well ladies... the time has drawn near....
#163
B A N N E D
i would just replace the slave cylinder now, and know you got a new one on there, and know you should have many years of trouble free service from it (also who knows how much water has gotten in there also, while it was sitting at the junkyard and such)
but yes it should come with the boot also
#167
so i cleaned up the clutch housing a bit and i installed a new clutch fork spring and throwout bearing.
from this...
![](http://i67.photobucket.com/albums/h299/fenderi/IMG_1540.jpg)
to
![](http://i67.photobucket.com/albums/h299/fenderi/IMG_1546.jpg)
![](http://i67.photobucket.com/albums/h299/fenderi/IMG_1547.jpg)
i ran out of brakleen so i'll have to do the rest of the transmission housing later....
btw what are these corroded copper wires? are they grounds??
from this...
to
![](http://i67.photobucket.com/albums/h299/fenderi/IMG_1548.jpg)
#172
looks like things are starting to fall together, i got the email from rich today, and the ECU i ordered on friday was waiting for me at my doorstep
$160 shipped, no bent pins and part #'s match
![](http://i67.photobucket.com/albums/h299/fenderi/IMG_1549.jpg)
now it's getting sent to richiev6 to have the immobilizer programmed to the ECU
#174
got some goodies today. thanks morgan it was definitely a deal i couldn't pass up.
the only thing not pictured here is the injectors and spark plugs (those are getting installed tonight. and misc bolts and such (no one really cares to see those)
![](http://i67.photobucket.com/albums/h299/fenderi/IMG_1555.jpg)
![](http://i67.photobucket.com/albums/h299/fenderi/IMG_1556.jpg)
![](http://i67.photobucket.com/albums/h299/fenderi/IMG_1557.jpg)
![](http://i67.photobucket.com/albums/h299/fenderi/IMG_1558.jpg)
![](http://i67.photobucket.com/albums/h299/fenderi/IMG_1559.jpg)
now i'm waiting on my stuff back from richie, some parts from honda (the clutch master cyl res. holder is on backorder). I need to order the rear engine mount bracket. I got sweet deal on a brand new OEM mount http://cgi.ebay.com/ebaymotors/ws/eB...SA:MOTORS:1123 and i just need to get the rest of the mounts. I need to order a battery relocation kit, SS clutch lines, and i need to get the Engine to transmission mounting gasket.
#175
junkyard for the res holder?
So you bought a big V6 powered margarita mixer?
![Reporter](https://acurazine.com/forums/images/smilies/reporter.gif)
#183
so questions about the fuel injectors
S2k injector on the left and stock on the right.
![](http://i67.photobucket.com/albums/h299/fenderi/IMG_1561.jpg)
![](http://i67.photobucket.com/albums/h299/fenderi/IMG_1563.jpg)
![](http://i67.photobucket.com/albums/h299/fenderi/IMG_1564.jpg)
i'm guessing i need to take the o-rings off the stock and place them on the s2k? they all fit on the s2k injector, except for the one near the fuel nozzle, it goes in, but with gravity it falls out. are there special o-rings for specific fuel injectors?
#189
B A N N E D
i would say still get the o-rings at the bottom, you don't want a vacuum leak to develop, especially considering you have not even had the engine running yet (might be worth it to install the motor without the turbo first, so you can get everything running properly first)
then is that 35 some type of screen or something (can't look it up right now) then if so that should transfer no issues, just make sure to clean out those screens for maxinum flow (there secondary fuel filters)
then 3, if a seal also, again you don't want leaks developing, especially fuel on a hot engine
#192
Oh my god!
This car will eat everything!!!!![Thumbs Up](https://acurazine.com/forums/images/smilies/thumbsup.gif)
I've never seen your car (too new) is it/she a sleeper?
Mine is a sleeper without the rims on, unless you double take - then you realize there's a lot of stuff has been done...
#193
What RPM is it normal on a 03 Type S in auto D5 for a shift from 2nd to 3rd to occur if just calmly accelerating? (is a 2.5-3k 2nd-3rd shift normal?) (ex: city traffic accelerating from a light) Is slipping only if I shift, then nothing happens, it revs really high, then shifts after a delay?
#195
B A N N E D
![Roll Eyes](https://acurazine.com/forums/images/smilies/rolleyes.gif)
#196
![Tongue](https://acurazine.com/forums/images/smilies/tongue.gif)
I love her too much - so I baby her (grandma style). I think I better start to drive like what she can do (like 5k), at least once and a while. Ill post some pics and you'll get the idea what I have on my hands
#198
That will be quite the handful!
Is there some way with longer wheel studs + wheel spacers you can fit fatter tires in? - or will that just cause too many problems with the handling/control and rubbing?
#199
B A N N E D
btw i baby mine also on maintence, but mine likes to stretch her legs often lol
![Sad](https://acurazine.com/forums/images/smilies/sad.gif)
