Automatic overevving
Old Sep 26, 2015 | 11:57 PM
Houston's Avatar
Here I come!
Unhappy Automatic overevving
Sup guys? Been a while, but I haven't given up on the TL yet. Anywho, I was on the road yesterday and something odd happened. I took off from a dead stop at full speed and when the RPM's reached the point to were the car automatically changes gear, instead of shifting, it over reved. I tried it a few more times and it did the same thing. When I let the pedal go, it' shifts and when I drive at normal speeds, nothing happens. Any ideas?
The transmission fluid is fine in color, scent, and level. Also, no codes.
Old Sep 27, 2015 | 12:08 AM
guitarplayer16's Avatar
Sounds like your transmission is slipping.
My transmission slips too so whenever I feel like the transmission needs to shift, I let go of the gas pedal and let the transmission slip into gear.
Old Oct 2, 2015 | 08:25 AM
kocyk123's Avatar
Transmission slipping was my first thought when looking at the thread subject before even reading the message... Does not sound too good...
Old Oct 8, 2015 | 12:01 AM
Chad05TL's Avatar
Oh that's got death written all over it. haha
Old Oct 8, 2015 | 12:05 AM
Chad05TL's Avatar
oh 1 thought.. Make sure you have Honda Fluid DW-1.... At least I think it is dw-1. If you put redline in it.. It may not shift properly. And I KNOW it will not shift properly if you too much redline in it. If you recently added fluid, then drain 1 time and add 3 quarts of Honda fluid. That should fix it, IF it is a fluid problem. Even then you have to drive it easy for a few miles untill the new fluid gets circulated.. trust me.. been there!
Old Oct 8, 2015 | 01:27 AM
polish_pat's Avatar
Start by what would cost you the least, flush fluid and replace. Then you can change the fluid pressure switches. In all, should not cost you more than 100$, and I am being generous. Then if problem persists, you can start saving up for a rebuild.
Pham Alvan
Mar 16, 2016 09:17 AM
navtool.com
Sponsored Sales & Group Buys
87
Jan 23, 2016 01:25 PM
Thuneau
Oct 3, 2015 04:19 PM
Joe Avesyan
Sep 29, 2015 03:57 PM
