a recent long trip and popped it in and found near the end it started doing the random skipping. I had been leaving it in the car and assumed the intense heat of the last few weeks had damaged it and haven't had time to reburn.
Reply 0
Sep 2, 2006 | 07:56 AM
  #166
Is is 5.1 quality?
Does the DVD Audio format wav files into 5.1 surround quality? Or is it just being used to burn a series of songs that a CD-r cant no hold (size wise)?
Reply 0
Sep 2, 2006 | 08:28 AM
  #167
Quote: Does the DVD Audio format wav files into 5.1 surround quality? Or is it just being used to burn a series of songs that a CD-r cant no hold (size wise)?
DVD-Audio has lots of different channel configurations within it's spec but the DVD-A images made by my GUI are only 2 channel. You must feed it 2 channel wav files. It is just being used to pack lots of songs on a disk.
The process of converting 2 channels to 4,5 or 6 channels is basically one of psycho-acoustics, "black magic" or a little of both and luck. Arguably the TL head unit should have had some "sound fields" implemented but it doesn't. If you want to play with 2 to 6 channel conversions play around with the Adobinizer. The link is in my sig block.
Reply 0
Sep 3, 2006 | 01:49 PM
  #168
Great Program Adobeman! Thanks. Flawless disc the first time using Memorex -R disc, Roxio Creator Plus - Dell Edition, and a Phillips DVD +-RW SDVD8820
Maybe its me, even with my converted MP3s, the sound is so much better from DVD audio...
Reply 0
Sep 6, 2006 | 10:04 AM
  #169
Quote: Same here ... The DVD's I burn play flawlessly on my computer. Tried the Verbatim DVD-R last week - same skipping to next track problem
-Venky
Alright ... brace urself - I finally managed to burn SKIP FREE DVD-A's - yaaaaay!
IT WAS THE WRITER!!!!
I suspected my drive (my old Lite-on 411) all the time - since it would burn the DVD-R at 1x only ... same wth my wife's laptop ... 1x burns and skippy discs.
So I borrowed my friends external LG DVD-writer and lo behold - none of the discs skipped! I even disc-copied my 1x burned "Dark side" DVD-A and that plays without skips.
So problem solved - thank you Adobeman - thank you everyone ... if u're getting skippy discs then try & change your writer (at least that did the trick for me) .
I tested 16x, 8x and 4x burns - all played flawlessly.
Need to test the following -
1. Use my HP DVD-R's and determine if the choice of discs is really an issue!
2. I suspect that the new DVD-R's don't really support 1x burns too well! will have to find out!
3. Get Disc Welder to burn mlp tracks properly - am still getting skippy Metallica discs ... which skip only on the MLP tracks!
will post results ... right now I'm spending more time listening to stuff
Reply 0
Sep 6, 2006 | 05:18 PM
  #170
Quote: Alright ... brace urself - I finally managed to burn SKIP FREE DVD-A's - yaaaaay!
Thanks for the update. I was starting to wonder if I "F"ed something up in my code. Unfortunately hardware issues can be all too common and difficult to find.
Reply 0
Sep 7, 2006 | 08:19 AM
  #171
I have that same burner!! Thanks for the update. Time to upgrade.
Reply 0
Sep 8, 2006 | 10:36 PM
  #172
re
so if i drag and drop my wav. songs into your dvd-a program i can instantly burn dvd-a songs or do i still need to drag and drop them into nero burning rom?
Reply 0
Sep 20, 2006 | 08:55 AM
  #173
This is so freakin' cool!
Thanks for creating it for all of us.
I must admit that I found it on yahoo search first.
I came here to validate that it wasn't made by a questionable character.
After all, I was about to run a msi file
Great work!
Now if I can just figure out how to get the songs from itune to the DVD-A.....
Reply 0
Sep 20, 2006 | 11:12 AM
  #174
Great work!
