View Poll Results: What am i doing
Voters: 281. You may not vote on this poll
Now what am i up to
#1161
Thanks. I would have liked to powder-coated the parts but im trying the paint out. I used Rust-oleum Metallic Engine Enamel (BlackNight).
#1166
#1167
Nope. At one point i was, but after my knifeedged 3.5 crank was damaged and as it turned into a 3.7 boost went out the door. I liked the idea of NA. If i were to do it again id probably go the FI route.
#1171
Those things break SO easy. I broke the one on the J32a2 i pulled out of my car by just unplugging it. And its not that its hard to replace, just a pain because of having to remove what you have to just to get to it.
#1182
I took a ton of pics. But each step of the assembly,
hands were usually oily and once in the grove i didnt want to stop.
Here are all the pics i took along the way
http://s265.photobucket.com/user/fst...?sort=3&page=1
![No](https://acurazine.com/forums/images/smilies/no.gif)
#1183
The following 2 users liked this post by fsttyms1:
CCColtsicehockey (10-24-2013),
dreem1er (10-17-2013)
#1185
deal with it
Lmao thats awesome. Well worth a night on the couch.
My knock sensor broke while I was putting the runners back on. I didn't even touch the damn plug, I pulled the cable by mistake and heard a crunch. I freaked out at first til I noticed the nut was still there and was an easy fix
#1186
I think between a little age and the heat it sees down in the valley the plastic just gets brittle.
#1189
Almost 500 miles and it keeps feeling stronger.
#1193
And now that there are more ECU options for the HonData Flash Pro im soon to be converting the wiring to be able to tune it
![Woot](https://acurazine.com/forums/images/smilies/woot.gif)
#1194
http://hondata.com/flashpro_04-06_tl...apter_kit.html
You can use various cars now for wiring, and ECUs. The big thing (if you arent opposed to using a soldier iron) you can use a Auto ECU and convert it to a manual ecu (modification is only needed for cruise to work) Having said that though, auto guys are screwed as this wont work for autos.
03 tls nc (10-23-2013)
#1200
Unregistered Member
Ohhh this is an interesting development. Another ECU option, hmm...
So basically this ECU will work with a Gen 1 J series engine, so that would work well for the 2G TL cars.
But I'm not sure if our cluster uses the same signal as the 3G ECU. Definitely will keep an eye out for updates.
