Any idea of what this is?
Old Jan 15, 2010 | 11:51 PM
lylen's Avatar
http://img706.imageshack.us/i/picture002l.jpg/
http://img25.imageshack.us/i/picture001fm.jpg/
this was from the previous owner. the first picture is right next to the rear view mirror, the second is next to the e-brake.
Old Jan 16, 2010 | 12:38 AM
Rafee2k9's Avatar
probably for a radar that was hardwired into the car or something
Old Jan 16, 2010 | 12:47 AM
swoosh's Avatar
takin care of Business in
lemme help u out here
sorry for the big picture !!! but if it was hardwired there wudnt be the 12V plug.....i think he just hid the wire and used the plug !!!
Old Jan 16, 2010 | 12:55 AM
lylen's Avatar
thanks I was trying to figure out how to post up the pictures like that but I couldn't figure it out.
Old Jan 16, 2010 | 01:26 AM
Rafee2k9's Avatar
true, yea thats what i meant. but you should take advantage of that
Old Jan 16, 2010 | 02:11 AM
lylen's Avatar
haha. i have no ideas how i can take advantage of that.
Old Jan 16, 2010 | 02:36 AM
Bender's Avatar
splice the larger plug into the back of your outlet and use it for a radar!
Old Jan 16, 2010 | 02:46 AM
Caiman's Avatar
or just tap an acc fuse. its too much trouble to go through the center console.
Old Jan 16, 2010 | 02:56 AM
lylen's Avatar
what's that mean? haha sorry, i'm a car noob. i'm just starting to get into cars.
Old Jan 16, 2010 | 03:03 AM
Caiman's Avatar
This is the ghetto way to do it...but this is how my radar detector and jaser jammer are hardwired.
Go to the fuse box on the drivers side to the left of the steering wheel. Its behind the kick panel.
Wire your pos (+) down to the fuse box, and find a fuse that is only active in the 2nd position on the ignition. I forgot what number fuse it is, but the cover has the names of what the fuses do on the inside of it.
(This is the ghetto part)
Wrap the (+) wire around the metal part of the fuse. Put the fuse back in. Then ground the negative wire to a bolt somewhere.
There are actual fuse taps you can buy somewhere, but i have no idea where.
Old Jan 16, 2010 | 07:44 PM
Fulani has a TL's Avatar
If You do it that way, you risk of "wrapping" the positive wire onto the unfused side of the fuse....
Just use a fuse tap. I believe there are some DIYs on it in the garage
Old Jan 16, 2010 | 08:00 PM
swoosh's Avatar
u can get a fuse tap at any auto store....and it was fuse #32 for ignition !!!
Old Jan 16, 2010 | 08:53 PM
nfnsquared's Avatar
If you want to hardwire a radar detector (passport, escort, V1, beltronic), I recommend http://invisicord.com. There is DIY somewhere here on Azine with pictures that show how to tap it into a power cord in the overhead console. This how I have my Escort wired.
Old Jan 16, 2010 | 09:33 PM
No need to even spend that money on the invisicord. For my STI Driver, used a regular four wire telephone cord (black color), cut one end off, used the Green wire as a ground, and the red wire as power. Only need those two wires...
Old Jan 17, 2010 | 05:47 PM
Caiman's Avatar
Yeah that was it!
And there is another that I wired my laser jammer to...it was closer to the front of the car. Next to the sunroof fuse.
08KBP_VA
Oct 22, 2019 01:55 PM
iRaw
ILX Photograph Gallery
30
Aug 5, 2016 04:41 PM
copmagnet82
4G TL Problems & Fixes
Jun 29, 2016 08:09 AM
Gout
Nov 2, 2015 12:22 AM
Houston
Oct 8, 2015 01:27 AM