If you have an iPod (some use iTunes w/o owning an iPod) the easiest way is to get an iPod adaptor for the car. Seriously, you will not have to have separate DVD-As and your iPod. Also, there will be very little sound difference between your iPod through a direct (not radio or tape adaptor) connection vs a DVD-A of the same source files. The iPod direct will probably sound better since creating a DVD-A of the same will introduce some losses or errors from conversion.
Otherwise I think iTunes will let you convert to other formats. WAV would be the one you want to feet to the GUI
Reply 0
Sep 20, 2006 | 11:38 AM
  #175
Hello Adobeman, thank you for all your hard work.
Now, it's all up to me to get this up and running.
Hopefully i will not run into any problems
Reply 0
Sep 21, 2006 | 10:18 AM
  #176
Quote: If you have an iPod (some use iTunes w/o owning an iPod) the easiest way is to get an iPod adaptor for the car. Seriously, you will not have to have separate DVD-As and your iPod. Also, there will be very little sound difference between your iPod through a direct (not radio or tape adaptor) connection vs a DVD-A of the same source files. The iPod direct will probably sound better since creating a DVD-A of the same will introduce some losses or errors from conversion.
I do use an ipod through a tape adaptor (sometimes FM transmitter for concurrent charging). I wanted to get the direct link, but I'm not a handy person.
There is no way I can figure out how to install it. It took me 5 hours and a bucket of sweat to install a pair of speakers on my wife's s2000, I don't think I want to "open" any panel any time soon.
I heard acura dealer can install a link for 400 bucks, but I'm just being cheap.
Reply 0
Sep 23, 2006 | 11:12 AM
  #177
...<snip>...
I finally got a good burn too. I was able to take the DVD's that I burned (and played well everywhere except my car), and copy them with a friends burner (he had a DVD-reader and writer on the PC, so I was able to do a straight disc copy), using the same type of media (Memorex 8x DVD-r).
The resulting discs seem to play flawlessly in my car.
Don't know if my burner isn't producing a 'deep enough' burn (don't know enough about the physics of disc burning), or if it is an incompatibility between my burner and the different types of media I have tried. Either way, guess I am now shopping for a new DVD burner...
If I haven't said it before, thanks Adobeman for the utility, it is great, and I'm now getting to listen to a bunch of my music that I don't often get to (from laziness in changing cd's on a regular basis!).
Reply 0
Sep 25, 2006 | 04:58 AM
  #178
It worked!
Worked like a charm! I used DVD+RW the first time around and the disc would not read, but DVD+R worked.
Reply 0
Oct 3, 2006 | 12:03 AM
  #179
1st, im new to this fourm and I gotta say, this forum rock!
Adobeman, great work on the GUI...worked like magic. Although I can only get it to work with DVD-R and not the DVD+R.
Anyway, Adobeman...is there any way I can make the system displays the file name? Please let me know. Thank you.
-Acura TL 2006 /wo Navi
Reply 0
Oct 3, 2006 | 11:18 PM
  #180
I can't get mine to work
First of all, a million thank you's for this piece of software. Works like a charm. Got to convert all my mp3's to wav files easily, then to iso. So the software works great.
Problem is, when I try burning the iso file to DVD. I've tried Alcohol 120% and NERO but they both give me no play. They stop the process almost as soon as I initiate it. I have logs saved and will enclose them below. This thing is frustrating. Tried every possible tweak I can think of.
Sorry about the long log, guys. I'll erase it if you all have a problem with it. Just let me know. Didn't want to upload it as a txt or doc, so as not to spark hack paranoia.
NERO
1A23-0809-4030-2295-7701-5727
Windows XP 5.1
IA32
WinAspi: -
ahead WinASPI: File 'C:\Program Files\Ahead\nero\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 10/26/2004 6:35:34 PM
Nero Version: 6.6.0.8 (Nero Express)
Recorder: <_NEC DVD+-RW ND-6500A> Version: 202C - HA 1 TA 0 - 6.6.0.8
Adapter driver: <atapi> HA 1
Drive buffer : 2048kB
Bus Type : default (0) -> ATAPI, detected: ATAPI
CD-ROM: <_NEC DVD+-RW ND-6500A>Version: 202C - HA 1 TA 0 - 6.6.0.8
=== Scsi-Device-Map ===
DiskPeripheral : FUJITSU MHT2060AT PL atapi Port 0 ID 0 DMA: On
CdRomPeripheral : _NEC DVD+-RW ND-6500A atapi Port 1 ID 0 DMA: On
DiskPeripheral : SanDisk SDCFB-128 atapi Port 2 ID 0 DMA: Off
CdRomPeripheral : AXV CD/DVD-ROM 2.2a a347scsi Port 3 ID 0 DMA: Off
=== CDRom-Device-Map ===
_NEC DVD+-RW ND-6500A D: CDRom0
AXV CD/DVD-ROM F: CDRom1
AutoRun : 0
Excluded drive IDs:
WriteBufferSize: 83886080 (0) Byte
ShowDrvBufStat : 0
BUFE : 0
Physical memory : 1015MB (1039740kB)
Free physical memory: 135MB (138480kB)
Memory in use : 86 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
3.10.2006
Burn DVD Image
11:10:35 PM #1 Text 0 File Reader.cpp, Line 127
Reader running
11:10:35 PM #2 Text 0 File Burncd.cpp, Line 3153
Turn on Disc-At-Once, using DVD media
11:10:36 PM #3 Text 0 File DlgWaitCD.cpp, Line 259
Last possible write address on media: 2298495 (510:46.45, 4489MB)
Last address to be written: 2243556 (498:34.06, 4381MB)
11:10:36 PM #4 Text 0 File DlgWaitCD.cpp, Line 271
Write in overburning mode: NO (enabled: CD)
11:10:36 PM #5 Text 0 File DlgWaitCD.cpp, Line 2316
Recorder: _NEC DVD+-RW ND-6500A, Media type: DVD-R
Disc Manufacturer: RITEKF - 1
Disc Application Code: 64, Disc Physical Code: 193
11:10:36 PM #6 Text 0 File DlgWaitCD.cpp, Line 433
>>> Protocol of DlgWaitCD activities: <<<
11:10:36 PM #7 Text 0 File ThreadedTransferInterface.cpp, Line 830
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 (2 - CD-ROM Mode 1, ISO 9660)
2 indices, index0 (150) not provided
original disc pos #0 + 2243557 (2243557) = #2243557/498:34.7
not relocatable, disc pos for caching/writing not required/not required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2243557 blocks [_NEC DVD+-RW ND-6500A]
11:10:36 PM #8 Text 0 File ThreadedTransferInterface.cpp, Line 1043
Prepare recorder [_NEC DVD+-RW ND-6500A] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 1:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 4594804736, ISRC ""
DAO layout:
__Start_|____Track_|_Idx_|_CtrlAdr_|_RecDep_______ ___
0 | lead-in | 0 | 0x41 | 0x00
0 | 1 | 0 | 0x41 | 0x00
0 | 1 | 1 | 0x41 | 0x00
2243557 | lead-out | 1 | 0x41 | 0x00
11:10:36 PM #9 Phase 24 File dlgbrnst.cpp, Line 1832
Caching of files started
11:10:36 PM #10 Text 0 File Burncd.cpp, Line 4040
Cache writing successful.
11:10:36 PM #11 Phase 25 File dlgbrnst.cpp, Line 1832
Caching of files completed
11:10:36 PM #12 Phase 36 File dlgbrnst.cpp, Line 1832
Burn process started at 2.4x (3,324 KB/s)
11:10:36 PM #13 Text 0 File ThreadedTransferInterface.cpp, Line 2609
Verifying disc position of item 0 (not relocatable, no disc pos, no patch infos, orig at #0): write at #0
11:10:36 PM #14 Text 0 File DVDR.cpp, Line 2194
Recording mode: Sequential Recording Mode
11:10:36 PM #15 Text 0 File Mmc.cpp, Line 21235
Set BUFE: JustLink -> ON
11:10:36 PM #16 Text 0 File DVDR.cpp, Line 2340
Start write address at LBA 0
DVD high compatibility mode: Yes
11:10:36 PM #17 Text 0 File Cdrdrv.cpp, Line 8430
---- DVD Structure: Physical Format Information (00h) ----
Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD-R (2), Part Version: 5
Disc Size: 120 mm, Maximum Rate: <not specified> (F h)
Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
End Physical Sector Number of Data Area: 26127F h
End Sector Number in Layer 0: 0 h (LBN: FFFD0000 h, 4193920 MB)
Data in Burst Cutting Area (BCA) does not exist
Start sector number of the current Border-Out: 2FE10 h
Start sector number of the next Border-In: 2FFA0 h
Media Specific [16..63]:
00 60 00 10 20 30 40 50 - 00 00 00 21 00 00 00 00 .`...0@P...!....
00 02 FE 10 00 02 FF A0 - 00 00 00 00 00 00 00 00 ................
00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
11:10:36 PM #18 SCSI -1046 File Cdrdrv.cpp, Line 1181
SCSI Exec, HA 1, TA 0, LUN 0
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
Sense Code: 0x30
Sense Qual: 0x05
CDB Data: 0x53 0x00 0x00 0x00 0x00 0x00 0x22 0x3B 0xF0 0x00 0x00 0x00
Sense Data: 0x70 0x00 0x05 0x00 0x00 0x00 0x00 0x0A
0x00 0x00 0x00 0x00 0x30 0x05
11:10:36 PM #19 CDR -1046 File ThreadedTransferInterface.cpp, Line 1765
Illegal disc
_NEC DVD+-RW ND-6500A\H1 T0
11:10:36 PM #20 TRANSFER -27 File ThreadedTransferInterface.cpp, Line 1765
Could not perform start of Disc-at-once
11:10:36 PM #21 Phase 38 File dlgbrnst.cpp, Line 1832
Burn process failed at 2.4x (3,324 KB/s)
Existing drivers:
File 'Drivers\ADPU160M.SYS': Ver=v3.60a (Lab01_N(johnstra).010529-2218), size=101888 bytes, created 8/17/2001 4:07:32 PM
File 'Drivers\CDRALW2K.SYS': Ver=8.0.0.212 , size=2560 bytes, created 5/19/2006 5:16:24 PM
File 'Drivers\PXHELP20.SYS': Ver=3.00.11B, size=46080 bytes, created 5/16/2006 4:23:54 PM (Prassi/Veritas driver for win 2K)
File 'Drivers\atapi.sys': Ver=?.?.?.?, size=95360 bytes, created 8/3/2004 10:59:44 PM (Adapter driver for rec)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
ALCOHOL
########################### System Information ###########################
Windows XP Home Edition 5.1 Service Pack 2 (Build 2600)
Processor info: Unknown P6 family (1496MHz)
Memory Available to Windows: 1,039,740 KB
############################ Program Information ###########################
File Name: C:\Program Files\Alcohol Soft\Alcohol 120\Alcohol.exe
Company Name: Alcohol Soft Development Team
Description: Alcohol 120%
Original: alcohol.exe
Product: Alcohol 120%
Trademarks: Alcohol Soft Development Team
Copyright: Copyright(C) 2002-2004 Alcohol Soft Development Team
Version: 1.9.2 ( Build 1705 )
Date: 2004/05/06
Hash: 7e9552025078b455c4c3d666f57dd414
Hash(1): d1a7659659473ef648eb5a05e23b291c5580f355673fdab02d 81ff332d01c5
Hash(2): 5e3cbc5c0e68bc7c14704ffb3f53bad933f799e64ef3f90047 5aa845b2cb00
File Name: C:\Program Files\Alcohol Soft\Alcohol 120\alcoholx.dll
Description: Alcohol virtual device control library
Original: alcoholx.dll
Copyright: Copyright (C) 2000-2004
Version: 3.47.0 ( Build 0 )
Date: 2004/04/30
Hash: c11b59c21722ca30141696c21b72578d
File Name: C:\Program Files\Alcohol Soft\Alcohol 120\devsupp.dll
Description: Alcohol Software Device Capability Library
Original: devsupp.dll
Product: Alcohol Software Device Capability Library
Copyright: Copyright(C) 2002-2003 Alcohol Soft Development Team
Version: 2.3.7 ( Build 505 )
Date: 2004/05/05
Hash: 0e6f733d3f570f3b0328261d11a2794e
########################### User Information ###########################
User Name:
Company Name:
Registered User ID:
########################### Options Setting ###########################
Devices control interface: Default Driver Control Interface
CPU Priority Level: High
Memory Buffer Size (MB): 128
Examine the accuracy of data read from physical device: Yes
Turn off "Auto-Select best write speed" function if possible: No
Overburn disc(s): No
Fill memory buffer before recording discs: Yes
Ignore Media Type: Yes
RMPS (Recordable Media Physical Signature) Emulation: No
BAD Sectors Emulation: No
Sub-Channel Data Fixed & Emulation: No
Laserlock Emulation: No
Current Language: English
############################ Device(s) List ############################
(D _NEC DVD+-RW ND-6500A (atapi, Port 1, Bus 0, Target 0, Lun 0)
(F AXV CD/DVD-ROM (a347scsi, Port 3, Bus 0, Target 0, Lun 0)
##################### Installed Device Drivers List #####################
1394BUS.SYS a347bus.sys a347scsi.sys ACPI.sys AegisP.sys
Afc.sys afd.sys Apfiltr.sys APPDRV.SYS arp1394.sys
ATMFD.DLL audstub.sys BATTC.SYS bcm4sbxp.sys Beep.SYS
BOOTVID.dll Cdfs.SYS cdrom.sys CLASSPNP.SYS CmBatt.sys
compbatt.sys disk.sys drmk.sys dump_atapi.sys dump_WMILIB.SYS
Dxapi.sys dxg.sys dxgthk.sys Fastfat.SYS Fips.SYS
fltMgr.sys Fs_Rec.SYS ftdisk.sys GEARAspiWDM.sys hal.dll
hcmon.sys HIDCLASS.SYS HIDPARSE.SYS hidusb.sys HSF_CNXT.sys
HSF_DP.sys HSFHWICH.sys HTTP.sys i2omgmt.SYS i8042prt.sys
ialmdd5.DLL ialmdev5.DLL ialmdnt5.dll ialmnt5.sys ialmrnt5.dll
imapi.sys intelide.sys intelppm.sys ipnat.sys ipsec.sys
isapnp.sys iwca.sys kbdclass.sys KDCOM.DLL KERNEL1.EXE
kernel1.exe kmixer.sys ks.sys KSecDD.sys LMImirr.sys
mdmxsdk.sys mnmdd.SYS Modem.SYS mouclass.sys mouhid.sys
MountMgr.sys mrxdav.sys mrxsmb.sys Msfs.SYS msgpc.sys
mssmbios.sys Mup.sys NDIS.sys ndistapi.sys ndisuio.sys
ndiswan.sys NDProxy.SYS netbios.sys netbt.sys nic1394.sys
Npfs.SYS ntdll.dll Ntfs.sys Null.SYS ohci1394.sys
omci.sys PartMgr.sys pci.sys pciide.sys PCIIDEX.SYS
pcmcia.sys portcls.sys psched.sys ptilink.sys PxHelp20.sys
RaInfo.sys rasacd.sys rasl2tp.sys raspppoe.sys raspptp.sys
raspti.sys rdbss.sys RDPCDD.sys redbook.sys RimSerial.sys
RootMdm.sys s24trans.sys SCSIPORT.SYS sdbus.sys secdrv.sys
srescan.sys srv.sys STAC97.sys StyleXPHelper.exe swenum.sys
sysaudio.sys tcpip.sys TDI.SYS termdd.sys update.sys
usbccgp.sys USBD.SYS usbehci.sys usbhub.sys USBPORT.SYS
USBSTOR.SYS usbuhci.sys VETFDDNT.SYS VET-FILT.SYS VETMONNT.SYS
VET-REC.SYS vga.sys VIDEOPRT.SYS VMNET.SYS vmnetadapter.sys
vmnetbridge.sys vmnetuserif.sys vmx86.sys VolSnap.sys vsdatant.sys
vstor2.sys w29n51.sys wanarp.sys watchdog.sys wdmaud.sys
win32k.sys WMILIB.SYS ws2ifsl.sys
################## Detailed Information of Device(s) ##################
(D _NEC DVD+-RW ND-6500A(1:0) detail information.
Vendor Identification: _NEC
Product Identification: DVD+-RW ND-6500A
Production Revision Level: 202C
Support recording method: DAO, RAW SAO, RAW SAO+SUB, RAW DAO(96), DVD DAO
BURN-Free Technology: Unknown
Auto-Select best write speed: Not Supported
*** NOT listed in Alcohol's database. Please report to development team
-* Note: This information below is provided by the unit, it might be inaccurate. *-
-* This software does not use this information! *-
Removable media: Yes
Version: ATAPI (INF-8090i/INF-8020i/INF-8028i)
Response Data Format: 02h
CD-R Read/Write: Yes/Yes
CD-RW Read/Write: Yes/Yes
Read CD-R Fixed Packet: Yes
Test Write: Yes
DVD-ROM Read: Yes
DVD-R Read/Write: Yes/Yes
DVD-RAM Read/Write: No/No
Audio Play: Yes
Composite Audio and Video Data Stream: No
Digital output (IEC958) on port 1 Supported: No
Digital output (IEC958) on port 2 Supported: No
Mode 1 Form 2: Yes
Mode 2 Form 2: Yes
Multi-Session: Yes
BUF: Yes
CD-DA Commands supported: Yes
CD-DA Stream is Accurate: Yes
R-W Supported: Yes
R-W De-interleaved and Corrected: No
C2 Pointers Support: Yes
ISRC Supported: Yes
UPC Supported: Yes
Read Bar Code: No
Lock media into the drive: Yes
Currently drive Lock state: Unlocked
Prevent Jumper: No
Eject Command: Yes
Separate volume levels: Yes
Separate channel mute: Yes
Changer Supports Disc Present: No
Software slot selection: No
Side change capable: No
P through W in Lead-In: Yes
Maximum Read Speed Supported (with current disc): 24X (3600 KB/Sec)
Maximum Write Speed Supported (with current Disc): 24X (3600 KB/Sec)
Current Read Speed Supported (with current Disc): 24X (3600 KB/Sec)
Current Write Speed Supported (with current Disc): 24X (3600 KB/Sec)
###################### Source Disc/Image Information ######################
Type: Standard ISO Image file
Path: C:\Program Files\Adobeman's DVDA GUI\Images\
Session: 1
Track: 1
Session 01:
Track 01: DVD, Length: 2243407(4.28 GB), Address: 000000
####################### Dumping/Recording Progress Log #######################
22:36:26 Processor info: Unknown P6 family (1496MHz)
22:36:26 Memory Available to Windows: 1,039,740 KB
22:36:26 Memory Buffer size: 128 MB
22:36:26 Image file loading: C:\Program Files\Adobeman's DVDA GUI\Images\untitled.iso
22:36:26 DVD Source Info: Session: 1, Track: 1, Length: 4.28 GB / 498:32:07
22:36:53 (D _NEC DVD+-RW ND-6500A(1:0): Recording Method/Speed
22:36:53 Recording - DVD DAO - 3.0X (4140 KB/Sec)
22:36:54 (D _NEC DVD+-RW ND-6500A(1:0): Recording failed!
22:36:54 Error message: [05/30/05] - Cannot Write Medium - Incompatible Format
22:36:54 Image file loading aborted!
22:36:57 Something is wrong with the recording procedure!
Please check the log file and report any errors to Technical Support.
Reply 0
Oct 4, 2006 | 05:52 PM
  #181
I'll admit up-front I ddin't look at most of the logs you posted, but seeing the following leads me to ask what type of media are you using i.e. DVD+R or DVD-R and are you sure it's supported by your burner? Could also be this particular burner just doesn't like the brand of DVD you're using or you might need a firmware update for your burner. Have youever burned DVDs succesfully before?
Just a couple of quick thoughts. I'm sure some of the others here will be able to pinpoint things better for you.
Test Write: Yes
DVD-ROM Read: Yes
Audio Play: Yes
Reply 0
Oct 4, 2006 | 06:33 PM
  #182
get Ri-data dvds, there cheap and always work for everything. I've got ri-data 12x-R's and have never costered one in nearly 500 burns. Pioneer or NEC drives are key too they have the highest quality lens for the lazer so everything is that much more percise. If you start with quality stuff your end result should be at an equal level of quality and error free.
Reply 0
Oct 4, 2006 | 06:37 PM
  #183
try using DVD Decrypter to burn the iso image. I've haven't tried burning Adobemans .iso in nero but usinig DvD Decryptor works for sure, and it's a free program.
GET IT HERE
Reply 0
Oct 14, 2006 | 09:58 PM
  #184
Quote: try using DVD Decrypter to burn the iso image. I've haven't tried burning Adobemans .iso in nero but usinig DvD Decryptor works for sure, and it's a free program.
GET IT HERE
Thanks alot, guys! Haven't had a chance to try ur ideas yet cos I've been so busy but as soon as I do, I'll let u know how it goes. Thanks again
Reply 0
Oct 16, 2006 | 05:29 PM
  #185
SW works great, burned easy, but no play
I have tried +RW,+R and –R, none work for me , does this work on pioneer in-dash navi system? What are the requirements for playing the DVDA?
Reply 0
Oct 18, 2006 | 12:52 PM
  #186
Will the headunit read dual layer disks (standard commerical dvd's) ?
Reply 0
Oct 19, 2006 | 11:25 AM
  #187
Hi E1!!!!!
It's work perfectly!!!! Thank you very much Adobeman.
I's able to burn .ISO sucessfully by using either DVD Power Burner (Expensive It costs between $40-$50) or ImgBurn (Excelent Freeware) Check it out!! http://www.imgburn.com/index.php?act=download
Enjoy!
Reply 0
Oct 20, 2006 | 09:22 AM
  #188
I just discovered this thread earlier in the week and have since successfully burned 3 discs worth of music. What a great tool! I did run into one issue that I didn't see discussed, however, but found a solution to it. I keep my music collection in lossless wma. As you know, this tool requires wav files. However, when I tried to convert the wma to wav using Switch, the headers got messed up and the tool couldn't read them. My solution was to use dbPowerAmp instead. The vanilla dbPowerAmp doesn't process wma, but they have a codec plug-in that does. I installed the plugin, converted my files, and generated an iso image. I then burned to dvd-r using the Sonic software that came with my pc, and now I've got 192 Beatles songs on 2 discs in my TL. Thank you Adobeman!
Reply 0
Oct 21, 2006 | 02:38 AM
  #189
I'm just wondering once the ISO file is created do you burn the DVD as a data file or a audio file. Also does it matter if DVD+R or DVD-R are used?
Reply 0
Oct 21, 2006 | 03:15 AM
  #190
Disreguard my last post. I tried the burn process again this time using DVD Decrypter with a DVD+R disc. This time everything worked and the sound is great. Thanks a bunch Adobeman and if anyone needs help please feel free to ask.........
Reply 0
Oct 22, 2006 | 01:36 AM
  #191
seems like a gr8 program, but after burning the created iso with nero, disc is unreadable in tl.
I am trying the burn now with nero...we'll see what happens.
Reply 0
Oct 22, 2006 | 12:18 PM
  #192
great app! was it written in VB?
Reply 0
Oct 22, 2006 | 02:43 PM
  #193
Quote: seems like a gr8 program, but after burning the created iso with nero, disc is unreadable in tl.
wow, i'm an idiot...I meant to say I was trying the burn with DVD Decryptor.
I did that, still no luck and same problem, any suggestions?
Reply 0
Oct 22, 2006 | 08:36 PM
  #194
Adobeman thanks a million!
First and foremost, thanks Adobeman for a great program to help alleviate my biggest gripe with the TL up to the '06 year of course. I can now burn a DVDA to my liking. Sure it takes a bit of time, but as they say the best things come to those who wait.
After a few minor issues and after reading the tons of replies/messages on this topic I was able to get my burn to work. I ended up using Memorex DVD-Rs as most mentioned here. I also avoided using Nero and used DVD Decryptor and burned at a slow 4x speed. I'll waste a DVD-R and see if buring at the max speed of my burner will still work fine. Thus far I only have had one song skip on me so not bad at all!
Luckily I got a great deal on the Memorex DVD-Rs. They were on sale @ CC for $7.34 (w/taxes). So again, thanks for your hard work and for sharing your talent with the community!
Reply 0
Oct 23, 2006 | 11:30 AM
  #195
Quote: After a few minor issues and after reading the tons of replies/messages on this topic I was able to get my burn to work. I ended up using Memorex DVD-Rs as most mentioned here. I also avoided using Nero and used DVD Decryptor and burned at a slow 4x speed.
Burning at 4x instead of 16x worked flawlessly! The music sounds great in the car now! Thank you adobeman for your gr8 software
Reply 0
Oct 23, 2006 | 06:41 PM
  #196
Quote: wow, i'm an idiot...I meant to say I was trying the burn with DVD Decryptor.
Bignips
Let me explain real quick. First use the CDex program to convert your mp3 or CD music file to wav. Next take those wave files over to the Adobeman's DVD-A GUI program. To make things easy leave them all in group one. You should be able to fit approximately 95 files in all. Next click on the make DVDA button. At this time Adobeman's program will convert all the files into DVDA format and combine them in to one ISO file. It usually takes about 30 minutes for this process to complete. Then for your last step use DVD Decryptor to burn that ISO file on your Blank DVD. At first I tried to use Nero and sonic with all attempts failing. Then there was a reply that someone used DVD Decryptor. I then gave it a try and it works perfect. I really don't think it matters if you use DVD-R or +R. Let me know if you need anymore help. Good Luck
Reply 0
Oct 24, 2006 | 01:03 AM
  #197
Thanks for your help, but I am afraid you are a little too late everything is working!
Quote: Burning at 4x instead of 16x worked flawlessly! The music sounds great in the car now! Thank you adobeman for your gr8 software
Reply 0
Oct 25, 2006 | 02:41 PM
  #198
OMG. I just ripped two CDs to a DVD-R using CDex, Adobeman's DVD-A GUI and ImgBurn. The downloads, setup, ripping and burning of the cds all took under 30 minutes. Having two CDs (groups) on one DVD is AWESOME plus the sound quality seems much, much, MUCH better.
I'm going to rip EVERY cd I put into my TL to DVD-A now!
Thanks SO much for this!!!!!
Reply 0
Oct 25, 2006 | 03:41 PM
  #199
You are a saint!
Reply 0
Oct 26, 2006 | 06:10 PM
  #200
My DVD-A Burn
+R's
I had absolutely no success using DVD+R's. I used Verbatim 16x DVD+R's and tried several different ways but the sound system rejected all of them.
-R's
So, I picked up some Verbatim 16x DVD-R's. Happy to say... SUCCESS! Used Adobeman's program, then burned with DVD Decrypter at 8x in a Pioneer DVD writer. Works nicely.
Reply 0
